Flashing on PCB gives Unknown Error in J-Link DLL
Hey Team,
I'm trying to flash the audio application on our custom PCB, this PCB follows the interfaces of the nrf5340 audio dk. Previously on lower SDK versions (2.7-2.9), I was able to flash my programs without any errors. However now with the newer toolchain version (3.0.1), Im getting this error whenever i run the west flash command
Command:
`west flash -d /opt/nordic/ncs/v3.0.1/nrf/applications/nrf5340_audio/build --domain nrf5340_audio --dev-id 801055229 --recover`
Logs:
Flashing nrf5340_audio to 801055229
-- west flash: rebuilding
[0/10] Performing build step for 'ipc_radio'
ninja: no work to do.
[1/10] Performing build step for 'nrf5340_audio'
[4/10] cd /opt/nordic/ncs/v3.0.1/nrf/applications/nrf5340_audio/build/_sysbuild && /opt/nordic/ncs/toolchains/ef4fc6722e/Cellar/cmake/3.21.0/bin/cmake -E true
[6/9] No install step for 'nrf5340_audio'
[7/9] Completed 'nrf5340_audio'
[8/9] cd /opt/nordic/ncs/v3.0.1/nrf/applications/nrf5340_audio/build/_sysbuild && /opt/nordic/ncs/toolchains/ef4fc6722e/Cellar/cmake/3.21.0/bin/cmake -E true
-- west flash: using runner nrfutil
-- runners.nrfutil: reset after flashing requested
-- runners.nrfutil: Recovering and erasing flash memory for both the network and application cores.
-- runners.nrfutil: Flashing file: /opt/nordic/ncs/v3.0.1/nrf/applications/nrf5340_audio/build/merged.hex
-- runners.nrfutil: Erasing address ranges touched by firmware
Error: One or more batch tasks failed:
 * 801055229: Device error: Emulator error: Unknown Error in J-Link DLL (error code =-1) (Generic)
FATAL ERROR: command exited with status 1: nrfutil --json device x-execute-batch --batch-path /opt/nordic/ncs/v3.0.1/nrf/applications/nrf5340_audio/build/generated_nrfutil_batch.json --serial-number 801055229
Sometimes I also get this error randomly
 * 801055229: Device error: Failed to read from memory address 0x500038e4: Failed to write DebugPort register 0x08: Unknown Error in J-Link DLL (error code =-1) (Generic)
What should be the cause of this error and how do I fix it? Please let me know if you require any further information.
PS: Relevant information about the PCB like schematics and stuff are already shared in the private threads with this same account.
Soham
  • Hey Abhijith,
    The bluetooth error was resolved after I updated nrfutl, but the PCB flashing error still exists.
    This is the error I'm getting on flashing,
    ❯ nrfutil device program --firmware /Users/soham/ksham/pcb-tests/led-test/build/merged.hex
    [00:00:01] ------   0% [1/2 801055229] Failed, Device error: Failed to read from memory address 0x500038e4: Failed to write DebugPor
    Error: One or more program tasks failed:
    The same program can be flashed successfully with the previous toolchain versions which use nrfjprog (working with v2.8.0). So I believe there's some issue with nrfutil. Can you please check with the technical team once and let me know?
    Best,
    Soham
    Could you please rerun the nrfutil device command with the --log-level trace option:
    nrfutil device program --firmware /Users/soham/ksham/pcb-tests/led-test/build/merged.hex --log-level trace
    Then share the log file located at <USERHOME>/.nrfutil/logs/nrfutil-device.log?
    Since there are two different errors occurring, it would be helpful if you could try to reproduce both issues and generate logs for each. If you’re unable to reproduce both with the above command alone, please try adding the following option:
    --options chip_erase_mode=ERASE_RANGES_TOUCHED_BY_FIRMWARE
    Additionally, it would be useful if you could run:
    nrfjprog --program /Users/soham/ksham/pcb-tests/led-test/build/merged.hex --chiperase --log log.txt
    and share the log.txt file. There might be J-Link stability issues with your board that nrfjprog is handling silently, and we might be able to catch that in the log.
    One more clarification: In one of your earlier responses, you mentioned that the issue started occurring after upgrading the nrfutil device tool. Does that mean you were able to flash the firmware successfully before the upgrade?
    Abhijith
  • Hey,
    Here are the two scenarios explained in detail.
    Scenario 1: nRF5340 Audio DK (Fixed)
    I was unable to flash the firmware as some bt_hci libraries weren't being linked properly during compilation. This was fixed when a newer version of `nrfutil device` was released. Now it works perfectly fine.
    Scenario 2: Custom PCB (Not fixed yet)
    I'm able to program the custom PCB with the previous version of toolchain & SDK (v2.8.0) as they use `nrjprog` for programming. However with the newer versions, `nrfutil` doesn't seem to read some register, therefore failing to flash the same code.
    This is the code I'm trying to flash (its a normal blinky code) which successfully flashes using `nrfjprog` but throws an error with `nrfutil`
    #include <zephyr/kernel.h>
    LOG_MODULE_REGISTER(main, LOG_LEVEL_DBG);
    static const struct device *gpio = DEVICE_DT_GET(DT_NODELABEL(gpio0));
    	LOG_INF("led test starting...");
    	if (!device_is_ready(gpio)) {
    		return -ENODEV;
    	gpio_pin_configure(gpio, 7, GPIO_OUTPUT_ACTIVE);
    	while (1) {
    		gpio_pin_set(gpio, 7, 1);
    		k_sleep(K_SECONDS(1));
    		gpio_pin_set(gpio, 7, 0);
    	return 0;
    And this is the error log fetched from `.nrfutil/logs/nrfutil-device.log`
    [2025-06-26T06:57:54.812Z] [71138] INFO - Starting parent process watchdog, current parent process ID: 71137
    [2025-06-26T06:57:54.812Z] [71138] DEBUG - cargo = false, force_libnrfdl_lookup = false, force_nrfutil_libdir = false
    [2025-06-26T06:57:54.812Z] [71138] DEBUG - Creating the nrfdl context via nrfdl_create_context_with_config: Plugin location is assumed to be /Users/soham/.nrfutil/lib/nrfutil-device
    [2025-06-26T06:57:54.812Z] [71138] DEBUG - Loading plugins from directory /Users/soham/.nrfutil/lib/nrfutil-device
    [2025-06-26T06:57:54.823Z] [71138] TRACE - [boardController] C API function: supported_traits
    [2025-06-26T06:57:54.828Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:54.828136Z] Opened J-Link DLL at /Applications/SEGGER/JLink/libjlinkarm.dylib with version 8.32
    [2025-06-26T06:57:54.828Z] [71138] TRACE - [boardController] C API function: get_version_list
    [2025-06-26T06:57:54.828Z] [71138] DEBUG - [boardController] Operation get_version_list failed with error code NRFDL_ERR_NOT_SUPPORTED
    [2025-06-26T06:57:54.828Z] [71138] DEBUG - Plugin BOARDCONTROLLER does not support `get_version_list`
    [2025-06-26T06:57:54.828Z] [71138] DEBUG - Plugin sdfu does not support `get_version_list`
    [2025-06-26T06:57:54.828Z] [71138] DEBUG - Plugin mcuBoot does not support `get_version_list`
    [2025-06-26T06:57:54.828Z] [71138] DEBUG - operation to get devices for : Ok("{\"operations\":[{\"operation\":{\"type\":\"program\",\"firmware\":{\"file\":\"/Users/soham/ksham/pcb-tests/led-test/build/merged.hex\"}},\"core\":\"NRFDL_DEVICE_CORE_APPLICATION\"}]}")
    [2025-06-26T06:57:54.828Z] [71138] TRACE - Operations required by a device to do: {"program"}
    [2025-06-26T06:57:54.828Z] [71138] DEBUG - enumerate_devices
    [2025-06-26T06:57:54.828Z] [71138] DEBUG - Probing device 1000cb6db
    [2025-06-26T06:57:54.828Z] [71138] DEBUG - Device does not have property `kUSBVendorString`
    [2025-06-26T06:57:54.828Z] [71138] DEBUG - Device does not have property `USB Vendor Name`
    [2025-06-26T06:57:54.828Z] [71138] DEBUG - Device does not have property `kUSBSerialNumberString`
    [2025-06-26T06:57:54.828Z] [71138] DEBUG - Device does not have property `USB Serial Number`
    [2025-06-26T06:57:54.828Z] [71138] DEBUG - Device does not have property `bInterfaceNumber`
    [2025-06-26T06:57:54.828Z] [71138] DEBUG - Device does not have property `kUSBString`
    [2025-06-26T06:57:54.828Z] [71138] DEBUG - Device does not have property `USB Interface Name`
    [2025-06-26T06:57:54.828Z] [71138] DEBUG - Probing device 1000cb6f4
    [2025-06-26T06:57:54.828Z] [71138] DEBUG - Probing device 1000cb723
    [2025-06-26T06:57:54.828Z] [71138] DEBUG - [Apple] Apple serialport enumerate.
    [2025-06-26T06:57:54.828Z] [71138] DEBUG - [Apple] Class is: AppleSimpleUARTSync
    [2025-06-26T06:57:54.828Z] [71138] DEBUG - [Apple] Class is: AppleSamsungSerial
    [2025-06-26T06:57:54.828Z] [71138] DEBUG - [Apple] Class is: AppleARMIODevice
    [2025-06-26T06:57:54.829Z] [71138] DEBUG - [Apple] Class is: AppleH16GFamilyIO
    [2025-06-26T06:57:54.829Z] [71138] DEBUG - [Apple] Class is: IOPlatformDevice
    [2025-06-26T06:57:54.829Z] [71138] DEBUG - [Apple] Class is: AppleARMPE
    [2025-06-26T06:57:54.829Z] [71138] DEBUG - [Apple] Class is: IOPlatformExpertDevice
    [2025-06-26T06:57:54.829Z] [71138] DEBUG - [Apple] Class is: IORegistryEntry
    [2025-06-26T06:57:54.829Z] [71138] DEBUG - [Apple] Class is: IOUserSerial
    [2025-06-26T06:57:54.829Z] [71138] DEBUG - [Apple] Class is: IOUserService
    [2025-06-26T06:57:54.829Z] [71138] DEBUG - [Apple] Class is: IOBluetoothDevice
    [2025-06-26T06:57:54.829Z] [71138] DEBUG - [Apple] Class is: IOBluetoothHCIController
    [2025-06-26T06:57:54.829Z] [71138] DEBUG - [Apple] Class is: IOResources
    [2025-06-26T06:57:54.829Z] [71138] DEBUG - enumerate plugin: Probe
    [2025-06-26T06:57:54.829Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:54.829977Z] Opened J-Link DLL at /Applications/SEGGER/JLink/libjlinkarm.dylib with version 8.32
    [2025-06-26T06:57:54.830Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:54.830192Z] Found 1 attached J-Link devices
    [2025-06-26T06:57:54.830Z] [71138] DEBUG - enumerate plugin done in: 0ms
    [2025-06-26T06:57:54.830Z] [71138] DEBUG - enumerate plugin: BOARDCONTROLLER
    [2025-06-26T06:57:54.830Z] [71138] TRACE - [boardController] C API function: enumerate
    [2025-06-26T06:57:54.833Z] [71138] DEBUG - [boardController] Found 53 HID devices.
    [2025-06-26T06:57:54.833Z] [71138] DEBUG - enumerate plugin done in: 3ms
    [2025-06-26T06:57:54.833Z] [71138] DEBUG - enumerate plugin: sdfu
    [2025-06-26T06:57:54.833Z] [71138] DEBUG - enumerate plugin done in: 0ms
    [2025-06-26T06:57:54.833Z] [71138] DEBUG - enumerate plugin: mcuBoot
    [2025-06-26T06:57:54.833Z] [71138] TRACE - List of devices capable of performing the operations : [Device { id: DeviceId(3), serial_number: Some("000801055229"), traits: {"boardController": false, "devkit": false, "jlink": true, "mcuBoot": false, "nordicDfu": false, "broken": false, "nordicUsb": false, "usb": true, "modem": false, "seggerUsb": true, "serialPorts": false}, plugin_data: {"usb": Object {"device": Object {"address": Number(3), "busNumber": Number(0), "descriptor": Object {"bDescriptorType": Number(1), "bcdDevice": Number(256), "idProduct": Number(4128), "idVendor": Number(4966)}}, "manufacturer": String("SEGGER"), "osDevicePath": Null, "product": String("J-Link"), "serialNumber": String("000801055229")}, "probe": Object {}} }]
    [2025-06-26T06:57:54.833Z] [71138] DEBUG - No serial-number or traits provided. But only one relevant device is connected. Will perform operation with Device { id: DeviceId(3), serial_number: Some("000801055229"), traits: {"boardController": false, "devkit": false, "jlink": true, "mcuBoot": false, "nordicDfu": false, "broken": false, "nordicUsb": false, "usb": true, "modem": false, "seggerUsb": true, "serialPorts": false}, plugin_data: {"usb": Object {"device": Object {"address": Number(3), "busNumber": Number(0), "descriptor": Object {"bDescriptorType": Number(1), "bcdDevice": Number(256), "idProduct": Number(4128), "idVendor": Number(4966)}}, "manufacturer": String("SEGGER"), "osDevicePath": Null, "product": String("J-Link"), "serialNumber": String("000801055229")}, "probe": Object {}} }
    [2025-06-26T06:57:54.833Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.833939Z] Checking whether operations are supported
    [2025-06-26T06:57:54.834Z] [71138] INFO - starting event loop thread
    [2025-06-26T06:57:54.834Z] [71138] DEBUG - Probing device 1000cb6db
    [2025-06-26T06:57:54.834Z] [71138] DEBUG - Device does not have property `kUSBVendorString`
    [2025-06-26T06:57:54.834Z] [71138] DEBUG - Device does not have property `USB Vendor Name`
    [2025-06-26T06:57:54.834Z] [71138] DEBUG - Device does not have property `kUSBSerialNumberString`
    [2025-06-26T06:57:54.834Z] [71138] DEBUG - Device does not have property `USB Serial Number`
    [2025-06-26T06:57:54.834Z] [71138] DEBUG - Device does not have property `bInterfaceNumber`
    [2025-06-26T06:57:54.834Z] [71138] DEBUG - Device does not have property `kUSBString`
    [2025-06-26T06:57:54.834Z] [71138] DEBUG - Device does not have property `USB Interface Name`
    [2025-06-26T06:57:54.834Z] [71138] DEBUG - Probing device 1000cb6f4
    [2025-06-26T06:57:54.834Z] [71138] DEBUG - Probing device 1000cb723
    [2025-06-26T06:57:54.834Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.834599Z] Executing operation: {"operations":[{"operation":{"type":"program","firmware":{"file":"/Users/soham/ksham/pcb-tests/led-test/build/merged.hex"}},"core":"NRFDL_DEVICE_CORE_APPLICATION"}]}
    [2025-06-26T06:57:54.834Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.834676Z] Looking for file in /Users/soham/.nrfutil/lib/nrfutil-device/plugin-probe-worker
    [2025-06-26T06:57:54.834Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.834698Z] Found file at /Users/soham/.nrfutil/lib/nrfutil-device/plugin-probe-worker
    [2025-06-26T06:57:54.834Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.834916Z] Created IPC server org.rust-lang.ipc-channel.-1052576113544301046
    [2025-06-26T06:57:54.835Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.835223Z] Spawned worker process with id 71139
    [2025-06-26T06:57:54.835Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.835239Z] Accepting IPC connection
    [2025-06-26T06:57:54.838Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.838752Z] Accepted IPC connection
    [2025-06-26T06:57:54.838Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.838763Z] The worker supervisor's role is finished
    [2025-06-26T06:57:54.847Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.847772Z] Received signal from master, returning alive worker.
    [2025-06-26T06:57:54.847Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:54.847822Z] Handshake signatures match
    [2025-06-26T06:57:54.847Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:54.847855Z] Connection with Probe worker established.
    [2025-06-26T06:57:54.847Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.847867Z] Starting trace thread
    [2025-06-26T06:57:54.847Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:54.838631Z] {jlink_usb_000801055229} nrf-probe version 0.40.1
    [2025-06-26T06:57:54.847Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.838662Z] {jlink_usb_000801055229} Sending IPC handshake response from worker...
    [2025-06-26T06:57:54.847Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.838708Z] {jlink_usb_000801055229} Started worker message processing loop
    [2025-06-26T06:57:54.847Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.847905Z] {jlink_usb_000801055229} Probe worker received initial message: Initialize(InitializeRequest { configuration: Configuration { jlink: JLinkConfig { dll_location: None }, target: DeviceConfig { swd_clock_frequency: None, adac_timeout: None, firmware_config: None, swd_mode: PointToPoint, target_family: None, override_detection: None, override_sdfw_variant: None } } })
    [2025-06-26T06:57:54.851Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.851401Z] {jlink_usb_000801055229} Setting up JLink interface.
    [2025-06-26T06:57:54.851Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.851424Z] {jlink_usb_000801055229} -> connect
    [2025-06-26T06:57:54.851Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.851630Z] {jlink_usb_000801055229} Applied firmware settings to JLink
    [2025-06-26T06:57:54.869Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.869232Z] {jlink_usb_000801055229} Max frequency: 4000 kHz
    [2025-06-26T06:57:54.869Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:54.869319Z] {jlink_usb_000801055229} Clock frequency was set to 2000 kHz
    [2025-06-26T06:57:54.869Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:54.869325Z] {jlink_usb_000801055229} Emulator Usb(JLinkSerialNumber(801055229)) running firmware: J-Link EDU Mini V1 compiled Apr  1 2025 10:05:11
    [2025-06-26T06:57:54.869Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.869328Z] {jlink_usb_000801055229} <- connect
    [2025-06-26T06:57:54.869Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.869382Z] {jlink_usb_000801055229} Probe worker received message: Request(DeviceIdentification)
    [2025-06-26T06:57:54.869Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.869550Z] {jlink_usb_000801055229} JLINKARM_HW_STATUS: JLINKARM_HW_STATUS { VTarget: 1884, tck: 0, tdi: 1, tdo: 1, tms: 1, tres: 1, trst: 255 }
    [2025-06-26T06:57:54.870Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:54.870465Z] {jlink_usb_000801055229} -> Powering up sys and debug region
    [2025-06-26T06:57:54.870Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.870491Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.870Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.870740Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.870Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.870742Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.870Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.870744Z] {jlink_usb_000801055229} -> read_dp
    [2025-06-26T06:57:54.870Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.870968Z] {jlink_usb_000801055229} DP read 0xf0000040 from CTRL/STAT
    [2025-06-26T06:57:54.870Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.870970Z] {jlink_usb_000801055229} <- read_dp
    [2025-06-26T06:57:54.870Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.870972Z] {jlink_usb_000801055229} Powered up sys and dbg regions in 0 ms
    [2025-06-26T06:57:54.870Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:54.870974Z] {jlink_usb_000801055229} <- Powering up sys and debug region
    [2025-06-26T06:57:54.871Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:54.871410Z] {jlink_usb_000801055229} -> detect device family
    [2025-06-26T06:57:54.871Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.871416Z] {jlink_usb_000801055229} -> read_dp
    [2025-06-26T06:57:54.871Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.871623Z] {jlink_usb_000801055229} DP read 0x6ba02477 from DPIDR
    [2025-06-26T06:57:54.871Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.871625Z] {jlink_usb_000801055229} <- read_dp
    [2025-06-26T06:57:54.871Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.871631Z] {jlink_usb_000801055229} DPIDR: Register { content: 1805657207, revision: 6, part_no: 186, res0: 0, min: 0, version: 2, designer: 571 }
    [2025-06-26T06:57:54.871Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.871633Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.871Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.871634Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.871Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.871838Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.871Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.871840Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.872Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.872068Z] {jlink_usb_000801055229} AP 0 read 0x43800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.872Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.872071Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.872Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.872072Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.872Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.872073Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.872Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.872268Z] {jlink_usb_000801055229} DP wrote 0x000000f0 to SELECT = 0x08
    [2025-06-26T06:57:54.872Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.872271Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.872Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.872502Z] {jlink_usb_000801055229} AP 0 read 0x84770001 from IDR
    [2025-06-26T06:57:54.872Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.872504Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.872Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.872509Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.872Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.872510Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.872Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.872722Z] {jlink_usb_000801055229} DP wrote 0x01000000 to SELECT = 0x08
    [2025-06-26T06:57:54.872Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.872724Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.872Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.872983Z] {jlink_usb_000801055229} AP 1 read 0x43800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.872Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.872985Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.873Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.872987Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.873Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.872988Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.873Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.873237Z] {jlink_usb_000801055229} DP wrote 0x010000f0 to SELECT = 0x08
    [2025-06-26T06:57:54.873Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.873239Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.873Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.873486Z] {jlink_usb_000801055229} AP 1 read 0x84770001 from IDR
    [2025-06-26T06:57:54.873Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.873489Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.873Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.873490Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.873Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.873491Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.873Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.873689Z] {jlink_usb_000801055229} DP wrote 0x02000000 to SELECT = 0x08
    [2025-06-26T06:57:54.873Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.873691Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.873Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.873926Z] {jlink_usb_000801055229} AP 2 read 0x00000000 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.873Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.873928Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.873Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.873929Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.873Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.873930Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.874Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.874121Z] {jlink_usb_000801055229} DP wrote 0x020000f0 to SELECT = 0x08
    [2025-06-26T06:57:54.874Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.874123Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.874Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.874381Z] {jlink_usb_000801055229} AP 2 read 0x12880000 from IDR
    [2025-06-26T06:57:54.874Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.874383Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.874Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.874385Z] {jlink_usb_000801055229} Detected CTRL-AP revision 1 at AP 2
    [2025-06-26T06:57:54.874Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.874386Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.874Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.874387Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.874Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.874586Z] {jlink_usb_000801055229} DP wrote 0x02000030 to SELECT = 0x08
    [2025-06-26T06:57:54.874Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.874588Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.874Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.874812Z] {jlink_usb_000801055229} AP 2 read 0x00000007 from Unknown AP address 0x30
    [2025-06-26T06:57:54.874Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.874814Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.874Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.874815Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.874Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.874816Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.875Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.875012Z] {jlink_usb_000801055229} DP wrote 0x02000030 to SELECT = 0x08
    [2025-06-26T06:57:54.875Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.875014Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.875Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.875239Z] {jlink_usb_000801055229} AP 2 read 0x00000002 from Unknown AP address 0x34
    [2025-06-26T06:57:54.875Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.875241Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.875Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.875243Z] {jlink_usb_000801055229} Device detection: partno 0x00000007 hwrevision 0x00000002
    [2025-06-26T06:57:54.875Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:54.875244Z] {jlink_usb_000801055229} <- detect device family
    [2025-06-26T06:57:54.875Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.875290Z] Got regular response.
    [2025-06-26T06:57:54.875Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.875731Z] Failed to get development board information, skipping default external flash configuration
    [2025-06-26T06:57:54.875Z] [71138] TRACE - progress:{"operation":"","name":"program","step":1,"amountOfSteps":2,"description":"","progressPercentage":0,"duration":null,"result":null,"state":"begin"}
    [2025-06-26T06:57:54.875Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:54.875759Z] Programming /Users/soham/ksham/pcb-tests/led-test/build/merged.hex
    [2025-06-26T06:57:54.876Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.876485Z] {jlink_usb_000801055229} Probe worker received message: Request(Program { core_id: Application, data: ObjectData::Segments([MemorySegment { address: Address(0x00000000), size: 31132, data (truncated): [40, 62, 0, 32, 249, 30, 0, 0, 29, 107, 0, 0, 229, 30, 0, 0, 229, 30, 0, 0, 229, 30, 0, 0, 229, 30, 0, 0, 229, 30, 0, 0], .. }, MemorySegment { address: Address(0x000079a0), size: 3064, data (truncated): [3, 56, 253, 216, 112, 71, 0, 0, 40, 19, 0, 32, 0, 4, 0, 0, 45, 105, 0, 0, 215, 104, 0, 0, 2, 0, 0, 0, 169, 106, 0, 0], .. }, MemorySegment { address: Address(0x000085a0), size: 330, data (truncated): [67, 98, 0, 0, 247, 104, 0, 0, 92, 18, 0, 32, 58, 0, 0, 0, 112, 18, 0, 32, 58, 0, 0, 0, 72, 18, 0, 32, 58, 0, 0, 0], .. }, MemorySegment { address: Address(0x000086ec), size: 160, data (truncated): [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], .. }]), options: ProgramOptions { erase_option: EraseOptions { chip_erase_mode: All, ext_mem_erase_mode: None }, reset: None, verify: None } })
    [2025-06-26T06:57:54.876Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:54.876493Z] {jlink_usb_000801055229} -> Powering down debug region
    [2025-06-26T06:57:54.876Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.876495Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.876Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.876725Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.876Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.876728Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.876Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.876730Z] {jlink_usb_000801055229} -> read_dp
    [2025-06-26T06:57:54.876Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.876968Z] {jlink_usb_000801055229} DP read 0xf0000040 from CTRL/STAT
    [2025-06-26T06:57:54.876Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.876971Z] {jlink_usb_000801055229} <- read_dp
    [2025-06-26T06:57:54.876Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.876973Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.877Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.877249Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.877Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.877251Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.877Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.877253Z] {jlink_usb_000801055229} -> read_dp
    [2025-06-26T06:57:54.877Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.877478Z] {jlink_usb_000801055229} DP read 0xf0000040 from CTRL/STAT
    [2025-06-26T06:57:54.877Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.877481Z] {jlink_usb_000801055229} <- read_dp
    [2025-06-26T06:57:54.877Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.877482Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.877Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.877701Z] {jlink_usb_000801055229} DP wrote 0x00000000 to CTRL/STAT = 0x04
    [2025-06-26T06:57:54.877Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.877703Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.880Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.880226Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.880Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.880495Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.880Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.880497Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.880Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.880499Z] {jlink_usb_000801055229} -> read_dp
    [2025-06-26T06:57:54.880Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.880723Z] {jlink_usb_000801055229} DP read 0x00000040 from CTRL/STAT
    [2025-06-26T06:57:54.880Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.880725Z] {jlink_usb_000801055229} <- read_dp
    [2025-06-26T06:57:54.880Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.880727Z] {jlink_usb_000801055229} Powered down sys and dbg regions in 3 ms
    [2025-06-26T06:57:54.880Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:54.880728Z] {jlink_usb_000801055229} <- Powering down debug region
    [2025-06-26T06:57:54.880Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.880931Z] {jlink_usb_000801055229} JLINKARM_HW_STATUS: JLINKARM_HW_STATUS { VTarget: 1882, tck: 0, tdi: 1, tdo: 1, tms: 1, tres: 1, trst: 255 }
    [2025-06-26T06:57:54.881Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:54.881720Z] {jlink_usb_000801055229} -> Powering up sys and debug region
    [2025-06-26T06:57:54.881Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.881726Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.881Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.881962Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.881Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.881964Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.881Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.881966Z] {jlink_usb_000801055229} -> read_dp
    [2025-06-26T06:57:54.882Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.882248Z] {jlink_usb_000801055229} DP read 0xf0000040 from CTRL/STAT
    [2025-06-26T06:57:54.882Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.882250Z] {jlink_usb_000801055229} <- read_dp
    [2025-06-26T06:57:54.882Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.882252Z] {jlink_usb_000801055229} Powered up sys and dbg regions in 0 ms
    [2025-06-26T06:57:54.882Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:54.882253Z] {jlink_usb_000801055229} <- Powering up sys and debug region
    [2025-06-26T06:57:54.882Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:54.882375Z] {jlink_usb_000801055229} -> Create core
    [2025-06-26T06:57:54.882Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.882733Z] {jlink_usb_000801055229} -> Get Protection Status
    [2025-06-26T06:57:54.882Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.882736Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.882Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.882737Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.883Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.882995Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.883Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.882998Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.883Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.883249Z] {jlink_usb_000801055229} AP 0 read 0x43800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.883Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.883251Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.883Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.883253Z] {jlink_usb_000801055229} Checking protection on AP 0: CSW=0x43800042
    [2025-06-26T06:57:54.883Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.883255Z] {jlink_usb_000801055229} Access port protection is 'None'
    [2025-06-26T06:57:54.883Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.883256Z] {jlink_usb_000801055229} <- Get Protection Status
    [2025-06-26T06:57:54.883Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.883258Z] {jlink_usb_000801055229} Core Application: Using AHB-AP 0
    [2025-06-26T06:57:54.883Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.883265Z] {jlink_usb_000801055229} Memory ficr @ 0x00ff0000 needs programmer peripheral NVMC
    [2025-06-26T06:57:54.883Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.883272Z] {jlink_usb_000801055229} Memory ram @ 0x20000000 needs programmer peripheral RAM
    [2025-06-26T06:57:54.883Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.883275Z] {jlink_usb_000801055229} Memory uicr @ 0x00ff8000 needs programmer peripheral NVMC
    [2025-06-26T06:57:54.883Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.883276Z] {jlink_usb_000801055229} External memory xip is not programmed because no firmware configuration is available
    [2025-06-26T06:57:54.883Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.883279Z] {jlink_usb_000801055229} Memory flash @ 0x00000000 needs programmer peripheral NVMC
    [2025-06-26T06:57:54.883Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.883282Z] {jlink_usb_000801055229} Set Index of AHB-AP to use to 0
    [2025-06-26T06:57:54.890Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.890105Z] {jlink_usb_000801055229} J-Link: Device "CORTEX-M33" selected.
    [2025-06-26T06:57:54.890Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.890492Z] {jlink_usb_000801055229} Device name set in JLINK to Cortex-M33
    [2025-06-26T06:57:54.891Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.891547Z] {jlink_usb_000801055229} J-Link: Found SW-DP with ID 0x6BA02477
    [2025-06-26T06:57:54.893Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.893531Z] {jlink_usb_000801055229} J-Link: DPIDR: 0x6BA02477
    [2025-06-26T06:57:54.893Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.893535Z] {jlink_usb_000801055229} J-Link: CoreSight SoC-400 or earlier
    [2025-06-26T06:57:54.893Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.893537Z] {jlink_usb_000801055229} J-Link: AP map detection skipped. Manually configured AP map found.
    [2025-06-26T06:57:54.893Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.893539Z] {jlink_usb_000801055229} J-Link: AP[0]: AHB-AP (IDR: Not set, ADDR: 0x00000000)
    [2025-06-26T06:57:54.894Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.894403Z] {jlink_usb_000801055229} J-Link: AP[0]: Core found
    [2025-06-26T06:57:54.894Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.894406Z] {jlink_usb_000801055229} J-Link: AP[0]: AHB-AP ROM base: 0xE00FF000
    [2025-06-26T06:57:54.894Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.894885Z] {jlink_usb_000801055229} J-Link: CPUID register: 0x410FD214. Implementer code: 0x41 (ARM)
    [2025-06-26T06:57:54.894Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.894888Z] {jlink_usb_000801055229} J-Link: Feature set: Mainline
    [2025-06-26T06:57:54.895Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.895357Z] {jlink_usb_000801055229} J-Link: Cache: No cache
    [2025-06-26T06:57:54.895Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.895363Z] {jlink_usb_000801055229} J-Link: Found Cortex-M33 r0p4, Little endian.
    [2025-06-26T06:57:54.897Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.897256Z] {jlink_usb_000801055229} J-Link: FPUnit: 8 code (BP) slots and 0 literal slots
    [2025-06-26T06:57:54.902Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.902111Z] {jlink_usb_000801055229} J-Link: Security extension: implemented
    [2025-06-26T06:57:54.902Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.902114Z] {jlink_usb_000801055229} J-Link: Secure debug: enabled
    [2025-06-26T06:57:54.902Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.902116Z] {jlink_usb_000801055229} J-Link: CoreSight components:
    [2025-06-26T06:57:54.902Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.902117Z] {jlink_usb_000801055229} J-Link: ROMTbl[0] @ E00FF000
    [2025-06-26T06:57:54.904Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.904379Z] {jlink_usb_000801055229} J-Link: [0][0]: E000E000 CID B105900D PID 000BBD21 DEVARCH 47702A04 DEVTYPE 00 Cortex-M33
    [2025-06-26T06:57:54.905Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.905766Z] {jlink_usb_000801055229} J-Link: [0][1]: E0001000 CID B105900D PID 000BBD21 DEVARCH 47701A02 DEVTYPE 00 DWT
    [2025-06-26T06:57:54.907Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.907127Z] {jlink_usb_000801055229} J-Link: [0][2]: E0002000 CID B105900D PID 000BBD21 DEVARCH 47701A03 DEVTYPE 00 FPB
    [2025-06-26T06:57:54.908Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.908493Z] {jlink_usb_000801055229} J-Link: [0][3]: E0000000 CID B105900D PID 000BBD21 DEVARCH 47701A01 DEVTYPE 43 ITM
    [2025-06-26T06:57:54.909Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.909848Z] {jlink_usb_000801055229} J-Link: [0][5]: E0041000 CID B105900D PID 002BBD21 DEVARCH 47724A13 DEVTYPE 13 ETM
    [2025-06-26T06:57:54.911Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.911158Z] {jlink_usb_000801055229} J-Link: [0][6]: E0042000 CID B105900D PID 000BBD21 DEVARCH 47701A14 DEVTYPE 14 CSS600-CTI
    [2025-06-26T06:57:54.911Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:54.911170Z] {jlink_usb_000801055229} <- Create core
    [2025-06-26T06:57:54.911Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:54.911192Z] {jlink_usb_000801055229} Erasing internal flash
    [2025-06-26T06:57:54.911Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.911211Z] Got progress from worker.
    [2025-06-26T06:57:54.911Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.911203Z] {jlink_usb_000801055229} -> Get Protection Status
    [2025-06-26T06:57:54.911Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.911220Z] Call callback with progress
    [2025-06-26T06:57:54.911Z] [71138] TRACE - progress:{"operation":"program","name":"program","step":1,"amountOfSteps":2,"description":"Erasing non-volatile memory (ERASEALL)","progressPercentage":0,"message":"Erasing non-volatile memory (ERASEALL)","duration":35,"result":"success","state":"progress"}
    [2025-06-26T06:57:54.911Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.911205Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.911Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.911206Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.911Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.911481Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.911Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.911484Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.911Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.911746Z] {jlink_usb_000801055229} AP 0 read 0x03800052 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.911Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.911748Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.911Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.911750Z] {jlink_usb_000801055229} Checking protection on AP 0: CSW=0x03800052
    [2025-06-26T06:57:54.911Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.911752Z] {jlink_usb_000801055229} Access port protection is 'None'
    [2025-06-26T06:57:54.911Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.911753Z] {jlink_usb_000801055229} <- Get Protection Status
    [2025-06-26T06:57:54.911Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.911756Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.911Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.911757Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.911Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.911987Z] {jlink_usb_000801055229} DP wrote 0x02000010 to SELECT = 0x08
    [2025-06-26T06:57:54.912Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.911989Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.912Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.912245Z] {jlink_usb_000801055229} AP 2 read 0x00000001 from ERASEPROTECT_STATUS(ctrl-ap)
    [2025-06-26T06:57:54.912Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.912247Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.912Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.912249Z] {jlink_usb_000801055229} erase_protect enabled: false
    [2025-06-26T06:57:54.912Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.912251Z] {jlink_usb_000801055229} Checking if core is halted through probe API
    [2025-06-26T06:57:54.917Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.917744Z] {jlink_usb_000801055229} Device family nRF53 does not have bprot
    [2025-06-26T06:57:54.917Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.917750Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.917Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.917751Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.918Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.918003Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.918Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.918006Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.918Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.918243Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.918Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.918246Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.918Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.918363Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.918Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.918365Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.918Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.918366Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.918Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.918565Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.918Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.918568Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.918Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.918798Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.918Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.918801Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.918Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.918803Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.918Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.918805Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.919Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.919002Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.919Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.919005Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.919Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.919247Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.919Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.919254Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.919Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.919256Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.919Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.919257Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.919Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.919580Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.919Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.919583Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.919Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.919807Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x50003600 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.919Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.919810Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.919Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.919812Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.919Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.919813Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.920Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.920027Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.920Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.920030Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.920Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.920262Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.920Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.920265Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.920Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.920267Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.920Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.920268Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.920Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.920270Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.920Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.920493Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.920Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.920495Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.920Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.920740Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.920Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.920742Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.920Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.920743Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.920Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.920745Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.920Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.920955Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.920Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.920957Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.921Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.921160Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.921Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.921162Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.921Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.921163Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.921Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.921164Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.921Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.921382Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.921Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.921384Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.921Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.921606Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x50003604 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.921Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.921612Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.921Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.921631Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.921Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.921633Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.921Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.921873Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.921Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.921876Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.922Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.922137Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.922Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.922139Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.922Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.922141Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.922Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.922143Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.922Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.922144Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.922Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.922382Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.922Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.922385Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.922Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.922647Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.922Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.922649Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.922Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.922650Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.922Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.922651Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.922Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.922881Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.922Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.922883Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.923Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.923119Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.923Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.923122Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.923Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.923123Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.923Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.923125Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.923Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.923382Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.923Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.923385Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.923Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.923605Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x50003608 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.923Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.923609Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.923Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.923610Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.923Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.923611Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.923Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.923846Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.923Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.923848Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.924Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.924118Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.924Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.924120Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.924Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.924121Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.924Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.924123Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.924Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.924123Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.924Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.924373Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.924Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.924375Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.924Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.924636Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.924Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.924638Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.924Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.924639Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.924Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.924640Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.924Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.924866Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.924Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.924869Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.925Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.925076Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.925Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.925078Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.925Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.925079Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.925Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.925080Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.925Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.925374Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.925Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.925376Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.925Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.925611Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x5000360c to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.925Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.925614Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.925Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.925615Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.925Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.925616Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.925Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.925852Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.925Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.925854Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.926Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.926104Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.926Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.926106Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.926Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.926107Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.926Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.926108Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.926Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.926109Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.926Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.926367Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.926Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.926369Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.926Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.926628Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.926Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.926630Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.926Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.926632Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.926Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.926633Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.926Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.926842Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.926Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.926844Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.927Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.927056Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.927Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.927058Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.927Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.927059Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.927Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.927060Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.927Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.927265Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.927Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.927266Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.927Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.927464Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x50003610 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.927Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.927466Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.927Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.927467Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.927Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.927468Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.927Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.927682Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.927Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.927684Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.927Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.927919Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.927Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.927921Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.927Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.927922Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.927Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.927923Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.927Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.927924Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.928Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.928126Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.928Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.928128Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.928Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.928388Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.928Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.928389Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.928Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.928390Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.928Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.928391Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.928Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.928603Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.928Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.928604Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.928Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.928808Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.928Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.928812Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.928Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.928813Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.928Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.928814Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.929Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.929022Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.929Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.929024Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.929Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.929231Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x50003614 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.929Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.929234Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.929Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.929235Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.929Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.929236Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.929Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.929443Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.929Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.929446Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.929Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.929682Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.929Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.929684Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.929Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.929686Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.929Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.929687Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.929Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.929688Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.929Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.929885Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.929Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.929887Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.930Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.930112Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.930Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.930114Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.930Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.930115Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.930Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.930116Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.930Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.930351Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.930Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.930353Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.930Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.930544Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.930Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.930546Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.930Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.930548Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.930Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.930548Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.930Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.930744Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.930Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.930746Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.930Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.930937Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x50003618 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.930Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.930939Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.930Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.930940Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.930Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.930941Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.931Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.931145Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.931Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.931146Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.931Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.931377Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.931Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.931379Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.931Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.931380Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.931Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.931381Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.931Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.931382Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.931Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.931589Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.931Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.931591Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.931Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.931843Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.931Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.931846Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.931Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.931847Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.931Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.931848Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.932Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.932047Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.932Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.932049Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.932Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.932248Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.932Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.932249Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.932Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.932250Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.932Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.932251Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.932Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.932516Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.932Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.932517Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.932Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.932734Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x5000361c to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.932Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.932736Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.932Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.932737Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.932Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.932738Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.932Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.932968Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.932Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.932970Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.933Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.933235Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.933Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.933237Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.933Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.933238Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.933Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.933239Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.933Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.933240Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.933Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.933453Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.933Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.933457Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.933Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.933692Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.933Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.933694Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.933Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.933695Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.933Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.933696Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.933Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.933907Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.933Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.933909Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.934Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.934116Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.934Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.934118Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.934Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.934119Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.934Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.934120Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.934Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.934368Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.934Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.934370Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.934Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.934571Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x50003620 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.934Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.934573Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.934Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.934574Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.934Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.934575Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.934Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.934788Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.934Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.934790Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.935Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.935030Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.935Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.935031Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.935Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.935033Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.935Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.935034Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.935Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.935035Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.935Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.935233Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.935Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.935235Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.935Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.935488Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.935Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.935491Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.935Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.935492Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.935Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.935493Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.935Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.935711Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.935Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.935713Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.935Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.935919Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.935Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.935922Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.935Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.935923Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.935Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.935924Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.936Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.936144Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.936Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.936145Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.936Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.936367Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x50003624 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.936Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.936370Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.936Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.936371Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.936Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.936372Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.936Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.936600Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.936Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.936602Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.936Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.936837Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.936Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.936839Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.936Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.936840Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.936Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.936842Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.936Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.936843Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.937Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.937040Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.937Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.937042Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.937Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.937267Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.937Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.937269Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.937Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.937270Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.937Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.937271Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.937Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.937471Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.937Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.937473Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.937Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.937673Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.937Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.937676Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.937Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.937677Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.937Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.937678Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.937Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.937875Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.937Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.937877Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.938Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.938079Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x50003628 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.938Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.938081Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.938Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.938083Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.938Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.938083Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.938Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.938350Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.938Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.938352Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.938Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.938588Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.938Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.938591Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.938Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.938592Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.938Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.938593Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.938Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.938594Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.938Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.938795Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.938Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.938796Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.939Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.939029Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.939Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.939031Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.939Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.939032Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.939Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.939033Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.939Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.939231Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.939Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.939232Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.939Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.939442Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.939Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.939444Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.939Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.939445Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.939Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.939446Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.939Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.939662Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.939Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.939664Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.939Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.939861Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x5000362c to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.939Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.939864Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.939Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.939865Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.939Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.939866Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.940Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.940088Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.940Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.940090Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.940Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.940391Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.940Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.940392Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.940Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.940394Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.940Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.940395Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.940Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.940396Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.940Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.940612Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.940Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.940614Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.940Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.940864Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.940Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.940866Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.940Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.940867Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.940Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.940868Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.941Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.941076Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.941Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.941078Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.941Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.941364Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.941Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.941366Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.941Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.941367Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.941Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.941368Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.941Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.941593Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.941Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.941595Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.941Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.941791Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x50003630 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.941Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.941793Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.941Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.941794Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.941Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.941795Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.942Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.942143Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.942Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.942145Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.942Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.942378Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.942Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.942380Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.942Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.942381Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.942Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.942382Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.942Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.942383Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.942Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.942608Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.942Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.942610Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.942Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.942854Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.942Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.942855Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.942Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.942856Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.942Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.942857Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.943Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.943067Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.943Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.943068Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.943Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.943281Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.943Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.943283Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.943Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.943284Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.943Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.943285Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.943Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.943498Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.943Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.943500Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.943Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.943707Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x50003634 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.943Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.943708Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.943Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.943709Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.943Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.943710Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.943Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.943919Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.943Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.943920Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.944Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.944153Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.944Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.944154Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.944Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.944155Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.944Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.944157Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.944Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.944158Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.944Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.944350Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.944Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.944351Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.944Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.944608Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.944Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.944610Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.944Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.944611Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.944Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.944612Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.944Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.944812Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.944Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.944814Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.945Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.945007Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.945Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.945009Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.945Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.945010Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.945Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.945011Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.945Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.945220Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.945Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.945222Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.945Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.945413Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x50003638 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.945Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.945415Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.945Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.945416Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.945Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.945417Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.945Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.945627Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.945Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.945630Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.945Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.945853Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.945Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.945855Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.945Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.945857Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.945Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.945857Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.945Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.945858Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.946Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.946048Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.946Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.946050Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.946Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.946271Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.946Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.946273Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.946Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.946274Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.946Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.946275Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.946Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.946469Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.946Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.946471Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.946Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.946658Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.946Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.946660Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.946Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.946661Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.946Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.946662Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.946Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.946856Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.946Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.946858Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.947Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.947047Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x5000363c to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.947Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.947049Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.947Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.947050Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.947Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.947051Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.947Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.947244Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.947Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.947246Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.947Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.947472Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.947Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.947474Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.947Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.947476Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.947Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.947477Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.947Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.947478Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.947Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.947664Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.947Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.947666Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.947Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.947889Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.947Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.947891Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.947Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.947892Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.947Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.947892Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.948Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.948096Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.948Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.948098Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.948Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.948360Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.948Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.948362Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.948Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.948363Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.948Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.948364Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.948Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.948580Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.948Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.948582Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.948Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.948787Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x50003640 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.948Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.948789Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.948Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.948790Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.948Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.948791Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.949Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.949004Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.949Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.949006Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.949Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.949242Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.949Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.949244Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.949Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.949245Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.949Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.949246Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.949Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.949247Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.949Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.949442Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.949Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.949445Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.949Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.949673Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.949Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.949674Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.949Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.949675Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.949Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.949676Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.949Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.949873Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.949Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.949875Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.950Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.950077Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.950Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.950078Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.950Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.950079Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.950Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.950080Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.950Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.950359Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.950Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.950361Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.950Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.950567Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x50003644 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.950Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.950569Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.950Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.950570Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.950Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.950571Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.950Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.950773Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.950Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.950775Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.951Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.951014Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.951Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.951015Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.951Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.951016Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.951Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.951017Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.951Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.951018Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.951Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.951241Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.951Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.951243Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.951Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.951478Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.951Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.951479Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.951Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.951480Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.951Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.951481Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.951Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.951675Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.951Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.951678Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.951Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.951867Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.951Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.951869Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.951Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.951870Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.951Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.951871Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.952Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.952091Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.952Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.952093Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.952Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.952364Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x50003648 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.952Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.952366Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.952Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.952367Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.952Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.952368Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.952Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.952593Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.952Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.952595Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.952Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.952829Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.952Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.952831Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.952Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.952832Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.952Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.952834Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.952Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.952834Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.953Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.953041Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.953Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.953043Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.953Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.953276Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.953Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.953278Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.953Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.953279Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.953Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.953279Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.953Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.953490Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.953Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.953492Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.953Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.953680Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.953Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.953682Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.953Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.953683Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.953Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.953684Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.953Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.953926Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.953Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.953928Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.954Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.954123Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x5000364c to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.954Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.954125Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.954Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.954126Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.954Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.954127Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.954Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.954349Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.954Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.954350Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.954Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.954594Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.954Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.954595Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.954Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.954596Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.954Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.954597Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.954Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.954598Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.954Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.954784Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.954Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.954786Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.955Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.955000Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.955Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.955002Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.955Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.955003Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.955Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.955004Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.955Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.955219Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.955Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.955221Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.955Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.955412Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.955Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.955414Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.955Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.955415Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.955Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.955416Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.955Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.955619Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.955Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.955620Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.955Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.955811Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x50003650 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.955Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.955813Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.955Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.955814Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.955Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.955814Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.956Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.956007Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.956Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.956009Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.956Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.956249Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.956Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.956251Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.956Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.956252Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.956Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.956253Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.956Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.956254Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.956Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.956474Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.956Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.956475Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.956Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.956710Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.956Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.956712Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.956Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.956713Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.956Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.956714Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.956Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.956906Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.956Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.956908Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.957Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.957109Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.957Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.957111Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.957Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.957112Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.957Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.957113Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.957Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.957349Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.957Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.957351Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.957Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.957544Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x50003654 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.957Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.957546Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.957Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.957547Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.957Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.957548Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.957Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.957744Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.957Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.957746Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.957Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.957973Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.957Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.957975Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.957Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.957976Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.957Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.957977Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.957Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.957978Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.958Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.958222Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.958Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.958224Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.958Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.958464Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.958Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.958466Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.958Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.958467Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.958Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.958468Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.958Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.958656Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.958Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.958658Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.958Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.958854Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.958Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.958857Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.958Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.958858Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.958Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.958859Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.959Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.959065Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.959Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.959067Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.959Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.959247Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x50003658 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.959Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.959249Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.959Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.959250Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.959Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.959251Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.959Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.959473Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.959Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.959475Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.959Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.959707Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.959Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.959708Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.959Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.959710Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.959Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.959711Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.959Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.959711Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.959Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.959896Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.959Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.959898Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.960Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.960120Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.960Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.960121Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.960Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.960122Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.960Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.960123Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.960Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.960347Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.960Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.960349Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.960Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.960540Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.960Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.960542Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.960Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.960543Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.960Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.960544Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.960Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.960732Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.960Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.960733Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.960Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.960916Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x5000365c to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.960Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.960918Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.960Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.960919Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.960Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.960919Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.961Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.961111Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.961Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.961112Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.961Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.961369Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.961Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.961370Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.961Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.961372Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.961Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.961373Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.961Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.961373Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.961Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.961577Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.961Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.961578Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.961Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.961796Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.961Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.961798Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.961Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.961799Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.961Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.961800Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.961Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.961982Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.961Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.961985Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.962Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.962217Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.962Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.962219Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.962Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.962221Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.962Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.962222Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.962Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.962441Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.962Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.962444Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.962Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.962630Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x50003660 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.962Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.962633Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.962Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.962634Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.962Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.962635Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.962Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.962840Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.962Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.962842Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.963Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.963068Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.963Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.963092Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.963Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.963095Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.963Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.963097Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.963Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.963099Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.963Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.963348Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.963Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.963351Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.963Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.963599Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.963Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.963602Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.963Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.963603Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.963Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.963604Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.963Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.963790Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.963Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.963791Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.963Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.963985Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.963Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.963987Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.964Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.963988Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.964Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.963989Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.964Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.964236Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.964Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.964238Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.964Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.964425Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x50003664 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.964Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.964426Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.964Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.964428Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.964Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.964428Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.964Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.964614Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.964Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.964616Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.964Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.964843Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.964Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.964845Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.964Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.964846Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.964Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.964847Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.964Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.964848Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.965Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.965048Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.965Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.965050Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.965Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.965279Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.965Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.965281Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.965Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.965282Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.965Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.965290Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.965Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.965498Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.965Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.965500Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.965Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.965688Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.965Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.965690Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.965Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.965691Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.965Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.965691Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.965Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.965884Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.965Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.965886Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.966Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.966073Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x50003668 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.966Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.966077Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.966Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.966078Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.966Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.966079Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.966Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.966263Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.966Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.966265Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.966Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.966485Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.966Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.966487Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.966Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.966488Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.966Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.966489Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.966Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.966490Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.966Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.966679Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.966Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.966681Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.966Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.966912Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.966Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.966914Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.966Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.966915Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.966Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.966916Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.967Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.967124Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.967Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.967126Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.967Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.967349Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.967Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.967351Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.967Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.967352Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.967Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.967353Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.967Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.967553Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.967Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.967555Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.967Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.967737Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x5000366c to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.967Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.967739Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.967Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.967740Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.967Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.967740Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.967Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.967934Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.967Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.967936Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.968Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.968232Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.968Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.968233Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.968Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.968235Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.968Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.968236Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.968Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.968237Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.968Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.968426Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.968Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.968428Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.968Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.968648Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.968Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.968650Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.968Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.968651Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.968Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.968651Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.968Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.968848Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.968Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.968850Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.969Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.969039Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.969Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.969041Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.969Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.969042Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.969Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.969049Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.969Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.969245Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.969Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.969247Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.969Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.969436Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x50003670 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.969Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.969438Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.969Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.969439Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.969Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.969440Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.969Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.969644Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.969Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.969646Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.969Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.969870Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.969Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.969872Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.969Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.969873Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.969Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.969874Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.969Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.969875Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.970Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.970090Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.970Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.970092Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.970Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.970369Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.970Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.970371Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.970Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.970372Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.970Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.970373Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.970Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.970553Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.970Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.970555Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.970Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.970738Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.970Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.970740Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.970Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.970741Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.970Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.970742Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.970Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.970928Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.970Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.970930Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.971Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.971109Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x50003674 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.971Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.971111Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.971Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.971112Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.971Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.971113Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.971Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.971343Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.971Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.971344Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.971Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.971577Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.971Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.971579Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.971Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.971581Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.971Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.971582Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.971Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.971582Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.971Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.971781Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.971Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.971783Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.972Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.971993Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.972Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.971995Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.972Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.971996Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.972Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.971997Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.972Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.972355Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.972Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.972357Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.972Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.972547Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.972Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.972549Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.972Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.972550Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.972Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.972551Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.972Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.972750Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.972Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.972751Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.972Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.972936Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x50003678 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.972Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.972938Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.972Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.972939Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.972Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.972940Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.973Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.973137Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.973Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.973139Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.973Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.973386Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.973Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.973388Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.973Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.973389Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.973Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.973390Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.973Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.973391Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.973Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.973598Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.973Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.973601Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.973Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.973863Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.973Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.973865Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.973Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.973866Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.973Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.973867Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.974Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.974068Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.974Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.974070Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.974Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.974254Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.974Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.974256Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.974Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.974257Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.974Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.974258Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.974Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.974482Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.974Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.974483Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.974Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.974664Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x5000367c to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.974Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.974665Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.974Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.974666Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.974Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.974667Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.974Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.974860Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.974Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.974861Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.975Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.975111Z] {jlink_usb_000801055229} AP 0 read 0x00000017 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.975Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.975113Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.975Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.975114Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:54.975Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.975115Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.975Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.975116Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.975Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.975364Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.975Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.975366Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.975Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.975599Z] {jlink_usb_000801055229} AP 0 read 0x03800042 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.975Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.975601Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.975Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.975602Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.975Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.975603Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.975Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.975799Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.975Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.975800Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.976Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.975998Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x03800042 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:54.976Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.976000Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.976Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.976001Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:54.976Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.976002Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.976Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.976233Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.976Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.976235Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.976Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.976424Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x50003680 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2025-06-26T06:57:54.976Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.976426Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:54.976Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.976426Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:54.976Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.976427Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:54.976Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.976627Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:54.976Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.976629Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:54.976Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.976844Z] {jlink_usb_000801055229} AP 0 read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2025-06-26T06:57:54.976Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.976846Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:54.976Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.976848Z] {jlink_usb_000801055229} Performing system reset to clear memory protection
    [2025-06-26T06:57:54.976Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:54.976849Z] {jlink_usb_000801055229} -> system_reset
    [2025-06-26T06:57:54.976Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:54.976850Z] {jlink_usb_000801055229} Performing system reset
    [2025-06-26T06:57:54.976Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.976858Z] {jlink_usb_000801055229} -> halt
    [2025-06-26T06:57:54.976Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.976859Z] {jlink_usb_000801055229} Halting CPU Application
    [2025-06-26T06:57:54.976Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:54.976862Z] {jlink_usb_000801055229} <- halt
    [2025-06-26T06:57:54.977Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.977226Z] {jlink_usb_000801055229} J-Link: Reset type: NORMAL (https://wiki.segger.com/J-Link_Reset_Strategies)
    [2025-06-26T06:57:54.978Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.978921Z] {jlink_usb_000801055229} J-Link: Reset: ARMv8M core with Security Extension enabled detected. Switch to secure domain.
    [2025-06-26T06:57:54.979Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.979255Z] {jlink_usb_000801055229} J-Link: Reset: Halt core after reset via DEMCR.VC_CORERESET.
    [2025-06-26T06:57:54.979Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:54.979586Z] {jlink_usb_000801055229} J-Link: Reset: Reset device via AIRCR.SYSRESETREQ.
    [2025-06-26T06:57:55.037Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.037852Z] {jlink_usb_000801055229} J-Link: Reset: SYSRESETREQ has confused core.
    [2025-06-26T06:57:55.038Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.038437Z] {jlink_usb_000801055229} J-Link: Found SW-DP with ID 0x6BA02477
    [2025-06-26T06:57:55.040Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.040524Z] {jlink_usb_000801055229} J-Link: DPIDR: 0x6BA02477
    [2025-06-26T06:57:55.040Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.040529Z] {jlink_usb_000801055229} J-Link: CoreSight SoC-400 or earlier
    [2025-06-26T06:57:55.040Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.040532Z] {jlink_usb_000801055229} J-Link: AP map detection skipped. Manually configured AP map found.
    [2025-06-26T06:57:55.040Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.040536Z] {jlink_usb_000801055229} J-Link: AP[0]: AHB-AP (IDR: Not set, ADDR: 0x00000000)
    [2025-06-26T06:57:55.042Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.042056Z] {jlink_usb_000801055229} J-Link: AP[0]: Skipped. Could not read CPUID register
    [2025-06-26T06:57:55.042Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.042059Z] {jlink_usb_000801055229} J-Link: Attach to CPU failed. Executing connect under reset.
    [2025-06-26T06:57:55.068Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.068728Z] {jlink_usb_000801055229} J-Link: Failed to power up DAP
    [2025-06-26T06:57:55.173Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.173828Z] {jlink_usb_000801055229} J-Link: Reset: Using fallback: VECTRESET.
    [2025-06-26T06:57:55.174Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.174757Z] {jlink_usb_000801055229} J-Link: Reset: Halt core after reset via DEMCR.VC_CORERESET.
    [2025-06-26T06:57:55.175Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.175001Z] {jlink_usb_000801055229} J-Link: Reset: Reset device via AIRCR.VECTRESET.
    [2025-06-26T06:57:55.176Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.176234Z] {jlink_usb_000801055229} J-Link: Reset: VECTRESET has confused core.
    [2025-06-26T06:57:55.176Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.176240Z] {jlink_usb_000801055229} J-Link: Reset: Using fallback: Reset pin.
    [2025-06-26T06:57:55.176Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.176889Z] {jlink_usb_000801055229} J-Link: Reset: Halt core after reset via DEMCR.VC_CORERESET.
    [2025-06-26T06:57:55.176Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.176894Z] {jlink_usb_000801055229} J-Link: Reset: Reset device via reset pin
    [2025-06-26T06:57:55.308Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.308373Z] {jlink_usb_000801055229} J-Link: Reset: VC_CORERESET did not halt CPU. (Debug logic also reset by reset pin?).
    [2025-06-26T06:57:55.308Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.308388Z] {jlink_usb_000801055229} J-Link: Reset: Reconnecting and manually halting CPU.
    [2025-06-26T06:57:55.309Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.309025Z] {jlink_usb_000801055229} J-Link: Found SW-DP with ID 0x6BA02477
    [2025-06-26T06:57:55.311Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.311141Z] {jlink_usb_000801055229} J-Link: DPIDR: 0x6BA02477
    [2025-06-26T06:57:55.311Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.311148Z] {jlink_usb_000801055229} J-Link: CoreSight SoC-400 or earlier
    [2025-06-26T06:57:55.311Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.311153Z] {jlink_usb_000801055229} J-Link: AP map detection skipped. Manually configured AP map found.
    [2025-06-26T06:57:55.311Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.311155Z] {jlink_usb_000801055229} J-Link: AP[0]: AHB-AP (IDR: Not set, ADDR: 0x00000000)
    [2025-06-26T06:57:55.312Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.312760Z] {jlink_usb_000801055229} J-Link: AP[0]: Skipped. Could not read CPUID register
    [2025-06-26T06:57:55.312Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.312764Z] {jlink_usb_000801055229} J-Link: Attach to CPU failed. Executing connect under reset.
    [2025-06-26T06:57:55.340Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.340503Z] {jlink_usb_000801055229} J-Link: Failed to power up DAP
    [2025-06-26T06:57:55.449Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.449366Z] {jlink_usb_000801055229} J-Link: CPU could not be halted
    [2025-06-26T06:57:55.456Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.456237Z] {jlink_usb_000801055229} J-Link: Reset: Core did not halt after reset, trying to disable WDT.
    [2025-06-26T06:57:55.457Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.457100Z] {jlink_usb_000801055229} J-Link: Reset: Halt core after reset via DEMCR.VC_CORERESET.
    [2025-06-26T06:57:55.457Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.457305Z] {jlink_usb_000801055229} J-Link: Reset: Reset device via reset pin
    [2025-06-26T06:57:55.588Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.588660Z] {jlink_usb_000801055229} J-Link: Reset: VC_CORERESET did not halt CPU. (Debug logic also reset by reset pin?).
    [2025-06-26T06:57:55.588Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.588671Z] {jlink_usb_000801055229} J-Link: Reset: Reconnecting and manually halting CPU.
    [2025-06-26T06:57:55.589Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.589265Z] {jlink_usb_000801055229} J-Link: Found SW-DP with ID 0x6BA02477
    [2025-06-26T06:57:55.591Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.591442Z] {jlink_usb_000801055229} J-Link: DPIDR: 0x6BA02477
    [2025-06-26T06:57:55.591Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.591448Z] {jlink_usb_000801055229} J-Link: CoreSight SoC-400 or earlier
    [2025-06-26T06:57:55.591Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.591451Z] {jlink_usb_000801055229} J-Link: AP map detection skipped. Manually configured AP map found.
    [2025-06-26T06:57:55.591Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.591453Z] {jlink_usb_000801055229} J-Link: AP[0]: AHB-AP (IDR: Not set, ADDR: 0x00000000)
    [2025-06-26T06:57:55.593Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.593021Z] {jlink_usb_000801055229} J-Link: AP[0]: Skipped. Could not read CPUID register
    [2025-06-26T06:57:55.593Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.593026Z] {jlink_usb_000801055229} J-Link: Attach to CPU failed. Executing connect under reset.
    [2025-06-26T06:57:55.621Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.620979Z] {jlink_usb_000801055229} J-Link: Failed to power up DAP
    [2025-06-26T06:57:55.728Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.728048Z] {jlink_usb_000801055229} J-Link: CPU could not be halted
    [2025-06-26T06:57:55.731Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.731326Z] {jlink_usb_000801055229} J-Link: Reset: Failed. Toggling reset pin and trying reset strategy again.
    [2025-06-26T06:57:55.843Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.843271Z] {jlink_usb_000801055229} J-Link: Failed to attach to CPU. Trying connect under reset.
    [2025-06-26T06:57:55.844Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.844345Z] {jlink_usb_000801055229} J-Link: Found SW-DP with ID 0x6BA02477
    [2025-06-26T06:57:55.845Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.845753Z] {jlink_usb_000801055229} J-Link: SWD speed too high. Reduced from 2000 kHz to 1350 kHz for stability
    [2025-06-26T06:57:55.847Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.847250Z] {jlink_usb_000801055229} J-Link: DPIDR: 0x6BA02477
    [2025-06-26T06:57:55.847Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.847263Z] {jlink_usb_000801055229} J-Link: CoreSight SoC-400 or earlier
    [2025-06-26T06:57:55.847Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.847268Z] {jlink_usb_000801055229} J-Link: AP map detection skipped. Manually configured AP map found.
    [2025-06-26T06:57:55.847Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.847272Z] {jlink_usb_000801055229} J-Link: AP[0]: AHB-AP (IDR: Not set, ADDR: 0x00000000)
    [2025-06-26T06:57:55.849Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.849000Z] {jlink_usb_000801055229} J-Link: AP[0]: Skipped. Could not read CPUID register
    [2025-06-26T06:57:55.849Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.849010Z] {jlink_usb_000801055229} J-Link: Attach to CPU failed. Executing connect under reset.
    [2025-06-26T06:57:55.879Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.877751Z] {jlink_usb_000801055229} J-Link: Failed to power up DAP
    [2025-06-26T06:57:55.984Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.984924Z] {jlink_usb_000801055229} J-Link: Reset: Halt core after reset via DEMCR.VC_CORERESET.
    [2025-06-26T06:57:55.985Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:55.985395Z] {jlink_usb_000801055229} J-Link: Reset: Reset device via AIRCR.SYSRESETREQ.
    [2025-06-26T06:57:56.040Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.040795Z] {jlink_usb_000801055229} J-Link: Reset: SYSRESETREQ has confused core.
    [2025-06-26T06:57:56.041Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.041552Z] {jlink_usb_000801055229} J-Link: Found SW-DP with ID 0x6BA02477
    [2025-06-26T06:57:56.044Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.044038Z] {jlink_usb_000801055229} J-Link: DPIDR: 0x6BA02477
    [2025-06-26T06:57:56.044Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.044043Z] {jlink_usb_000801055229} J-Link: CoreSight SoC-400 or earlier
    [2025-06-26T06:57:56.044Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.044046Z] {jlink_usb_000801055229} J-Link: AP map detection skipped. Manually configured AP map found.
    [2025-06-26T06:57:56.044Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.044049Z] {jlink_usb_000801055229} J-Link: AP[0]: AHB-AP (IDR: Not set, ADDR: 0x00000000)
    [2025-06-26T06:57:56.045Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.045921Z] {jlink_usb_000801055229} J-Link: AP[0]: Skipped. Could not read CPUID register
    [2025-06-26T06:57:56.045Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.045926Z] {jlink_usb_000801055229} J-Link: Attach to CPU failed. Executing connect under reset.
    [2025-06-26T06:57:56.074Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.074508Z] {jlink_usb_000801055229} J-Link: Failed to power up DAP
    [2025-06-26T06:57:56.179Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.179685Z] {jlink_usb_000801055229} J-Link: Reset: Using fallback: VECTRESET.
    [2025-06-26T06:57:56.180Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.180920Z] {jlink_usb_000801055229} J-Link: Reset: Halt core after reset via DEMCR.VC_CORERESET.
    [2025-06-26T06:57:56.181Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.181158Z] {jlink_usb_000801055229} J-Link: Reset: Reset device via AIRCR.VECTRESET.
    [2025-06-26T06:57:56.182Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.182418Z] {jlink_usb_000801055229} J-Link: Reset: VECTRESET has confused core.
    [2025-06-26T06:57:56.182Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.182439Z] {jlink_usb_000801055229} J-Link: Reset: Using fallback: Reset pin.
    [2025-06-26T06:57:56.183Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.183290Z] {jlink_usb_000801055229} J-Link: Reset: Halt core after reset via DEMCR.VC_CORERESET.
    [2025-06-26T06:57:56.183Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.183312Z] {jlink_usb_000801055229} J-Link: Reset: Reset device via reset pin
    [2025-06-26T06:57:56.315Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.315494Z] {jlink_usb_000801055229} J-Link: Reset: VC_CORERESET did not halt CPU. (Debug logic also reset by reset pin?).
    [2025-06-26T06:57:56.315Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.315584Z] {jlink_usb_000801055229} J-Link: Reset: Reconnecting and manually halting CPU.
    [2025-06-26T06:57:56.316Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.316339Z] {jlink_usb_000801055229} J-Link: Found SW-DP with ID 0x6BA02477
    [2025-06-26T06:57:56.318Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.318775Z] {jlink_usb_000801055229} J-Link: DPIDR: 0x6BA02477
    [2025-06-26T06:57:56.318Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.318784Z] {jlink_usb_000801055229} J-Link: CoreSight SoC-400 or earlier
    [2025-06-26T06:57:56.318Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.318789Z] {jlink_usb_000801055229} J-Link: AP map detection skipped. Manually configured AP map found.
    [2025-06-26T06:57:56.318Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.318793Z] {jlink_usb_000801055229} J-Link: AP[0]: AHB-AP (IDR: Not set, ADDR: 0x00000000)
    [2025-06-26T06:57:56.320Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.320627Z] {jlink_usb_000801055229} J-Link: AP[0]: Skipped. Could not read CPUID register
    [2025-06-26T06:57:56.320Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.320634Z] {jlink_usb_000801055229} J-Link: Attach to CPU failed. Executing connect under reset.
    [2025-06-26T06:57:56.349Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.349349Z] {jlink_usb_000801055229} J-Link: Failed to power up DAP
    [2025-06-26T06:57:56.458Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.458754Z] {jlink_usb_000801055229} J-Link: CPU could not be halted
    [2025-06-26T06:57:56.466Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.466815Z] {jlink_usb_000801055229} J-Link: Reset: Core did not halt after reset, trying to disable WDT.
    [2025-06-26T06:57:56.467Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.467609Z] {jlink_usb_000801055229} J-Link: Reset: Halt core after reset via DEMCR.VC_CORERESET.
    [2025-06-26T06:57:56.467Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.467622Z] {jlink_usb_000801055229} J-Link: Reset: Reset device via reset pin
    [2025-06-26T06:57:56.599Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.599163Z] {jlink_usb_000801055229} J-Link: Reset: VC_CORERESET did not halt CPU. (Debug logic also reset by reset pin?).
    [2025-06-26T06:57:56.599Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.599178Z] {jlink_usb_000801055229} J-Link: Reset: Reconnecting and manually halting CPU.
    [2025-06-26T06:57:56.599Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.599809Z] {jlink_usb_000801055229} J-Link: Found SW-DP with ID 0x6BA02477
    [2025-06-26T06:57:56.602Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.602076Z] {jlink_usb_000801055229} J-Link: DPIDR: 0x6BA02477
    [2025-06-26T06:57:56.602Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.602087Z] {jlink_usb_000801055229} J-Link: CoreSight SoC-400 or earlier
    [2025-06-26T06:57:56.602Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.602093Z] {jlink_usb_000801055229} J-Link: AP map detection skipped. Manually configured AP map found.
    [2025-06-26T06:57:56.602Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.602097Z] {jlink_usb_000801055229} J-Link: AP[0]: AHB-AP (IDR: Not set, ADDR: 0x00000000)
    [2025-06-26T06:57:56.604Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.604689Z] {jlink_usb_000801055229} J-Link: AP[0]: Skipped. Could not read CPUID register
    [2025-06-26T06:57:56.604Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.604704Z] {jlink_usb_000801055229} J-Link: Attach to CPU failed. Executing connect under reset.
    [2025-06-26T06:57:56.631Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.631851Z] {jlink_usb_000801055229} J-Link: Failed to power up DAP
    [2025-06-26T06:57:56.740Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.740283Z] {jlink_usb_000801055229} J-Link: CPU could not be halted
    [2025-06-26T06:57:56.749Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.749256Z] {jlink_usb_000801055229} J-Link: CPU could not be halted
    [2025-06-26T06:57:56.749Z] [71138] ERROR - [ProbeLib] [2025-06-26 06:57:56.749272Z] {jlink_usb_000801055229} J-Link: Failed to halt CPU.
    [2025-06-26T06:57:56.749Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:56.749281Z] {jlink_usb_000801055229} system reset performed
    [2025-06-26T06:57:56.749Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:56.749287Z] {jlink_usb_000801055229} <- system_reset
    [2025-06-26T06:57:56.749Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.749301Z] {jlink_usb_000801055229} Cached has_secure_access for AP 0: true
    [2025-06-26T06:57:56.749Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.749306Z] {jlink_usb_000801055229} -> read_ap
    [2025-06-26T06:57:56.749Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.749309Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:56.750Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.750160Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:56.750Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.750169Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:56.750Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.750457Z] {jlink_usb_000801055229} AP 0 read 0x00000000 from CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:56.750Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.750463Z] {jlink_usb_000801055229} <- read_ap
    [2025-06-26T06:57:56.750Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.750467Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:56.750Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.750469Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:56.750Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.750716Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:56.750Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.750721Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:56.750Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.750965Z] {jlink_usb_000801055229} Submitted write to AP 0: Write 0x00000002 to CSW(mem-ap) or RESET(ctrl-ap)
    [2025-06-26T06:57:56.750Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.750971Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:56.751Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.750973Z] {jlink_usb_000801055229} -> write_ap
    [2025-06-26T06:57:56.751Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.750975Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:56.751Z] [71138] WARN - [ProbeLib] [2025-06-26 06:57:56.751275Z] {jlink_usb_000801055229} DAP write error: DebugPort,  register DapRegisterAddress(0x08) = 0x00000000, err: Unknown Error in J-Link DLL (error code =-1)
    [2025-06-26T06:57:56.751Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:56.751281Z] {jlink_usb_000801055229} Aborting debug operation, writing 0x1FF to ABORT register
    [2025-06-26T06:57:56.751Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.751535Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:56.751Z] [71138] ERROR - [ProbeLib] [2025-06-26 06:57:56.751582Z] {jlink_usb_000801055229} Writing to the SELECT register failed: Failed to write DebugPort register 0x08: Unknown Error in J-Link DLL (error code =-1). This might indicate that the debug port is unavailable
    [2025-06-26T06:57:56.751Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.751586Z] {jlink_usb_000801055229} <- write_ap
    [2025-06-26T06:57:56.751Z] [71138] ERROR - [ProbeLib] [2025-06-26 06:57:56.751597Z] {jlink_usb_000801055229} Could not perform programming. Erase failed: Failed to read from memory address 0x500038e4: Failed to write DebugPort register 0x08: Unknown Error in J-Link DLL (error code =-1)
    [2025-06-26T06:57:56.751Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:56.751607Z] {jlink_usb_000801055229} -> Powering down debug region
    [2025-06-26T06:57:56.751Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.751610Z] {jlink_usb_000801055229} -> write_dp_unchecked
    [2025-06-26T06:57:56.751Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.751899Z] {jlink_usb_000801055229} DP wrote 0x00000000 to SELECT = 0x08
    [2025-06-26T06:57:56.751Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.751909Z] {jlink_usb_000801055229} <- write_dp_unchecked
    [2025-06-26T06:57:56.751Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.751913Z] {jlink_usb_000801055229} -> read_dp
    [2025-06-26T06:57:56.752Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.752149Z] {jlink_usb_000801055229} DP read 0x00000040 from CTRL/STAT
    [2025-06-26T06:57:56.752Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.752156Z] {jlink_usb_000801055229} <- read_dp
    [2025-06-26T06:57:56.752Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:56.752159Z] {jlink_usb_000801055229} <- Powering down debug region
    [2025-06-26T06:57:56.752Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.752321Z] Got device error response
    [2025-06-26T06:57:56.752Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.752355Z] Expecting trace channel to disconnect.
    [2025-06-26T06:57:56.752Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:56.752367Z] Terminating worker with id 71139
    [2025-06-26T06:57:56.752Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.752390Z] Waiting for worker to exit.
    [2025-06-26T06:57:56.752Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:56.752405Z] {jlink_usb_000801055229} Probe worker received message: Shutdown
    [2025-06-26T06:57:56.752Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.752416Z] {jlink_usb_000801055229} Closing emulator connection
    [2025-06-26T06:57:56.753Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.753667Z] Waiting for worker to exit.
    [2025-06-26T06:57:56.754Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.754941Z] Waiting for worker to exit.
    [2025-06-26T06:57:56.757Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.757462Z] Waiting for worker to exit.
    [2025-06-26T06:57:56.761Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.761235Z] Waiting for worker to exit.
    [2025-06-26T06:57:56.767Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.767504Z] Waiting for worker to exit.
    [2025-06-26T06:57:56.777Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.777524Z] Waiting for worker to exit.
    [2025-06-26T06:57:56.780Z] [71138] DEBUG - [ProbeLib] [2025-06-26 06:57:56.780862Z] {jlink_usb_000801055229} Probe worker stopped.
    [2025-06-26T06:57:56.781Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.781728Z] Trace channel disconnected as expected.
    [2025-06-26T06:57:56.781Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.781742Z] Trace thread ends now...
    [2025-06-26T06:57:56.793Z] [71138] INFO - [ProbeLib] [2025-06-26 06:57:56.793808Z] Worker exited successfully
    [2025-06-26T06:57:56.793Z] [71138] TRACE - [ProbeLib] [2025-06-26 06:57:56.793882Z] Joined trace thread.
    [2025-06-26T06:57:56.793Z] [71138] DEBUG - join thread finished: true
    [2025-06-26T06:57:56.794Z] [71138] INFO - event loop thread exited
    [2025-06-26T06:57:56.794Z] [71138] TRACE - [boardController] BoardControllerPlugin::drop - ref 0x600002054200
    This is the log.txt file from `nrfjprog` which flashes properly.
    03680.log.txt
    Thanks for explaining the scenario in detail, it helped clarify some of the confusion.
    From the log, it looks like nrfutil-device detects that write/erase protection is enabled on a memory range by the running firmware. It then tries to disable it using a system reset. This reset is handled by J-Link, but it fails badly—something goes wrong during the reset, and when J-Link tries to reconnect to the core, that also fails and is retried a few times. As a result, the next operation fails because J-Link seems to have powered down the debug regions or something similar.
    From the nrfjprog log, it doesn't appear to attempt clearing the erase protection using a system reset at this point. However, the firmware might not have been running due to side effects from earlier operations. So could you please try running the following commands:
    nrfjprog --program /Users/soham/ksham/pcb-tests/led-test/build/merged.hex --chiperase --pinreset
    nrfjprog --program /Users/soham/ksham/pcb-tests/led-test/build/merged.hex --chiperase --log log.txt
    From the shared log, I see this error:
    * 801055229: Device error: Failed to read from memory address 0x500038e4: Failed to write DebugPort register 0x08: Unknown Error in J-Link DLL (error code = -1)
    However, the error you mentioned in your response:
    * 801055229: Device error: Emulator error: Unknown Error in J-Link DLL (error code = -1) (Generic) is missing.
    I’d appreciate it if you could rerun the command to try to reproduce the missing error, so we can investigate further. Ideally, you should keep running the command until the first error appears again. But even if it doesn't, sharing the full log from multiple attempts, maybe limit it to 5 tries, would still be helpful.
    Kind Regards,
    Abhijith
