NCS v3.0.0 async SPI slave: How to get pin numbers from .overlay to C file for SPI slave configuration?
Working on the nRF52833DK board and based off the nrfx_spim_spis advanced non-blocking example sample.  I've already converted the SPI master to use the Zephyr driver instead of using the NRFX driver directly.  (My understanding is the NRFX driver is still used by the Zephyr SPI driver under the covers.)  Unfortunately I cannot convert the SPI slave to use the Zephyr driver because the Zephyr driver does not support asynchronous SPI slave, and I want the asynchronous feature.  So I'm stuck using the NRFX driver for SPI slave.
I'm trying to do things "properly" regarding Zephyr and the devicetree, so I want to define the pins in the .overlay file since I will eventually want this firmware to run on multiple boards (each defining their own pin configuration via a .overlay or the base .dts).  Thus I need the NRFX SPI slave driver to get the SPI slave pin configuration from the devicetree directly OR my C code needs a way to pull the pin settings from the devicetree.
Unfortunately, even though the nrfx_spim_spis advanced non-blocking example DOES define pins in the .overlay files, it does NOT actually use those in the C file.  Instead it pulls the pin definitions from common/nrfx_example.h via a series of "LOOPBACK_PIN_xxx" defines, which defeats the purpose of having a devicetree specify pin configurations.  (This would be an example of not doing things "properly" regarding Zephyr and NCS.)
My question is this:  For the NRFX SPI slave, using NCS v3.0.0 (or later if needed), how do I define the SPI slave pins in the .overlay so they can be used for NRFX SPI slave configuration in the C file?  And how do I access them in the C file?
Or an even shorter and more generic version of the question:  How do I define pin numbers in a .overlay and then get those pin numbers in a C file?
For reference, following the advanced non-blocking example I currently have the pins defined like this in the .overlay:
&pinctrl {
    spis_default: spis_default {
        group1 {
            psels = <NRF_PSEL(SPIS_SCK, 0, 29)>,
                    <NRF_PSEL(SPIS_MOSI, 0, 31)>,
                    <NRF_PSEL(SPIS_MISO, 0, 30)>,
                    <NRF_PSEL(SPIS_CSN, 0, 27)>;
    spis_sleep: spis_sleep {
        group1 {
            low-power-enable;
&spi2 {
    status = "okay";
    compatible = "nordic,nrf-spis";
    pinctrl-names = "default","sleep";
    pinctrl-0 = <&spis_default>;
    pinctrl-1 = <&spis_sleep>;
    def-char = <0xFF>;
Unfortunately there does not appear to be an easy way to get those values from the pinctrl into the C code.
  • Hi Andreas.  I'm afraid the replies have gone into the weeds on this one.  Ignoring anything about compatibility between SPIM and SPIS, I want to focus on the initial question:
    I've not found any other suggestions than that you'll have to manually sync the configurations between your overlay and the nrfx spi configuration in your c file as there are no API or macros for the nRFX driver to extract this from an overlay
    Suggestion 1 (same as https://devzone.nordicsemi.com/f/nordic-q-a/115516/using-nrfx-spis-in-nrf-connect-sdk?)
    An option could be to use the device driver to fetch the input from the devicetree and then use the populated device struct to define the
    nrf52840dk_nrf52840.overlay:
    &spi1 {
    // Keep the compatible property otherwise a compile error ('NRFX_SPIS1_INST_IDX' undeclared here) occurs.
    status = "disabled";
    And in prj.conf have CONFIG_NRFX_SPIS1=y
    and initialize nrfx_spis_init() as
        nrfx_spis_config_t spis_config = {
            .miso_pin     = 38,
            .mosi_pin     = 37,
            .sck_pin      = 36,
            .csn_pin      = 35,
            .mode         = NRF_SPIS_MODE_0,
            .bit_order    = NRF_SPIS_BIT_ORDER_LSB_FIRST,
            .csn_pullup   = NRF_GPIO_PIN_NOPULL,
            .miso_drive   = NRF_GPIO_PIN_S0S1,
            .def          = 0xFF,
            .orc          = 0xFF,
            .irq_priority = 6,
        nrfx_err_t err = nrfx_spis_init(&spis, &spis_config, &nrfx_spis_event_handler, NULL);
    This sugggestion has been confirmed to work, but it requires you to manually sync between overlay and the C file.
    Suggestion 2:
    The same as suggestion 1 with one modification (not confirmed to work, just me speculating based on the device.h and nrfx_spis driver)
    &spi1 {
    Add the pins that you need to add with or without using pin-control
    Populate the device struct using  'const struct device *const dev = DEVICE_DT_GET_ANY(spi1);'
    Initialize your SPI device with the nrfx_spis_init() by fetching the information generated by the device struct that fetched from the overlay either by extracting.
    Suggestion 3:
    Same as 2, but instead initialise nrfx_spis_init() with something like
    spi_nrfx_init()
        const struct spi_nrfx_config *dev_config = dev->config;
    err = gpio_pin_configure_dt(&dev_config->wake_gpio,
                            GPIO_INPUT |
                            GPIO_OUTPUT_HIGH |
                            GPIO_OPEN_DRAIN);
    etc
    However you spin it, there will be some modifications that you will have to do if you wish to use the nRFX driver this way together with the zephyr overlay methods. The nrfx spis driver does handle it this way, i.e it fetches the gpios that it will use based on the devicetree implementation, but there's more under the hood that goes on in the driver than simply "look up whats present in the overlay once and use that".
    Andreas
    Andreas
