nRF7002 randomly unable to connect to Wifi
I have an application that syncs via the internet using a nRF5340 and nRF7002.  I am using the thingy53 with a nRF7002EB for now while the custom circuit boards are being manufactured.  The application connects via wifi every 4 minutes to transmit data.  It then disconnects from the Wifi network to save power between sync intervals.  The application is currently using nRF Connect v3.0.1 and is based on the Azure IoT sample.
The application is in early field testing with around 20 users.  It works well most of the time, but randomly, after 1-2 weeks the system will stop being able to connect to the Wifi network.  A Wifi scan is initiated, but a connection event is never received.  I have also discovered that the system will start working again if I issue the new diagnostic command nrf70 util rpu_recovery_test via a shell connection.
My suspicion is that this is a bug in the nRF7002 where it can somehow get into a semi-unresponsive state.  The only way to recover is to externally reset the nRF7002.  It is difficult to know for sure because this issue takes a week or two to reproduce.  I do have CONFIG_NRF_WIFI_RPU_RECOVERY set, but this doesn't seem to be working.  I am considering updating the application firmware to add a custom nRF7002 watchdog timer that can reset it if it hangs.  However, I wanted to check with the Nordic team to make sure there aren't any known issues or other suggested troubleshooting steps.
  • We had a couple more hang ups over the weekend that have some interesting log snippets.  These users recovered by performing a full cold start of the system after running fine for many hours.  I was hoping the wifi ready and RPU recovery would catch/fix these issue automatically without needing a cold start.  I haven't experimented with the propagation delay yet, but please let me know if these errors provide any clues.
    uart:~$ uart:~$ [34:20:16.434,112] <err> wifi_nrf: hal_rpu_ready_wait: Timed out waiting (msg_type = 0)
    uart:~$ uart:~$ [34:20:16.434,204] <err> wifi_nrf: hal_rpu_cmd_process_queue: Timeout waiting to get free cmd buff from RPU
    uart:~$ uart:~$ [34:20:17.434,112] <err> wifi_nrf: hal_rpu_ready_wait: Timed out waiting (msg_type = 0)
    uart:~$ uart:~$ [34:20:17.434,234] <err> wifi_nrf: hal_rpu_cmd_process_queue: Timeout waiting to get free cmd buff from RPU
    uart:~$ uart:~$ [34:20:17.434,295] <err> wifi_nrf: nrf_wifi_wpa_supp_scan2: Scan trigger failed
    uart:~$ uart:~$ [34:20:17.434,356] <err> wpa_supp: wpa_drv_zep_scan2: scan2 op failed
    uart:~$ uart:~$ [34:20:18.435,150] <err> wifi_nrf: hal_rpu_ready_wait: Timed out waiting (msg_type = 0)
    uart:~$ uart:~$ [34:20:18.435,211] <err> wifi_nrf: hal_rpu_cmd_process_queue: Timeout waiting to get free cmd buff
    [07:46:44.967,102] <err> wifi_nrf: hal_rpu_ps_wake: RPU is not ready for more than 1 sec,reg_val = 0x2 rpu_ps_state_mask = 0x6
    [07:46:44.967,193] <err> wifi_nrf: hal_rpu_reg_read: RPU wake failed
    [07:46:44.967,285] <err> wifi_nrf: hal_rpu_hpq_is_empty: Read from dequeue address failed, val (0x0)
    [07:46:44.967,346] <err> wifi_nrf: hal_rpu_ready_wait: Timed out waiting (msg_type = 0)
    [07:46:44.967,437] <err> wifi_nrf: hal_rpu_cmd_process_queue: Timeout waiting to get free cmd buff from RPU
    [07:46:44.967,498] <err> wifi_nrf: nrf_wifi_wpa_supp_scan_results_get: nrf_wifi_sys_fmac_scan_res_get failed
    [07:46:44.967,559] <err> wpa_supp: wpa_drv_zep_get_scan_results2: get_scan_results2 op failed
    [07:46:45.968,139] <err> wifi_nrf: hal_rpu_ps_wake: RPU is not ready for more than 1 sec,reg_val = 0x2 rpu_ps_state_mask = 0x6
    [07:46:45.968,231] <err> wifi_nrf: hal_rpu_reg_read: RPU wake failed
    [07:46:45.968,353] <err> wifi_nrf: hal_rpu_hpq_is_empty: Read from dequeue address failed, val (0x0)
    [07:46:45.968,444] <err> wifi_nrf: hal_rpu_ready_wait: Timed out waiting (msg_type = 0)
    [07:46:45.968,536] <err> wifi_nrf: hal_rpu_cmd_process_queue: Timeout waiting to get free cmd buff from RPU
    [07:46:45.968,627] <err> wifi_nrf: nrf_wifi_if_stop_zep: nrf_wifi_sys_fmac_set_power_save failed
    [07:46:46.968,139] <err> wifi_nrf: hal_rpu_ps_wake: RPU is not ready for more than 1 sec,reg_val = 0x2 rpu_ps_state_mask = 0x6
    [07:46:46.968,231] <err> wifi_nrf: hal_rpu_reg_read: RPU wake failed
    [07:46:46.968,353] <err> wifi_nrf: hal_rpu_hpq_is_empty: Read from dequeue address failed, val (0x0)
    [07:46:46.968,444] <err> wifi_nrf: hal_rpu_ready_wait: Timed out waiting (msg_type = 0)
    [07:46:46.968,536] <err> wifi_nrf: hal_rpu_cmd_process_queue: Timeout waiting to get free cmd buff from RPU
    [07:46:57.656,616] <err> wifi_nrf: nrf_wifi_sys_fmac_chg_vif_state: RPU is unresponsive for 10 sec
    [07:46:57.656,677] <err> wifi_nrf: nrf_wifi_if_stop_zep: nrf_wifi_sys_fmac_chg_vif_state failed
    [07:46:57.671,691] <inf> wifi: nRF7002 ready?: no
    [07:46:59.665,191] <inf> wifi_nrf_bus: SPIM spi@a000: freq = 8 MHz
    [07:46:59.665,252] <inf> wifi_nrf_bus: SPIM spi@a000: latency = 0
    [07:47:10.490,234] <err> wifi_nrf: nrf_wifi_sys_fmac_chg_vif_state: RPU is unresponsive for 10 sec
    [07:47:10.490,325] <err> wifi_nrf: nrf_wifi_if_start_zep: nrf_wifi_sys_fmac_chg_vif_state failed
    [07:47:10.492,584] <err> wifi_nrf: nrf_wifi_rpu_recovery_work_handler: rpu_ctx_zep is NULL
    [07:47:10.494,598] <err> wifi_nrf: nrf_wifi_wpa_supp_set_key: rpu_ctx_zep is NULL
    [07:47:10.494,659] <err> wpa_supp: _wpa_drv_zep_set_key: set_key op failed
    [07:47:10.494,720] <err> wifi_nrf: nrf_wifi_wpa_supp_set_key: rpu_ctx_zep is NULL
    [07:47:10.494,781] <err> wpa_supp: _wpa_drv_zep_set_key: set_key op failed
    [07:47:10.494,812] <err> wifi_nrf: nrf_wifi_wpa_supp_set_key: rpu_ctx_zep is NULL
    [07:47:10.494,873] <err> wpa_supp: _wpa_drv_zep_set_key: set_key op failed
    [07:47:10.494,934] <err> wifi_nrf: nrf_wifi_wpa_supp_set_key: rpu_ctx_zep is NULL
    [07:47:10.494,995] <err> wpa_supp: _wpa_drv_zep_set_key: set_key op failed
    [07:47:10.495,056] <err> wifi_nrf: nrf_wifi_wpa_supp_set_key: rpu_ctx_zep is NULL
    [07:47:10.495,117] <err> wpa_supp: _wpa_drv_zep_set_key: set_key op failed
    [07:47:10.495,147] <err> wifi_nrf: nrf_wifi_wpa_supp_set_key: rpu_ctx_zep is NULL
    [07:47:10.495,208] <err> wpa_supp: _wpa_drv_zep_set_key: set_key op failed
    [07:47:10.496,734] <inf> wifi: nRF7002 ready?: yes
  • Got a reply from the relevant team:
    rpu_recovery_test is purely for testing, but the fact that it's helping recover Wi-Fi means that nRF70 is stuck but for some reason the auto-recovery has not kicked in. Could you try to collect stats using nrf70 util rpu_stats_mem? The command needs to be repeated for at least 5 times to see the diff.
    And regarding the code shared in wifi.c, a few comment based on limited understanding:
    • Connection timeout of 500s is excessive, we typically use 60s as the worst case time. Is that a typo?
    • On successful connection, the connection timeout is restarted, and will disconnect after the timeout, is this a desired behaviour? In a typical use case, connection timer should be stopped upon successful connection.
    • From connection timeout handler, no need to issue a disconnect as the connection isn't successful, so, disconnect would be a no-op.
    • Wi-Fi ready doesn't seem to be integrated properly: When the application receives a Wi-Fi not ready event, it has to stop using Wi-Fi (don't send any traffic) and wait for Wi-Fi ready event and trigger a connection explicitly and then start using Wi-Fi on successful connection. The code just check for Wi-Fi readiness only before issue connect, this is incomplete. Please see the event loop for reference (should be customized as per use case).
    Elfving
  • Hi  ,
    Sorry if this is something I've forgotten to touch on in a previous response. I see here though that this case is now handled by a coworker of mine, and propagation delay is being discussed there, so I assume things are fine now?
    Elfving
  • I think the reviewer misunderstood the code I shared slightly.  I could share more, but we would need to take the ticket private.  Please advise if you think that is worthwhile.
    I agree the rpu_recovery_test is test feature.  I opened the ticket because it seems like the auto-recovery feature isn't working (or isn't implemented correctly).  Also, it seems like a the RPU should never lock up.  Isn't this a bug in the wifi driver or RPU firmware?
    This is a battery powered application that is normally sleeping (wifi disconnected).  Every 4 minutes it wakes up and syncs data that it collected via wifi.  The connection timeout is a watchdog to make sure the wifi connection doesn't stay active too long as this would drain the battery.  It isn't a timeout for establishing a connection.
    I could add more checks to the wifi-ready flag drops during a connection (or force a disconnect).  However the error seems to occur while trying to establish a connection (not while a connection is active).  The data transfer to the cloud happens in another dedicated workqueue thread and will disconnect/exit on its own if connectivity is lost.
    I could add the rpu_stats_mem command to the logging.  This issue isn't easily reproduced (usually takes about 2 weeks).  I am storing the logs to NOR flash so I have limited space for logging.  However, I could issue the rpu_stats_mem command and log the results once every few hours if the team thinks it is useful.
  • Hi again, and thanks for waiting.
    I got some questions here for you.
    • Can they share the full details of their application and sequence of interactions with Wi-Fi. Specifically,
      • Data transfer (TCP?) - periodicity? size of the data transferred
      • interface down/up (when, periodicity)
      • Configuration of the Wi-Fi Router (Wi-Fi 4/5/6 security settings etc), band and channel used if possible.
    • Can this application run on any Nordic DKs (nRF7002DK or nRF5340+nrf7002EK etc) and reproduce the issue?
    • Can they provide the following -
      • Wireshark capture when the issue is seen
      • More PPK traces simultaneously with the wireshark captures
      • Can they check in any way if scan works when the device is in this erroneous mode.
      • Stored RPU stats for every hr into NOR flash. Probably the last 10 stats before the issue is hit are sufficient.
      • Also 5 consecutive RPU stats when the issue is hit (if it is possible)
    Elfving
