Hi all,
nrf54l15dk,v3.0.1,peripheral_uart demo and no changes have been made.
Then add the following content to prj.conf
sysbuild.conf
mcuboot.conf
Finally, use the OTA file under build to upgrade
Looking forward to your reply!
Hi all,
sysbuild.conf
mcuboot.conf
I only made changes to the red box section, I didn't make any changes to the rest
HI,
What is the solution? Have you tested it?
in V3.0.1 ,adding SB_CONFIG_BOOT_SIGNATURE_TYPE_RSA=y(or SB_CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=y) to sysbuild.conf resulted in normal running.
Is there any restriction on v3.0.1 in OTA?
I am checking internally whether there are any differences in the versions for OTA. Please expect a slight delay as it's the summer holidays here.
Could you try with the v2.9.0? Also, please note that in newer SDK (from v3.x.x) one needs to use Sysbuild, so maybe you had CONFIG_BOOT_SIGNATURE_TYPE_RSA in mcuboot.conf before and now in v3.0.1 since there is Sysbuild, SB_CONFIG_BOOT_SIGNATURE_TYPE_RSA is what helps.
Please do verify these in the meantime.
-Priyanka
