We have a working firmware that uses LTE-M for network connectivity to connect to NRF Cloud. But upon testing with NB-IoT configuration (CONFIG_LTE_NETWORK_MODE_NBIOT_GPS=y), we are getting error -111. See logs below.
Hi Adrian! Could you confirm which SDK version you are using? Also, could you check if the UDP sample works with this network configuration?
Max.
I am using v3.0.1. UDP sample works with CONFIG_LTE_NETWORK_MODE_NBIOT_GPS added to prj.conf
I have the exact same problem. Same firmware version. Happens in multi service example and asset tracker template
Error code -111 is ECONNREFUSED. This could be due to invalid login data. Please double check that you are using the correct sectag and device ID. If you need more info about how to onboard your devices, please refer to this new docs page: https://docs.nordicsemi.com/bundle/nrf-cloud/page/GettingStarted.html
