How to debug lwm2m_client sample on Thingy91 development kit?
Our company is in the process of developing a new IoT product for LTE-M and NB-IoT. The sample application lwm2m_client runs fine on our devkits nRF9151DK & Thingy91 and connects fine with Leshan, AVSystems and nRFCloud. UART console of both devkits show a lot of shell outputs. So far so good.
Past days I had to debug an issue but depending on some conditions I didn't know some times I could easily SWD debug and sometimes not. In the end I found this out:
  • nRF9151DK both standard builds and debug-build configs run just fine on those boards, UART output is correct.
  • Thingy:91 (nRF9160):
    • standard builds work both via MCUBoot-Update and via SWD debugger. In the debugger I can single step and run and the app run fine.
    • debug builds for the Thingy/nRF9160ns target (-Og, -DCONFIG_DEBUG_THREAD_INFO=y) dont work, dont show UART outputs, even the blinky sample is doing nothing
    • debug builds for the Thingy/nRF9160 target (no ns, -Og, -DCONFIG_DEBUG_THREAD_INFO=y) work, show UART outputs, but this is only valid for very simple MCU-like applications. Using the no-ns build target is preventing applications which require the LTE modem (TP-M)
Currently I'm out of ideas how I can debug an application using the LTE modem on the Thingy91 platform. Whats the supposed way to go in May 2025?
  • Ok, lets first show the good version using the nRF9151DK:
    New VSCode Window:
    create new app, copy sample from "nrf/samples.../blinky"
    created in c:\blinky
    nrf connect/application/blinky/add build configuration:
    - sdk & toolchain v3.0.1
    - board: nrF9151dk/nRF9151/ns
    - prj.conf
    - optimize for debugging (-Og)
    - Build directory name: build_51_dbg
    - click: generate and build, wait several minutes on my 16 Core i7-1360p
    - build OK:
    Click on actions/debug
    - some west magic, flashing, debugg view loads
    I can single step using F10:
    Serial terminal is showing blinky Uart output:
    LED1 is blinking
  • Now the good version using Thingy91.
    Lets create a non debug in build_60:
    flash it:
    It blinks and UART output is working:
  • Now lets create and build a thingy91 debug version:
    And  lunch the debugger:
    Now the CPU doesnt hit the apps main():
    single stepping is not working:
    Oh wow, after several atempts to F10/F5 this time I get a blinking board and a UART output:
    - but the call stack is not showing app threads and I cannot single step
    After stopping the debugger, reflashing, attach debugger it looks like this - that the exception/assertion I see most often when I try to debug the lwm2m_client sample on the thingy91:
    And what helps reliably is to disable "optimize for debug (-Og), use -Os and manually add cmake argument -DCONFIG_DEBUG_THREAD_INFO=y
  • when I try to debug the sample lwm2m_client, it works as expected on the nRF9151DK and not on the thing91, mostly the CPU spins endless in the "flash is not locked" assertion like here:
    So it looks like the larger the app the higher the chance the debug setup is breaking
    I have tried to replicate debugging issue that you reported.
    There seems to be a problem when debug optimization is included in the project build configuration in VS Code. I have reported this internally. I expect to get back to you with status update by the end of the week.
    Dejan
