Help with the nrf21540 on the nrf5340_audio project
I'm using nRF Connect version 2.9.1 with the buildprog script method of building this project.
I've got some custom boards based on the nRF5340_audio_dk. We swapped out the codec for a stereo one and went to a Fanstel BT40N module for better range, but it doesn't seem like the FEM/amplifier is working right.
Right now I'm handling it by adding --nrf21540 to the end of my buildprog command to tell it that I've got a nrf21540 shield, and then I edited the arduino_compatible.overlay and arduino_compatible_fwd.overlay files (attached) to change up the pinout to match what the BT40N needs.
It's definitely working better than before I made those changes, but it doesn't seem to be working nearly as well as it should and I'm wondering if the amplifier is the problem.
Should the FEM be fully working with the changes I've made?
Also, even when it works I get a ton of sync errors. See attached debug log.
I'm going to try removing the --nrf21540 and just see what happens when I hardcode the pins to be in a TX or RX configuration - does the BIS broadcaster firmware do any receiving and does the BIS receiver firmware do any transmitting?
Glen
*** Booting nRF Connect SDK v2.9.1-60d0d6c8d42d ***
*** Using Zephyr OS v3.7.99-ca954a6216c9 ***
[00:00:01.036,041] <inf> fw_info:
         nRF5340 Audio nRF5340 Audio DK cpuapp
         NCS base version: 2.9.1
         Cmake run : Tue Jul 15 11:58:50 2025
[00:00:01.056,518] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:01.056,518] <inf> bt_hci_core: HW Variant: nRF53x (0x0003)
[00:00:01.056,549] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 121.4259
 Build 3078678206
[00:00:01.090,606] <inf> bt_hci_core: Identity: F3:1F:3E:44:97:B6 (random)
[00:00:01.090,637] <inf> bt_hci_core: HCI: version 6.0 (0x0e) revision 0x209a, manufacturer 0x0059
[00:00:01.090,637] <inf> bt_hci_core: LMP: version 6.0 (0x0e) subver 0x209a
[00:00:01.091,003] <inf> bt_mgmt_ctlr_cfg: Controller: SoftDevice: Version 6.0 (0x0e), Revision 8346
[00:00:01.091,156] <inf> bt_mgmt: Local identity addr: F3:1F:3E:44:97:B6 (random)
[00:00:01.092,437] <err> TLV320: GDM cs47l63_comm_init
[00:00:01.092,468] <err> audiocodec: GDM cs47l63_initialize
[00:00:01.092,468] <err> TLV320: GDM cs47l63_comm_gpio_set
[00:00:01.094,543] <err> TLV320: GDM cs47l63_comm_gpio_set
[00:00:01.194,580] <err> TLV320: GDM End of cs47l63_comm_init
[00:00:01.194,610] <err> hw_codec: GDM Soft reset code
[00:00:01.195,831] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:01.195,831] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:02.503,387] <inf> main: PA sync lost, reason: 62
[00:00:02.503,387] <err> main: Failed to restart scanning: -120
[00:00:03.703,857] <inf> bt_mgmt_scan: PA synced to name: NRF5340_BROADCASTER, id: 0x06d1bf, addr: 2C
:87:9B:72:0B:28 (random)
[00:00:04.903,900] <inf> broadcast_sink: Sync with stereo channel
[00:00:04.903,900] <inf> broadcast_sink: Syncing to broadcast stream index 0
[00:00:04.904,083] <err> audio_system: GDM Decoder sample rate 48000
[00:00:04.904,083] <inf> main: Presentation delay 3000 us is set
[00:00:06.158,142] <wrn> bt_conn: conn 0x20003660 failed to establish. RF noise?
[00:00:06.158,172] <inf> broadcast_sink: Stream sync lost
[00:00:06.158,203] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:06.158,203] <wrn> bt_conn: conn 0x20003730 failed to establish. RF noise?
[00:00:06.158,233] <inf> broadcast_sink: Stream sync lost
[00:00:06.158,264] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:06.158,355] <inf> main: Sync lost
[00:00:06.158,752] <inf> main: PA sync lost, reason: 22
[00:00:06.159,576] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:06.159,606] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:06.159,606] <inf> main: Restarted scanning for broadcaster
[00:00:06.159,606] <inf> main: Sync lost
[00:00:06.159,637] <wrn> main: PA sync is NULL
[00:00:06.159,973] <wrn> bt_hci_core: opcode 0x2045 status 0x0c
[00:00:06.159,973] <err> bt_mgmt: Failed to delete PA sync
[00:00:06.159,973] <wrn> main: Failed to delete PA sync -13
[00:00:06.161,132] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:06.161,132] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:06.161,132] <inf> main: Restarted scanning for broadcaster
[00:00:07.503,906] <inf> bt_mgmt_scan: PA synced to name: NRF5340_BROADCASTER, id: 0x06d1bf, addr: 2C
[00:00:08.103,912] <inf> broadcast_sink: Sync with stereo channel
[00:00:08.103,912] <inf> broadcast_sink: Syncing to broadcast stream index 0
[00:00:08.104,064] <err> audio_system: GDM Decoder sample rate 48000
[00:00:08.104,064] <inf> main: Presentation delay 3000 us is set
[00:00:09.958,160] <wrn> bt_conn: conn 0x20003660 failed to establish. RF noise?
[00:00:09.958,190] <inf> broadcast_sink: Stream sync lost
[00:00:09.958,221] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:09.958,221] <wrn> bt_conn: conn 0x20003730 failed to establish. RF noise?
[00:00:09.958,251] <inf> broadcast_sink: Stream sync lost
[00:00:09.958,282] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:09.958,374] <inf> main: Sync lost
[00:00:09.958,770] <inf> main: PA sync lost, reason: 22
[00:00:09.959,594] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:09.959,625] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:09.959,625] <inf> main: Restarted scanning for broadcaster
[00:00:09.959,625] <inf> main: Sync lost
[00:00:09.959,655] <wrn> main: PA sync is NULL
[00:00:09.959,991] <wrn> bt_hci_core: opcode 0x2045 status 0x0c
[00:00:09.959,991] <err> bt_mgmt: Failed to delete PA sync
[00:00:09.959,991] <wrn> main: Failed to delete PA sync -13
[00:00:09.961,151] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:09.961,151] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:09.961,151] <inf> main: Restarted scanning for broadcaster
[00:00:11.303,405] <inf> main: PA sync lost, reason: 62
[00:00:11.303,436] <err> main: Failed to restart scanning: -120
[00:00:12.503,906] <inf> bt_mgmt_scan: PA synced to name: NRF5340_BROADCASTER, id: 0x06d1bf, addr: 2C
[00:00:13.103,942] <inf> broadcast_sink: Sync with stereo channel
[00:00:13.103,942] <inf> broadcast_sink: Syncing to broadcast stream index 0
[00:00:13.104,095] <err> audio_system: GDM Decoder sample rate 48000
[00:00:13.104,095] <inf> main: Presentation delay 3000 us is set
[00:00:15.558,197] <wrn> bt_conn: conn 0x20003660 failed to establish. RF noise?
[00:00:15.558,197] <inf> broadcast_sink: Stream sync lost
[00:00:15.558,258] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:15.558,258] <wrn> bt_conn: conn 0x20003730 failed to establish. RF noise?
[00:00:15.558,288] <inf> broadcast_sink: Stream sync lost
[00:00:15.558,319] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:15.558,410] <inf> main: Sync lost
[00:00:15.558,807] <inf> main: PA sync lost, reason: 22
[00:00:15.559,631] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:15.559,631] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:15.559,661] <inf> main: Restarted scanning for broadcaster
[00:00:15.559,661] <inf> main: Sync lost
[00:00:15.559,661] <wrn> main: PA sync is NULL
[00:00:15.560,028] <wrn> bt_hci_core: opcode 0x2045 status 0x0c
[00:00:15.560,028] <err> bt_mgmt: Failed to delete PA sync
[00:00:15.560,028] <wrn> main: Failed to delete PA sync -13
[00:00:15.561,187] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:15.561,187] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:15.561,187] <inf> main: Restarted scanning for broadcaster
[00:00:16.503,936] <inf> bt_mgmt_scan: PA synced to name: NRF5340_BROADCASTER, id: 0x06d1bf, addr: 2C
[00:00:17.703,948] <inf> broadcast_sink: Sync with stereo channel
[00:00:17.703,948] <inf> broadcast_sink: Syncing to broadcast stream index 0
[00:00:17.704,132] <err> audio_system: GDM Decoder sample rate 48000
[00:00:17.704,132] <inf> main: Presentation delay 3000 us is set
[00:00:20.758,209] <wrn> bt_conn: conn 0x20003660 failed to establish. RF noise?
[00:00:20.758,239] <inf> broadcast_sink: Stream sync lost
[00:00:20.758,270] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:20.758,270] <wrn> bt_conn: conn 0x20003730 failed to establish. RF noise?
[00:00:20.758,300] <inf> broadcast_sink: Stream sync lost
[00:00:20.758,361] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:20.758,422] <inf> main: Sync lost
[00:00:20.758,850] <inf> main: PA sync lost, reason: 22
[00:00:20.759,674] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:20.759,674] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:20.759,674] <inf> main: Restarted scanning for broadcaster
[00:00:20.759,704] <inf> main: Sync lost
[00:00:20.759,704] <wrn> main: PA sync is NULL
[00:00:20.760,040] <wrn> bt_hci_core: opcode 0x2045 status 0x0c
[00:00:20.760,040] <err> bt_mgmt: Failed to delete PA sync
[00:00:20.760,040] <wrn> main: Failed to delete PA sync -13
[00:00:20.761,199] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:20.761,230] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:20.761,230] <inf> main: Restarted scanning for broadcaster
[00:00:21.503,967] <inf> bt_mgmt_scan: PA synced to name: NRF5340_BROADCASTER, id: 0x06d1bf, addr: 2C
[00:00:22.103,973] <inf> broadcast_sink: Sync with stereo channel
[00:00:22.103,973] <inf> broadcast_sink: Syncing to broadcast stream index 0
[00:00:22.104,156] <err> audio_system: GDM Decoder sample rate 48000
[00:00:22.104,156] <inf> main: Presentation delay 3000 us is set
[00:00:22.758,239] <wrn> bt_conn: conn 0x20003660 failed to establish. RF noise?
[00:00:22.758,239] <inf> broadcast_sink: Stream sync lost
[00:00:22.758,300] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:22.758,300] <wrn> bt_conn: conn 0x20003730 failed to establish. RF noise?
[00:00:22.758,331] <inf> broadcast_sink: Stream sync lost
[00:00:22.758,361] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:22.758,453] <inf> main: Sync lost
[00:00:22.758,850] <inf> main: PA sync lost, reason: 22
[00:00:22.759,674] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:22.759,674] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:22.759,704] <inf> main: Restarted scanning for broadcaster
[00:00:22.759,704] <inf> main: Sync lost
[00:00:22.759,704] <wrn> main: PA sync is NULL
[00:00:22.760,040] <wrn> bt_hci_core: opcode 0x2045 status 0x0c
[00:00:22.760,070] <err> bt_mgmt: Failed to delete PA sync
[00:00:22.760,070] <wrn> main: Failed to delete PA sync -13
[00:00:22.761,230] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:22.761,230] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:22.761,230] <inf> main: Restarted scanning for broadcaster
[00:00:23.903,717] <inf> main: PA sync lost, reason: 62
[00:00:23.903,747] <err> main: Failed to restart scanning: -120
[00:00:24.503,997] <inf> bt_mgmt_scan: PA synced to name: NRF5340_BROADCASTER, id: 0x06d1bf, addr: 2C
[00:00:25.704,010] <inf> broadcast_sink: Sync with stereo channel
[00:00:25.704,010] <inf> broadcast_sink: Syncing to broadcast stream index 0
[00:00:25.704,162] <err> audio_system: GDM Decoder sample rate 48000
[00:00:25.704,162] <inf> main: Presentation delay 3000 us is set
[00:00:29.358,276] <wrn> bt_conn: conn 0x20003660 failed to establish. RF noise?
[00:00:29.358,276] <inf> broadcast_sink: Stream sync lost
[00:00:29.358,337] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:29.358,337] <wrn> bt_conn: conn 0x20003730 failed to establish. RF noise?
[00:00:29.358,367] <inf> broadcast_sink: Stream sync lost
[00:00:29.358,398] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:29.358,489] <inf> main: Sync lost
[00:00:29.358,886] <inf> main: PA sync lost, reason: 22
[00:00:29.359,710] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:29.359,710] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:29.359,741] <inf> main: Restarted scanning for broadcaster
[00:00:29.359,741] <inf> main: Sync lost
[00:00:29.359,741] <wrn> main: PA sync is NULL
[00:00:29.360,076] <wrn> bt_hci_core: opcode 0x2045 status 0x0c
[00:00:29.360,107] <err> bt_mgmt: Failed to delete PA sync
[00:00:29.360,107] <wrn> main: Failed to delete PA sync -13
[00:00:29.361,267] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:29.361,267] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:29.361,267] <inf> main: Restarted scanning for broadcaster
[00:00:30.703,491] <inf> main: PA sync lost, reason: 62
[00:00:30.703,491] <err> main: Failed to restart scanning: -120
[00:00:31.504,028] <inf> bt_mgmt_scan: PA synced to name: NRF5340_BROADCASTER, id: 0x06d1bf, addr: 2C
[00:00:32.704,040] <inf> broadcast_sink: Sync with stereo channel
[00:00:32.704,040] <inf> broadcast_sink: Syncing to broadcast stream index 0
[00:00:32.704,193] <err> audio_system: GDM Decoder sample rate 48000
[00:00:32.704,193] <inf> main: Presentation delay 3000 us is set
[00:00:33.958,282] <wrn> bt_conn: conn 0x20003660 failed to establish. RF noise?
[00:00:33.958,312] <inf> broadcast_sink: Stream sync lost
[00:00:33.958,343] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:33.958,343] <wrn> bt_conn: conn 0x20003730 failed to establish. RF noise?
[00:00:33.958,374] <inf> broadcast_sink: Stream sync lost
[00:00:33.958,404] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:33.958,496] <inf> main: Sync lost
[00:00:33.958,923] <inf> main: PA sync lost, reason: 22
[00:00:33.959,747] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:33.959,747] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:33.959,747] <inf> main: Restarted scanning for broadcaster
[00:00:33.959,777] <inf> main: Sync lost
[00:00:33.959,777] <wrn> main: PA sync is NULL
[00:00:33.960,113] <wrn> bt_hci_core: opcode 0x2045 status 0x0c
[00:00:33.960,113] <err> bt_mgmt: Failed to delete PA sync
[00:00:33.960,113] <wrn> main: Failed to delete PA sync -13
[00:00:33.961,273] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:33.961,273] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:33.961,273] <inf> main: Restarted scanning for broadcaster
[00:00:34.904,052] <inf> bt_mgmt_scan: PA synced to name: NRF5340_BROADCASTER, id: 0x06d1bf, addr: 2C
[00:00:36.104,064] <inf> broadcast_sink: Sync with stereo channel
[00:00:36.104,064] <inf> broadcast_sink: Syncing to broadcast stream index 0
[00:00:36.104,217] <err> audio_system: GDM Decoder sample rate 48000
[00:00:36.104,217] <inf> main: Presentation delay 3000 us is set
[00:00:36.758,300] <wrn> bt_conn: conn 0x20003660 failed to establish. RF noise?
[00:00:36.758,331] <inf> broadcast_sink: Stream sync lost
[00:00:36.758,361] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:36.758,361] <wrn> bt_conn: conn 0x20003730 failed to establish. RF noise?
[00:00:36.758,392] <inf> broadcast_sink: Stream sync lost
[00:00:36.758,422] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:36.758,514] <inf> main: Sync lost
[00:00:36.758,911] <inf> main: PA sync lost, reason: 22
[00:00:36.759,735] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:36.759,735] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:36.759,735] <inf> main: Restarted scanning for broadcaster
[00:00:36.759,735] <inf> main: Sync lost
[00:00:36.759,765] <wrn> main: PA sync is NULL
[00:00:36.760,101] <wrn> bt_hci_core: opcode 0x2045 status 0x0c
[00:00:36.760,101] <err> bt_mgmt: Failed to delete PA sync
[00:00:36.760,101] <wrn> main: Failed to delete PA sync -13
[00:00:36.761,260] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:36.761,260] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:36.761,260] <inf> main: Restarted scanning for broadcaster
[00:00:37.304,046] <inf> bt_mgmt_scan: PA synced to name: NRF5340_BROADCASTER, id: 0x06d1bf, addr: 2C
[00:00:38.504,058] <inf> broadcast_sink: Sync with stereo channel
[00:00:38.504,089] <inf> broadcast_sink: Syncing to broadcast stream index 0
[00:00:38.504,241] <err> audio_system: GDM Decoder sample rate 48000
[00:00:38.504,241] <inf> main: Presentation delay 3000 us is set
[00:00:39.158,325] <wrn> bt_conn: conn 0x20003660 failed to establish. RF noise?
[00:00:39.158,325] <inf> broadcast_sink: Stream sync lost
[00:00:39.158,386] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:39.158,386] <wrn> bt_conn: conn 0x20003730 failed to establish. RF noise?
[00:00:39.158,416] <inf> broadcast_sink: Stream sync lost
[00:00:39.158,447] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:39.158,538] <inf> main: Sync lost
[00:00:39.158,935] <inf> main: PA sync lost, reason: 22
[00:00:39.159,729] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:39.159,729] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:39.159,759] <inf> main: Restarted scanning for broadcaster
[00:00:39.159,759] <inf> main: Sync lost
[00:00:39.159,759] <wrn> main: PA sync is NULL
[00:00:39.160,095] <wrn> bt_hci_core: opcode 0x2045 status 0x0c
[00:00:39.160,125] <err> bt_mgmt: Failed to delete PA sync
[00:00:39.160,125] <wrn> main: Failed to delete PA sync -13
[00:00:39.161,285] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:39.161,285] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:39.161,285] <inf> main: Restarted scanning for broadcaster
[00:00:40.304,077] <inf> bt_mgmt_scan: PA synced to name: NRF5340_BROADCASTER, id: 0x06d1bf, addr: 2C
[00:00:41.504,089] <inf> broadcast_sink: Sync with stereo channel
[00:00:41.504,089] <inf> broadcast_sink: Syncing to broadcast stream index 0
[00:00:41.504,241] <err> audio_system: GDM Decoder sample rate 48000
[00:00:41.504,272] <inf> main: Presentation delay 3000 us is set
[00:00:42.158,325] <wrn> bt_conn: conn 0x20003660 failed to establish. RF noise?
[00:00:42.158,355] <inf> broadcast_sink: Stream sync lost
[00:00:42.158,386] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:42.158,386] <wrn> bt_conn: conn 0x20003730 failed to establish. RF noise?
[00:00:42.158,416] <inf> broadcast_sink: Stream sync lost
[00:00:42.158,447] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:42.158,538] <inf> main: Sync lost
[00:00:42.158,935] <inf> main: PA sync lost, reason: 22
[00:00:42.159,759] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:42.159,759] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:42.159,759] <inf> main: Restarted scanning for broadcaster
[00:00:42.159,790] <inf> main: Sync lost
[00:00:42.159,790] <wrn> main: PA sync is NULL
[00:00:42.160,125] <wrn> bt_hci_core: opcode 0x2045 status 0x0c
[00:00:42.160,125] <err> bt_mgmt: Failed to delete PA sync
[00:00:42.160,125] <wrn> main: Failed to delete PA sync -13
[00:00:42.161,285] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:42.161,285] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:42.161,285] <inf> main: Restarted scanning for broadcaster
[00:00:42.704,071] <inf> bt_mgmt_scan: PA synced to name: NRF5340_BROADCASTER, id: 0x06d1bf, addr: 2C
[00:00:44.504,089] <inf> broadcast_sink: Sync with stereo channel
[00:00:44.504,119] <inf> broadcast_sink: Syncing to broadcast stream index 0
[00:00:44.504,272] <err> audio_system: GDM Decoder sample rate 48000
[00:00:44.504,272] <inf> main: Presentation delay 3000 us is set
[00:00:46.958,374] <wrn> bt_conn: conn 0x20003660 failed to establish. RF noise?
[00:00:46.958,374] <inf> broadcast_sink: Stream sync lost
[00:00:46.958,404] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:46.958,435] <wrn> bt_conn: conn 0x20003730 failed to establish. RF noise?
[00:00:46.958,465] <inf> broadcast_sink: Stream sync lost
[00:00:46.958,496] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:46.958,557] <inf> main: Sync lost
[00:00:46.958,984] <inf> main: PA sync lost, reason: 22
[00:00:46.959,808] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:46.959,808] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:46.959,808] <inf> main: Restarted scanning for broadcaster
[00:00:46.959,838] <inf> main: Sync lost
[00:00:46.959,838] <wrn> main: PA sync is NULL
[00:00:46.960,174] <wrn> bt_hci_core: opcode 0x2045 status 0x0c
[00:00:46.960,174] <err> bt_mgmt: Failed to delete PA sync
[00:00:46.960,205] <wrn> main: Failed to delete PA sync -13
[00:00:46.961,364] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:46.961,364] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:46.961,364] <inf> main: Restarted scanning for broadcaster
[00:00:47.704,101] <inf> bt_mgmt_scan: PA synced to name: NRF5340_BROADCASTER, id: 0x06d1bf, addr: 2C
[00:00:48.904,113] <inf> broadcast_sink: Sync with stereo channel
[00:00:48.904,144] <inf> broadcast_sink: Syncing to broadcast stream index 0
[00:00:48.904,296] <err> audio_system: GDM Decoder sample rate 48000
[00:00:48.904,296] <inf> main: Presentation delay 3000 us is set
[00:00:49.558,380] <wrn> bt_conn: conn 0x20003660 failed to establish. RF noise?
[00:00:49.558,380] <inf> broadcast_sink: Stream sync lost
[00:00:49.558,441] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:49.558,441] <wrn> bt_conn: conn 0x20003730 failed to establish. RF noise?
[00:00:49.558,471] <inf> broadcast_sink: Stream sync lost
[00:00:49.558,502] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:49.558,593] <inf> main: Sync lost
[00:00:49.558,990] <inf> main: PA sync lost, reason: 22
[00:00:49.559,783] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:49.559,814] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:49.559,814] <inf> main: Restarted scanning for broadcaster
[00:00:49.559,814] <inf> main: Sync lost
[00:00:49.559,814] <wrn> main: PA sync is NULL
[00:00:49.560,150] <wrn> bt_hci_core: opcode 0x2045 status 0x0c
[00:00:49.560,180] <err> bt_mgmt: Failed to delete PA sync
[00:00:49.560,180] <wrn> main: Failed to delete PA sync -13
[00:00:49.561,340] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:49.561,340] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:49.561,340] <inf> main: Restarted scanning for broadcaster
[00:00:50.504,119] <inf> bt_mgmt_scan: PA synced to name: NRF5340_BROADCASTER, id: 0x06d1bf, addr: 2C
[00:00:52.904,144] <inf> broadcast_sink: Sync with stereo channel
[00:00:52.904,144] <inf> broadcast_sink: Syncing to broadcast stream index 0
[00:00:52.904,327] <err> audio_system: GDM Decoder sample rate 48000
[00:00:52.904,327] <inf> main: Presentation delay 3000 us is set
[00:00:54.158,416] <wrn> bt_conn: conn 0x20003660 failed to establish. RF noise?
[00:00:54.158,416] <inf> broadcast_sink: Stream sync lost
[00:00:54.158,447] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:54.158,477] <wrn> bt_conn: conn 0x20003730 failed to establish. RF noise?
[00:00:54.158,508] <inf> broadcast_sink: Stream sync lost
[00:00:54.158,538] <inf> broadcast_sink: Stream index 0 stopped. Reason: 62
[00:00:54.158,599] <inf> main: Sync lost
[00:00:54.159,027] <inf> main: PA sync lost, reason: 22
[00:00:54.159,851] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:54.159,851] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:54.159,851] <inf> main: Restarted scanning for broadcaster
[00:00:54.159,881] <inf> main: Sync lost
[00:00:54.159,881] <wrn> main: PA sync is NULL
[00:00:54.160,217] <wrn> bt_hci_core: opcode 0x2045 status 0x0c
[00:00:54.160,217] <err> bt_mgmt: Failed to delete PA sync
[00:00:54.160,217] <wrn> main: Failed to delete PA sync -13
[00:00:54.161,376] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random). May time out. Updates
not printed
[00:00:54.161,407] <inf> bt_mgmt_scan: Scanning successfully started
[00:00:54.161,407] <inf> main: Restarted scanning for broadcaster
  • Well after poring over all of that information and my setup, I fixed the chip select polarity setting in my overlay file to make it active low. On the CONFIG options, from the documentation it looks like if you have the right stuff in devicetree it's supposed to just set it up for GPIO mode without further intervention. I tried it that way and also with CONFIG_MPSL_FEM_NRF21540_GPIO_SPI=y in my nrf5340_audio_dk_nrf5340_cpunet_defconfig file.
    Without anything I continue to get the "bt_conn: conn 0x200035c0 failed to establish. RF noise?" messages I have been getting. With the above GPIO_SPI define in, it connects and stays connected, but I get a ton of underruns and the audio is clicking garbage (no noticeable trace of my real audio). See attached debug log for the details of those errors.
    I thought I might need to add CONFIG_FEM_AL_LIB=y but it failed to compile with errors related to MPSL.
    I just tried switching my broadcaster back to the eval board (still using my custom receiver) and I got underruns for a few seconds, but I also got real audio and after a few seconds the underruns stopped
    Is there a way to see FEM debug messages on an nrf5340 or since that is on the network core and the debug port seems to be connected to the app core do those get lost?
    [00:00:00.931,518] <inf> fw_info:
             Cmake run : Mon Jul 21 17:23:53 2025
    [00:00:00.953,094] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x000
    2)
    [00:00:00.953,094] <inf> bt_hci_core: HW Variant: nRF53x (0x0003)
    [00:00:00.953,125] <inf> bt_hci_core: Firmware: Standard Bluetooth controller
    (0x00) Version 121.4259 Build 3078678206
    [00:00:00.987,548] <inf> bt_hci_core: Identity: F3:1F:3E:44:97:B6 (random)
    [00:00:00.987,548] <inf> bt_hci_core: HCI: version 6.0 (0x0e) revision 0x209a,
     manufacturer 0x0059
    [00:00:00.987,579] <inf> bt_hci_core: LMP: version 6.0 (0x0e) subver 0x209a
    [00:00:00.987,945] <inf> bt_mgmt_ctlr_cfg: Controller: SoftDevice: Version 6.0
    [00:00:00.988,067] <inf> bt_mgmt: Local identity addr: F3:1F:3E:44:97:B6 (rand
    om)
    [00:00:00.989,166] <err> TLV320: GDM cs47l63_comm_init
    [00:00:01.004,302] <err> TLV320: GDM End of cs47l63_comm_init
    [00:00:01.004,333] <err> hw_codec: GDM Soft reset code
    [00:00:01.005,584] <inf> bt_mgmt_scan: Local addr: F3:1F:3E:44:97:B6 (random).
     May time out. Updates not printed
    [00:00:01.005,584] <inf> bt_mgmt_scan: Scanning successfully started
    [00:00:25.546,600] <inf> bt_mgmt_scan: PA synced to name: NRF5340_BROADCASTER,
     id: 0x004a99, addr: 16:87:03:A0:BE:22 (random)
    [00:00:26.146,606] <inf> broadcast_sink: Sync with stereo channel
    [00:00:26.146,606] <inf> broadcast_sink: Syncing to broadcast stream index 0
    [00:00:26.146,759] <err> audio_system: GDM Decoder sample rate 48000
    [00:00:26.146,759] <inf> main: Presentation delay 3000 us is set
    [00:00:26.751,159] <inf> broadcast_sink: Stream index 0 started
    [00:00:26.751,159] <inf> broadcast_sink: Codec config for LC3:
    [00:00:26.751,159] <inf> broadcast_sink:        Frequency: 48000 Hz
    [00:00:26.751,159] <inf> broadcast_sink:        Frame Duration: 10000 us
    [00:00:26.751,190] <inf> broadcast_sink:        Octets per frame: 120 (96000 k
    bps)
    [00:00:26.751,190] <inf> broadcast_sink:        Frames per SDU: 1
    [00:00:26.751,190] <inf> broadcast_sink:        Channel allocation: 0x1
    [00:00:26.751,251] <err> audio_system: GDM: Codec: 1, audio_ch 0, chmode 2, nu
    m 2
    [00:00:26.751,586] <inf> broadcast_sink: Stream index 1 started
    [00:00:26.751,586] <inf> broadcast_sink: Codec config for LC3:
    [00:00:26.751,617] <inf> broadcast_sink:        Frequency: 48000 Hz
    [00:00:26.751,617] <inf> broadcast_sink:        Frame Duration: 10000 us
    [00:00:26.751,617] <inf> broadcast_sink:        Octets per frame: 120 (96000 k
    bps)
    [00:00:26.751,617] <inf> broadcast_sink:        Frames per SDU: 1
    [00:00:26.751,617] <inf> broadcast_sink:        Channel allocation: 0x2
    [00:00:26.752,166] <wrn> le_audio_rx: Not in streaming state (1), thrown 1 pac
    ket(s)
    [00:00:26.756,591] <err> hw_codec: GDM hw_codec_default_conf_enable
    [00:00:26.757,690] <err> TLV320: GDM TLV320 detailed init
    [00:00:27.250,915] <wrn> le_audio_rx: Not in streaming state (1), thrown 101 p
    acket(s)
    [00:00:27.750,915] <wrn> le_audio_rx: Not in streaming state (1), thrown 201 p
    acket(s)
    [00:00:28.250,915] <wrn> le_audio_rx: Not in streaming state (1), thrown 301 p
    acket(s)
    [00:00:28.751,586] <wrn> le_audio_rx: Not in streaming state (1), thrown 401 p
    acket(s)
    [00:00:29.028,167] <err> TLV320: RECEIVER firmware build
    [00:00:29.250,915] <wrn> le_audio_rx: Not in streaming state (1), thrown 501 p
    acket(s)
    [00:00:29.751,434] <wrn> le_audio_rx: Not in streaming state (1), thrown 601 p
    acket(s)
    [00:00:30.251,434] <wrn> le_audio_rx: Not in streaming state (1), thrown 701 p
    acket(s)
    [00:00:30.751,434] <wrn> le_audio_rx: Not in streaming state (1), thrown 801 p
    acket(s)
    [00:00:31.251,464] <wrn> le_audio_rx: Not in streaming state (1), thrown 901 p
    acket(s)
    [00:00:31.751,464] <wrn> le_audio_rx: Not in streaming state (1), thrown 1001
    packet(s)
    [00:00:32.251,434] <wrn> le_audio_rx: Not in streaming state (1), thrown 1101
    packet(s)
    [00:00:32.494,354] <inf> audio_datapath: Drft comp state: CALIB
    [00:00:32.497,344] <wrn> audio_datapath: Data received, total under-runs: 9
    [00:00:32.548,339] <wrn> audio_datapath: Data received, total under-runs: 10
    [00:00:32.594,360] <inf> audio_datapath: Drft comp state: OFFSET
    [00:00:32.694,335] <inf> audio_datapath: Drft comp state: LOCKED
    [00:00:32.703,582] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:32.813,568] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:32.817,321] <wrn> audio_datapath: Data received, total under-runs: 11
    [00:00:32.858,337] <wrn> audio_datapath: Data received, total under-runs: 12
    [00:00:32.953,582] <inf> audio_datapath: Pres comp state: INIT
    [00:00:32.963,592] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:33.073,577] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:33.077,331] <wrn> audio_datapath: Data received, total under-runs: 13
    [00:00:33.213,592] <inf> audio_datapath: Pres comp state: INIT
    [00:00:33.223,571] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:33.333,587] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:33.337,341] <wrn> audio_datapath: Data received, total under-runs: 14
    [00:00:33.473,571] <inf> audio_datapath: Pres comp state: INIT
    [00:00:33.483,581] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:33.593,597] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:33.597,351] <wrn> audio_datapath: Data received, total under-runs: 15
    [00:00:33.733,581] <inf> audio_datapath: Pres comp state: INIT
    [00:00:33.743,591] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:33.853,576] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:33.857,330] <wrn> audio_datapath: Data received, total under-runs: 16
    [00:00:33.993,591] <inf> audio_datapath: Pres comp state: INIT
    [00:00:34.003,601] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:34.113,586] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:34.117,340] <wrn> audio_datapath: Data received, total under-runs: 17
    [00:00:34.253,601] <inf> audio_datapath: Pres comp state: INIT
    [00:00:34.263,580] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:34.373,596] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:34.377,349] <wrn> audio_datapath: Data received, total under-runs: 18
    [00:00:34.514,251] <inf> audio_datapath: Pres comp state: INIT
    [00:00:34.523,590] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:34.633,575] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:34.637,359] <wrn> audio_datapath: Data received, total under-runs: 19
    [00:00:34.773,590] <inf> audio_datapath: Pres comp state: INIT
    [00:00:34.783,599] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:34.893,585] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:34.917,358] <wrn> audio_datapath: Data received, total under-runs: 20
    [00:00:34.948,364] <wrn> audio_datapath: Data received, total under-runs: 21
    [00:00:35.033,599] <inf> audio_datapath: Pres comp state: INIT
    [00:00:35.043,579] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:35.153,594] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:35.157,348] <wrn> audio_datapath: Data received, total under-runs: 22
    [00:00:35.293,579] <inf> audio_datapath: Pres comp state: INIT
    [00:00:35.303,588] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:35.413,604] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:35.417,358] <wrn> audio_datapath: Data received, total under-runs: 23
    [00:00:35.553,588] <inf> audio_datapath: Pres comp state: INIT
    [00:00:35.563,598] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:35.673,583] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:35.677,337] <wrn> audio_datapath: Data received, total under-runs: 24
    [00:00:35.813,598] <inf> audio_datapath: Pres comp state: INIT
    [00:00:35.824,249] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:35.933,593] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:35.937,347] <wrn> audio_datapath: Data received, total under-runs: 25
    [00:00:36.073,608] <inf> audio_datapath: Pres comp state: INIT
    [00:00:36.083,587] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:36.193,603] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:36.197,326] <wrn> audio_datapath: Data received, total under-runs: 26
    [00:00:36.238,342] <wrn> audio_datapath: Data received, total under-runs: 27
    [00:00:36.333,587] <inf> audio_datapath: Pres comp state: INIT
    [00:00:36.343,597] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:36.453,613] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:36.457,366] <wrn> audio_datapath: Data received, total under-runs: 28
    [00:00:36.593,597] <inf> audio_datapath: Pres comp state: INIT
    [00:00:36.603,607] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:36.713,592] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:36.717,346] <wrn> audio_datapath: Data received, total under-runs: 29
    [00:00:36.853,607] <inf> audio_datapath: Pres comp state: INIT
    [00:00:36.863,586] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:36.948,364] <wrn> audio_datapath: Data received, total under-runs: 30
    [00:00:36.973,602] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:37.113,616] <inf> audio_datapath: Pres comp state: INIT
    [00:00:37.123,596] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:37.233,612] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:37.237,365] <wrn> audio_datapath: Data received, total under-runs: 31
    [00:00:37.373,596] <inf> audio_datapath: Pres comp state: INIT
    [00:00:37.383,605] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:37.493,591] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:37.497,375] <wrn> audio_datapath: Data received, total under-runs: 32
    [00:00:37.633,605] <inf> audio_datapath: Pres comp state: INIT
    [00:00:37.643,615] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:37.753,601] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:37.757,354] <wrn> audio_datapath: Data received, total under-runs: 33
    [00:00:37.893,615] <inf> audio_datapath: Pres comp state: INIT
    [00:00:37.903,594] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:38.013,610] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:38.017,364] <wrn> audio_datapath: Data received, total under-runs: 34
    [00:00:38.153,594] <inf> audio_datapath: Pres comp state: INIT
    [00:00:38.163,604] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:38.274,261] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:38.277,374] <wrn> audio_datapath: Data received, total under-runs: 35
    [00:00:38.413,604] <inf> audio_datapath: Pres comp state: INIT
    [00:00:38.423,614] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:38.533,599] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:38.537,353] <wrn> audio_datapath: Data received, total under-runs: 36
    [00:00:38.673,614] <inf> audio_datapath: Pres comp state: INIT
    [00:00:38.683,593] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:38.794,281] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:38.797,363] <wrn> audio_datapath: Data received, total under-runs: 37
    [00:00:38.898,376] <wrn> audio_datapath: Data received, total under-runs: 38
    [00:00:38.933,624] <inf> audio_datapath: Pres comp state: INIT
    [00:00:38.944,885] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:39.053,619] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:39.057,373] <wrn> audio_datapath: Data received, total under-runs: 39
    [00:00:39.193,603] <inf> audio_datapath: Pres comp state: INIT
    [00:00:39.203,613] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:39.313,598] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:39.317,352] <wrn> audio_datapath: Data received, total under-runs: 40
    [00:00:39.453,613] <inf> audio_datapath: Pres comp state: INIT
    [00:00:39.463,623] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:39.573,608] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:39.577,362] <wrn> audio_datapath: Data received, total under-runs: 41
    [00:00:39.714,355] <inf> audio_datapath: Pres comp state: INIT
    [00:00:39.723,602] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:39.833,618] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:39.837,371] <wrn> audio_datapath: Data received, total under-runs: 42
    [00:00:39.973,602] <inf> audio_datapath: Pres comp state: INIT
    [00:00:39.983,612] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:40.093,627] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:40.097,381] <wrn> audio_datapath: Data received, total under-runs: 43
    [00:00:40.233,612] <inf> audio_datapath: Pres comp state: INIT
    [00:00:40.243,621] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:40.353,607] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:40.357,360] <wrn> audio_datapath: Data received, total under-runs: 44
    [00:00:40.493,621] <inf> audio_datapath: Pres comp state: INIT
    [00:00:40.503,631] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:40.613,616] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:40.617,370] <wrn> audio_datapath: Data received, total under-runs: 45
    [00:00:40.738,372] <wrn> audio_datapath: Data received, total under-runs: 46
    [00:00:40.753,631] <inf> audio_datapath: Pres comp state: INIT
    [00:00:40.763,610] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:40.873,626] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:40.877,380] <wrn> audio_datapath: Data received, total under-runs: 47
    [00:00:40.948,364] <wrn> audio_datapath: Data received, total under-runs: 48
    [00:00:41.013,610] <inf> audio_datapath: Pres comp state: INIT
    [00:00:41.023,620] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:41.133,636] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:41.137,390] <wrn> audio_datapath: Data received, total under-runs: 49
  • Sorry for the late response Glen,
    You have done a lot of good troubleshooting already but the Fanstel BT40N’s front-end module doesn’t perfectly match the nRF21540 timing assumptions in the standard driver. The FEM is switching, but the PA/LNA delays and possibly gain are not tuned for the BT40N, which is why you’re seeing frequent sync losses and RF noise errors. The audio underruns come directly from dropped RF packets, not from the LC3 decoder itself.
    I would suggest that you first confirm stability of your system by running without the FEM. If that seems to work, then enable the FEM again and try to calibrate the pa-time-gap-us, lna-time-gap-us, and TX power level. Also, enable MPSL FEM debug logs so you can confirm the timing changes are applied on the network core. The BIS broadcaster only transmits, and the receiver only receives, so hardcoding PA or LNA states can help isolate RF issues but won’t represent actual timing behavior.
  • Still stuck. I've been using the devkit as a broadcaster so I can just focus on my receiver board.
    I tried getting rid of the --nrf21540 compile switch and the overlays to simplify the devicetree stuff but in the end it worked the same as yesterday. The relevant files from that are in the attached zip file. I feel like there's still something I need to get right in the CONFIG settings on either the app or network core.
    I tried turning on logging from the network core but I haven't been able to get that to work. How are you supposed to do that?
    Regarding the timing settings, why are they different from the standard driver settings? I thought it was just a regular nrf21540 in the BT40N module.
     nrf5340_audio_dk.zip
    I then tried removing all of the devicetree stuff for the FEM and just set the pins manually and I haven't even been able to make it work as well as it has been. With my last iteration of code that I'm pretty sure all the IO lines are being set to the correct states it doesn't receive at all.
    Here is that code:
    #if(1)
    // Force the FEM pins to be what I want manually here, RX for the receiver board, TX for the gateway board
    // P1.04 MODE TX power level control
    gpio_pin_configure(gpio1_dev, 4, GPIO_OUTPUT);
    gpio_pin_set_raw(gpio1_dev, 4, 1);
    //P1.05 ANT-SEL picks the antenna... 0 seems to be correct
    gpio_pin_configure(gpio1_dev, 5, GPIO_OUTPUT);
    gpio_pin_set_raw(gpio1_dev, 5, 0);
    //P0.26 PDN When PDN is set to 1 the device is in the Program state. It can then be set to any other state
    // (Receive, Transmit, and UICR Program) using pin control orthe SPI interface
    gpio_pin_configure(gpio0_dev, 26, GPIO_OUTPUT);
    gpio_pin_set_raw(gpio0_dev, 26, 1);
    k_sleep(K_MSEC(10));
    if (CONFIG_AUDIO_DEV == GATEWAY)
    { // Gateway config
    LOG_ERR("Manual FEM pin config for GATEWAY");
    //P1.06 CSN chip select
    gpio_pin_configure(gpio1_dev, 6, GPIO_OUTPUT);
    gpio_pin_set_raw(gpio1_dev, 6, 1);
    // P0.27 RX_EN To transmit, set 0
    gpio_pin_configure(gpio0_dev, 27, GPIO_OUTPUT);
    gpio_pin_set_raw(gpio0_dev, 27, 0);
    // P0.21 TX_EN To transmit, set 1
    gpio_pin_configure(gpio0_dev, 21, GPIO_OUTPUT);
    gpio_pin_set_raw(gpio0_dev, 21, 1);
    { // Receiver config
    LOG_ERR("Manual FEM pin config for RECEIVER/HEADSET");
    //P1.06 CSN chip select, must be set low when receiving per Figure 4: Control pin controls state change in nrf21540 datasheet
    gpio_pin_set_raw(gpio1_dev, 6, 0);
    // P0.21 TX_EN To receive, set 0
    gpio_pin_set_raw(gpio0_dev, 21, 0);
    // P0.27 RX_EN To receive, set 1
    gpio_pin_set_raw(gpio0_dev, 27, 1);
  • Hi Glen,
    Sorry for the late reply.
    I think I need some guidance here from Audio experts to look  into the device tree files here. I will be back to you when I have some update on this. Thanks for your patience so far, I think the main issue here is to make sure that your DTS and SPI interface.
    Can you please enable these in your nrf5340_audio_dk_nrf5340_cpunet_defconfig configs and pristine build and flash both cores again and show us some more detailed logs?
    CONFIG_MPSL_FEM=y
    +CONFIG_MPSL_FEM_NRF21540_GPIO_SPI=y
    +CONFIG_MPSL_FEM_NRF21540_RUNTIME_PA_GAIN_CONTROL=y
    +CONFIG_MPSL_LOG_LEVEL_DBG=y
    +CONFIG_MPSL_FEM_LOG_LEVEL_DBG=y
    +CONFIG_LOG=y
    +CONFIG_USE_SEGGER_RTT=y
    +CONFIG_LOG_BACKEND_RTT=y
    +CONFIG_LOG_BUFFER_SIZE=4096
    +CONFIG_LOG_MODE_IMMEDIATE=y
  • switched to GPIO mode for the FEM and not GPIO+SPI, and the receiver started receiving audio from the devkit broadcaster without continuous errors.  So some combination of other things I've fixed plus skipping the SPI FEM control seems to have made a difference. Though I'd like to know why the SPI isn't working, for this application maybe it doesn't matter.
    With the real gateway board as a broadcaster (same FEM configuration) I still get a steady flow of errors at the receiver as follows, but it does receive and play the audio:
    [00:00:09.396,301] <wrn> audio_sync_timer: Unable to get new CC value
    [00:00:09.421,539] <inf> audio_datapath: Pres comp state: INIT
    [00:00:09.432,220] <inf> audio_datapath: Pres comp state: MEAS
    [00:00:09.541,534] <inf> audio_datapath: Pres comp state: WAIT
    [00:00:09.545,318] <wrn> audio_datapath: Data received, total under-runs: 13
    I did a rough range test by leaving the receiver at my desk in the house and walking down the street with the gateway until the audio stopped. So the signal has to penetrate the house. The range was roughly 213 feet, so that seems like the FEM is likely working and maybe there's another issue to blame for the errors? Does the timing issue we talked about still apply for GPIO mode? Maybe the timing is to blame?
