BLE NRF52805 DFU bootloader can't jump to the app
Setup: SDK 17.1.0, SES 8.2, S112, custom buttonless uartless nrf52805 board, non-BLE test apps.
Objective: To enable robust wireless image download as next batch of boards will have debug interface removed. Security doesn't matter at all
Problem: I can't make secure bootloader to jump to app.
Description
I took BLE secure bootloader as a basis despite of extrta security steps which are not needed but hoping it would work out-of-the-box.
By following this guide, I have successfully built debug version of the bootloader. In addition, I have created a test app by slimming random number generator example so the app takes only 8k of flash. My custom application is also tiny. None of the apps require softdevice so the upgrade is only for the app itself.
The bootloader seems to be working as 'advertised' - DFU app (Android phone) works without any issues, bootloader RTT messages look just fine during upgrade, but nothing happens after that.
The initial DFU cycle log:
00> <info> app: Inside main
00>
00> <debug> app: In nrf_bootloader_init
00>
00> <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
00>
00> <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
00>
00> <warning> nrf_dfu_settings: Resetting bootloader settings since neither the settings page nor the backup are valid (CRC error).
00>
00> <debug> nrf_dfu_settings: Writing settings...
00>
00> <debug> nrf_dfu_settings: Erasing old settings at: 0x0002F000
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0002F000, len=1 pages), queue usage: 0
00>
00> <debug> nrf_dfu_flash: Flash erase success: addr=0x0002F000, pending 0
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F000, src=0x20003BA8, len=896 bytes), queue usage: 1
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002F000, pending 0
00>
00> <info> nrf_dfu_settings: Backing up settings page to address 0x2E000.
00>
00>
00> <debug> nrf_dfu_settings: Erasing old settings at: 0x0002E000
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0002E000, len=1 pages), queue usage: 1
00>
00> <debug> nrf_dfu_flash: Flash erase success: addr=0x0002E000, pending 0
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E000, src=0x20003828, len=896 bytes), queue usage: 1
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002E000, pending 0
00>
00> <debug> app: Enter nrf_bootloader_fw_activate
00>
00> <info> app: No firmware to activate.
00>
00> <info> app: Boot validation failed. No valid app to boot.
00>
00> <debug> app: DFU mode because app is not valid.
00>
00> <info> nrf_bootloader_wdt: WDT is not enabled
00>
00> <debug> app: in weak nrf_dfu_init_user
00>
00> <debug> app: timer_stop (0x200022E8)
00>
00> <debug> app: timer_activate (0x200022E8)
00>
00> <info> app: Entering DFU mode.
00>
00> <debug> app: Initializing transports (found: 1)
00>
00> <debug> nrf_dfu_ble: Initializing BLE DFU transport
00>
00> <debug> nrf_dfu_ble: Setting up vector table: 0x00022000
00>
00> <debug> nrf_dfu_ble: Enabling SoftDevice.
00>
00> <debug> nrf_dfu_ble: Configuring BLE stack.
00>
00> <debug> nrf_dfu_ble: Enabling the BLE stack.
00>
00> <debug> nrf_dfu_ble: No advertising name found
00>
00> <debug> nrf_dfu_ble: Using default advertising name
00>
00> <debug> nrf_dfu_ble: Advertising...
00>
00> <debug> nrf_dfu_ble: BLE DFU transport initialized.
00>
00> <debug> nrf_dfu_flash: Initializing nrf_fstorage_sd backend.
00>
00> <debug> app: Enter main loop
00>
00> <debug> nrf_dfu_ble: Connected
00>
00> <debug> nrf_dfu_ble: Received BLE_GAP_EVT_CONN_PARAM_UPDATE
00>
00> <debug> nrf_dfu_ble: max_conn_interval: 12
00>
00> <debug> nrf_dfu_ble: min_conn_interval: 12
00>
00> <debug> nrf_dfu_ble: slave_latency: 0
00>
00> <debug> nrf_dfu_ble: conn_sup_timeout: 600
00>
00>
00> <debug> nrf_dfu_ble: max_conn_interval: 6
00>
00> <debug> nrf_dfu_ble: min_conn_interval: 6
00>
00>
00> <debug> nrf_dfu_ble: conn_sup_timeout: 500
00>
00> <debug> nrf_dfu_ble: Received BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST (request: 517, reply: 247).
00>
00>
00>
00>
00>
00>
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (command)
00>
00> <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
00>
00> <debug> nrf_dfu_ble: Set receipt notif
00>
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_RECEIPT_NOTIF_SET
00>
00>
00> <debug> app: Shutting down transports (found: 1)
00>
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (command)
00>
00>
00>
00>
00> <debug> nrf_dfu_ble: Buffer 0x20002790 acquired, len 141 (244)
00>
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (command)
00>
00> <debug> nrf_dfu_ble: Freeing buffer 0x20002790
00>
00>
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (command)
00>
00>
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (command)
00>
00> <debug> nrf_dfu_validation: PB: Init packet data len: 64
00>
00> <info> nrf_dfu_validation: Signature required. Checking signature.
00>
00> <info> nrf_dfu_validation: Calculating hash (len: 64)
00>
00> <info> nrf_dfu_validation: Verify signature
00>
00>
00>
00>
00>
00>
00> <info> nrf_dfu_validation: Image verified
00>
00> <debug> app: Enter nrf_dfu_cache_prepare()
00>
00> <debug> app: required_size: 0x11BC.
00>
00> <debug> app: single_bank: false.
00>
00> <debug> app: keep_app: false.
00>
00> <debug> app: keep_softdevice: true.
00>
00> <debug> app: SD_PRESENT: true.
00>
00> <debug> app: Bank contents:
00>
00> <debug> app: Bank 0 code: 0x00: Size: 0x0
00>
00> <debug> app: Bank 1 code: 0x00: Size: 0x0
00>
00> <debug> app: pass: 0.
00>
00> <debug> app: cache_address: 0x19000.
00>
00> <debug> app: cache_too_small: false.
00>
00> <debug> app: keep_firmware: false.
00>
00> <debug> app: delete_more: false.
00>
00> <debug> nrf_dfu_validation: Write address set to 0x00019000
00>
00>
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0002F000, len=1 pages), queue usage: 1
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F000, src=0x20003BA8, len=896 bytes), queue usage: 2
00>
00>
00>
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0002E000, len=1 pages), queue usage: 3
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E000, src=0x20003828, len=896 bytes), queue usage: 4
00>
00> <debug> nrf_dfu_req_handler: Writing valid init command to flash.
00>
00>
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (data)
00>
00> <debug> nrf_dfu_req_handler: crc = 0x0, offset = 0x0, max_size = 0x1000
00>
00>
00> <debug> nrf_dfu_flash: Flash erase success: addr=0x0002F000, pending 4
00>
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (data)
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00019000, len=1 pages), queue usage: 4
00>
00> <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00000000, CRC: 0x00000000
00>
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002F000, pending 4
00>
00> <debug> nrf_dfu_flash: Flash erase success: addr=0x0002E000, pending 3
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002E000, pending 2
00>
00> <debug> nrf_dfu_flash: Flash erase success: addr=0x00019000, pending 1
00>
00> <debug> nrf_dfu_ble: Buffer 0x20002790 acquired, len 244 (244)
00>
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019000, src=0x20002790, len=244 bytes), queue usage: 1
00>
00>
00> <debug> nrf_dfu_ble: Buffer 0x20002884 acquired, len 244 (244)
00>
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000190F4, src=0x20002884, len=244 bytes), queue usage: 2
00>
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x00019000, pending 2
00>
00>
00>
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000191E8, src=0x20002790, len=244 bytes), queue usage: 2
00>
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x000190F4, pending 2
00>
00> <debug> nrf_dfu_ble: Freeing buffer 0x20002884
00>
00>
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000192DC, src=0x20002884, len=244 bytes), queue usage: 2
00>
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x000191E8, pending 2
00>
00>
00>
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000193D0, src=0x20002790, len=244 bytes), queue usage: 2
00>
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x000192DC, pending 2
00>
00>
00>
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000194C4, src=0x20002884, len=244 bytes), queue usage: 2
00>
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x000193D0, pending 2
00>
00>
00>
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000195B8, src=0x20002790, len=244 bytes), queue usage: 2
00>
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x000194C4, pending 2
00>
00>
00>
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000196AC, src=0x20002884, len=244 bytes), queue usage: 2
00>
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x000195B8, pending 2
00>
00>
00>
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000197A0, src=0x20002790, len=244 bytes), queue usage: 2
00>
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x000196AC, pending 2
00>
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x000197A0, pending 1
00>
00>
00>
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019894, src=0x20002790, len=244 bytes), queue usage: 1
00>
00>
00>
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019988, src=0x20002884, len=244 bytes), queue usage: 2
00>
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x00019894, pending 2
00>
00>
00>
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019A7C, src=0x20002790, len=244 bytes), queue usage: 2
00>
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x00019988, pending 2
00>
00>
00>
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019B70, src=0x20002884, len=244 bytes), queue usage: 2
00>
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x00019A7C, pending 2
00>
00>
00>
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019C64, src=0x20002790, len=244 bytes), queue usage: 2
00>
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x00019B70, pending 2
00>
00>
00>
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019D58, src=0x20002884, len=244 bytes), queue usage: 2
00>
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x00019C64, pending 2
00>
00>
00>
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019E4C, src=0x20002790, len=244 bytes), queue usage: 2
00>
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x00019D58, pending 2
00>
00>
00> <debug> nrf_dfu_ble: Buffer 0x20002884 acquired, len 192 (244)
00>
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019F40, src=0x20002884, len=192 bytes), queue usage: 2
00>
00>
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (data)
00>
00> <debug> nrf_dfu_req_handler: Offset:4096, CRC:0x87A77365
00>
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x00019E4C, pending 2
00>
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x00019F40, pending 1
00>
00>
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (data)
00>
00>
00>
00>
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0001A000, len=1 pages), queue usage: 1
00>
00> <debug> nrf_dfu_req_handler: Creating object with size: 444. Offset: 0x00001000, CRC: 0x87A77365
00>
00>
00> <debug> nrf_dfu_flash: Flash erase success: addr=0x0001A000, pending 1
00>
00>
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A000, src=0x20002884, len=244 bytes), queue usage: 1
00>
00>
00> <debug> nrf_dfu_ble: Buffer 0x20002790 acquired, len 200 (244)
00>
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A0F4, src=0x20002790, len=200 bytes), queue usage: 2
00>
00>
00>
00> <debug> nrf_dfu_req_handler: Offset:4540, CRC:0x75B42CCA
00>
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x0001A000, pending 2
00>
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x0001A0F4, pending 1
00>
00>
00>
00> <debug> nrf_dfu_req_handler: Whole firmware image received. Postvalidating.
00>
00> <debug> nrf_dfu_validation: Hash verification. start address: 0x19000, size: 0x11BC
00>
00> <debug> nrf_dfu_validation: Invalidating old application in bank 0.
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002F000, pending 3
00>
00> <debug> nrf_dfu_flash: Flash erase success: addr=0x0002E000, pending 2
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002E000, pending 1
00>
00> <debug> nrf_dfu_req_handler: All flash operations have completed. DFU completed.
00>
00>
00> <debug> nrf_dfu_ble: Shutting down BLE transport.
00>
00> <debug> nrf_dfu_ble: Disconnecting.
00>
00> <debug> nrf_dfu_ble: BLE transport shut down.
00>
00> <debug> app: Resetting bootloader.
00>
00>
00> <debug> nrf_dfu_settings: Destination settings are identical to source, wri<info> app: Inside main
00>
00>
00>
00>
00> <debug> nrf_dfu_settings: Using settings page.
00>
00> <debug> nrf_dfu_settings: Copying forbidden parts from backup page.
00>
00> <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
00>
00>
00>
00>
00> <debug> app: Valid App
00>
00> <debug> app: Enter nrf_dfu_app_continue
00>
00> <debug> app: No copy needed
00>
00> <debug> app: Setting app as valid
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00> <debug> app: App is valid
00>
00> <debug> nrf_dfu_settings_svci: Erasing settings page additional data.
00>
00>
00>
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0002E000, len=1 pages), queue usage: 0
00>
00>
00>
00>
00> <debug> app: Running nrf_bootloader_app_start with address: 0x00001000
00>
00> <debug> app: Disabling interrupts. NVIC->ICER[0]: 0x0
The output after reboot:
00>
00>
00>
00>
00>
00>
00>
00>
00> E000.
00>
00> 001000
If I generate bootloader setting and program them as well, the bootloader never starts DFU even on a blank (erased) chip with the same message as above.
Judging by the power consumption (about 2.5ma)  nrf52805 is stuck in some sort of waiting loop or similar.
I went through a gazillion of similar issues here on Devzone but, frankly, it didn't help much.
I am looking for some guidance here as I suspect it is something simple I have overlooked.
Questions that I have at the moment:
  1. Is there some bootloader/app integration guide? Or bootloader is smart enough to relocate off-the-shelf app to jump to?
  2. What NO_VTOR_CONFIG actually does? Just sets vector table? I presume Softdevce sets vector table so both bootloader and app should be compiled with NO_VTOR_CONFIG?
  3. What app version 0xff means? Ignore?
Thanks in advance.
