MQTT simple example code (api based)
Hi Team,
We are using nRF9160 MQTT sample code 'mqtt_simple'.
1. What is the maximum payload we can send in one single PUBLISH?
2. I want to send 4KB of data in single PUBLISH, is this possible? if not, what is the way to send 4KB in single PUBLISH?
3. Is the nRF9160 supports secure boot?
4. Is the nRF9160 has boot ROM? If yes, is this boot ROM available for us to add some piece of code in the boot ROM?
Sravan Rikka
  • Hi Dejan,
    Thank you for the support to resolving float value issue.
    I have added CONFIG_NEWLIB_LIBC_FLOAT_PRINTF=y in the .prj as you suggested, now I can see the float values in the buffer.
    Queries:
    1. I am connecting to the network only at power ON and making continuous calls for every 30min to the MQTT broker successfully. Now I am implementing that connect to the network and publish the data then disconnect from the network for every call. Hence, I have implemented socket close as below and got response as 'ret=0' for "ret = zsock_close(socketfd);"  but when I connect to the network again for the second call getting error as "mqtt_simple: Failed to establish LTE connection: -120". (#define EALREADY 120 /* Socket already connected */).
    Can you suggest, how to resolve this issue.
    function()
    err = mqtt_disconnect(&client);
    k_sleep(K_MSEC(2000u));
    printk("mqtt_disconnect:%d\n", err);
    current_state = STATE_EXIT;
    k_sleep(K_MSEC(200u));
    close_socket();
    void close_socket(void)
    int err;
    int socketfd = 0;
    int ret;
    socketfd = zsock_socket(AF_INET6, SOCK_STREAM, IPPROTO_TCP);
    printk("zsock_close:%d\r\n", ret);
    err = at_cmd_write(AT_CFUN_OFF_RADIO_CMD, NULL, 0, NULL);
    k_sleep(K_MSEC(20u));
    if(err < 0)
    printk("Failed AT_CFUN_OFF_RADIO_CMD\r\n");
    printk("Success AT_CFUN_OFF_RADIO_CMD\r\n");
    Sravan Rikka
    Can you share complete log that shows the error ""mqtt_simple: Failed to establish LTE connection: -120". (#define EALREADY 120 /* Socket already connected */)."?
    Dejan
  • <\0>*** Booting Zephyr OS build v2.6.99-ncs1  ***<\r><\n>
    Flash regions<9><9>Domain<9><9>Permissions<\r><\n>
    00 01 0x00000 0x10000 <9>Secure<9><9>rwxl<\r><\n>
    02 31 0x10000 0x100000 <9>Non-Secure<9>rwxl<\r><\n>
    <\r><\n>
    Non-secure callable region 0 placed in flash region 1 with size 32.<\r><\n>
    <\r><\n>
    SRAM region<9><9>Domain<9><9>Permissions<\r><\n>
    00 07 0x00000 0x10000 <9>Secure<9><9>rwxl<\r><\n>
    08 31 0x10000 0x40000 <9>Non-Secure<9>rwxl<\r><\n>
    <\r><\n>
    Peripheral<9><9>Domain<9><9>Status<\r><\n>
    00 NRF_P0               Non-Secure<9>OK<\r><\n>
    01 NRF_CLOCK            Non-Secure<9>OK<\r><\n>
    02 NRF_RTC0             Non-Secure<9>OK<\r><\n>
    03 NRF_RTC1             Non-Secure<9>OK<\r><\n>
    04 NRF_NVMC             Non-Secure<9>OK<\r><\n>
    05 NRF_UARTE1           Non-Secure<9>OK<\r><\n>
    06 NRF_UARTE2           Secure<9><9>SKIP<\r><\n>
    07 NRF_TWIM2            Non-Secure<9>OK<\r><\n>
    08 NRF_SPIM3            Non-Secure<9>OK<\r><\n>
    09 NRF_TIMER0           Non-Secure<9>OK<\r><\n>
    10 NRF_TIMER1           Non-Secure<9>OK<\r><\n>
    11 NRF_TIMER2           Non-Secure<9>OK<\r><\n>
    12 NRF_SAADC            Non-Secure<9>OK<\r><\n>
    13 NRF_PWM0             Non-Secure<9>OK<\r><\n>
    14 NRF_PWM1             Non-Secure<9>OK<\r><\n>
    15 NRF_PWM2             Non-Secure<9>OK<\r><\n>
    16 NRF_PWM3             Non-Secure<9>OK<\r><\n>
    17 NRF_WDT              Non-Secure<9>OK<\r><\n>
    18 NRF_IPC              Non-Secure<9>OK<\r><\n>
    19 NRF_VMC              Non-Secure<9>OK<\r><\n>
    20 NRF_FPU              Non-Secure<9>OK<\r><\n>
    21 NRF_EGU1             Non-Secure<9>OK<\r><\n>
    22 NRF_EGU2             Non-Secure<9>OK<\r><\n>
    23 NRF_DPPIC            Non-Secure<9>OK<\r><\n>
    24 NRF_REGULATORS       Non-Secure<9>OK<\r><\n>
    25 NRF_PDM              Non-Secure<9>OK<\r><\n>
    26 NRF_I2S              Non-Secure<9>OK<\r><\n>
    27 NRF_GPIOTE1          Non-Secure<9>OK<\r><\n>
    <\r><\n>
    SPM: NS image at 0x10000<\r><\n>
    SPM: NS MSP at 0x2001df40<\r><\n>
    SPM: NS reset vector at 0x1528d<\r><\n>
    SPM: prepare to jump to Non-Secure image.<\r><\n>
    uart init<\r><\n>
    UART RX buffer request<\r><\n>
    UART2 initialized with baud rate 115200<\r><\n>
    UART RX ready<\r><\n>
    UART RX buffer released<\r><\n>
    DATA_CMD<\r><\n>
    ALARM_CMD<\r><\n>
    RSL10 data received<\r><\n>
    state machine start<\r><\n>
    STATE_NETWORK_REGISTRATION<\r><\n>
    Success AT_CFUN_READ_CMD before write: +CFUN: 0<\r><\r><\n>
    <\r><\r><\n>
    Success AT_CFUN_OFF_CMD<\r><\r><\n>
    Success AT_CFUN_READ_CMD after write: +CFUN: 4<\r><\r><\n>
    <\r><\r><\n>
    Success AT_CGDCONT_READ_CMD before write: <\r><\r><\n>
    successfully set APN using AT_CGDCONT_WRITE_CMD<\r><\r><\n>
    Success AT_CGDCONT_READ_CMD after write: +CGDCONT: 0,"IPV6","AIRTELMETERV6","",0,0<\r><\r><\n>
    <\r><\r><\n>
    HVPP ----- connecting to network...<\r><\n>
    [00:02:14.131,866] <27>[0m<inf> mqtt_simple: Disabling PSM and eDRX<27>[0m<\r><\n>
    [00:02:14.138,946] <27>[0m<inf> mqtt_simple: LTE Link Connecting...<27>[0m<\r><\n>
    +CEREG: 2,"2B67","0DCC6751",9<\r><\n>
    +CSCON: 1<\r><\n>
    +CEREG: 1,"2B67","0DCC6751",9,,,"11100000","11100000"<\r><\n>
    HVPP ----- connected to network...<\r><\n>
    [00:02:20.484,954] <27>[0m<inf> mqtt_simple: LTE Link Connected!<27>[0m<\r><\n>
    STATE_INIT<\r><\n>
    username size1=5, password size1=36, username size2=5, password size1=36<\r><\n>
    ai_family = 2<\r><\n>
    IP_type = 1<\r><\n>
    MQTT_hostname = mqtt.tago.io<\r><\n>
    MQTT_username = token<\r><\n>
    MQTT_password = a8c46146-622d-46e7-8b3b-a244bca88648<\r><\n>
    MQTT_portnumber = 0<\r><\n>
    MQTT_topic = devices/HON_HVPP_5G_0001/events<\r><\n>
    broker_portnumber = 1883<\r><\n>
    Client initialized successfully.<\r><\n>
    STATE_CONNECT<\r><\n>
    Connecting to MQTT broker...<\r><\n>
    ----- connected to MQTT broker --- client connect ...<\r><\n>
    ----- connected to MQTT broker...<\r><\n>
    ----- fds_init pass .....<\r><\n>
    STATE_WAIT<\r><\n>
    Waiting...<\r><\n>
    mqtt_evt_handler executedstate machine start<\r><\n>
    STATE_SEND_PERIODIC_DATA<\r><\n>
    Sending data to MQTT broker...<\r><\n>
    data_publish size = len1:553, len2:536974336data_publish:{"deviceId":"HVPP100A0000C7","deviceType":"HVPP","eventTime":946684933,"eventType":"SensorData","eventData":{"batteryLevel":{"value":90,"uom":"%"},"ambientTemperature":{"value":0.000000,"uom":"DegC"},"humidity":{"value":0.000000,"uom":"%RH"},"ambientPressure":{"value":335.000000,"uom":"hPa"},"processTemperature":{"value":0.000000,"uom":"DegC"},"processPressureAbsolute":{"value":0.000000,"uom":"Bar"},"processPressureGauge":{"value":0.000000,"uom":"Bar"},"processLevel":{"value":508.979156,"uom":"cm"},"processVolume":{"value":1017.958313,"uom":"L"}}}[00:02:31.597,534] <27>[0m<inf> mqtt_simple: IPv6 Address found 2600:1f10:4526:8003:ea3c:5d6c:ccbd:3940<27>[0m<\r><\n>
    [00:02:31.597,595] <27>[0m<dbg> mqtt_simple.client_id_get: client_id = hvpp_hon1<27>[0m<\r><\n>
    [00:02:32.549,499] <27>[0m<inf> mqtt_simple: MQTT client connected<27>[0m<\r><\n>
    [00:02:32.549,530] <27>[0m<inf> mqtt_simple: Subscribing to: my/subscribe/topic len 18<27>[0m<\r><\n>
    [00:02:32.559,387] <27>[0m<inf> mqtt_simple: Publishing: {"deviceId":"HVPP100A0000C7","deviceType":"HV~<27>[0m<\r><\n>
    [00:02:32.559,417] <27>[0m<inf> mqtt_simple: to topic: devices/HON_HVPP_5G_0001/events len: 31<27>[0m<\r><\n>
    [00:02:32.659,210] <27>[1;31m<err> log: argument 0 in source mqtt_simple log message "to topic: %s len: %u" missinglog_strdup().<27>[0m<\r><\n>
    STATE_SEND_ALARM_DATA<\r><\n>
    data_publish size = len1:536970239, len2:687data_publish:{"deviceId":"HVPP100A0000C7","deviceType":"HVPP","eventTime":946684934,"eventType":"AlarmData","eventData":{"ambientTemperatureAlarm": {"low":0,"high":1,"value":25.600000,"uom":"DegC"},"humidityAlarm":{"low":0,"high":0,"value":0.000000,"uom":"%RH"},"ambientPressureAlarm":{"low":1,"high":0,"value":906.500000,"uom":"hPa"},"processTemperatureAlarm":{"low":0,"high":0,"value":0.000000,"uom":"DegC"},"processPressureAbsoluteAlarm":{"low":0,"high":0,"value":0.000000,"uom":"Bar"},"processPressureGaugeAlarm":{"low":0,"high":0,"value":0.000000,"uom":"Bar"},"processLevelAlarm":{"low":0,"high":0,"value":0.000000,"uom":"cm"},"processVolumeAlarm":{"low":0,"high":0,"value":0.000000,"uom":"L"}}}[00:02:42.625,885] <27>[0m<inf> mqtt_simple: Publishing: {"deviceId":"HVPP100A0000C7","deviceType":"HV~<27>[0m<\r><\n>
    [00:02:42.625,915] <27>[0m<inf> mqtt_simple: to topic: devices/HON_HVPP_5G_0001/events len: 31<27>[0m<\r><\n>
    [00:02:43.635,711] <27>[1;31m<err> log: argument 0 in source mqtt_simple log message "to topic: %s len: %u" missinglog_strdup().<27>[0m<\r><\n>
    STATE_DONE ---- MQTT operation completed<\r><\n>
    mqtt_evt_handler executed[00:02:52.706,115] <27>[0m<inf> mqtt_simple: MQTT client disconnected: 0<27>[0m<\r><\n>
    mqtt_disconnect:0<\r><\n>
    Success AT_CGDCONT_READ_CMD Azure Done: +CGDCONT: 0,"IPV6","airtelmeterv6","2401:4900:9829:A7A8:0000:0000:0000:0002",0,0<\r><\r><\n>
    <\r><\r><\n>
    zsock_close:0<\r><\r><\n>
    +CEREG: 0<\r><\n>
    +CSCON: 0<\r><\n>
    Success AT_CFUN_OFF_RADIO_CMD<\r><\r><\n>
    DATA_CMD<\r><\n>
    ALARM_CMD<\r><\n>
    <\r><\r><\n>
    <\r><\r><\n>
    <\r><\r><\n>
    [00:04:14.120,361] <27>[0m<inf> mqtt_simple: Disabling PSM and eDRX<27>[0m<\r><\n>
    [00:04:14.127,441] <27>[0m<inf> mqtt_simple: LTE Link Connecting...<27>[0m<\r><\n>
    [00:04:14.127,441] <27>[0m<inf> mqtt_simple: Failed to establish LTE connection: -120<27>[0m<\r><\n>
    Retrying Network Regstartion..... (2 retries left)<\r><\n>
    [00:04:19.135,742] <27>[0m<inf> mqtt_simple: Disabling PSM and eDRX<27>[0m<\r><\n>
    [00:04:19.145,080] <27>[0m<inf> mqtt_simple: LTE Link Connecting...<27>[0m<\r><\n>
    [00:04:19.145,080] <27>[0m<inf> mqtt_simple: Failed to establish LTE connection: -120<27>[0m<\r><\n>
    Retrying Network Regstartion..... (1 retries left)<\r><\n>
    [00:04:24.153,411] <27>[0m<inf> mqtt_simple: Disabling PSM and eDRX<27>[0m<\r><\n>
    [00:04:24.162,719] <27>[0m<inf> mqtt_simple: LTE Link Connecting...<27>[0m<\r><\n>
    [00:04:24.162,719] <27>[0m<inf> mqtt_simple: Failed to establish LTE connection: -120<27>[0m<\r><\n>
    Retrying Network Regstartion..... (0 retries left)<\r><\n>
    STATE_ERROR<\r><\n>
    Error occurred in Azure IoT Hub operation<\r><\n>
    mqtt_disconnect:-128<\r><\n>
    Success AT_CGDCONT_READ_CMD Azure Done: +CGDCONT: 0,"IPV6","AIRTELMETERV6","",0,0<\r><\r><\n>
    <\r><\r><\n>
    Hi Dejan,
    Please check the attached log.
    Sravan Rikka
    There is a limitation on a number of connection requests. It could be that you are exceeding number of connection attempts per hour. You can get more information in this discussion.
    Dejan
  • Hi Dejan,
    I am not making two many calls in an hour, I am making call for every 30minutes, 1st call is successful but second call is not connecting to network. Please suggest how can I resolve this issue.
    Sravan Rikka
