Ble pairing with linux - zero distribution flags
Hi!
We are having problems pairing a nRF52840 against linux (ubuntu 25.04). Pairing fails instantly, before any passkey is shown on the host, returning with code 9.
Short log is here:
<dbg> bt_smp: bt_smp_recv: Received SMP code 0x01 len 6
<dbg> bt_smp: smp_pairing_req: req: io_capability 0x04, oob_flag 0x00, auth_req 0x2D, max_key_size 0x10, init_key_dist 0x0D, resp_key_dist 0x0F
<dbg> bt_smp: smp_init: prnd 849156b688e37e12ad063cb072baf74f
<dbg> bt_smp: smp_pairing_req: rsp: io_capability 0x02, oob_flag 0x00, auth_req 0x0D, max_key_size 0x10, init_key_dist 0x00, resp_key_dist 0x00
<dbg> bt_smp: bt_smp_recv: Received SMP code 0x0c len 64
<dbg> bt_smp: smp_public_key:
<inf> Bt: Received passkey pairing inquiry.
<inf> Bt: Type `uhk passkey xxxxxx` to pair, or `uhk passkey -1` to reject
<wrn> bt_conn: conn 0x20010498: not connected
<dbg> bt_smp: bt_smp_disconnected: chan 0x20010b9c cid 0x0006
<dbg> bt_smp: smp_pairing_complete: got status 0x8
<dbg> bt_smp: bt_smp_encrypt_change: chan 0x20010b9c conn 0x20010498 handle 1 encrypt 0x00 hci status 0x1f
<wrn> Bt: Bt security failed: n/a (n/a, 98:5f:41:d2:92:3a), level 1, err 9, disconnecting
<wrn> Bt: The connection (n/a (n/a, 98:5f:41:d2:92:3a)) isn't even connected! Ignoring.
<wrn> Bt: Pairing of auth conn failed because of 9
<wrn> Bt: Pairing failed: n/a (n/a, 98:5f:41:d2:92:3a), reason 9
AI back and forths suggest that the host PC cancels pairing because it receives the zero distribution flags in
Detailed logs (attaching file here doesn't work, so linking externally):
- zephyr with hci_core and smp logging: http://ktweb.cz/upload/logs2/right.log
- the same, but filtered: http://ktweb.cz/upload/logs2/right_filtered.log
- btmon log: http://ktweb.cz/upload/logs2/btmon.log
Any ideas what the problem might be and where to look further?
EDIT: here is wireshark log (paired from gui this time):
  - fails on gatt instead  http://ktweb.cz/upload/logs2/wireshark_linux_pairing.pcapng (This is probably our problem, since gatt is handled by an external service.)
- this one actually contains pairing attempt similar to the key distribution problem: http://ktweb.cz/upload/logs2/wireshark_linux_pairing2.pcapng
EDIT2 my updated conclusions and hypotheses:
- I think that the distribution flags are correct and (on of the) troubles is that zephyr doesn't reply with its own keys within the next 400ms or so.
- Looks like key generation takes too long on zephyr side. Before it is finished, the connection gets terminated.
- Reason for termination seems to be related to gatt and the ll buffers. Right before the connection is determined as disconnected, I see this check to fail in conn.c. Increasing the number doesn't fix the issue, but results in increased number of calls to bt_conn_tx_processor before failure (which is where the disconnect is determined):
static bool should_stop_tx(struct bt_conn *conn)
	if (atomic_get(&conn->in_ll) < 3) {
	   return false;
    return true;
- my guess is that the bt_conn_tx_processor is triggered by receiving the gatt requests
- successful pairing against android http://ktweb.cz/upload/logs2/wireshark_android_pairing.pcapng
- there is a minor difference between linux and android flow. I think it is not important, but it should be noted that we are trying to achieve security level 4:
Initiator Key Distribution: 0x0d, Link Key, Signature Key (CSRK), Encryption Key (LTK)
    0000 .... = Reserved: 0x0
    .... 1... = Link Key: True
    .... .1.. = Signature Key (CSRK): True
    .... ..0. = Id Key (IRK): False         // This is false from linux, but true from android
    .... ...1 = Encryption Key (LTK): True
- failed pairing with the number from above excerpt increased 3 to 12 and buffer count: http://ktweb.cz/upload/logs2/wireshark_linux_pairing3.pcapng (flood of gatt packets from central to peripheral)
- This makes me think that either linux simply overwhelms zephyr with gatt requests, or there is some problem with our gatt provider (which is implemented by a custom implementation from c2usb). Still will be grateful for any thoughts on the subject.
  • kat829 said:
    What exactly is the problem there? Tested multiple times...
    It won't open. I guess it is the company firewall.
    Are you using the nRF52840 as a HCI dongle? This still isn't clear to me. (I see that hci is mentioned in the log from your initial post, the one pasted into the added text box, but there is HCI logging in normal samples (not just HCI) running on our devices as well. HCI will always be the communication layer between the application and the Bluetooth Controller).
    So are the logs from your computer, or from the nRF? And what application is running on your nRF52840?
    Edvin
  • I am not sure what you mean by "HCI dongle".
    The setup is as follows:
    - nRF52840 DevKit with the nrf sniffer - this is the source of wireshark/pcapng sniffs
    - ubuntu linux (the central) - this is where btmon log is from
    - uhk80 (a bluetooth keyboard; the peripheral) right half, which is a nRF52840-powered board. This acts as a peripheral.
      - right.log comes from there (gathered over uart), with CONFIG_BT_SMP=y and CONFIG_BT_HCI_CORE_LOG_LEVEL_DBG=y if I am not mistaken
      - this device uses zephyr bluetooth stack, with c2usb to handle USB HID and BLE HID. C2usb also provides the gatt service. It hooks in via udc_mac.
  • Ok, I understand. So it is in fact not an HCI dongle. It is a peripheral application. A BLE keyboard.
    (An HCI dongle/device is the typical "bluetooth dongle" that you can buy and plug in your computer to give it Bluetooth capabilities, if your computer doesn't have Bluetooth)
    In that case, I recommend that you look into using the Nordic SoftDevice Controller instead of the Zephyr Bluetooth controller. I believe we (Nordic) were involved in the zephyr bluetooth controller at some point, but I am not sure it is maintained, or who maintains it. At least, we do not support that bluetooth controller.
    Check if the issue still persists if you change to the SoftDevice controller.
    Edvin
  • Oops, sorry. We are actually using the SoftDevice controller: i.e., CONFIG_BT_LL_SOFTDEVICE=y.
    What I meant is that we are using the default zephyr host implementation (by which I mean that we have not reimplemented or customized the zephyr/subsys/bluetooth functionality). Zephyr 3.7.99 to be specific.
    Ok, yes. That is the intended way. You shouldn't change anything in the bluetooth host implementation, so that is good.
    I know that DevZone has some hickups some times, but can you please try to upload your attachments again? I am still not able to see them.
    Edvin
