sysbuild + MCUboot can't resolve SPI NOR symbols (NCS v2.7.0)
I'm using Zephyr/NCS v2.7.0 with a custom multi-image project based on sysbuild. My top-level project has a sysbuild.conf at the root, and a sysbuild/ folder containing a mcuboot.conf that enables CONFIG_SPI_NOR=y, CONFIG_MULTITHREADING=y, etc. Despite this, building fails with an error like:
/opt/toolchains/zephyr-sdk-0.16.1/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/drivers/flash/libdrivers__flash.a(spi_nor.c.obj):(.rodata.spi_nor_0_config+0x0): undefined reference to `__device_dts_ord_24'
This implies MCUboot can't resolve the SPI NOR driver, even though it's configured and works in the main app. I've verified that CONFIG_SPI_NOR is enabled for MCUboot via build logs.
Project structure looks like this:
project/
├── sysbuild.conf
├── CmakeLists.txt.conf
├── prj.conf
├── pm_static.yml
├── sysbuild/
│ └── mcuboot.conf
│ └── CMakeLists.txt
│ └── mcuboot.overlay
Any ideas why the SPI NOR driver instance isn’t being linked correctly into MCUboot? Do I need to mirror the devicetree overlay into sysbuild/mcuboot.overlay, or manually define a node alias to make it resolve properly?
I am happy to share the contents of any of these files on the public forum.
  • Hi Hakon,
    Thanks that is a great spot, I always do a pristine build for build errors, but I have just deleted the build folder and re-run:
    west build -b JUNA --sysbuild -p
    Here is the updated build log:
    As a side note, we mount our environment in a a dev container in WSL, so safe to use root.
    Many thanks,
    Andrew
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: /usr/bin/python3 (found suitable version "3.10.12", minimum required is "3.8") found components: Interpreter
    -- Cache files will be written to: /root/.cache/zephyr
    -- Found west (found suitable version "1.4.0", minimum required is "0.14.0")
    -- Board: JUNA, qualifiers: nrf52840
    Parsing /home/ee/ncs/zephyr/share/sysbuild/Kconfig
    Loaded configuration '/home/ee/juna-fw/build/_sysbuild/empty.conf'
    Merged configuration '/home/ee/juna-fw/sysbuild.conf'
    Configuration saved to '/home/ee/juna-fw/build/zephyr/.config'
    Kconfig header saved to '/home/ee/juna-fw/build/_sysbuild/autoconf.h'
       * Running CMake for mcuboot *
    -- Application: /home/ee/ncs/bootloader/mcuboot/boot/zephyr
    -- CMake version: 3.21.0
    -- Found Python3: /usr/bin/python (found suitable version "3.10.12", minimum required is "3.8") found components: Interpreter
    -- Zephyr version: 3.6.99 (/home/ee/ncs/zephyr)
    -- Found host-tools: zephyr 0.16.1 (/opt/toolchains/zephyr-sdk-0.16.1)
    -- Found toolchain: zephyr 0.16.1 (/opt/toolchains/zephyr-sdk-0.16.1)
    -- Found Dtc: /opt/toolchains/zephyr-sdk-0.16.1/sysroots/x86_64-pokysdk-linux/usr/bin/dtc (found suitable version "1.6.0", minimum required is "1.4.6")
    -- Found BOARD.dts: /home/ee/juna-fw/boards/chiaro/JUNA/JUNA.dts
    -- Found devicetree overlay: /home/ee/ncs/bootloader/mcuboot/boot/zephyr/app.overlay
    -- Generated zephyr.dts: /home/ee/juna-fw/build/mcuboot/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /home/ee/juna-fw/build/mcuboot/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: /home/ee/juna-fw/build/mcuboot/zephyr/dts.cmake
    Parsing /home/ee/ncs/bootloader/mcuboot/boot/zephyr/Kconfig
    Loaded configuration '/home/ee/juna-fw/boards/chiaro/JUNA/JUNA_defconfig'
    Merged configuration '/home/ee/ncs/bootloader/mcuboot/boot/zephyr/prj.conf'
    Merged configuration '/home/ee/ncs/nrf/subsys/bootloader/bl_override/override_external_mcuboot.conf'
    Merged configuration '/home/ee/ncs/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf'
    Merged configuration '/home/ee/juna-fw/build/mcuboot/zephyr/.config.sysbuild'
    Configuration saved to '/home/ee/juna-fw/build/mcuboot/zephyr/.config'
    Kconfig header saved to '/home/ee/juna-fw/build/mcuboot/zephyr/include/generated/autoconf.h'
    -- Found GnuLd: /opt/toolchains/zephyr-sdk-0.16.1/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
    -- Found assembler: /opt/toolchains/zephyr-sdk-0.16.1/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    CMake Warning at /home/ee/ncs/nrf/lib/flash_patch/CMakeLists.txt:8 (message):
            --- WARNING: To maintain the integrity of secure boot, ---
            --- enable CONFIG_DISABLE_FLASH_PATCH in production.   ---
    -- Using ccache: /usr/bin/ccache
    CMake Warning at /home/ee/ncs/zephyr/CMakeLists.txt:895 (message):
      No SOURCES given to Zephyr library: drivers__spi
      Excluding target from build.
    MCUBoot bootloader key file: /home/ee/ncs/bootloader/mcuboot/root-ec-p256.pem
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/ee/juna-fw/build/mcuboot
       * Running CMake for juna-fw *
    -- Found Git: /usr/bin/git (found version "2.34.1")
    -- [MunkeiVersionFromGit] Version: 4.1.0
         Git tag:     [v4.1.0]
         Git hash:    [5b017006]
         Git branch:  [ncs_upgrade]
         Git dirty:   [dirty]
         Decorated:   [v4.1.0-15-g5b017006]
         Identifiers: []
         Metadata:    []
         SemVer:      [4.1.0]
    -- Application: /home/ee/juna-fw
    -- Generated zephyr.dts: /home/ee/juna-fw/build/juna-fw/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /home/ee/juna-fw/build/juna-fw/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: /home/ee/juna-fw/build/juna-fw/zephyr/dts.cmake
    warning: UART_CONSOLE (defined at drivers/console/Kconfig:43) was assigned the value 'y' but got the
    value 'n'. Check these unsatisfied dependencies: CONSOLE (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_UART_CONSOLE and/or look up UART_CONSOLE in
    the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration
    Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
    warning: STACK_SENTINEL (defined at subsys/debug/Kconfig:177) was assigned the value 'y' but got the
    value 'n'. Check these unsatisfied dependencies: (!MPU_STACK_GUARD) (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_STACK_SENTINEL and/or look up
    STACK_SENTINEL in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
    too.
    warning: The choice symbol LEDS_MODULE_LOG_LEVEL_INF (defined at
    subsys/logging/Kconfig.template.log_config:17, subsys/logging/Kconfig.template.log_config:17) was
    selected (set =y), but no symbol ended up as the choice selection. See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_LEDS_MODULE_LOG_LEVEL_INF and/or look up
    LEDS_MODULE_LOG_LEVEL_INF in the menuconfig/guiconfig interface. The Application Development Primer,
    Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
    helpful too.
    warning: The choice symbol METRICS_MODULE_LOG_LEVEL_INF (defined at
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_METRICS_MODULE_LOG_LEVEL_INF and/or look up
    METRICS_MODULE_LOG_LEVEL_INF in the menuconfig/guiconfig interface. The Application Development
    Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
    warning: The choice symbol SENSOR_LOG_LEVEL_WRN (defined at
    subsys/logging/Kconfig.template.log_config:14) was selected (set =y), but no symbol ended up as the
    choice selection. See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_SENSOR_LOG_LEVEL_WRN
    and/or look up SENSOR_LOG_LEVEL_WRN in the menuconfig/guiconfig interface. The Application
    Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of
    warning: The choice symbol THREAD_ANALYZER_USE_LOG (defined at subsys/debug/Kconfig:31) was selected
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_THREAD_ANALYZER_USE_LOG and/or look up
    THREAD_ANALYZER_USE_LOG in the menuconfig/guiconfig interface. The Application Development Primer,
    helpful too.
    Parsing /home/ee/juna-fw/Kconfig
    Merged configuration '/home/ee/juna-fw/prj.conf'
    Merged configuration '/home/ee/juna-fw/build/juna-fw/zephyr/.config.sysbuild'
    Configuration saved to '/home/ee/juna-fw/build/juna-fw/zephyr/.config'
    Kconfig header saved to '/home/ee/juna-fw/build/juna-fw/zephyr/include/generated/autoconf.h'
      No SOURCES given to Zephyr library: ..__nrf__subsys__caf__modules
    -- Including signing script: /home/ee/ncs/nrf/cmake/sysbuild/image_signing.cmake
    CMake Warning at /home/ee/ncs/zephyr/CMakeLists.txt:2027 (message):
    -- Setup Protobuf...
    -- Found Nanopb: /home/ee/ncs/modules/lib/nanopb
    -- Found protoc: /home/ee/ncs/modules/lib/nanopb/generator/protoc
    --2025-06-18 08:42:39--  https://raw.githubusercontent.com/boost-ext/sml/v1.1.11/include/boost/sml.hpp
    Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.110.133, 185.199.109.133, 185.199.111.133, ...
    Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.110.133|:443... connected.
    HTTP request sent, awaiting response... 200 OK
    Length: 126527 (124K) [text/plain]
    Saving to: ‘/home/ee/juna-fw/build/juna-fw/boost/sml.hpp’
         0K .......... .......... .......... .......... .......... 40% 3.51M 0s
        50K .......... .......... .......... .......... .......... 80% 4.12M 0s
       100K .......... .......... ...                             100% 2.61M=0.03s
    2025-06-18 08:42:39 (3.49 MB/s) - ‘/home/ee/juna-fw/build/juna-fw/boost/sml.hpp’ saved [126527/126527]
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/ee/juna-fw/build/juna-fw
    -- Found Python3: /usr/bin/python3 (found version "3.10.12") found components: Interpreter
    -- Found partition manager static configuration : /home/ee/juna-fw/pm_static.yml
    Partition 'mcuboot' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_pad' is not included in the dynamic resolving since it is statically defined.
    Partition 'settings_storage' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_primary' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_primary_app' is not included in the dynamic resolving since it is statically defined.
    Partition 'littlefs_storage' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_secondary' is not included in the dynamic resolving since it is statically defined.
    -- Configuring done
    -- Generating done
    [9/21] Performing build step for 'juna-fw'
    [0/1] Re-running CMake...
         Git tag:     [v4.1.0]
         Git dirty:   [dirty]
         Identifiers: []
         Metadata:    []
         SemVer:      [4.1.0]
    Loading Zephyr default modules (Zephyr base (cached)).
    Loaded configuration '/home/ee/juna-fw/build/juna-fw/zephyr/.config'
    No change to configuration in '/home/ee/juna-fw/build/juna-fw/zephyr/.config'
    No change to Kconfig header in '/home/ee/juna-fw/build/juna-fw/zephyr/include/generated/autoconf.h'
    -- Configuring done
    -- Generating done
    [1/415] Preparing syscall dependency handling
    [6/415] Generating include/generated/version.h
    -- Zephyr version: 3.6.99 (/home/ee/ncs/zephyr), build: v3.6.99-ncs2
    [415/415] Linking CXX executable zephyr/zephyr.elf
               FLASH:      765296 B     945664 B     80.93%
                 RAM:      159136 B       256 KB     60.71%
            IDT_LIST:          0 GB        32 KB      0.00%
    Generating files from /home/ee/juna-fw/build/juna-fw/zephyr/zephyr.elf for board: JUNA
    image.py: sign the payload
    [11/21] Performing build step for 'mcuboot'
    [1/190] Preparing syscall dependency handling
    [7/190] Generating include/generated/version.h
    [185/190] Linking C executable zephyr/zephyr_pre0.elf
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /home/ee/juna-fw/build/mcuboot/zephyr/zephyr_pre0.map
    : && ccache /opt/toolchains/zephyr-sdk-0.16.1/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc  -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -fuse-ld=bfd  -T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/home/ee/juna-fw/build/mcuboot/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/libarch__arm__core.a  zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a  zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a  zephyr/lib/libc/minimal/liblib__libc__minimal.a  zephyr/lib/libc/common/liblib__libc__common.a  zephyr/soc/soc/nrf52840/libsoc__nordic.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a  modules/nrf/drivers/hw_cc3xx/lib..__nrf__drivers__hw_cc3xx.a  modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  modules/segger/libmodules__segger.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L"/opt/toolchains/zephyr-sdk-0.16.1/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v7e-m+fp/hard"  -L/home/ee/juna-fw/build/mcuboot/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  -mcpu=cortex-m4  -mthumb  -mabi=aapcs  -mfpu=fpv4-sp-d16  -mfloat-abi=hard  -mfp16-format=ieee  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -Wl,-no-pie  /home/ee/ncs/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m4/hard-float/no-interrupts/libnrf_cc310_platform_0.9.19.a  /home/ee/ncs/nrfxlib/crypto/nrf_cc310_bl/lib/cortex-m4/hard-float/no-interrupts/libnrf_cc310_bl_0.9.12.a && cd /home/ee/juna-fw/build/mcuboot/zephyr && /usr/local/bin/cmake -E true
    collect2: error: ld returned 1 exit status
    [16/21] Generating ../dfu_application.zip
    FAILED: _sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build /home/ee/juna-fw/build/_sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build
    cd /home/ee/juna-fw/build/mcuboot && /usr/local/bin/cmake --build .
    FATAL ERROR: command exited with status 1: /usr/local/bin/cmake --build /home/ee/juna-fw/build
    ├── sysbuild/
    │ └── mcuboot.conf
    your log still does not pick up mcuboot.conf or mcuboot.overlay?
    This is a bit strange that it does not pick up the two.
    Håkon
  • Hi Hakon,
    yes it still does not pick them up. Do I need to set a .dts root for the sysbuild folder in my top-level cmake?
    For now I will paste my current sysbuild/CMakeLists.txt:
    set(mcuboot_CONF_FILE ${CMAKE_CURRENT_LIST_DIR}/mcuboot.conf)
    get_filename_component(CURRENT_DIR ${CMAKE_CURRENT_LIST_DIR} ABSOLUTE)
    # Get the parent directory
    get_filename_component(PARENT_DIR ${CURRENT_DIR} DIRECTORY)
    get_filename_component(APP_NAME ${PARENT_DIR} NAME)
    set(BOARD_ROOT ${PARENT_DIR})
    find_package(Sysbuild REQUIRED HINTS $ENV{ZEPHYR_BASE})
    project(sysbuild LANGUAGES)
    A lot of samples I look at do not have a CMakeLists.txt in the sysbuild/ directory, but if I delete the one I am using then I get:
    -- west build: making build dir /home/ee/juna-fw/build pristine
    No board named 'JUNA' found.
    Please choose one of the following boards:
    CMake Error at /home/ee/ncs/zephyr/cmake/modules/boards.cmake:244 (message):
    Invalid BOARD; see above.
    cmake/modules/sysbuild_default.cmake:14 (include)
    /home/ee/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
    /home/ee/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
    /home/ee/ncs/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
    template/CMakeLists.txt:10 (find_package)
    See also "/home/ee/juna-fw/build/CMakeFiles/CMakeOutput.log".
    FATAL ERROR: command exited with status 1: /usr/local/bin/cmake -DWEST_PYTHON=/usr/bin/python3 -B/home/ee/juna-fw/build -GNinja -DBOARD=JUNA -S/home/ee/ncs/zephyr/share/sysbuild -DAPP_DIR:PATH=/home/ee/juna-fw
    Do you have any thoughts?
    Many thanks,
    Andy
    you can have a sysbuild.cmake file in your root directory, but it is strictly not required.
    Your current error is related to the board root, ie cmake def. BOARD_ROOT, which you can specify when using west:
    west build -b board_name/nrf52840 -- -DBOARD_ROOT=.
    You can set these in your application/CMakeLists.txt file instead of for the sysbuild images.
    I have never seen a CMakeLists.txt directly in the sysbuild-folder, so that might be the reason why your build behaves so strange.
    PS: You do not need to specify sysbuild/mcuboot.conf and .overlay. these should be picked up by the build system automatically when SB_CONFIG_BOOTLOADER_MCUBOOT=y is set.
    Håkon
  • Hey Hakon,
    thanks for your help, solution was to delete that sysbuild/CMakeLists.txt file and solve everything that came after that.
    Many thanks,
    Andy
