nRF9151 stuck in disconnected, unable to reconnect to LTE-M
We are testing connection resilience on our nRF9151 product. Generally, LTE-M connectivity (Germany, on Telefonica and/or Telekom) works fine.
However, under certain circumstances the nRF9151 appears unable to reconnect to the network. The only way to get it reconnect is with a full reboot.
One situation is when the SIM is briefly inactive for whatever reason (for example, an outage on the carrier side or because the network assignments change and the SIM is reset). The nRF9151 will loose connectivity immediately (as expected) and will try to connect later, but fails forever with "<err> modem_info_params: Link data not obtained: 5 -5". Only a reboot resolves it, after which the nRF9151 will immediately reconnect (no change on the SIM/network side).
In the same situation, we've also seen the modem actually re-attach to the network (as seen from the signallng logs) but the nRF9151 network stack apparently fails to establish a PDN session repeatedly with "nrf_cloud_transport: Could not connect to nRF Cloud MQTT Broker mqtt.nrfcloud.com, port: 45858. err: -111". Here also after a reboot it immediately reconnects.
I understand the FPLMN List may come into play here, but I've also tested this by adding a new LTE-M network to the SIM that the device has not seen since the reboot, so it should not be in the FPLMN. But the nRF9151 is still unable to connect even to that new network (until a reboot).
My interpretation is that once the nRF9151 has disconnected it gets into a state where some part of the stack (modem, network stack, link manager) is stuck and fails to reconnect even though it could (SIM is active and suitable networks are available). A reboot resolves that state.
Unfortunately, a reboot is not a good option for us because we would then loose the data queued in RAM.
Note: We are using the nRF9151 with the latest modem FW and nRF SDK, the application is based on the multi service sample.
Is this a known issue? Can I provide more information to help you analyse it? Do you have recommendations to deal with this situation?
Thanks much!
  • I'm also facing the exact same issue, have you managed to get any work around for this?
    best regards,
  • Hello Akshay,
    I kindly recommend creating a separate ticket for your issue, as each case is handled independently. Once you've created the new ticket, please share the relevant details there, similar to what I've requested in this conversation.
    Abhijith
  • Hi  ,
    I was able to do some more testing and create modem traces.
    I reproduced the problem with the nRF SDK 2.9.0 Modem Shell application on a nRF9161-DK. This means the problem is not related to our hardware or application, but must be somewhere in the nRF software stack.
    I used the Modem Shell unmodified, just built it with CONFIG_MOSH_CLOUD_MQTT=y and the nrf91-modem-trace-uart snippet.
    Here is the trace in the serial window. At ">>>" you see my comments interleaved.
    You can see that after the loss of the connection (poor signal or brief deactivation of SIM) the modem is in auto-connect mode and sees networks, but doesn't try to reconnect. It just 'sits there'. I have experience with other modems (e.g. Quectel) and in such cases the modem would automatically try to reconnect.
    When I 'kick' the nRF9161 (cfun=4, then cfun=1) it immediately reestablishes the connection.
    To me this indicates that after connection loss the modem gets stuck in some state where it fails to try and auto-connect, and that state is only cleared with a modem soft reset.
    I've very similar reports from other developers: https://community.circuitdojo.com/d/224-reconnecting-lte-after-disconnect.
    >>> Reboot:
    Booting TF-M v2.1.1-ncs3
    [Sec Thread] Secure image initializing!
    TF-M isolation level is: 0x00000001
    TF-M Float ABI: Hard
    Lazy stacking enabled
    *** Booting nRF Connect SDK v2.9.0-7787b2649840 ***
    *** Using Zephyr OS v3.7.99-1f8f3dc29142 ***
    Reset reason: PIN reset
    mosh:~$
    MOSH version:       v2.9.0-7787b2649840
    MOSH build id:      custom
    MOSH build variant: dev
    HW version:         nRF9161 LACA ADA
    Modem FW version:   mfw_nrf91x1_2.0.0
    Modem FW UUID:      c234531b-9f14-4135-9092-f4e52d37fb23
    > at AT+CGMR
    at AT+CGMR
    mfw_nrf91x1_2.0.0
    OK
    mosh:~$ > at AT+CFUN=1
    at AT+CFUN=1
    OK
    mosh:~$ > at AT%XCONNSTAT=1
    at AT%XCONNSTAT=1
    OK
    mosh:~$ > at AT%XCONNSTAT?
    at AT%XCONNSTAT?
    %XCONNSTAT: 0,0,0,0,0,0
    OK
    mosh:~$ > at AT+CMEE=1
    at AT+CMEE=1
    OK
    mosh:~$ > at AT%XSIM=1
    at AT%XSIM=1
    OK
    mosh:~$ > at AT+CEREG=5
    at AT+CEREG=5
    OK
    mosh:~$ > at AT%MDMEV=1
    at AT%MDMEV=1
    OK
    mosh:~$ > at AT%CESQ=1
    at AT%CESQ=1
    OK
    mosh:~$ > at AT+CGSN=1
    at AT+CGSN=1
    +CGSN: "352696950002997"
    OK
    mosh:~$ > at AT+CGMM
    at AT+CGMM
    nRF9161-LACA
    OK
    mosh:~$ > at AT+CEMODE?
    at AT+CEMODE?
    +CEMODE: 2
    OK
    mosh:~$ > at AT+CMEE?
    at AT+CMEE?
    +CMEE: 1
    OK
    mosh:~$ > at AT+CNEC?
    at AT+CNEC?
    +CNEC: 16
    OK
    mosh:~$ > at AT+CGEREP?
    at AT+CGEREP?
    +CGEREP: 1,0
    OK
    mosh:~$ at A> at AT+CIND=1,1,1
    T+CIND=1,1,1
    OK
    mosh:~$ > at AT+COPS=3,2
    at AT+COPS=3,2
    OK
    mosh:~$ > at AT+CGDCONT?
    at AT+CGDCONT?
    OK
    mosh:~$ > at AT+CGACT?
    at AT+CGACT?
    OK
    mosh:~$ > at AT+CESQ
    at AT+CESQ
    +CESQ: 99,99,255,255,255,255
    OK
    mosh:~$ > at AT%XSIM?
    at AT%XSIM?
    %XSIM: 0
    OK
    mosh:~$ > at AT+CPIN?
    at AT+CPIN?
    +CME ERROR: 13
    mosh:~$ > at AT+CIMI
    at AT+CIMI
    +CME ERROR: 0
    mosh:~$ > at AT+CNEC=24
    at AT+CNEC=24
    OK
    mosh:~$ > at AT+CEER
    at AT+CEER
    OK
    mosh:~$ > at AT+CGEREP=1
    at AT+CGEREP=1
    OK
    mosh:~$ > at AT%XPOFWARN=1,30
    at AT%XPOFWARN=1,30
    OK
    mosh:~$ > at AT%XVBATLVL=1
    at AT%XVBATLVL=1
    OK
    mosh:~$ > at AT+CGMI
    at AT+CGMI
    Nordic Semiconductor ASA
    OK
    mosh:~$ > at AT+CGMR
    at AT+CGMR
    mfw_nrf91x1_2.0.0
    OK
    at AT+CGSN
    352696950002997
    OK
    mosh:~$ > at AT%XMODEMUUID
    at AT%XMODEMUUID
    %XMODEMUUID: c234531b-9f14-4135-9092-f4e52d37fb23
    OK
    mosh:~$ > at AT%XDATAPRFL?
    at AT%XDATAPRFL?
    %XDATAPRFL: 2
    OK
    mosh:~$ > at AT+CEREG?
    at AT+CEREG?
    +CEREG: 5,0
    OK
    mosh:~$ > at AT+CFUN?
    at AT+CFUN?
    +CFUN: 1
    OK
    at AT%CESQ=1
    OK
    mosh:~$ > at AT+CSCON=1
    at AT+CSCON=1
    OK
    mosh:~$ > at AT+CSCON?
    at AT+CSCON?
    +CSCON: 1,0
    OK
    mosh:~$ > at AT+CPAS
    at AT+CPAS
    +CPAS: 0
    OK
    mosh:~$ > at AT+CEDRXRDP
    at AT+CEDRXRDP
    +CEDRXRDP: 0
    OK
    mosh:~$ > at AT%XTIME=1
    at AT%XTIME=1
    OK
    mosh:~$ > at AT%CONEVAL
    at AT%CONEVAL
    %CONEVAL: 1
    OK
    mosh:~$ > at AT%XCBAND=?
    at AT%XCBAND=?
    %XCBAND: (1,2,3,4,5,8,12,13,18,19,20,25,26,28,66,85)
    OK
    at AT%XCBAND
    %XCBAND: 0
    OK
    mosh:~$ > at AT%HWVERSION
    at AT%HWVERSION
    %HWVERSION: nRF9161 LACA ADA
    OK
    mosh:~$ > at AT%XMODEMTRACE=1,2
    OK
    mosh:~$ > at AT%XSYSTEMMODE?
    at AT%XSYSTEMMODE?
    %XSYSTEMMODE: 1,0,0,0
    OK
    mosh:~$ > at AT%XICCID
    at AT%XICCID
    %XICCID: 89457300000010597907
    OK
    mosh:~$ > at AT%XEMPR?
    at AT%XEMPR?
    %XEMPR:
    OK
    mosh:~$ at AT+CGDC> at AT+CGDCONT?
    ONT?
    OK
    mosh:~$ > at AT+COPS?
    at AT+COPS?
    +COPS: 0
    OK
    mosh:~$ > at AT%XMONITOR
    at AT%XMONITOR
    %XMONITOR: 0
    OK
    mosh:~$ > at AT+CPINR="SIM PIN"
    +CPINR: "SIM PIN",3
    OK
    mosh:~$ > at AT+CPINR="SIM PIN2"
    +CPINR: "SIM PIN2",3
    OK
    mosh:~$ > at AT+CPINR="SIM PUK"
    +CPINR: "SIM PUK",10
    OK
    mosh:~$ > at AT+CPINR="SIM PUK2"
    +CPINR: "SIM PUK2",10
    OK
    at AT%XSIM?
    %XSIM: 1
    OK
    Network registration status: searching
    Currently active system mode: LTE-M
    LTE cell changed: ID: 45508877, Tracking area: 26552
    RRC mode: Connected
    PDN event: PDP context 0 activated
    PDN event: PDP context 0, PDN type IPv4 only allowed
    Modem domain event: Search done
    Network registration status: Connected - roaming
    PSM parameter update: TAU: 3240, Active time: -1 seconds
    Modem config for system mode: LTE-M
    Modem config for LTE preference: No preference, automatically selected by the modem
    Battery voltage:       5042 mV
    Modem temperature:     27 C
    Device ID:             nrf-352696950002997
    Operator full name:   ""
    Operator short name:  ""
    Operator PLMN:        "26201"
    Current cell id:       45508877 (0x02B6690D)
    Current phy cell id:   337
    Current band:          3
    Current TAC:           26552 (0x67B8)
    Current rsrp:          37: -104dBm
    Current snr:           29: 5dB
    Mobile network time and date: 25/06/27,04:58:30+08
    PDP context info 1:
      CID:                0
      PDN ID:             0
      PDP context active: yes
      PDP type:           IP
      APN:                onomondo
      IPv4 MTU:           1360
      IPv4 address:       100.76.21.49
      IPv6 address:       ::
      IPv4 DNS address:   172.30.8.5, 172.30.8.6
      IPv6 DNS address:   ::, ::
    RRC mode: Idle
    >>> connection established, everything OK. Establish MQTT cloud connection:
    mosh:~$ > cloud connect
    cloud connect
    Endpoint: mqtt.nrfcloud.com
    Connecting to nRF Cloud...
    nRF Cloud event: NRF_CLOUD_EVT_TRANSPORT_CONNECTING
    RRC mode: Connected
    [00:00:45.708,557] <inf> nrf_cloud_info: Device ID: nrf-352696950002997
    [00:00:45.717,956] <inf> nrf_cloud_info: IMEI:      352696950002997
    [00:00:45.810,791] <inf> nrf_cloud_info: UUID:      50363953-3234-40cb-80ae-1e21b10ad7e4
    [00:00:45.816,925] <inf> nrf_cloud_info: Modem FW:  mfw_nrf91x1_2.0.0
    [00:00:45.816,955] <inf> nrf_cloud_info: Protocol:          MQTT
    [00:00:45.816,986] <inf> nrf_cloud_info: Download protocol: HTTPS
    [00:00:45.817,016] <inf> nrf_cloud_info: Sec tag:           16842753
    [00:00:45.817,047] <inf> nrf_cloud_info: Host name:         mqtt.nrfcloud.com
    nRF Cloud event: NRF_CLOUD_EVT_TRANSPORT_CONNECTED
    nRF Cloud event: NRF_CLOUD_EVT_RX_DATA_SHADOW
    nRF Cloud event: NRF_CLOUD_EVT_USER_ASSOCIATED
    [00:00:49.732,299] <inf> nrf_cloud_log: Changing cloud log level from:1 to:3
    [00:00:49.732,330] <inf> nrf_cloud_log: Changing cloud logging enabled to:1
    nRF Cloud event: NRF_CLOUD_EVT_READY
    Connection to nRF Cloud established
    [00:00:51.133,270] <inf> nrf_cloud_info: Team ID:   be46c77d-xxx
    RRC mode: Idle
    >>> Attached network info
    mosh:~$ > at at+cops?
    at at+cops?
    +COPS: 0,2,"26201",7
    OK
    mosh:~$ > at at+cereg?
    at at+cereg?
    +CEREG: 5,5,"67B8","02B6690D",7,,,"11100000","11100000"
    OK
    RRC mode: Connected
    >>> Now: Loss of connectivity:
    nRF Cloud event: NRF_CLOUD_EVT_TRANSPORT_DISCONNECTED, status: 3
    Network registration status: not registered
    Connection to nRF Cloud disconnected
    PDN event: PDP context 0 network detach
    Reconnecting in 10 seconds...
    RRC mode: Idle
    [00:01:53.207,977] <wrn> lte_lc: Registration rejected, EMM cause: 7, Cell ID: 45508877, Tracking area: 26552, LTE mode: 7
    nRF Cloud event: NRF_CLOUD_EVT_TRANSPORT_CONNECT_ERROR, status: -9
    Connecting to nRF Cloud failed
    [00:02:03.257,019] <err> nrf_cloud_transport: Could not connect to nRF Cloud MQTT Broker mqtt.nrfcloud.com, port: 45858. err: -111
    >>> Modem sees networks, is in automatic mode, but does not try to reconnect
    at at+cereg?
    +CEREG: 5,0
    OK
    at at+cops?
    +COPS: 0
    OK
    mosh:~$ at at+cops=?
    > at at+cops=?
    +COPS: (1,"","","26203",7),(1,"","","26201",7),(1,"","","26202",7)
    OK
    Currently active system mode: None
    LTE cell changed: ID: -1, Tracking area: -1
    ONT?
    OK
    >>> manually force offline mode, then back to normal mode
    mosh:~$ > at at+cfun=4
    at at+cfun=4
    OK
    mosh:~$ > at at+cfun=1
    at at+cfun=1
    OK
    >>> modem reestablishes connection without further input or actions
    LTE cell changed: ID: 45508865, Tracking area: 26552
    RRC mode: Connected
    Battery voltage:       5031 mV
    Modem temperature:     28 C
    Current cell id:       45508865 (0x02B66901)
    Current phy cell id:   379
    Current band:          20
    Current rsrp:          46: -95dBm
    Current snr:           30: 6dB
    Mobile network time and date: 25/06/27,05:02:49+08
    PDP context info 1:
      CID:                0
      PDN ID:             0
      PDP type:           IP
      APN:                onomondo
      IPv4 MTU:           1360
      IPv6 address:       ::
    LTE cell changed: ID: 30601474 (0x01D2F102), PCI 164, Tracking area: 26552 (0x67B8), Band: 3, RSRP: 36 (-105dBm), SNR: 29 (5dB)
    >>> Reestablish MQTT cloud connection
    cloud connect
    [00:05:04.917,236] <inf> nrf_cloud_info: Team ID:   be46c77d-e0a8-4ee0-92cc-85525808fc1b
    RRC mode: Idle
    LTE cell changed: ID: 45508877 (0x02B6690D), PCI 337, Tracking area: 26552 (0x67B8), Band: 3, RSRP: 38 (-103dBm), SNR: 31 (7dB)
    mosh:~$
    trace-2025-06-27T04-58-14.712Z.mtrace
  • Hello Terrence,
    Thanks for the update. I’ve reported this issue internally, but to investigate further, we need a modem trace. I didn’t see one attached in your last response.
    If you missed attaching it, please upload the trace using the Insert tab.
    Abhijith
    Sorry, I now attached the trace to my previous post.
    Terrence
