Try to build peripheral-uart example for nrf54L15-DK without west
Hello at all,
I try to compile the example peripheral_uart for the nrf54L15-DK. The goal is
to compile without west.
My directory structure:
example3
+---boards
+---build
+---modules
+---nrf
+---nrfxlib
+---src
+---zephyr
where I copied everything from the ncs 3.0.2 install. The files below src and the files in the exmaple3 main directory are taken from the  samples/bluetooth/peripheral_uart, to be modified later and evolve towards the application I want to write. This idea comes from here:
devzone.nordicsemi.com/.../building-a-minimal-nordic-connect-sdk-without-west-this-is-not-a-question
The CMakeLists has the following content:
cmake_minimum_required(VERSION 3.20.0)
set(BOARD nrf54l15dk/nrf54l15/cpuapp)
set(ZEPHYR_BASE ${CMAKE_CURRENT_LIST_DIR}/zephyr)
set(CMAKE_EXPORT_COMPILE_COMMANDS ON)
set(CONF_FILE ${CMAKE_CURRENT_LIST_DIR}/prj_minimal.conf)
find_package(Zephyr REQUIRED HINTS ${ZEPHYR_BASE})
project(my_example)
target_sources(app PRIVATE
  src/main.c
I exported the env variables
export ZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb
export GNUARMEMB_TOOLCHAIN_PATH=/usr/local/arm-gnu-toolchain-12.2.mpacbti-rel1-x86_64-arm-none-eabi
Inside the build directory, I call cmake and get the output:
Loading Zephyr default modules (Zephyr base (cached)).
-- Application: /home/dirk/projekte/mcuports/nrf54/example3
-- CMake version: 3.25.1
-- Found Python3: /home/dirk/.local/venv/bin/python (found suitable version "3.11.2", minimum required is "3.10") found components: Interpreter
-- Cache files will be written to: /home/dirk/.cache/zephyr
-- Zephyr version: 4.0.99 (/home/dirk/projekte/mcuports/nrf54/example3/zephyr)
-- Board: nrf54l15dk, qualifiers: nrf54l15/cpuapp
-- Found toolchain: gnuarmemb (/usr/local/arm-gnu-toolchain-12.2.mpacbti-rel1-x86_64-arm-none-eabi)
-- Found Dtc: /usr/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
-- Found BOARD.dts: /home/dirk/projekte/mcuports/nrf54/example3/zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l15_cpuapp.dts
-- Found devicetree overlay: /home/dirk/projekte/mcuports/nrf54/example3/boards/nrf54l15dk_nrf54l15_cpuapp.overlay
-- Generated zephyr.dts: /home/dirk/projekte/mcuports/nrf54/example3/build/zephyr/zephyr.dts
-- Generated pickled edt: /home/dirk/projekte/mcuports/nrf54/example3/build/zephyr/edt.pickle
-- Generated devicetree_generated.h: /home/dirk/projekte/mcuports/nrf54/example3/build/zephyr/include/generated/zephyr/devicetree_generated.h
-- Including generated dts.cmake file: /home/dirk/projekte/mcuports/nrf54/example3/build/zephyr/dts.cmake
warning: SPI (defined at soc/nxp/kinetis/k6x/Kconfig.defconfig:19,
soc/nxp/kinetis/kwx/Kconfig.defconfig:12, soc/gaisler/gr716a/Kconfig.defconfig:17,
drivers/spi/Kconfig:9) was assigned the value 'n' but got the value 'y'. See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_SPI and/or look up SPI in the
menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values,
and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
warning: NRFX_UARTE0 (defined at modules/hal_nordic/nrfx/Kconfig:1033,
drivers/serial/Kconfig.nrfx_uart_instance:32) was assigned the value 'y' but got the value 'n'.
Check these unsatisfied dependencies: (HAS_HW_NRF_UART0 || HAS_HW_NRF_UARTE0) (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_NRFX_UARTE0 and/or look up NRFX_UARTE0 in
the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration
Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
warning: THREAD_STACK_INFO (defined at kernel/Kconfig:189) was assigned the value 'n' but got the
value 'y'. See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_THREAD_STACK_INFO and/or
look up THREAD_STACK_INFO in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
/home/dirk/projekte/mcuports/nrf54/example3/prj_minimal.conf:22: warning: attempt to assign the value 'y' to the undefined symbol BT_NUS
/home/dirk/projekte/mcuports/nrf54/example3/prj_minimal.conf:31: warning: attempt to assign the value 'y' to the undefined symbol DK_LIBRARY
/home/dirk/projekte/mcuports/nrf54/example3/prj_minimal.conf:51: warning: attempt to assign the value 'n' to the undefined symbol NCS_BOOT_BANNER
/home/dirk/projekte/mcuports/nrf54/example3/prj_minimal.conf:94: warning: attempt to assign the value '256' to the undefined symbol MPSL_WORK_STACK_SIZE
warning: HAS_NORDIC_DRIVERS (defined at modules/hal_nordic/Kconfig:7) has direct dependencies 0 with value n, but is currently being y-selected by the following symbols:
 - SOC_SERIES_NRF54LX (defined at soc/nordic/Kconfig.soc:48, soc/nordic/nrf54l/Kconfig:6), with value y, direct dependencies y (value: y), and select condition SOC_FAMILY_NORDIC_NRF (value: y)
warning: MBEDTLS (defined at modules/mbedtls/Kconfig:19) has direct dependencies 0 with value n, but is currently being y-selected by the following symbols:
 - BT_HOST_CRYPTO (defined at subsys/bluetooth/host/Kconfig:172), with value y, direct dependencies BT_HCI_HOST && BT_HCI && BT (value: y), and select condition !BUILD_WITH_TFM && BT_HCI_HOST && BT_HCI && BT (value: y)
 - BT_ECC (defined at subsys/bluetooth/host/Kconfig:999), with value y, direct dependencies BT_HCI_HOST && BT_HCI && BT (value: y), and select condition !BUILD_WITH_TFM && BT_HCI_HOST && BT_HCI && BT (value: y)
 - BT_CRYPTO (defined at subsys/bluetooth/crypto/Kconfig:4), with value y, direct dependencies BT_HCI && BT (value: y), and select condition !BUILD_WITH_TFM && BT_HCI && BT (value: y)
warning: HAS_CMSIS_CORE (defined at modules/cmsis/Kconfig:7) has direct dependencies 0 with value n, but is currently being y-selected by the following symbols:
 - CPU_CORTEX_M (defined at arch/arm/core/Kconfig:6), with value y, direct dependencies ARM (value: y), and select condition ARM (value: y)
warning: CMSIS_CORE_HAS_SYSTEM_CORE_CLOCK (defined at soc/nxp/imxrt/imxrt6xx/Kconfig.defconfig:8, modules/cmsis/Kconfig:31) has direct dependencies (SOC_SERIES_IMXRT6XX && SOC_FAMILY_NXP_IMXRT) || (HAS_CMSIS_CORE && 0) with value n, but is currently being y-selected by the following symbols:
 - SOC_FAMILY_NORDIC_NRF (defined at soc/nordic/Kconfig.soc:19, soc/nordic/Kconfig:9), with value y, direct dependencies y (value: y), and select condition ARM (value: y)
warning: HAS_NRFX (defined at modules/hal_nordic/nrfx/Kconfig:4) has direct dependencies 0 with value n, but is currently being y-selected by the following symbols:
warning: MBEDTLS_PSA_CRYPTO_C (defined at modules/mbedtls/Kconfig.tls-generic:601) has direct dependencies !BUILD_WITH_TFM && MBEDTLS_BUILTIN && MBEDTLS_CFG_FILE = "config-tls-generic.h" && MBEDTLS && 0 with value n, but is currently being y-selected by the following symbols:
warning: NRFX_CLOCK (defined at modules/hal_nordic/nrfx/Kconfig:16) has direct dependencies HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols:
 - CLOCK_CONTROL_NRF (defined at drivers/clock_control/Kconfig.nrf:13), with value y, direct dependencies DT_HAS_NORDIC_NRF_CLOCK_ENABLED && CLOCK_CONTROL (value: y), and select condition !CLOCK_CONTROL_NRF_FORCE_ALT && DT_HAS_NORDIC_NRF_CLOCK_ENABLED && CLOCK_CONTROL (value: y)
warning: NRFX_GRTC (defined at modules/hal_nordic/nrfx/Kconfig:215) has direct dependencies HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols:
 - NRF_GRTC_TIMER (defined at drivers/timer/Kconfig.nrf_grtc:4), with value y, direct dependencies DT_HAS_NORDIC_NRF_GRTC_ENABLED && SYS_CLOCK_EXISTS (value: y), and select condition DT_HAS_NORDIC_NRF_GRTC_ENABLED && SYS_CLOCK_EXISTS (value: y)
warning: NRFX_SPIM00 (defined at modules/hal_nordic/nrfx/Kconfig:517) has direct dependencies HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols:
 - SPI_NRFX_SPIM (defined at drivers/spi/Kconfig.nrfx:22), with value y, direct dependencies DT_HAS_NORDIC_NRF_SPIM_ENABLED && SPI_NRFX && SPI (value: y), and select condition HAS_HW_NRF_SPIM00 && DT_HAS_NORDIC_NRF_SPIM_ENABLED && SPI_NRFX && SPI (value: y)
warning: NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED (defined at modules/hal_nordic/nrfx/Kconfig:20) has direct dependencies NRFX_CLOCK && HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols:
 - CLOCK_CONTROL_NRF_K32SRC_XTAL (defined at drivers/clock_control/Kconfig.nrf:36), with value y, direct dependencies <choice CLOCK_CONTROL_NRF_SOURCE> (value: y), and select condition !SOC_SERIES_BSIM_NRFXX && !CLOCK_CONTROL_NRF_FORCE_ALT && <choice CLOCK_CONTROL_NRF_SOURCE> (value: y)
warning: NRFX_RRAMC (defined at modules/hal_nordic/nrfx/Kconfig:435) has direct dependencies HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols:
 - SOC_FLASH_NRF_RRAM (defined at drivers/flash/Kconfig.nrf_rram:7), with value y, direct dependencies DT_HAS_NORDIC_RRAM_CONTROLLER_ENABLED && FLASH (value: y), and select condition !BUILD_WITH_TFM && DT_HAS_NORDIC_RRAM_CONTROLLER_ENABLED && FLASH (value: y)
warning: PSA_WANT_ALG_CMAC (defined at modules/mbedtls/Kconfig.psa.auto:35) has direct dependencies PSA_CRYPTO_CLIENT && 0 with value n, but is currently being y-selected by the following symbols:
 - BT_CRYPTO (defined at subsys/bluetooth/crypto/Kconfig:4), with value y, direct dependencies BT_HCI && BT (value: y), and select condition BT_HCI && BT (value: y)
warning: PSA_WANT_ALG_ECB_NO_PADDING (defined at modules/mbedtls/Kconfig.psa.auto:51) has direct dependencies PSA_CRYPTO_CLIENT && 0 with value n, but is currently being y-selected by the following symbols:
 - BT_HOST_CRYPTO (defined at subsys/bluetooth/host/Kconfig:172), with value y, direct dependencies BT_HCI_HOST && BT_HCI && BT (value: y), and select condition BT_HCI_HOST && BT_HCI && BT (value: y)
warning: PSA_WANT_ALG_ECDH (defined at modules/mbedtls/Kconfig.psa.auto:55) has direct dependencies PSA_CRYPTO_CLIENT && 0 with value n, but is currently being y-selected by the following symbols:
 - BT_ECC (defined at subsys/bluetooth/host/Kconfig:999), with value y, direct dependencies BT_HCI_HOST && BT_HCI && BT (value: y), and select condition BT_HCI_HOST && BT_HCI && BT (value: y)
warning: PSA_WANT_ALG_HMAC (defined at modules/mbedtls/Kconfig.psa.auto:84) has direct dependencies PSA_CRYPTO_CLIENT && 0 with value n, but is currently being y-selected by the following symbols:
 - BT_HOST_CRYPTO_PRNG (defined at subsys/bluetooth/host/Kconfig:183), with value y, direct dependencies BT_HOST_CRYPTO && BT_HCI_HOST && BT_HCI && BT (value: y), and select condition BT_HOST_CRYPTO && BT_HCI_HOST && BT_HCI && BT (value: y)
warning: PSA_WANT_ALG_SHA_256 (defined at modules/mbedtls/Kconfig.psa.auto:132) has direct dependencies PSA_CRYPTO_CLIENT && 0 with value n, but is currently being y-selected by the following symbols:
warning: PSA_WANT_ECC_SECP_R1_256 (defined at modules/mbedtls/Kconfig.psa.auto:216) has direct dependencies PSA_CRYPTO_CLIENT && 0 with value n, but is currently being y-selected by the following symbols:
warning: PSA_WANT_KEY_TYPE_HMAC (defined at modules/mbedtls/Kconfig.psa.auto:240) has direct dependencies PSA_CRYPTO_CLIENT && 0 with value n, but is currently being y-selected by the following symbols:
warning: PSA_WANT_KEY_TYPE_AES (defined at modules/mbedtls/Kconfig.psa.auto:244) has direct dependencies PSA_CRYPTO_CLIENT && 0 with value n, but is currently being y-selected by the following symbols:
warning: PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT (defined at modules/mbedtls/Kconfig.psa.auto:266) has direct dependencies PSA_CRYPTO_CLIENT && 0 with value n, but is currently being y-selected by the following symbols:
warning: PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT (defined at modules/mbedtls/Kconfig.psa.auto:271) has direct dependencies PSA_CRYPTO_CLIENT && 0 with value n, but is currently being y-selected by the following symbols:
warning: PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE (defined at modules/mbedtls/Kconfig.psa.auto:276) has direct dependencies PSA_CRYPTO_CLIENT && 0 with value n, but is currently being y-selected by the following symbols:
Parsing /home/dirk/projekte/mcuports/nrf54/example3/Kconfig
Loaded configuration '/home/dirk/projekte/mcuports/nrf54/example3/zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l15_cpuapp_defconfig'
Merged configuration '/home/dirk/projekte/mcuports/nrf54/example3/prj_minimal.conf'
error: Aborting due to Kconfig warnings
CMake Error at zephyr/cmake/modules/kconfig.cmake:396 (message):
  command failed with return code: 1
  nrf/cmake/modules/kconfig.cmake:36 (include)
  zephyr/cmake/modules/zephyr_default.cmake:133 (include)
  zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
  zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:97 (include_boilerplate)
  CMakeLists.txt:21 (find_package)
Looking at the first problems (SPI and NRFX_UARTE0), it looks like the board selection and the project configuration is not propagated through the zephyr scripts in the correct way.
I know that there should be -DZEPHYR_MODULES=module1;module2; in some cases,
but is this the case here and which modules?
I assume the following problems have the same root cause.
Dirk.
