Appcore rng sample build fails with NRF5340 + MCUBOOT + CONFIG_NRF_SECURITY with SDK2.9.1
Using nrf sample from v2.9.1/nrf/samples/crpyto/rng
Configure build with v2.9.1 SDK/Toolchain
Configure build with board target: nrf5340dk/nrf5340/cpuapp
Add MCUBOOT support via sysbuild config
Appcore Build fails with
warning: MBEDTLS_SHA256 (defined at C:/ncs/v2.9.1/zephyr/modules/mbedtls\Kconfig.tls-generic:349, modules\mbedtls\Kconfig.tls-generic:349) has direct dependencies (!(NRF_SECURITY || NORDIC_SECURITY_BACKEND) && MBEDTLS_BUILTIN && MBEDTLS_CFG_FILE = "config-tls-generic.h" && MBEDTLS) || (!(NRF_SECURITY || NORDIC_SECURITY_BACKEND) && MBEDTLS_BUILTIN && MBEDTLS_CFG_FILE = "config-tls-generic.h" && MBEDTLS && 0) with value n, but is currently being y-selected by the following symbols:
- FLASH_AREA_CHECK_INTEGRITY_MBEDTLS (defined at subsys/storage/flash_map/Kconfig:58), with value y, direct dependencies <choice FLASH_AREA_CHECK_INTEGRITY_BACKEND> (value: y), and select condition <choice FLASH_AREA_CHECK_INTEGRITY_BACKEND> (value: y)
error: Aborting due to Kconfig warnings
Attached is the full project minus the build directory
rng - Copy.zip
    Yes, I have enabled MCUboot in my sysbuild.config, and I am able to build the sample without issues. Please see the logs below, although there are some warnings from MCUboot during the build, I don’t see any critical errors. It’s possible that your custom application has some conflicting configurations enabled. From my side, I don’t see any issue with enabling both MCUboot and NRF_SECURITY.
    I recommend checking the generated .config folder to see if there are any conflicting configurations.
    Executing task: nRF Connect: Generate config nrf5340dk/nrf5340/cpuapp for c:\ncs\v3.0.2\nrf\samples\crypto\rng
    Building rng
    C:\WINDOWS\system32\cmd.exe /d /s /c "west build --build-dir c:/ncs/v3.0.2/nrf/samples/crypto/rng/build c:/ncs/v3.0.2/nrf/samples/crypto/rng --pristine --board nrf5340dk/nrf5340/cpuapp --sysbuild -- -DBOARD_ROOT=c:/ncs/v3.0.2/nrf/samples/crypto/rng"
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: C:/ncs/toolchains/0b393f9e1b/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Cache files will be written to: C:/ncs/v3.0.2/zephyr/.cache
    -- Board: nrf5340dk, qualifiers: nrf5340/cpuapp
    Parsing C:/ncs/v3.0.2/zephyr/share/sysbuild/Kconfig
    Loaded configuration 'C:/ncs/v3.0.2/nrf/samples/crypto/rng/build/_sysbuild/empty.conf'
    Merged configuration 'c:/ncs/v3.0.2/nrf/samples/crypto/rng/sysbuild.conf'
    Configuration saved to 'C:/ncs/v3.0.2/nrf/samples/crypto/rng/build/zephyr/.config'
    Kconfig header saved to 'C:/ncs/v3.0.2/nrf/samples/crypto/rng/build/_sysbuild/autoconf.h'
       * Running CMake for mcuboot *
    -- Application: C:/ncs/v3.0.2/bootloader/mcuboot/boot/zephyr
    -- CMake version: 3.21.0
    -- Zephyr version: 4.0.99 (C:/ncs/v3.0.2/zephyr)
    -- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk)
    -- Found Dtc: C:/ncs/toolchains/0b393f9e1b/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/ncs/v3.0.2/zephyr/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpuapp.dts
    -- Found devicetree overlay: C:/ncs/v3.0.2/bootloader/mcuboot/boot/zephyr/app.overlay
    -- Generated zephyr.dts: C:/ncs/v3.0.2/nrf/samples/crypto/rng/build/mcuboot/zephyr/zephyr.dts
    -- Generated pickled edt: C:/ncs/v3.0.2/nrf/samples/crypto/rng/build/mcuboot/zephyr/edt.pickle
    -- Generated devicetree_generated.h: C:/ncs/v3.0.2/nrf/samples/crypto/rng/build/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/ncs/v3.0.2/nrf/samples/crypto/rng/build/mcuboot/zephyr/dts.cmake
    Parsing C:/ncs/v3.0.2/bootloader/mcuboot/boot/zephyr/Kconfig
    Loaded configuration 'C:/ncs/v3.0.2/zephyr/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpuapp_defconfig'
    Merged configuration 'C:/ncs/v3.0.2/bootloader/mcuboot/boot/zephyr/prj.conf'
    Merged configuration 'C:/ncs/v3.0.2/nrf/samples/crypto/rng/build/mcuboot/zephyr/.config.sysbuild'
    Configuration saved to 'C:/ncs/v3.0.2/nrf/samples/crypto/rng/build/mcuboot/zephyr/.config'
    Kconfig header saved to 'C:/ncs/v3.0.2/nrf/samples/crypto/rng/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: c:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
    -- Found assembler: C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    MCUBoot bootloader key file: C:/ncs/v3.0.2/bootloader/mcuboot/root-rsa-2048.pem
    CMake Warning at CMakeLists.txt:393 (message):
      WARNING: Using default MCUboot signing key file, this file is for debug use
      only and is not secure!
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/ncs/v3.0.2/nrf/samples/crypto/rng/build/mcuboot
       * Running CMake for rng *
    -- Application: C:/ncs/v3.0.2/nrf/samples/crypto/rng
    -- Generated zephyr.dts: C:/ncs/v3.0.2/nrf/samples/crypto/rng/build/rng/zephyr/zephyr.dts
    -- Generated pickled edt: C:/ncs/v3.0.2/nrf/samples/crypto/rng/build/rng/zephyr/edt.pickle
    -- Generated devicetree_generated.h: C:/ncs/v3.0.2/nrf/samples/crypto/rng/build/rng/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/ncs/v3.0.2/nrf/samples/crypto/rng/build/rng/zephyr/dts.cmake
    warning: UPDATEABLE_IMAGE_NUMBER (defined at
    C:/ncs/v3.0.2/nrf\samples\common\mcumgr_bt_ota_dfu/Kconfig:99, subsys/dfu/Kconfig:96) was assigned
    the value '1' but got the value ''. Check these unsatisfied dependencies:
    (((BOARD_THINGY53_NRF5340_CPUAPP || BOARD_THINGY53_NRF5340_CPUAPP_NS) && SOC_SERIES_NRF53X &&
    NCS_SAMPLE_MCUMGR_BT_OTA_DFU) || (!MCUBOOT && IMG_MANAGER)) (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_UPDATEABLE_IMAGE_NUMBER and/or look up
    UPDATEABLE_IMAGE_NUMBER in the menuconfig/guiconfig interface. The Application Development Primer,
    Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
    helpful too.
    warning: MCUBOOT_UPDATE_FOOTER_SIZE (defined at subsys/dfu/Kconfig:55) was assigned the value
    '0x2000' but got the value ''. Check these unsatisfied dependencies: MCUBOOT_IMG_MANAGER (=n),
    IMG_MANAGER (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MCUBOOT_UPDATE_FOOTER_SIZE and/or look up
    MCUBOOT_UPDATE_FOOTER_SIZE in the menuconfig/guiconfig interface. The Application Development
    Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
    might be helpful too.
    Parsing C:/ncs/v3.0.2/zephyr/Kconfig
    Merged configuration 'C:/ncs/v3.0.2/nrf/samples/crypto/rng/prj.conf'
    Merged configuration 'C:/ncs/v3.0.2/nrf/samples/crypto/rng/boards/nrf5340dk_nrf5340_cpuapp.conf'
    Merged configuration 'C:/ncs/v3.0.2/nrf/samples/crypto/rng/build/rng/zephyr/.config.sysbuild'
    Configuration saved to 'C:/ncs/v3.0.2/nrf/samples/crypto/rng/build/rng/zephyr/.config'
    Kconfig header saved to 'C:/ncs/v3.0.2/nrf/samples/crypto/rng/build/rng/zephyr/include/generated/zephyr/autoconf.h'
    =========== Generating psa_crypto_config ===============
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: True
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Backup: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: True
    Backup: CONFIG_MBEDTLS_THREADING: False
    Backup: CONFIG_MBEDTLS_THREADING_ALT: True
    =========== Checkpoint: backup ===============
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_C: True
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Restore: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: True
    Restore: CONFIG_MBEDTLS_THREADING: False
    Restore: CONFIG_MBEDTLS_THREADING_ALT: True
    =========== End psa_crypto_config ===============
    =========== Generating psa_crypto_library_config ===============
    Backup: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
    Backup: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    Restore: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
    Restore: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    =========== End psa_crypto_library_config ===============
    -- Including signing script: C:/ncs/v3.0.2/nrf/cmake/sysbuild/image_signing.cmake
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/ncs/v3.0.2/nrf/samples/crypto/rng/build/rng
    CMake Warning at C:/ncs/v3.0.2/nrf/cmake/sysbuild/partition_manager.cmake:121 (message):
            --- WARNING: Using a bootloader without pm_static.yml.            ---
            --- There are cases where a deployed product can consist of       ---
            --- multiple images, and only a subset of these images can be     ---
            --- upgraded through a firmware update mechanism. In such cases,  ---
            --- the upgradable images must have partitions that are static    ---
            --- and are matching the partition map used by the bootloader     ---
            --- programmed onto the device.                                   ---
      C:/ncs/v3.0.2/nrf/cmake/sysbuild/partition_manager.cmake:620 (partition_manager)
      C:/ncs/v3.0.2/nrf/sysbuild/CMakeLists.txt:779 (include)
      cmake/modules/sysbuild_extensions.cmake:583 (nrf_POST_CMAKE)
      cmake/modules/sysbuild_extensions.cmake:583 (cmake_language)
      cmake/modules/sysbuild_images.cmake:46 (sysbuild_module_call)
      cmake/modules/sysbuild_default.cmake:21 (include)
      C:/ncs/v3.0.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
      C:/ncs/v3.0.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      C:/ncs/v3.0.2/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
      template/CMakeLists.txt:10 (find_package)
    -- Configuring done
    -- Generating done
    [0/1] Re-running CMake...
    Loading Zephyr default modules (Zephyr base (cached)).
    Loaded configuration 'C:/ncs/v3.0.2/nrf/samples/crypto/rng/build/rng/zephyr/.config'
    No change to configuration in 'C:/ncs/v3.0.2/nrf/samples/crypto/rng/build/rng/zephyr/.config'
    No change to Kconfig header in 'C:/ncs/v3.0.2/nrf/samples/crypto/rng/build/rng/zephyr/include/generated/zephyr/autoconf.h'
    -- Configuring done
    -- Generating done
    [4/199] Generating include/generated/zephyr/version.h
    -- Zephyr version: 4.0.99 (C:/ncs/v3.0.2/zephyr), build: v4.0.99-ncs1-2
    [199/199] Linking C executable zephyr\zephyr.elf
               FLASH:       42240 B     491008 B      8.60%
                 RAM:       25792 B       448 KB      5.62%
            IDT_LIST:          0 GB        32 KB      0.00%
    Generating files from C:/ncs/v3.0.2/nrf/samples/crypto/rng/build/rng/zephyr/zephyr.elf for board: nrf5340dk
    image.py: sign the payload
    [6/292] Generating include/generated/zephyr/version.h
    [292/292] Linking C executable zephyr\zephyr.elf
               FLASH:       39024 B        48 KB     79.39%
                 RAM:       22760 B       448 KB      4.96%
    Generating files from C:/ncs/v3.0.2/nrf/samples/crypto/rng/build/mcuboot/zephyr/zephyr.elf for board: nrf5340dk
    [20/20] Generating ../merged.hex
    Kind Regards,
    Abhijith
  • The problem was enabling the following in the prj.conf
    CONFIG_IMG_ENABLE_IMAGE_CHECK
    The attached settings were pulled from prior SDK builds with no issues.
    Thank you for looking into this issue.
    Good to hear that! But does that mean your issue has been resolved? Please let me know if I need to look into this more.
    Kind Regards,
    Abhijith
    Glad to hear that, and don't hesitate to create a new ticket if you come across another issue.
    Abhijith
