Inconsistent QSPI flash behavior between APP and MCUBOOT
It seems that I'm getting different results reading QSPI flash from the APP vs MCUBOOT, with the exact same configuration. Writes appear to work fine from either, but MCUBOOT isn't able to read the flash, whereas the APP can.
Initially I was trying to track down why uploaded DFU images weren't able to be validated by MCUBOOT, which looks like this:
I'm starting to think it's because MCUBOOT isn't properly reading the image from flash.  I am able to upload images via SERIAL directly to MCUBOOT, or via BLE to MCUMGR in the APP.  In either case, I am able to see the uploaded image through MCUMGR from the APP, but neither shows up in the image list when accessing from MCUBOOT, see example:
Initial image list from BLE (APP/MCUMgr):
Initial image list from SERIAL (MCUBOOT):
Upload image 105CFF via BLE and see it was uploaded to slot 1:
Image list with both images uploaded via SERIAL:
Upload image 777E0 via SERIAL ,and view the image list:
View the image list via BLE and see slot 1 was in fact replaced with 777E0:
The DTS is identical for both applications.  Here is the PM config:
app:
  address: 0x12200
  end_address: 0xfe000
  region: flash_primary
external_flash:
  address: 0xec000
  end_address: 0x400000
  region: external_flash
mcuboot:
  address: 0x0
  end_address: 0x12000
mcuboot_pad:
  address: 0x12000
  end_address: 0x12200
  placement:
    align:
      start: 0x1000
    before:
    - mcuboot_primary_app
mcuboot_primary:
  address: 0x12000
  orig_span: &id001
  - mcuboot_pad
  - app
  span: *id001
mcuboot_primary_app:
  address: 0x12200
  orig_span: &id002
  - app
  span: *id002
mcuboot_secondary:
  address: 0x0
  device: DT_CHOSEN(nordic_pm_ext_flash)
  end_address: 0xec000
  placement:
    align:
      start: 0x4
  share_size:
  - mcuboot_primary
settings_storage:
  address: 0xfe000
  end_address: 0x100000
  placement:
    align:
      start: 0x1000
    before:
    - end
sram_primary:
  address: 0x20000000
  end_address: 0x20040000
  region: sram_primary
Any ideas?  Thank you!
Chris
  • Hello Chris,
    That’s a good finding. I’m not entirely sure about the issue, so I’ve taken it up internally and was checking for updates. One comment I received is that this might be related to the SDK version. Would it be possible for you to update the SDK version and check if the same issue persists?
    Abhijith
  • Hi Abhijith,
    Is there any specific bug you're considering as the culprit?  Is there a specific SDK version you believe would resolve it?  I don't want to update the SDK simply as a guess, and if I do, I would want to be sure it's to a version you believe would resolve the issue.
    I will take a look at the upgrade notes for v2.7.0, I'm not really sure what the effort would be there.  But I'll definitely take a look and see if we can try it.
    Chris
  • Hi Abhijith,
    As usual upgrading the SDK was quite painful, but I did manage to get everything working on v2.7.0.  The issue appears to be exactly the same.
    Chris
    Does that mean the issue still persists with SDK version v2.7.0? I assume you are using sysbuild with NCS v2.7.0 instead of the multi-image build.
    I would really like to give you a suggestion on this, but I’m not sure what is going wrong here , that’s why I checked internally. Since you are on NCS v2.6.4, which is quite old, the issue could be harder to narrow down as there have been several releases and bug fixes since then.
    I will get back to you on this soon.
    Kind Regards,
    Abhijith
    Can you try using the external flash in single-line SPI mode and stop the driver from using Deep Power Down (DPD)?
    Inside the device tree, use:
    writeoc = "pp";
    readoc = "fastread";
    Then try removing the has-dpd property, which tells the flash driver not to enter deep power-down.Please give this a try and let me know the behavior.
    Abhijith
