How to Improve the Commissioning Speed of Matter over Thread?
Background : To set up a Matter ICD (Internet Connectivity Device) and Thread as a SSD (Sleepy End Device). Here are the detailed settings:
CONFIG_OPENTHREAD_NORDIC_LIBRARY_MTD=y
CONFIG_OPENTHREAD_MTD=y
CONFIG_OPENTHREAD_FTD=n
CONFIG_CHIP_ENABLE_ICD_SUPPORT=y
CONFIG_CHIP_THREAD_SSED=
CONFIG_CHIP_ICD_SLOW_POLL_INTERVAL=30000
CONFIG_CHIP_ICD_FAST_POLLING_INTERVAL=500
CONFIG_CHIP_ICD_ACTIVE_MODE_THRESHOLD=2000
Currently, the Matter over Thread network commissioning has been tested 100 times, with a typical time of 65 seconds.
The following is my question:
1.I would like to set a macro definition during the Matter over Thread network commissioning phase, temporarily disabling the low - power limits of Matter ICD and SSED to boost the Matter over Thread commissioning speed. Is there such a macro definition?
2.After setting Matter ICD slow poll to 30000, the first Matter over Thread commissioning succeeded. But when I clicked "identify" in the Matter app, I found that the nRF54L15 took up to 30 seconds to receive the identify command, which is too long. How can I reduce this 30 - second delay while keeping the slow poll time at 30000?
Looking forward to your reply.
  • biubiubiubiu said:
    If the only way to re - establish the link is to reboot the HUB, this outcome is hard to accept.
    The Persistent subscriptions section of the Advanced Matter Kconfig options documentation may be relevant for this.
    Maria
  • Thank you for your reply.
    1.The UAT is effective. The networking time has been almost halved, with the current average time being around 30 seconds.
    2.CONFIG_CHIP_PERSISTENT_SUBSCRIPTIONS is experimental. I am not ready to try it at this point.
    3.There is still a remaining issue. When the user's board is networked via a scan using Amazon Echo Dot Gen 4 (which supports acting as a Thread Border Router) or Aqara M3 (an independent gateway type Border Router), it prompts to enter a Thread Network Key. Where can I obtain this Thread Network Key?
    Great to see!
    Ok, no problem.
    Can you explain in detail what you mean with the "networked via a scan"?
    Which device is prompting for a Thread Network Key?
    Generally, the Thread Network Key is shared with joining devices during commissioning, and this is happening without user intervention. If your Thread Commissioner/Matter hub does not have a way of displaying the Thread Network Key, you won't be able to obtain it unless a device on the network supports displaying the Thread Network Key.
    Maria
    1. Scanning to join the network refers to using a mobile phone to scan the QR code for Matter network setup.
    2. The mobile phone will prompt you to enter the Thread network key.
    3. You can refer to the video below.
  • Just to mention again, the Aqara P2 door sensor(matter over thread) doesn't have this issue.
