MISO line mimics the MOSI line in SPIM configuration sdk 17.1.0
When I looked at the SPI lines using the oscilloscope, I saw that the MISO line had the same signal as the MOSI line. As you can see from the image, basically SPI configuration works properly. Before message transfer CS pin goes low, and after that, the MOSI line works. I can read message that I sent using the oscilloscope.
What can be the problem with the MISO line signal reflecting the MOSI line signal? The SPI config stage CPOL = 0, CPAH = 1, I am using a 2 MHz clock signal. Thanks for your help.
  • I wrote all the code I posted; I can only share snippets as the code is very extensive and on a product in service.
  • Thanks for your reply  I have a project presentation to do on Tuesday, and I'm a little nervous about it. I think my code is logical and works, but I can't even read the data in the registers yet. The reason I asked for your code was to compare it and see if I made any wrong configurations.  I believe the problem lies within the software; however, if I am mistaken, I shall examine the hardware component. Thanks again.
  • I didn't get time to load your code onto a similar device, but maybe have a look at the power-up sequence on this code I wrote. In particular note the power-up timings and the use or not of the START and RESET pins. It can use nrfx drivers or bare-metal, though the nrfx SDK may be older than the SDK you are using.
    // Delay about 30 msecs to allow regulator feeding AFE and Flash to charge capacitance
    #define ADS_POWER_RAMP_TIME_MSECS   30 // mSecs
    // Use nrfx or low-level drivers
    #define USING_NORDIC_SPIM_DRIVERS
    #if defined(USING_NORDIC_SPIM_DRIVERS)
     #warning SPI0_ENABLED and USING_NORDIC_SPIM_DRIVERS
     #define SPI_INSTANCE 0 // SPI instance index
     static const nrf_drv_spi_t mAfeSpiInstance = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);
    #else
     #warning SPI0 uses Low-Level drivers
     static void spiInit(NRF_SPIM_Type * const pSPIM, const IRQn_Type IRQn, const uint32_t IRQpriority);
     static void spiTransfer(uint8_t const * p_tx_buffer,
                             uint8_t         tx_buffer_length,
                             uint8_t       * p_rx_buffer,
                             uint8_t         rx_buffer_length);
    // Interrupt-driven events related to AFE sampling
    static volatile bool mAfePacketTransferComplete = false;
    static volatile bool mAfeSampleDataReady        = false;
    static volatile bool mAfeEventRequestPending    = false;
    // AFE status
    static bool amInitialized = false;
    static volatile uint32_t mAfeSampleDataReadyCount = 0UL;
    static volatile uint32_t mSpiInterruptCounter     = 0UL;
     * @brief SPI event handler indicating SPI transfer has completed
     * @param event
    static void afe_spi_event_handler(nrf_drv_spi_evt_t const * p_event, void *p_context)
       mAfePacketTransferComplete = true;
       mSpiInterruptCounter++;
    #else
     * @param none
    void SPIM0_SPIS0_TWIM0_TWIS0_SPI0_TWI0_IRQHandler(void)
       // Clearing ->EVENTS_END MUST be first or add void read else get double interrupt ..
       NRF_SPIM0->EVENTS_END = 0;
       //NRF_SPIM0->EVENTS_ENDRX = 0;
       //NRF_SPIM0->EVENTS_ENDTX = 0;
    void afeInitialize(void)
       ret_code_t err_code;
       nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
       spi_config.ss_pin    = ADS_CS_PIN;     // SPI_SS_PIN;
       spi_config.miso_pin  = ADS_MISO_PIN;   // SPI_MISO_PIN;
       spi_config.mosi_pin  = ADS_MOSI_PIN;   // SPI_MOSI_PIN;
       spi_config.sck_pin   = ADS_SCK_PIN;    // SPI_SCK_PIN;
       spi_config.frequency = NRF_DRV_SPI_FREQ_500K;  // Ensure less than 4 clk cycles for ADS1292
       spi_config.bit_order = NRF_DRV_SPI_BIT_ORDER_MSB_FIRST;
       spi_config.mode      = NRF_DRV_SPI_MODE_1;
       APP_ERROR_CHECK(nrf_drv_spi_init(&mAfeSpiInstance, &spi_config, afe_spi_event_handler, NULL));
    #else
       spiInit(NRF_SPIM0, SPIM0_SPIS0_TWIM0_TWIS0_SPI0_TWI0_IRQn, 6);
       // Setup starting power-up condition, all signals off but power-on supply to AFE
    #if defined(ADS_START_PIN)
       nrf_gpio_pin_clear(ADS_START_PIN);  // Tie the START pin low to control conversions by command
       TURN_ON_ADS_PWR_PIN;                // Turn on Active-High ADS & Flash power regulator enable
       ACTIVATE_ADS_RESET_PIN;             // Activate active-low combined /Reset and /Powerdown
       // Configure pins to output mode
       nrf_gpio_cfg_output(ADS_START_PIN); // Activate START pin
       nrf_gpio_cfg_output(ADS_RESET_PIN); // Activate active-low combined /Reset and /Powerdown
       // High power output pins
       nrf_gpio_cfg(ADS_PWR_PIN,             // 32 P0.27 ADS_PWR, 960k pull-down on pcb
                    NRF_GPIO_PIN_DIR_OUTPUT,
                    NRF_GPIO_PIN_INPUT_DISCONNECT,
                    NRF_GPIO_PIN_NOPULL,
                    NRF_GPIO_PIN_S0H1,       // Require High Drive high level
                    NRF_GPIO_PIN_NOSENSE);
       // Enable ADS1292 AFE - Power on & remove reset
       nrf_delay_ms(ADS_POWER_RAMP_TIME_MSECS); // Delay about 30 msecs to allow regulator to charge capacitance
       DEACTIVATE_ADS_RESET_PIN;           // Release active-low combined /Reset and /Powerdown
       nrf_delay_ms(1000);                 // Delay 1 sec as per data sheet
       nrf_delay_ms(2);                    // Delay to allow ADS internal clock to start
       nrf_delay_us(200);                  // Delay to allow 18 tclk minimum
       if (!amInitialized)
          // Configure GPIOTE to give an interrupt on pin change - maybe later redo this
          if (!nrf_drv_gpiote_is_init())
          // AFE active-low /DRDY signal on pin ADS_DRDY_PIN, using pull-up
          nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_HITOLO(true);
          in_config.pull = NRF_GPIO_PIN_PULLUP;
          err_code = nrf_drv_gpiote_in_init(ADS_DRDY_PIN, &in_config, afe_drdy_event_handler);
          nrf_drv_gpiote_in_event_enable(ADS_DRDY_PIN, true);
       // Ensure no sample pending
       // Clear common error counter for AFE SPI transfer failures
       mAfeSpiErrorCount = 0;
       // Indicate hardware has been initialized
       amInitialized = true;
    // The SPI master implements EasyDMA for reading and writing of data packets from and to the DATA RAM
    // without CPU involvement.
    // The RXD.PTR and TXD.PTR point to the RXD buffer (receive buffer) and TXD buffer (transmit buffer)
    // respectively. RXD.MAXCNT and TXD.MAXCNT specify the maximum number of bytes allocated to the buffers.
    // The SPI master will automatically stop transmitting after TXD.MAXCNT bytes have been transmitted and
    // RXD.MAXCNT bytes have been received. If TXD.MAXCNT is larger than RXD.MAXCNT, the superfluous
    // received bytes will be ignored. If RXD.MAXCNT is larger than TXD.MAXCNT, the remaining transmitted
    // bytes will contain the value defined in the ORC register.
    // If the RXD.PTR and the TXD.PTR are not pointing to the Data RAM region, an EasyDMA transfer may result
    // in a HardFault or RAM corruption.
    // The .PTR and .MAXCNT registers are double-buffered. They can be updated and prepared for the next
    // transmission immediately after having received the STARTED event.
    // The ENDRX/ENDTX event indicate that EasyDMA has finished accessing respectively the RX/TX buffer in
    // RAM. The END event gets generated when both RX and TX are finished accessing the buffers in RAM.
    // EasyDMA array list
    // The EasyDMA array list can be represented by the data structure ArrayList_type. This data structure
    // includes only a buffer with size equal
    // to Channel.MAXCNT. EasyDMA will use the Channel.MAXCNT register to determine when the buffer
    // is full. Replace 'Channel' by the specific data channel you want to use, for instance 'NRF_SPIM->RXD',
    // 'NRF_SPIM->TXD', 'NRF_TWIM->RXD', etc.
    // The Channel.MAXCNT register cannot be specified larger than the actual size of the buffer. If
    // Channel.MAXCNT is specified larger than the size of the buffer, the EasyDMA channel may overflow the
    // buffer.
    // This array list does not provide a mechanism to explicitly specify where the next item in the list is located.
    // Instead, it assumes that the list is organized as a linear array where items are located one after the other in
    // RAM.
    // SPI master transaction sequence
    // An SPI master transaction consists of a sequence started by the START task followed by a number of
    // events, and finally the STOP task.
    // An SPI master transaction is started by triggering the START task. The ENDTX event will be generated
    // when the transmitter has transmitted all bytes in the TXD buffer as specified in the TXD.MAXCNT register.
    // The ENDRX event will be generated when the receiver has filled the RXD buffer, i.e. received the last
    // possible byte as specified in the RXD.MAXCNT register.
    // Following a START task, the SPI master will generate an END event when both ENDRX and ENDTX have
    // been generated.
    // The SPI master is stopped by triggering the STOP task. A STOPPED event is generated when the SPI
    // master has stopped.
    // If the ENDRX event has not already been generated when the SPI master has come to a stop, the SPI
    // master will generate the ENDRX event explicitly even though the RX buffer is not full.
    // If the ENDTX event has not already been generated when the SPI master has come to a stop, the SPI
    // master will generate the ENDTX event explicitly even though all bytes in the TXD buffer, as specified in the
    // TXD.MAXCNT register, have not been transmitted.
    // The SPI master is a synchronous interface, and for every byte that is sent, a different byte will be received at
    // the same time
    // Master mode pin configuration
    // The SCK, MOSI, and MISO signals associated with the SPI master are mapped to physical pins according to
    // the configuration specified in the PSEL.SCK, PSEL.MOSI, and PSEL.MISO registers respectively.
    // The PSEL.SCK, PSEL.MOSI, and PSEL.MISO registers and their configurations are only used as long as
    // the SPI master is enabled, and retained only as long as the device is in ON mode. PSEL.SCK, PSEL.MOSI
    // and PSEL.MISO must only be configured when the SPI master is disabled.
    // To secure correct behavior in the SPI, the pins used by the SPI must be configured in the GPIO peripheral
    #else
       //spi_config.mode      = NRF_DRV_SPI_MODE_1;
       pSPIM->ENABLE = 0;                        // disable SPI
       NRF_GPIO->PIN_CNF[ADS_CS_PIN]   = 0x301;  // output, high drive high and low H0H1
       NRF_GPIO->PIN_CNF[ADS_SCK_PIN]  = 0x301;  // output, high drive high and low H0H1
       NRF_GPIO->PIN_CNF[ADS_MOSI_PIN] = 1;      // output, standard drive S0S1
       NRF_GPIO->PIN_CNF[ADS_MISO_PIN] = 0;      // input pin, input buffer connected, no pull, S0S1, sense disabled
       NRF_GPIO->OUTSET = 1 << ADS_CS_PIN;       // deactivate by setting chip select high
       pSPIM->PSEL.SCK   = ADS_SCK_PIN;
       pSPIM->PSEL.MOSI  = ADS_MOSI_PIN;
       pSPIM->PSEL.MISO  = ADS_MISO_PIN;
       pSPIM->CONFIG = 2;                  // CPOL 0 -- clock polarity active high, CPHA 1 -- sample on trailing clock edge, send Msb first
       pSPIM->FREQUENCY = NRF_DRV_SPI_FREQ_500K;  // Ensure less than 4 clk cycles for ADS1292
       pSPIM->ORC = 0xFF;                     // Unused Tx bytes, set all bits high
       pSPIM->EVENTS_ENDTX = 0;
       pSPIM->EVENTS_ENDRX = 0;
       pSPIM->EVENTS_END   = 0;
       // Disable all interrupts
       pSPIM->INTENCLR = 0xFFFFFFFFUL;
       // Enable selected interrupts
       pSPIM->INTENSET = 0x040;   // END
       //pSPIM->INTENSET = 0x010;   // END_RX
       //pSPIM->INTENSET = 0x100;   // END_TX
       // Set interrupt priority and enable interrupt
       NVIC_SetPriority(IRQn, IRQpriority);
       NVIC_ClearPendingIRQ(IRQn);
       NVIC_EnableIRQ(IRQn);
       pSPIM->ENABLE = 7;               // enable SPI
       NRF_SPIM0->ENABLE = 7;               // enable SPI
       NRF_SPIM0->TXD.PTR = (uint32_t)p_tx_buffer;
       NRF_SPIM0->TXD.MAXCNT = tx_buffer_length;
       NRF_SPIM0->RXD.PTR = (uint32_t)p_rx_buffer;
       NRF_SPIM0->RXD.MAXCNT = rx_buffer_length;
       NRF_GPIO->OUTCLR = 1 << ADS_CS_PIN;  // drive cs low to initiate spi comm
       nrf_delay_us(10);
       NRF_SPIM0->TASKS_START = 1;
       while(!NRF_SPIM0->EVENTS_ENDTX);     // last byte transmitted
       while(!NRF_SPIM0->EVENTS_ENDRX);     // last byte received
       NRF_SPIM0->TASKS_STOP = 1;
       nrf_delay_us(10);
       while(!NRF_SPIM0->EVENTS_STOPPED);
       //NRF_SPIM0->ENABLE = 0;               // disable SPI
  • Thanks for your reply  . The problem continues. When I pull down the MISO pin, it returns 0x00; when I apply no pull, it shows 0xff. Following the structure of your power-up sequence, I implemented a similar setup, but nothing is returning from the MISO line. Could this be a hardware issue?
  • Technically yes, because I suspect you still got at least one of the input/config pins wrong.
    You can check: Connect the MMB0 (and disconnect the NRF), use the PC example software from TI and record ALL digital pin waveforms that you can with your scope/LA. Pin config is non-trivial for these chips.
    Could be an argument for a better logic analyser in your upcoming presentation/meeting. A 4-channel scope won't cut it here IMHO.
