BLE doesn't work.
Bluetooth connection cache processing - Nordic Q&A - Nordic DevZone - Nordic DevZone
Continuing from last time. After some optimization, the program was able to work. However, after verification, the program could only operate normally for a few hours and then failed to run properly. The phenomenon was manifested as: the USB-related connection was directly disconnected and could not be restored by itself.
After verification, I found that the main reason is that this issue is triggered when multiple connections are in progress simultaneously.
Here is my code.
An error indicates insufficient memory, but even though I set a larger memory, this error still occurs.
I modified some code to disable the previous BLE restart function, and at the same time, I turned off the CODED and 2M PHY switching functions.
Here is my log:
[15:41:36.081]收←◆*** Booting nRF Connect SDK v2.9.0-7787b2649840 ***
*** Using Zephyr OS v3.7.99-1f8f3dc29142 ***
[00:00:00.002,593] <inf> littlefs: LittleFS version 2.9, disk version 2.1
[00:00:00.002,868] <inf> littlefs: FS at w25q64jvs@0:0x0 is 256 0x1000-byte blocks with 512 cycle
[00:00:00.002,868] <inf> littlefs: sizes: rd 16 ; pr 16 ; ca 64 ; la 32
[USB]: status: 5.
[15:41:36.293]收←◆[USB]: status: 1.
[USB]: status: 6.
[USB]: status: 1.
[00:00:00.209,228] <inf> fs_nvs: 2 Sectors of 4096 bytes
[00:00:00.209,228] <inf> fs_nvs: alloc wra: 0, fd0
[00:00:00.209,259] <inf> fs_nvs: data wra: 0, 1c
[00:00:00.209,381] <inf> bt_sdc_hci_driver: SoftDevice Controller build revision:
                                            2d 79 a1 c8 6a 40 b7 3c  f6 74 f9 0b 22 d3 c4 80 |-y..j@.< .t.."...
                                            74 72 82 ba
[15:41:36.355]收←◆                       |tr..
[00:00:00.212,188] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.212,219] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
[00:00:00.212,249] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 45.41337 Build 3074452168
[00:00:00.212,707] <inf> bt_hci_core: No ID address. App must call settings_load()
[00:00:00.213,287] <inf> bt_hci_core: Identity: EF:E6:40:48:0B:0F (random)
[00:00:00.213,317] <inf> bt_hci_core: HCI: version 6.0 (0x0e) revision 0x106b, manufacturer 0x0059
[00:00:00.213,348] <inf> bt_hci_core: LMP: version 6.0 (0x0e) subver 0x106b
start scan.
[15:41:37.453]收←◆[USB]: status: 5.
[USB]: status: 1.
[USB]: status: 6.
[USB]: status: 1.
[00:00:00.545,562] <inf> usb_cdc_acm: Device configured
[15:41:40.293]收←◆scan stop.
start scan.
[15:41:43.297]收←◆scan stop.
start scan.
[15:41:46.303]收←◆scan stop.
start scan.
scan stop.
connect [6C], rssi: -63 phy: 1.
[15:41:47.555]收←◆connect [6C], ret: 1.
start scan.
scan stop.
connect [8F], rssi: -71 phy: 1.
[00:00:11.121,246] <wrn> bt_hci_core: opcode 0x2043 status 0x0d
[bt_conn_le_create]: ERROR -12.
connect [95], ret: 0.
start scan.
scan stop.
connect [46], rssi: -54 phy: 1.
[00:00:11.477,233] <wrn> bt_hci_core: opcode 0x2043 status 0x0d
start scan.
[15:41:48.257]收←◆scan stop.
connect [9C], rssi: -59 phy: 1.
[00:00:11.817,626] <wrn> bt_hci_core: opcode 0x2043 status 0x0d
start scan.
scan stop.
connect [3A], rssi: -67 phy: 1.
[00:00:12.179,290] <wrn> bt_hci_core: opcode 0x2043 status 0x0d
start scan.
8203.Downloads.zip
