Inconsistent QSPI flash behavior between APP and MCUBOOT
It seems that I'm getting different results reading QSPI flash from the APP vs MCUBOOT, with the exact same configuration. Writes appear to work fine from either, but MCUBOOT isn't able to read the flash, whereas the APP can.
Initially I was trying to track down why uploaded DFU images weren't able to be validated by MCUBOOT, which looks like this:
I'm starting to think it's because MCUBOOT isn't properly reading the image from flash.  I am able to upload images via SERIAL directly to MCUBOOT, or via BLE to MCUMGR in the APP.  In either case, I am able to see the uploaded image through MCUMGR from the APP, but neither shows up in the image list when accessing from MCUBOOT, see example:
Initial image list from BLE (APP/MCUMgr):
Initial image list from SERIAL (MCUBOOT):
Upload image 105CFF via BLE and see it was uploaded to slot 1:
Image list with both images uploaded via SERIAL:
Upload image 777E0 via SERIAL ,and view the image list:
View the image list via BLE and see slot 1 was in fact replaced with 777E0:
The DTS is identical for both applications.  Here is the PM config:
app:
  address: 0x12200
  end_address: 0xfe000
  region: flash_primary
external_flash:
  address: 0xec000
  end_address: 0x400000
  region: external_flash
mcuboot:
  address: 0x0
  end_address: 0x12000
mcuboot_pad:
  address: 0x12000
  end_address: 0x12200
  placement:
    align:
      start: 0x1000
    before:
    - mcuboot_primary_app
mcuboot_primary:
  address: 0x12000
  orig_span: &id001
  - mcuboot_pad
  - app
  span: *id001
mcuboot_primary_app:
  address: 0x12200
  orig_span: &id002
  - app
  span: *id002
mcuboot_secondary:
  address: 0x0
  device: DT_CHOSEN(nordic_pm_ext_flash)
  end_address: 0xec000
  placement:
    align:
      start: 0x4
  share_size:
  - mcuboot_primary
settings_storage:
  address: 0xfe000
  end_address: 0x100000
  placement:
    align:
      start: 0x1000
    before:
    - end
sram_primary:
  address: 0x20000000
  end_address: 0x20040000
  region: sram_primary
Any ideas?  Thank you!
Chris
  • Hi Hieu,
    After having narrowed this down as far as we have, I think I'm convinced it must be a hardware issue that only crops up in certain software configurations, causing it to masquerade as a software issue.
    While I have no way to prove it at the moment, I do suspect power stability for the flash chip may be the culprit.  I can't come up with any other explanation, and I think we've exhausted all of the other possibilities.
    Thank you for your help!  I think we can consider this resolved, and I'll try to understand why it's an issue in our case.  Thanks again!
    Chris
  • Hi Chris,
    It's just my job to help, but I don't feel like I was able to support much this time. Thank you too, for the pleasant cooperation.
    In that case, I will close this case. We do provide hardware review, so if you feel the need for it, please feel free to open a new private DevZone case.
    Hieu
