Partition Alignment
I am using the nrf54l15 on a custom board in our current project and want to use it with DFU over BLE FOTA as well as TF-M.
I can compile the project just fine before adding DFU as described in your tutorial (tutorial) The only diffrence being that i started from the Blinky Example.
When i try to compile the project it gives me an alignment error:
!!!Partition alignment error!!!
The non-secure start address in pm_static.yml or generated partition.yml is: 0x64600
which is not aligned with the SPU/MPC HW requirements.
In nRF53/nRF91 series the flash region need to be aligned with the SPU region size.
In nRF54L15 the flash region need to be aligned with the MPC region size.
Refer to the documentation section 'TF-M partition alignment requirements'
for more information.
Here is my compiled partitons.yml (when i delete the sysbuild.conf-File thus not implementing the DFU i suppose?)
EMPTY_0:
  address: 0x164000
  end_address: 0x165000
  placement:
    after:
    - mcuboot_secondary
  region: flash_primary
app:
  address: 0x64600
  end_address: 0xbc000
mcuboot:
  address: 0x0
  end_address: 0xc000
  placement:
    align:
      end: 0x1000
    before:
    - mcuboot_primary
mcuboot_pad:
  address: 0x14000
  end_address: 0x14800
  placement:
    align:
      start: 0x1000
    before:
    - mcuboot_primary_app
mcuboot_primary:
  address: 0x14000
  orig_span: &id001
  - app
  - tfm
  - mcuboot_pad
  sharers: 0x1
  span: *id001
mcuboot_primary_app:
  address: 0x14800
  orig_span: &id002
  - app
  - tfm
  span: *id002
mcuboot_secondary:
  address: 0xbc000
  end_address: 0x164000
  placement:
    after:
    - mcuboot_primary
    align:
      start: 0x1000
    align_next: 0x1000
  share_size:
  - mcuboot_primary
mcuboot_sram:
  address: 0x20000000
  end_address: 0x20013000
  orig_span: &id003
  - tfm_sram
  region: sram_primary
  span: *id003
otp:
  address: 0xffd500
  end_address: 0xffd9fc
  region: otp
sram_nonsecure:
  address: 0x20013000
  end_address: 0x2002f000
  orig_span: &id004
  - sram_primary
  span: *id004
sram_primary:
  address: 0x20013000
sram_secure:
  address: 0x20000000
  orig_span: &id005
  - tfm_sram
  span: *id005
tfm:
  address: 0x14800
  end_address: 0x64600
  inside:
  placement:
    before:
    - app
tfm_its:
  address: 0xc000
  end_address: 0xe000
  inside:
  - tfm_storage
  placement:
    before:
    - tfm_otp_nv_counters
tfm_nonsecure:
  address: 0x64600
  orig_span: &id006
  - app
  span: *id006
tfm_otp_nv_counters:
  address: 0xe000
  end_address: 0x10000
  inside:
  - tfm_storage
  placement:
    before:
    - tfm_ps
tfm_ps:
  address: 0x10000
  end_address: 0x14000
  inside:
  - tfm_storage
  placement:
    after:
    - mcuboot
    - tfm_secure
tfm_secure:
  address: 0x14000
  orig_span: &id007
  - mcuboot_pad
  - tfm
  span: *id007
tfm_sram:
  address: 0x20000000
  inside:
  - sram_secure
  placement:
    after:
    - start
tfm_storage:
  address: 0xc000
  orig_span: &id008
  - tfm_ps
  - tfm_its
  span: *id008
I understand that i need to define custom partitions taht are properly aligned to the CONFIG_NRF_TRUSTZONE_FLASH_REGION_SIZE wich defaults to 0x1000 (as it is in the KCONFIG file in the board definition).
Can you please point out to me what is wrong and how i define this correctly?
Maybe you also have resources on how to define a static partitioning-table for your diffrent board-targets as we are currently also in development for a project using the nrf52-Series wich will encounter similar problems i suppose.
  • H.Marske said:
    i read the documentation-page for TF-M and in the limitations-chapter it states:
    "Firmware Update service is not supported"
    The reason is that we don't use or rely this service to support DFU. Instead we use the same implementation as we would without TF-M enabled.
    H.Marske said:
    it has a size as well as start and end address. can i omit one of them?
    Technically you can chose to omit either "end_address"  or "size". Start address must always be specified.
    I generally think it's best to let the build system generate the partitions file, and then adjust it as needed as this is usually less error prone.
