FOTA speed
Hello Nordic
Using the old SDK, i was able to do FOTA wiht 10kb/s.
After doing all kinds of tweaks, I am only able to obtain 5kb/s with the new connect SDK.
Can i increase the speed?
Here is my configuration file:
#CONFIG_NO_OPTIMIZATIONS=y
CONFIG_DEBUG_OPTIMIZATIONS=n
# General config
CONFIG_LOG=y
# Choose RTT console
CONFIG_LOG_BACKEND_RTT=y
CONFIG_UART_CONSOLE=n
# To enable floating point support
CONFIG_CBPRINTF_FP_SUPPORT=y
# Timer configuration
CONFIG_NRFX_TIMER0=y
CONFIG_NRFX_TIMER1=y
CONFIG_NRFX_TIMER2=y
CONFIG_NRFX_TIMER3=y
CONFIG_NRFX_TIMER4=y
CONFIG_GPIO=y
# Enable ADC
CONFIG_ADC=y
# Enable PWM
CONFIG_PWM=y
# Enable sensor
CONFIG_SENSOR=y
# Bluetooth settings
CONFIG_BT=y                    # Enable Bluetooth stack
CONFIG_BT_PERIPHERAL=y          # Enable peripheral role
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_DEVICE_NAME="HBLC/LT"    # Set Bluetooth device name
CONFIG_BT_GATT_DYNAMIC_DB=y
# Increase stack size for the main thread and System Workqueue
CONFIG_MAIN_STACK_SIZE=2048
# Flash storage and settings
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_NVS_LOG_LEVEL_DBG=y
#Enable FOTA over Bluetooth LE without using CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU
# --------------- core ---------------
CONFIG_CRC=y
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_MCUMGR=y
CONFIG_ZCBOR=y
CONFIG_MCUMGR_GRP_IMG=y          # DFU command set
CONFIG_IMG_MANAGER=y
CONFIG_STREAM_FLASH=y            # buffered writes
# --------------- Bluetooth ---------------
CONFIG_BT=y
CONFIG_MCUMGR_TRANSPORT_BT=y
CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL=y   # optional
CONFIG_MCUMGR_TRANSPORT_BT_REASSEMBLY=y
CONFIG_MCUMGR_TRANSPORT_NETBUF_SIZE=2475
# --------- (optional) throughput tweak ------
CONFIG_BT_L2CAP_TX_MTU=498
CONFIG_BT_BUF_ACL_TX_SIZE=255
CONFIG_BT_BUF_ACL_RX_SIZE=502
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
CONFIG_BT_CTLR_PHY_2M=y
# OS-management group – optional but handy
CONFIG_MCUMGR_GRP_OS=y
CONFIG_MCUMGR_GRP_OS_BOOTLOADER_INFO=y
# Progressive erase (optional, usually speeds up slot erase)
CONFIG_IMG_ERASE_PROGRESSIVELY=y
  • Hello Vidar
    I do not have the k_cpu_idle() command in my code and i do not remember putting the cpu to sleep anywhere in the code.
    I have captured the FOTA event using wireshark:
    13659	95.263119	63:c8:81:16:07:14	fc:e6:79:70:0b:3c	LE LL	60	CONNECT_IND
    13660	95.269846	Master_0xb182ec15	Slave_0xb182ec15	LE LL	35	Control Opcode: LL_FEATURE_REQ
    13661	95.270147	Slave_0xb182ec15	Master_0xb182ec15	ATT	33	Rcvd Exchange MTU Request, Client Rx MTU: 498
    13662	95.314846	Master_0xb182ec15	Slave_0xb182ec15	ATT	33	Sent Exchange MTU Response, Server Rx MTU: 517
    13663	95.315131	Slave_0xb182ec15	Master_0xb182ec15	LE LL	35	Control Opcode: LL_FEATURE_RSP
    13664	95.315433	Master_0xb182ec15	Slave_0xb182ec15	ATT	37	Sent Read By Group Type Request, GATT Primary Service Declaration, Handles: 0x0001..0xffff
    13665	95.359846	Master_0xb182ec15	Slave_0xb182ec15	ATT	37	Sent Read By Group Type Request, GATT Primary Service Declaration, Handles: 0x0001..0xffff
    13666	95.360163	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13667	95.360394	Master_0xb182ec15	Slave_0xb182ec15	LE LL	35	Control Opcode: LL_LENGTH_REQ
    13668	95.404846	Master_0xb182ec15	Slave_0xb182ec15	LE LL	35	Control Opcode: LL_LENGTH_REQ
    13669	95.405147	Slave_0xb182ec15	Master_0xb182ec15	LE LL	35	Control Opcode: LL_SLAVE_FEATURE_REQ
    13670	95.405449	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13671	95.449847	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13672	95.450075	Slave_0xb182ec15	Master_0xb182ec15	ATT	44	Rcvd Read By Group Type Response, Attribute List Length: 2, Generic Attribute Profile, Generic Access Profile
    13673	95.450449	Master_0xb182ec15	Slave_0xb182ec15	LE LL	35	Control Opcode: LL_FEATURE_RSP
    13674	95.494847	Master_0xb182ec15	Slave_0xb182ec15	LE LL	35	Control Opcode: LL_FEATURE_RSP
    13675	95.495149	Slave_0xb182ec15	Master_0xb182ec15	LE LL	35	Control Opcode: LL_LENGTH_RSP
    13676	95.495451	Master_0xb182ec15	Slave_0xb182ec15	ATT	37	Sent Read By Group Type Request, GATT Primary Service Declaration, Handles: 0x000c..0xffff
    13677	95.539847	Master_0xb182ec15	Slave_0xb182ec15	ATT	37	Sent Read By Group Type Request, GATT Primary Service Declaration, Handles: 0x000c..0xffff
    13678	95.540166	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13679	95.540396	Master_0xb182ec15	Slave_0xb182ec15	LE LL	38	Control Opcode: LL_CONNECTION_UPDATE_IND
    13680	95.584848	Master_0xb182ec15	Slave_0xb182ec15	LE LL	38	Control Opcode: LL_CONNECTION_UPDATE_IND
    13681	95.585174	Slave_0xb182ec15	Master_0xb182ec15	LE LL	29	Control Opcode: LL_PHY_REQ
    13682	95.585428	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13683	95.629848	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13684	95.630078	Slave_0xb182ec15	Master_0xb182ec15	ATT	72	Rcvd Read By Group Type Response, Attribute List Length: 2, Unknown, Unknown
    13685	95.674848	Master_0xb182ec15	Slave_0xb182ec15	LE LL	29	Control Opcode: LL_REJECT_EXT_IND
    13686	95.675102	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13687	95.675332	Master_0xb182ec15	Slave_0xb182ec15	ATT	37	Sent Read By Group Type Request, GATT Primary Service Declaration, Handles: 0x006a..0xffff
    13688	95.719848	Master_0xb182ec15	Slave_0xb182ec15	ATT	37	Sent Read By Group Type Request, GATT Primary Service Declaration, Handles: 0x006a..0xffff
    13689	95.720166	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13690	95.764848	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13691	95.765078	Slave_0xb182ec15	Master_0xb182ec15	ATT	35	Rcvd Error Response - Attribute Not Found, Handle: 0x006a (Unknown: Unknown)
    13692	95.809848	Master_0xb182ec15	Slave_0xb182ec15	ATT	37	Sent Read By Type Request, GATT Include Declaration, Handles: 0x0001..0x0004
    13693	95.810167	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13694	95.854849	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13695	95.855079	Slave_0xb182ec15	Master_0xb182ec15	ATT	35	Rcvd Error Response - Attribute Not Found, Handle: 0x0001 (Generic Attribute Profile)
    13696	95.899849	Master_0xb182ec15	Slave_0xb182ec15	ATT	37	Sent Read By Type Request, GATT Characteristic Declaration, Handles: 0x0001..0x0004
    13697	95.900167	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13698	95.944849	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13699	95.945079	Slave_0xb182ec15	Master_0xb182ec15	ATT	39	Rcvd Read By Type Response, Attribute List Length: 1, Service Changed
    13700	95.952349	Master_0xb182ec15	Slave_0xb182ec15	LE LL	32	Control Opcode: LL_VERSION_IND
    13701	95.952627	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13702	95.952857	Master_0xb182ec15	Slave_0xb182ec15	ATT	37	Sent Read By Type Request, GATT Characteristic Declaration, Handles: 0x0003..0x0004
    13703	95.959849	Master_0xb182ec15	Slave_0xb182ec15	ATT	37	Sent Read By Type Request, GATT Characteristic Declaration, Handles: 0x0003..0x0004
    13704	95.960167	Slave_0xb182ec15	Master_0xb182ec15	LE LL	32	Control Opcode: LL_VERSION_IND
    13705	95.967349	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13706	95.967579	Slave_0xb182ec15	Master_0xb182ec15	ATT	35	Rcvd Error Response - Attribute Not Found, Handle: 0x0003 (Generic Attribute Profile: Service Changed)
    13707	95.974849	Master_0xb182ec15	Slave_0xb182ec15	ATT	37	Sent Read By Type Request, Client Supported Features, Handles: 0x0001..0xffff
    13708	95.975168	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13709	95.982349	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13710	95.982579	Slave_0xb182ec15	Master_0xb182ec15	ATT	35	Rcvd Error Response - Attribute Not Found, Handle: 0x0001 (Generic Attribute Profile)
    13711	95.989850	Master_0xb182ec15	Slave_0xb182ec15	ATT	35	Sent Find Information Request, Handles: 0x0004..0x0004
    13712	95.990152	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13713	95.997350	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13714	95.997580	Slave_0xb182ec15	Master_0xb182ec15	ATT	36	Rcvd Find Information Response, Handle: 0x0004 (Generic Attribute Profile: Service Changed: Client Characteristic Configuration)
    13715	96.004850	Master_0xb182ec15	Slave_0xb182ec15	ATT	37	Sent Read By Type Request, GATT Include Declaration, Handles: 0x0005..0x000b
    13716	96.005168	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13717	96.012350	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13718	96.012580	Slave_0xb182ec15	Master_0xb182ec15	ATT	35	Rcvd Error Response - Attribute Not Found, Handle: 0x0005 (Generic Access Profile)
    13719	96.019850	Master_0xb182ec15	Slave_0xb182ec15	ATT	37	Sent Read By Type Request, GATT Characteristic Declaration, Handles: 0x0005..0x000b
    13720	96.020168	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13721	96.027350	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13722	96.027580	Slave_0xb182ec15	Master_0xb182ec15	ATT	53	Rcvd Read By Type Response, Attribute List Length: 3, Device Name, Appearance, Peripheral Preferred Connection Parameters
    13723	96.034850	Master_0xb182ec15	Slave_0xb182ec15	ATT	37	Sent Read By Type Request, GATT Characteristic Declaration, Handles: 0x000b..0x000b
    13724	96.035168	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13725	96.042350	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13726	96.042580	Slave_0xb182ec15	Master_0xb182ec15	ATT	35	Rcvd Error Response - Attribute Not Found, Handle: 0x000b (Generic Access Profile: Peripheral Preferred Connection Parameters)
    13727	96.049850	Master_0xb182ec15	Slave_0xb182ec15	ATT	37	Sent Read By Type Request, GATT Include Declaration, Handles: 0x000c..0x000f
    13728	96.050168	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13729	96.057350	Master_0xb182ec15	Slave_0xb182ec15	ATT	37	Sent Read By Type Request, GATT Include Declaration, Handles: 0x000c..0x000f
    13730	96.057668	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13731	96.057898	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13732	96.058128	Slave_0xb182ec15	Master_0xb182ec15	ATT	35	Rcvd Error Response - Attribute Not Found, Handle: 0x000c (Unknown)
    13733	96.064850	Master_0xb182ec15	Slave_0xb182ec15	ATT	37	Sent Read By Type Request, GATT Characteristic Declaration, Handles: 0x000c..0x000f
    13734	96.065168	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13735	96.072350	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13736	96.072580	Slave_0xb182ec15	Master_0xb182ec15	ATT	53	Rcvd Read By Type Response, Attribute List Length: 1, Unknown
    13737	96.079850	Master_0xb182ec15	Slave_0xb182ec15	ATT	37	Sent Read By Type Request, GATT Characteristic Declaration, Handles: 0x000e..0x000f
    13738	96.080169	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13739	96.087350	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13740	96.087580	Slave_0xb182ec15	Master_0xb182ec15	ATT	35	Rcvd Error Response - Attribute Not Found, Handle: 0x000e (Unknown: Unknown)
    13741	96.094851	Master_0xb182ec15	Slave_0xb182ec15	ATT	35	Sent Find Information Request, Handles: 0x000f..0x000f
    13742	96.095153	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13743	96.102351	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13744	96.102581	Slave_0xb182ec15	Master_0xb182ec15	ATT	36	Rcvd Find Information Response, Handle: 0x000f (Unknown: Unknown: Client Characteristic Configuration)
    13745	96.109851	Master_0xb182ec15	Slave_0xb182ec15	ATT	37	Sent Read By Type Request, GATT Include Declaration, Handles: 0x0010..0x0069
    13746	96.110169	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13747	96.117351	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13748	96.117581	Slave_0xb182ec15	Master_0xb182ec15	ATT	35	Rcvd Error Response - Attribute Not Found, Handle: 0x0010 (Unknown)
    13749	96.124851	Master_0xb182ec15	Slave_0xb182ec15	ATT	37	Sent Read By Type Request, GATT Characteristic Declaration, Handles: 0x0010..0x0069
    13750	96.125169	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13751	96.132351	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13752	96.132581	Slave_0xb182ec15	Master_0xb182ec15	LE LL	277	L2CAP Fragment Start
    13753	96.134820	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13754	96.135049	Slave_0xb182ec15	Master_0xb182ec15	ATT	264	Rcvd Read By Type Response, Attribute List Length: 23, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown
    13755	96.139851	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13756	96.140081	Slave_0xb182ec15	Master_0xb182ec15	LE LL	264	L2CAP Fragment
    13757	96.147352	Master_0xb182ec15	Slave_0xb182ec15	ATT	37	Sent Read By Type Request, GATT Characteristic Declaration, Handles: 0x0041..0x0069
    13758	96.147669	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13759	96.162352	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13760	96.162582	Slave_0xb182ec15	Master_0xb182ec15	LE LL	277	L2CAP Fragment Start
    13761	96.164820	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13762	96.165050	Slave_0xb182ec15	Master_0xb182ec15	ATT	201	Rcvd Read By Type Response, Attribute List Length: 20, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown, Unknown
    13763	96.169852	Master_0xb182ec15	Slave_0xb182ec15	ATT	37	Sent Read By Type Request, GATT Characteristic Declaration, Handles: 0x0069..0x0069
    13764	96.170170	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13765	96.177352	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13766	96.177582	Slave_0xb182ec15	Master_0xb182ec15	ATT	35	Rcvd Error Response - Attribute Not Found, Handle: 0x0069 (Unknown: Unknown)
    13767	96.184852	Master_0xb182ec15	Slave_0xb182ec15	ATT	35	Sent Find Information Request, Handles: 0x0013..0x0013
    13768	96.185154	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13769	96.192353	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13770	96.192583	Slave_0xb182ec15	Master_0xb182ec15	ATT	36	Rcvd Find Information Response, Handle: 0x0013 (Unknown: Unknown: Client Characteristic Configuration)
    13771	96.199853	Master_0xb182ec15	Slave_0xb182ec15	ATT	35	Sent Find Information Request, Handles: 0x0016..0x0016
    13772	96.200155	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13773	96.207353	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13774	96.207583	Slave_0xb182ec15	Master_0xb182ec15	ATT	36	Rcvd Find Information Response, Handle: 0x0016 (Unknown: Unknown: Client Characteristic Configuration)
    13775	96.214853	Master_0xb182ec15	Slave_0xb182ec15	ATT	35	Sent Find Information Request, Handles: 0x0019..0x0019
    13776	96.215155	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13777	96.222353	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13778	96.222583	Slave_0xb182ec15	Master_0xb182ec15	ATT	36	Rcvd Find Information Response, Handle: 0x0019 (Unknown: Unknown: Client Characteristic Configuration)
    13779	96.229853	Master_0xb182ec15	Slave_0xb182ec15	LE LL	38	Control Opcode: LL_CONNECTION_UPDATE_IND
    13780	96.230179	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13781	96.237353	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13782	96.237583	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13783	96.244854	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13784	96.245084	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13785	96.252354	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13786	96.252584	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13787	96.259854	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13788	96.260084	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13789	96.267354	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13790	96.267584	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13791	96.274854	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13792	96.275084	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13793	96.282354	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13794	96.282584	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13795	96.289855	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13796	96.290085	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13797	96.304855	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13798	96.305085	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13799	96.349855	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13800	96.350085	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13801	96.394855	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13802	96.395085	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13803	96.439856	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13804	96.440085	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13805	96.484856	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13806	96.485085	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13807	96.529856	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13808	96.530086	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13809	96.574856	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13810	96.575086	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13811	96.619856	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13812	96.620086	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13813	96.664856	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13814	96.665086	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13815	96.709856	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13816	96.710086	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13817	96.754857	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13818	96.755086	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13819	96.799857	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13820	96.800086	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13821	96.844857	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13822	96.845087	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13823	96.889857	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13824	96.890087	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13825	96.934857	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13826	96.935087	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13827	96.979857	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13828	96.980087	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13829	97.024858	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13830	97.025087	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13831	97.069858	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13832	97.070087	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13833	97.114857	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13834	97.115086	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13835	97.159857	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13836	97.160086	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13837	97.204857	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13838	97.205087	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13839	97.294857	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13840	97.295087	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13841	97.339858	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13842	97.340087	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13843	97.384858	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13844	97.385087	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13845	97.429858	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13846	97.430087	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13847	97.474858	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13848	97.475087	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13849	97.519858	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13850	97.520088	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13851	97.564858	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13852	97.565089	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13853	97.609859	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13854	97.610089	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13855	97.654859	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13856	97.655089	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13857	97.699859	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13858	97.700089	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13859	97.744859	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13860	97.745089	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13861	97.789859	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13862	97.790089	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13863	97.834859	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13864	97.835089	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13865	97.879859	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13866	97.880090	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13867	97.924860	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13868	97.925090	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13869	97.969860	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13870	97.970090	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13871	98.014860	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13872	98.015090	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13873	98.059860	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13874	98.060091	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13875	98.104861	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13876	98.105091	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13877	98.149861	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13878	98.150091	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13879	98.194862	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13880	98.195091	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13881	98.239862	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13882	98.240092	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13883	98.284862	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13884	98.285092	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13885	98.329862	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13886	98.330092	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13887	98.374862	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13888	98.375092	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13889	98.419862	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13890	98.420092	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13891	98.464863	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13892	98.465092	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13893	98.509863	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13894	98.510092	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13895	98.554863	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13896	98.555091	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13897	98.599862	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13898	98.600092	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13899	98.644862	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13900	98.645093	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13901	98.689863	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13902	98.690093	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13903	98.734863	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13904	98.735093	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13905	98.779864	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13906	98.780093	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13907	98.824863	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13908	98.825092	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13909	98.869863	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13910	98.870092	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13911	98.914863	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13912	98.915093	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13913	98.959863	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13914	98.960093	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13915	99.004863	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13916	99.005093	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13917	99.049864	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13918	99.050093	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13919	99.094864	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13920	99.095093	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13921	99.139864	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13922	99.140093	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13923	99.184864	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13924	99.185093	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13925	99.229864	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13926	99.230093	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13927	99.274864	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13928	99.275095	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13929	99.319865	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13930	99.320095	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13931	99.364865	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13932	99.365095	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13933	99.409865	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13934	99.410095	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13935	99.454865	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13936	99.455095	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13937	99.499865	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13938	99.500095	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13939	99.544865	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13940	99.545095	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13941	99.589865	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13942	99.590096	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13943	99.634866	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13944	99.635096	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13945	99.679866	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13946	99.680096	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13947	99.724866	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13948	99.725096	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13949	99.769866	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13950	99.770096	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13951	99.859866	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13952	99.860096	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13953	99.904867	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13954	99.905096	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13955	99.949867	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13956	99.950097	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13957	99.994867	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13958	99.995097	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13959	100.039867	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13960	100.040098	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13961	100.084868	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13962	100.085098	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13963	100.129868	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13964	100.130098	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13965	100.174868	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13966	100.175098	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13967	100.219869	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13968	100.220098	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13969	100.264869	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13970	100.265099	Slave_0xb182ec15	Master_0xb182ec15	L2CAP	42	Connection Parameter Update Request
    13971	100.309869	Master_0xb182ec15	Slave_0xb182ec15	LE LL	38	Control Opcode: LL_CONNECTION_UPDATE_IND
    13972	100.310195	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13973	100.310425	Master_0xb182ec15	Slave_0xb182ec15	L2CAP	36	Connection Parameter Update Response (Accepted)
    13974	100.354869	Master_0xb182ec15	Slave_0xb182ec15	L2CAP	36	Connection Parameter Update Response (Accepted)
    13975	100.355179	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13976	100.399869	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13977	100.400099	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13978	100.444869	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13979	100.445099	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13980	100.489870	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13981	100.490099	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13982	100.534869	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13983	100.535098	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13984	100.579869	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13985	100.580098	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13986	100.624869	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13987	100.625099	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13988	100.669869	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13989	100.670099	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13990	100.714869	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13991	100.715099	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13992	100.759870	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13993	100.760099	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13994	100.804870	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13995	100.805099	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13996	100.849870	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13997	100.850099	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    13998	100.894870	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    13999	100.895099	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14000	100.939870	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14001	100.940099	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14002	100.984870	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14003	100.985100	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14004	101.029870	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14005	101.030101	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14006	101.074871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14007	101.075101	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14008	101.119871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14009	101.120101	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14010	101.164871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14011	101.165101	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14012	101.209871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14013	101.210101	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14014	101.254871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14015	101.255101	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14016	101.299871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14017	101.300102	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14018	101.344871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14019	101.345101	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14020	101.389871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14021	101.390101	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14022	101.434871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14023	101.435101	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14024	101.479871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14025	101.480101	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14026	101.524871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14027	101.525101	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14028	101.569871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14029	101.570100	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14030	101.614871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14031	101.615100	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14032	101.659871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14033	101.660101	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14034	101.704871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14035	101.705101	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14036	101.749871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14037	101.750101	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14038	101.794871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14039	101.795101	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14040	101.839871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14041	101.840100	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14042	101.884871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14043	101.885100	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14044	101.929871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14045	101.930100	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14046	101.974871	Master_0xb182ec15	Slave_0xb182ec15	ATT	35	Sent Write Request, Handle: 0x000f (Unknown: Unknown: Client Characteristic Configuration)
    14047	101.975172	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14048	102.019871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14049	102.020101	Slave_0xb182ec15	Master_0xb182ec15	ATT	31	Rcvd Write Response, Handle: 0x000f (Unknown: Unknown: Client Characteristic Configuration)
    14050	102.064871	Master_0xb182ec15	Slave_0xb182ec15	ATT	42	Sent Write Command, Handle: 0x000e (Unknown: Unknown)
    14051	102.065229	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14052	102.109871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14053	102.110101	Slave_0xb182ec15	Master_0xb182ec15	L2CAP	42	Connection Parameter Update Request
    14054	102.154871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	38	Control Opcode: LL_CONNECTION_UPDATE_IND
    14055	102.155197	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14056	102.155427	Master_0xb182ec15	Slave_0xb182ec15	L2CAP	36	Connection Parameter Update Response (Accepted)
    14057	102.199871	Master_0xb182ec15	Slave_0xb182ec15	L2CAP	36	Connection Parameter Update Response (Accepted)
    14058	102.200181	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14059	102.244872	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14060	102.245101	Slave_0xb182ec15	Master_0xb182ec15	ATT	47	Rcvd Handle Value Notification, Handle: 0x000e (Unknown: Unknown)
    14061	102.289872	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14062	102.290101	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14063	102.334872	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14064	102.335102	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14065	102.379872	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14066	102.380102	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14067	102.424872	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14068	102.425102	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14069	102.469872	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14070	102.470102	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14071	102.514873	Master_0xb182ec15	Slave_0xb182ec15	ATT	42	Sent Write Command, Handle: 0x000e (Unknown: Unknown)
    14072	102.515230	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14073	102.559873	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14074	102.560102	Slave_0xb182ec15	Master_0xb182ec15	ATT	62	Rcvd Handle Value Notification, Handle: 0x000e (Unknown: Unknown)
    14075	102.571123	Master_0xb182ec15	Slave_0xb182ec15	LE LL	38	Control Opcode: LL_CONNECTION_UPDATE_IND
    14076	102.571448	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14077	102.582373	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14078	102.582602	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14079	102.593622	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14080	102.593851	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14081	102.604872	Master_0xb182ec15	Slave_0xb182ec15	ATT	53	Sent Write Command, Handle: 0x000e (Unknown: Unknown)
    14082	102.605317	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14083	102.616122	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14084	102.616351	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14085	102.627372	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14086	102.627601	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14087	102.638622	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14088	102.638850	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14089	102.649871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14090	102.650100	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14091	102.661121	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14092	102.661350	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14093	102.679871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14094	102.680101	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14095	102.694871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14096	102.695101	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14097	102.709871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14098	102.710101	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14099	102.724871	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14100	102.725101	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14101	102.739872	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14102	102.740102	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14103	102.754872	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14104	102.755102	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14105	102.769872	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14106	102.770102	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14107	102.784872	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14108	102.785102	Slave_0xb182ec15	Master_0xb182ec15	ATT	49	Rcvd Handle Value Notification, Handle: 0x000e (Unknown: Unknown)
    14109	102.799873	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14110	102.800102	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14111	102.814873	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14112	102.815102	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14113	102.829873	Master_0xb182ec15	Slave_0xb182ec15	ATT	42	Sent Write Command, Handle: 0x000e (Unknown: Unknown)
    14114	102.830231	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14115	102.844873	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14116	102.845103	Slave_0xb182ec15	Master_0xb182ec15	LE LL	277	L2CAP Fragment Start
    14117	102.847341	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14118	102.847571	Slave_0xb182ec15	Master_0xb182ec15	ATT	34	Rcvd Handle Value Notification, Handle: 0x000e (Unknown: Unknown)
    14119	102.859873	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14120	102.860103	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14121	102.874873	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14122	102.875103	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14123	102.889873	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment Start
    14124	102.890319	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14125	102.890549	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14126	102.890995	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14127	102.891225	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14128	102.891671	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14129	102.891902	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14130	102.892348	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14131	102.892578	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14132	102.893024	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14133	102.893254	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14134	102.893700	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14135	102.893930	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14136	102.894376	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14137	102.894606	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14138	102.895052	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14139	102.895282	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14140	102.895728	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14141	102.895958	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14142	102.896405	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14143	102.896635	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14144	102.897081	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14145	102.897311	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14146	102.897757	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14147	102.897987	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14148	102.898433	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14149	102.898663	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14150	102.899109	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14151	102.899339	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14152	102.899785	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14153	102.900015	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14154	102.900461	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14155	102.900692	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14156	102.901138	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14157	102.901368	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14158	102.901814	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14159	102.902044	Master_0xb182ec15	Slave_0xb182ec15	ATT	40	Sent Write Command, Handle: 0x000e (Unknown: Unknown)
    14160	102.904876	Master_0xb182ec15	Slave_0xb182ec15	LE LL	40	L2CAP Fragment
    14161	102.905218	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14162	102.919876	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14163	102.920106	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14164	102.934876	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14165	102.935106	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14166	102.949876	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14167	102.950106	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14168	102.964876	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14169	102.965106	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14170	102.979876	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14171	102.980106	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14172	102.994876	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14173	102.995106	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14174	103.009876	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14175	103.010107	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14176	103.024876	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14177	103.025107	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14178	103.039876	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14179	103.040108	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14180	103.054878	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14181	103.055108	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14182	103.069878	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14183	103.070108	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14184	103.084878	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14185	103.099878	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14186	103.114878	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14187	103.129878	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14188	103.144878	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14189	103.159878	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14190	103.174878	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14191	103.175108	Slave_0xb182ec15	Master_0xb182ec15	ATT	50	Rcvd Handle Value Notification, Handle: 0x000e (Unknown: Unknown)
    14192	103.189878	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment Start
    14193	103.190325	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14194	103.190555	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14195	103.191001	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14196	103.191231	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14197	103.191677	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14198	103.191907	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14199	103.192353	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14200	103.192583	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14201	103.193029	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14202	103.193259	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14203	103.193705	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14204	103.193935	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14205	103.194382	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14206	103.194612	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14207	103.195058	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14208	103.195288	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14209	103.195734	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14210	103.195964	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14211	103.196410	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14212	103.196640	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14213	103.197086	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14214	103.197316	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14215	103.197762	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14216	103.197992	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14217	103.198438	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14218	103.198669	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14219	103.199115	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14220	103.199345	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14221	103.199791	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14222	103.200021	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14223	103.200467	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14224	103.200697	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14225	103.201143	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14226	103.201373	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14227	103.201819	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14228	103.202049	Master_0xb182ec15	Slave_0xb182ec15	ATT	39	Sent Write Command, Handle: 0x000e (Unknown: Unknown)
    14229	103.204881	Master_0xb182ec15	Slave_0xb182ec15	LE LL	39	L2CAP Fragment
    14230	103.205215	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14231	103.205445	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment Start
    14232	103.205891	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14233	103.206121	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14234	103.206568	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14235	103.206798	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14236	103.207244	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14237	103.207474	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14238	103.207920	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14239	103.208150	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14240	103.208596	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14241	103.208826	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14242	103.209272	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14243	103.209502	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14244	103.209948	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14245	103.210178	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14246	103.210624	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14247	103.210855	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14248	103.211301	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14249	103.211531	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14250	103.211977	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14251	103.212207	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14252	103.212653	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14253	103.212883	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14254	103.213329	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14255	103.213559	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14256	103.214005	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14257	103.214235	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14258	103.214681	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14259	103.214911	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14260	103.215358	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14261	103.215588	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14262	103.216034	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14263	103.216264	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14264	103.216710	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14265	103.216940	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14266	103.219884	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14267	103.220330	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14268	103.220560	Master_0xb182ec15	Slave_0xb182ec15	ATT	39	Sent Write Command, Handle: 0x000e (Unknown: Unknown)
    14269	103.220894	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14270	103.221124	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment Start
    14271	103.221570	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14272	103.221800	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14273	103.222246	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14274	103.222477	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14275	103.222923	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14276	103.223153	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14277	103.223599	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14278	103.223829	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14279	103.224275	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14280	103.224505	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14281	103.224951	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14282	103.225181	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14283	103.225627	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14284	103.225857	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14285	103.226303	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14286	103.226533	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14287	103.226980	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14288	103.227210	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14289	103.227656	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14290	103.227886	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14291	103.228332	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14292	103.228562	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14293	103.229008	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14294	103.229238	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14295	103.229684	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14296	103.229914	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14297	103.230360	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14298	103.230590	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14299	103.231036	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14300	103.231267	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14301	103.231713	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14302	103.231943	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14303	103.234887	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14304	103.235333	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14305	103.235563	Master_0xb182ec15	Slave_0xb182ec15	LE LL	53	L2CAP Fragment
    14306	103.236009	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14307	103.236239	Master_0xb182ec15	Slave_0xb182ec15	ATT	39	Sent Write Command, Handle: 0x000e (Unknown: Unknown)
    14308	103.236573	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14309	103.249887	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14310	103.250117	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14311	103.264887	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14312	103.265117	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14313	103.279887	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14314	103.280117	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14315	103.294887	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14316	103.295117	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14317	103.309887	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14318	103.310118	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14319	103.324888	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14320	103.325118	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    14321	103.339888	Master_0xb182ec15	Slave_0xb182ec15	LE LL	26	Empty PDU
    14322	103.340118	Slave_0xb182ec15	Master_0xb182ec15	LE LL	26	Empty PDU
    k_cpu_idle() turned out to be the culprit in the other case, but this is a function that normally should not be used at all in a multi threaded app. The question is whether you have any threads or other components in your application that might be blocking the workqueue. Have you tried to debug the application to see if the app is allowed to enter the idle thread? Do you have debug logging enabled?
    WS trace looks similar to the one posted in the other thread.
  • Hello
    Yes I was blocking the workqueue, doing to mush work in main and not releasing the thread.
    After adding this code, i have increased to FOTA speed to 10kb/s
    static atomic_t is_bootloading = false;
    /* 1. event handler ------------------------------------------------------ */
    static enum mgmt_cb_return dfu_cb(uint32_t event,
                                      enum mgmt_cb_return prev,
                                      int32_t *rc, uint16_t *grp,
                                      bool *abort_more,
                                      void *data, size_t len)
        switch (event) {
        case MGMT_EVT_OP_IMG_MGMT_DFU_STARTED:
            atomic_set(&is_bootloading, 1);
        case MGMT_EVT_OP_IMG_MGMT_DFU_STOPPED:
        case MGMT_EVT_OP_IMG_MGMT_DFU_CONFIRMED:
            atomic_set(&is_bootloading, 0);
        return MGMT_CB_OK;              /* always allow DFU */
    /* 2. mcumgr callback registration object -------------------------------- */
    static struct mgmt_callback dfu_cb_reg = {
        .callback = dfu_cb,
        .event_id = MGMT_EVT_OP_IMG_MGMT_DFU_STARTED |
                    MGMT_EVT_OP_IMG_MGMT_DFU_STOPPED |
                    MGMT_EVT_OP_IMG_MGMT_DFU_CONFIRMED,
    /* 3. tiny init routine that runs at boot -------------------------------- */
    static int dfu_cb_init(const struct device *unused)
        ARG_UNUSED(unused);
        mgmt_callback_register(&dfu_cb_reg);
        return 0;
    /* 4. ask Zephyr to call it at the APPLICATION init level ---------------- */
    SYS_INIT(dfu_cb_init, APPLICATION, CONFIG_APPLICATION_INIT_PRIORITY);
    Then i am using the is_bootloading variable to suspend tasks in my main loop.
        while (1) {
            if (atomic_get(&is_bootloading))
                wdt_feed(wdt, wdt_channel_id);
                toggle_all_leds();
                k_sleep(K_MSEC(100));
                continue;
    Does this way of suspending seem good code practice to you?
    I have not yet suspended the display update, I asume suspending the display, might bring me up to 20kb/s.
    Good to hear that you are getting better speeds now.
    I don't see anything wrong with your approach, but it sounds like your app spends most of its time processing tasks in the main loop, which also means the system isn’t able to spend much time in sleep. Are the tasks in this loop really that compute heavy and need to be blocking, or could the main loop perhaps yield more often?
  • Yes, we had not paid much attention to the multithreaded nature of the Zephyr RTOS. We could definitely yield more frequently. Thank you for helping us realize that the main issue was the lack of frequent yielding, rather than the settings in the .conf file.
