TLS Credential: cannot make Amazon root CA 2 and 4 to work
We are working on an NRF5340/NRF7002 based project with NCS 2.7.0 SDK.
We have been able to get Amazon Root CA 1 and 3 working with the following .conf:
# Wifi is nrf7002 based
CONFIG_WIFI=y
CONFIG_WIFI_NRF700X=y
CONFIG_NRF700X_P2P_MODE=n
CONFIG_NRF700X_MAX_TX_PENDING_QLEN=12
CONFIG_NRF_WIFI_IF_AUTO_START=n
CONFIG_NRF_WIFI_LOW_POWER=y
CONFIG_NRF_WIFI_RPU_RECOVERY=y
# WPA supplicant
CONFIG_WPA_SUPP=y
CONFIG_WPA_SUPP_CRYPTO_WEP=n
CONFIG_WPA_SUPP_NO_DEBUG=y
# Networking
CONFIG_NETWORKING=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NET_IPV4=y
CONFIG_NET_IPV6=y
CONFIG_NET_UDP=y
CONFIG_NET_TCP=y
CONFIG_NET_DHCPV4=y
CONFIG_NET_CONFIG_SETTINGS=n
# CONFIG_NET_CONFIG_INIT_TIMEOUT=0
# CONFIG_NET_CONFIG_AUTO_INIT=n
CONFIG_NET_NATIVE=y
CONFIG_DNS_RESOLVER=y
# Need 16 FDs for WiFi
CONFIG_POSIX_MAX_FDS=16
# Net Management
CONFIG_NET_L2_ETHERNET=y # This is mandatory even for WIFI
CONFIG_NET_L2_WIFI_MGMT=y
CONFIG_NET_MAX_CONTEXTS=4
CONFIG_NET_SOCKETS_OFFLOAD=n
// HTTP
CONFIG_HTTP_CLIENT=y
CONFIG_NET_TCP_KEEPALIVE=y
CONFIG_JSON_LIBRARY=y
CONFIG_BASE64=y
CONFIG_OHTTP_SIGNATURE=y
CONFIG_TINYCRYPT_SHA256_HMAC=y
#TLS
CONFIG_NET_SOCKETS_SOCKOPT_TLS=y
CONFIG_TLS_CREDENTIALS=y
CONFIG_MBEDTLS=y
CONFIG_MBEDTLS_RSA_C=y
CONFIG_MBEDTLS_SSL_SERVER_NAME_INDICATION=y
CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY=y
CONFIG_PSA_WANT_RSA_KEY_SIZE_2048=y
CONFIG_MBEDTLS_ENABLE_HEAP=y
CONFIG_MBEDTLS_HEAP_SIZE=61440
CONFIG_MBEDTLS_DEBUG=n
CONFIG_MBEDTLS_DEBUG_C=n
Now with this config when I replace Amazon Root CA 1 and 3 by the 2 and 4, I always get a -22 error on the socket opening.
The examples I found in the DevAcademy uses Amazon Root CA 1 and I did not found any document explaining how to make it work with certificate using "sha384WithRSAEncryption" like amazon root CA 2 and "ecdsa-with-SHA384" like Amazon root CA 4.
I have tried playing with different setting in the .conf with no success...
Is there any kConfig combination that is recommended, an example or a documentation that could help us with this issue ?
For information, credentials are added using "tls_credential_add", certificate are converted from .pem to const uint8_t * see attached files
 8244.certificates.h
  • Hi Charles
    I spoke to the developer today, and the main dependency for WIFI_DATA_HEAP_SIZE depends on the throughput requirements of your application, so can you share some details on what throughput numbers you need/would like to see in your application, and we can come back with some suggestions for HEAP_SIZE
  • Hi !
    I would say the maximum that we use for now is around 0.5 Mbps.
    We could make use of 1 Mbps in some case scenario.
    Could you give me suggestion for both of those value ?
    Thank you
  • Hi again
    Here's a suggested memory optimization overlay from our developers. For reference, setting the heap_size config to 25000 with this configuration should be sufficient for your requirement and cover up to 1Mbps throughput.
    Simon
    Thanks for the suggestion, however there must be some dependencies that I have missed to mention because anything less than 80000 on WIFI_DATA_HEAP_SIZE  does not work.
    When I say that I does not work, the device hang on boot, locked in "net_if_up" function, the function just never returns...
    Here is my wifi configuration overlay:
    CONFIG_WIFI=y
    CONFIG_WIFI_NRF70=y
    CONFIG_NRF70_AP_MODE=n
    CONFIG_NRF70_P2P_MODE=n
    CONFIG_NRF70_MAX_TX_PENDING_QLEN=12
    CONFIG_NRF70_QSPI_LOW_POWER=y
    CONFIG_WIFI_READY_LIB=y
    # WPA supplicant
    CONFIG_WIFI_NM_WPA_SUPPLICANT=y
    CONFIG_WIFI_NM_WPA_SUPPLICANT_WEP=n
    CONFIG_WIFI_NM_WPA_SUPPLICANT_NO_DEBUG=y
    # Memory
    # Must not be changed
    CONFIG_HEAP_MEM_POOL_SIZE=40144
    CONFIG_NRF_WIFI_CTRL_HEAP_SIZE=20000
    # This value can be changed depending on the wanted throughput of WiFi
    CONFIG_NRF_WIFI_DATA_HEAP_SIZE=89000
    # Networking
    CONFIG_NETWORKING=y
    CONFIG_POSIX_API=y
    CONFIG_NET_IPV4=y
    CONFIG_NET_UDP=y
    CONFIG_NET_TCP=y
    CONFIG_NET_DHCPV4=y
    CONFIG_NET_NATIVE=y
    CONFIG_POSIX_MAX_FDS=32
    CONFIG_NET_IPV6=y
    # Net Management
    CONFIG_NET_MGMT_EVENT=y
    CONFIG_NET_L2_ETHERNET_MGMT=y
    CONFIG_NET_MGMT_EVENT_QUEUE_TIMEOUT=5000
    Is there anything, that could cause this higher memory requirement ?
    Also, if I can boot up the device and make it communicate properly with 90000, will it still be the case after multiple net_if_up/net_if_down or if the network configuration changes ?
    Thank you for your help
    Have a nice day,
    Charles
