Channel Sounding with nRF54L15 – Poor Accuracy Compared to Nordic's Demo
Hi Nordic team,
I'm currently working on a real-time distance measurement project using channel sounding with the nRF54L15 DKs. I’ve been using the channel_sounding_ras_initiator and channel_sounding_ras_reflector samples from your official GitHub repository, and I’ve managed to get the system running successfully.
However, the performance I’m getting in terms of distance accuracy and responsiveness is noticeably worse than what’s shown in your YouTube demo (https://www.youtube.com/watch?v=dbQKqXN80ms). In your video, the distance tracking appears smooth and accurate, even when the devices are in motion.
In my case, the measurements are much more noisy, and there’s a significant delay (sometimes several seconds) between physical movement and updated distance readings. I’ve only made minor modifications to the sample code—such as increasing buffer sizes and applying a median filter to reduce noise.
My questions are:
  1. Is the code used in the YouTube demo exactly the same as the channel_sounding_ras_initiator and channel_sounding_ras_reflector samples, or was it modified for the demo?
  2. Are there specific hardware requirements or environmental conditions (e.g., antenna placement, orientation, shielding) that are crucial for achieving the best performance?
  3. Is any calibration or parameter tuning needed beyond what is included in the sample projects?
I’d really appreciate any tips or insights on how to get results closer to what you demonstrate in the video.
Thanks in advance,
Ibai
  • The distance estimation accuracy will be impacted by the change in environment so moving it will move it through different environments and distance estimation will this be impacted.
    Without actual numbers it is impossible to comment if what you see is inside expectations or not.
  • Hello I have the same Problem. I am using the nrf54l15dk Board and the 3.0.2 SDK with the given samples. Just looking at the ifft measurment the distance is measured very inaccurate. If I have 20cm between my devices (facing each other) with no movement the measurement jumps around between 38 and 65 cm. So for me this is very inaccurate. Can I improve this in any way?
    I would be glad if you could help me to get as good accuracy as in your demo.
