I was wondering how I can update my current code (see below) to reuse a single socket for multiple HTTPS requests, rather than opening and closing a socket for each HTTPS request. The code is a slightly modified version of the Nordic SDK HTTPS client sample code which can be found under /nrf/samples/net/https_client. It should be noted that I am using an nRF9160 DK over an LTE connection.
Alternatively, if there is any way to speed up the current code as it is taking me at least 3-4 seconds to run a single request.
Any help is appreciated.
main.c
#include <string.h>
#include <zephyr/kernel.h>
#include <stdlib.h>
#include <zephyr/net/socket.h>
#include <zephyr/net/conn_mgr_monitor.h>
#include <zephyr/net/conn_mgr_connectivity.h>
#include <zephyr/net/tls_credentials.h>
#if defined(CONFIG_POSIX_API)
#include <zephyr/posix/arpa/inet.h>
#include <zephyr/posix/netdb.h>
#include <zephyr/posix/unistd.h>
#include <zephyr/posix/sys/socket.h>
#if CONFIG_MODEM_KEY_MGMT
#include <modem/modem_key_mgmt.h>
#define HTTPS_PORT "443"
#define HTTPS_HOSTNAME "[insert url here]"
#define HTTP_GET_PATH "/?mac=[insert mac address here]"
#define HTTP_POST_PATH "/[...]/[...]/[insert mac address here]"
#define HTTP_POST_BODY "[insert body here]"
#define USE_POST 1
#define RECV_BUF_SIZE 2048
#define TLS_SEC_TAG 42
#define L4_EVENT_MASK (NET_EVENT_L4_CONNECTED | NET_EVENT_L4_DISCONNECTED)
#define CONN_LAYER_EVENT_MASK (NET_EVENT_CONN_IF_FATAL_ERROR)
static char send_buf[1024];
static char recv_buf[RECV_BUF_SIZE];
static K_SEM_DEFINE(network_connected_sem, 0, 1);
static const char cert[] = {
#include "DigiCertGlobalRootG2.pem.inc"
IF_ENABLED(CONFIG_TLS_CREDENTIALS, (0x00))
static struct net_mgmt_event_callback l4_cb;
static struct net_mgmt_event_callback conn_cb;
BUILD_ASSERT(sizeof(cert) < KB(4), "Certificate too large");
int cert_provision(void)
int err;
printk("Provisioning certificate\n");
bool exists;
int mismatch;
err = modem_key_mgmt_exists(TLS_SEC_TAG, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN, &exists);
if (err) return err;
if (exists) {
mismatch = modem_key_mgmt_cmp(TLS_SEC_TAG, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN, cert, sizeof(cert));
if (!mismatch) return 0;
modem_key_mgmt_delete(TLS_SEC_TAG, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN);
err = modem_key_mgmt_write(TLS_SEC_TAG, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN, cert, sizeof(cert));
#else
err = tls_credential_add(TLS_SEC_TAG, TLS_CREDENTIAL_CA_CERTIFICATE, cert, sizeof(cert));
if (err == -EEXIST) err = 0;
return err;
int tls_setup(int fd)
int err;
int verify = 2;
const sec_tag_t tls_sec_tag[] = { TLS_SEC_TAG };
err = setsockopt(fd, SOL_TLS, TLS_PEER_VERIFY, &verify, sizeof(verify));
err = setsockopt(fd, SOL_TLS, TLS_SEC_TAG_LIST, tls_sec_tag, sizeof(tls_sec_tag));
err = setsockopt(fd, SOL_TLS, TLS_HOSTNAME, HTTPS_HOSTNAME, strlen(HTTPS_HOSTNAME));
return err;
static void on_net_event_l4_disconnected(void) { printk("Disconnected from the network\n"); }
static void on_net_event_l4_connected(void) { k_sem_give(&network_connected_sem); }
static void l4_event_handler(struct net_mgmt_event_callback *cb, uint32_t event, struct net_if *iface)
if (event == NET_EVENT_L4_CONNECTED) on_net_event_l4_connected();
else if (event == NET_EVENT_L4_DISCONNECTED) on_net_event_l4_disconnected();
static void connectivity_event_handler(struct net_mgmt_event_callback *cb, uint32_t event, struct net_if *iface)
if (event == NET_EVENT_CONN_IF_FATAL_ERROR)
printk("Fatal error received from the connectivity layer\n");
static int send_http_request(void)
int err, fd, bytes;
size_t off = 0;
struct addrinfo *res;
struct addrinfo hints = {
.ai_flags = AI_NUMERICSERV,
.ai_socktype = SOCK_STREAM,
char peer_addr[INET6_ADDRSTRLEN];
printk("Looking up %s\n", HTTPS_HOSTNAME);
err = getaddrinfo(HTTPS_HOSTNAME, HTTPS_PORT, &hints, &res);
if (err) return;
inet_ntop(res->ai_family, &((struct sockaddr_in *)(res->ai_addr))->sin_addr,
peer_addr, INET6_ADDRSTRLEN);
printk("Resolved %s (%s)\n", peer_addr, net_family2str(res->ai_family));
fd = socket(res->ai_family, SOCK_STREAM, IPPROTO_TLS_1_2);
if (fd == -1) goto clean_up;
if (tls_setup(fd)) goto clean_up;
printk("Connecting to %s\n", HTTPS_HOSTNAME);
if (connect(fd, res->ai_addr, res->ai_addrlen)) goto clean_up;
if (USE_POST) {
snprintf(send_buf, sizeof(send_buf),
"POST %s HTTP/1.1\r\n"
"Host: %s\r\n"
"User-Agent: slm\r\n"
"Accept: */*\r\n"
"Content-Type: application/json\r\n"
"Content-Length: %zu\r\n"
"Connection: close\r\n\r\n%s",
HTTP_POST_PATH, HTTPS_HOSTNAME,
strlen(HTTP_POST_BODY), HTTP_POST_BODY);
} else {
"GET %s HTTP/1.1\r\n"
"Host: %s\r\n"
"Connection: close\r\n\r\n",
HTTP_GET_PATH, HTTPS_HOSTNAME);
size_t total_len = strlen(send_buf);
off = 0;
do {
bytes = send(fd, &send_buf[off], total_len - off, 0);
if (bytes < 0) {
printk("send() failed: errno=%d\n", errno);
goto clean_up;
off += bytes;
} while (off < total_len);
printk("Sent %d bytes\n", off);
// clear the receive buffer before use
memset(recv_buf, 0, sizeof(recv_buf));
off = 0;
do {
bytes = recv(fd, &recv_buf[off], RECV_BUF_SIZE - off - 1, 0);
if (bytes < 0) {
printk("recv() failed: errno=%d\n", errno);
goto clean_up;
off += bytes;
// prevent buffer overflow
if (off >= RECV_BUF_SIZE - 1) {
printk("Warning: response too large, truncating\n");
} while (bytes != 0); // 0 means peer closed connection
recv_buf[off] = '\0';
printk("\nFull response:\n%s\n", recv_buf);
freeaddrinfo(res);
close(fd);
return 0;
clean_up:
if (res) freeaddrinfo(res);
if (fd >= 0) close(fd);
return -1;
int err;
int request_count = 0;
printk("HTTPS client sample started\n\r");
net_mgmt_init_event_callback(&l4_cb, l4_event_handler, L4_EVENT_MASK);
net_mgmt_add_event_callback(&l4_cb);
net_mgmt_init_event_callback(&conn_cb, connectivity_event_handler, CONN_LAYER_EVENT_MASK);
net_mgmt_add_event_callback(&conn_cb);
printk("Bringing network interface up\n");
if (conn_mgr_all_if_up(true)) return -1;
if (cert_provision()) return -1;
printk("Connecting to the network\n");
if (conn_mgr_all_if_connect(true)) return -1;
k_sem_take(&network_connected_sem, K_FOREVER);
while (1) {
request_count++;
printk("\n>>> Sending POST request #%d\n", request_count);
err = send_http_request(); // return 0 on success, <0 on fail
if (err < 0) {
printk("POST request #%d failed. Exiting loop.\n", request_count);
// k_sleep(K_MSEC(100)); // optional: short delay between requests
printk("Disconnecting network after %d requests\n", request_count);
k_sleep(K_SECONDS(1));
conn_mgr_all_if_disconnect(true);
conn_mgr_all_if_down(true);
return 0;
}prj.conf
# General CONFIG_HEAP_MEM_POOL_SIZE=4096 CONFIG_MAIN_STACK_SIZE=8192 # Logging CONFIG_LOG=y # Network CONFIG_NETWORKING=y CONFIG_NET_SOCKETS=y CONFIG_POSIX_API=y CONFIG_NET_IPV4=y CONFIG_NET_IPV6=y CONFIG_NET_CONNECTION_MANAGER=y CONFIG_NET_CONNECTION_MANAGER_MONITOR_STACK_SIZE=4600
