Error programming Thingy 91X: slot_index_primary is required
I have rebuilt the sample app at_client using VS Code (Mac)
nRF Connect SDK v2.6.0 and Toolchain v2.6.0
Board target: thingy91_nrf9151
Snippets: nrf91-modem-trace-uart
I am using nRF Connect for Desktop -> Programmer v4.6.2 to program the device
File: at_client/build/zephyr/dfu_application.zip
When programming I get the following failure:
Message: Failed, Error parsing multi-image file entry: slot_index_primary is required.
Same result if I try to use command line.
Full log:
2025-07-20T21:01:38.782Z INFO Device connected with the serial number THINGY91X_941D1C15D72
2025-07-20T21:01:45.430Z INFO Getting serial port options from the persistent store for THINGY91X_941D1C15D72.pc-nrfconnect-programmer
2025-07-20T21:01:45.431Z INFO Device connected with the serial number THINGY91X_941D1C15D72
2025-07-20T21:01:45.431Z DEBUG Sending event "programmer: device connected"
2025-07-20T21:01:45.657Z INFO Getting serial port options from the persistent store for THINGY91X_941D1C15D72.pc-nrfconnect-programmer
2025-07-20T21:01:45.657Z DEBUG Sending event "programmer: device connected"
2025-07-20T21:01:45.664Z INFO Getting serial port options from the persistent store for THINGY91X_941D1C15D72.pc-nrfconnect-programmer
2025-07-20T21:01:45.664Z DEBUG Sending event "programmer: device connected"
2025-07-20T21:01:56.082Z INFO Selecting device with the serial number THINGY91X_941D1C15D72
2025-07-20T21:01:56.089Z DEBUG Sending event "programmer: running nrfutil device"
2025-07-20T21:01:56.210Z INFO Selected device with the serial number THINGY91X_941D1C15D72
2025-07-20T21:01:56.211Z DEBUG Sending event "programmer: device selected"
2025-07-20T21:02:01.650Z INFO Checking ZIP file: /Users/anders/Sources/thingy91x/at_client/build/zephyr/dfu_application.zip
2025-07-20T21:02:01.650Z INFO File was last modified at 7/18/2025, 12:36:15 PM
2025-07-20T21:02:07.003Z INFO Modem DFU starts to write...
2025-07-20T21:02:07.003Z INFO Writing /Users/anders/Sources/nrf52840dk/at_client/build/zephyr/dfu_application.zip to device THINGY91X_941D1C15D72
2025-07-20T21:02:07.006Z DEBUG Sending event "programmer: running nrfutil device"
2025-07-20T21:02:07.129Z ERROR Error: Failed with exit code 1.
One or more program tasks failed:
* THINGY91X_941D1C15D72: Error parsing multi-image file entry: slot_index_primary is required (FileOpenFailed)
2025-07-20T21:02:07.129Z ERROR Modem DFU failed with error: Error: Failed with exit code 1.
    In your VS Code screenshot board target is specified as thingy91x/nrf9151/ns while your build command shows --board thingy91x/nrf9151. Have you built the sample as secure or non-secure?
    Dejan
  • I just deleted build directory , set up environment as shown and pressed "Generate and Build". I deleted the build directory again, kept build configuration and did another "Generate and Build". This time the build target is correct, but I still get an error:
    * Executing task: nRF Connect: Generate config thingy91x/nrf9151/ns for /Users/anders/Sources/thingy91x/at_client
    Building at_client
    west build --build-dir /Users/anders/Sources/thingy91x/at_client/build /Users/anders/Sources/thingy91x/at_client --pristine --board thingy91x/nrf9151/ns
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: /opt/nordic/ncs/toolchains/ef4fc6722e/opt/[email protected]/bin/python3.12 (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Cache files will be written to: /Users/anders/Library/Caches/zephyr
    -- Board: thingy91x, qualifiers: nrf9151/ns
    Parsing /opt/nordic/ncs/v3.0.2/zephyr/share/sysbuild/Kconfig
    Loaded configuration '/Users/anders/Sources/thingy91x/at_client/build/_sysbuild/empty.conf'
    Merged configuration '/Users/anders/Sources/thingy91x/at_client/build/_sysbuild/empty.conf'
    Configuration saved to '/Users/anders/Sources/thingy91x/at_client/build/zephyr/.config'
    Kconfig header saved to '/Users/anders/Sources/thingy91x/at_client/build/_sysbuild/autoconf.h'
    * Running CMake for mcuboot *
    -- Application: /opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/zephyr
    -- CMake version: 3.21.0
    -- Found Python3: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/python (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Zephyr version: 4.0.99 (/opt/nordic/ncs/v3.0.2/zephyr)
    -- Found host-tools: zephyr 0.17.0 (/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk)
    -- Found Dtc: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
    -- Found BOARD.dts: /opt/nordic/ncs/v3.0.2/nrf/boards/nordic/thingy91x/thingy91x_nrf9151.dts
    -- Found devicetree overlay: /opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/zephyr/boards/thingy91x_nrf9151.overlay
    -- Generated zephyr.dts: /Users/anders/Sources/thingy91x/at_client/build/mcuboot/zephyr/zephyr.dts
    -- Generated pickled edt: /Users/anders/Sources/thingy91x/at_client/build/mcuboot/zephyr/edt.pickle
    -- Generated devicetree_generated.h: /Users/anders/Sources/thingy91x/at_client/build/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: /Users/anders/Sources/thingy91x/at_client/build/mcuboot/zephyr/dts.cmake
    Parsing /opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/zephyr/Kconfig
    Loaded configuration '/opt/nordic/ncs/v3.0.2/nrf/boards/nordic/thingy91x/thingy91x_nrf9151_defconfig'
    Merged configuration '/opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/zephyr/prj.conf'
    Merged configuration '/opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/zephyr/boards/thingy91x_nrf9151.conf'
    Merged configuration '/opt/nordic/ncs/v3.0.2/nrf/modules/mcuboot/tfm.conf'
    Merged configuration '/opt/nordic/ncs/v3.0.2/nrf/subsys/bootloader/bl_override/override_external_mcuboot.conf'
    Merged configuration '/opt/nordic/ncs/v3.0.2/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf'
    Merged configuration '/opt/nordic/ncs/v3.0.2/nrf/subsys/bootloader/image/log_minimal.conf'
    Merged configuration '/opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/zephyr/external_crypto.conf'
    Merged configuration '/Users/anders/Sources/thingy91x/at_client/build/mcuboot/zephyr/.config.sysbuild'
    Configuration saved to '/Users/anders/Sources/thingy91x/at_client/build/mcuboot/zephyr/.config'
    Kconfig header saved to '/Users/anders/Sources/thingy91x/at_client/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
    -- Found assembler: /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    -- Using ccache: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/ccache
    MCUBoot bootloader key file: /opt/nordic/ncs/v3.0.2/bootloader/mcuboot/root-ec-p256.pem
    CMake Warning at CMakeLists.txt:393 (message):
    WARNING: Using default MCUboot signing key file, this file is for debug use
    only and is not secure!
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /Users/anders/Sources/thingy91x/at_client/build/mcuboot
    * Running CMake for b0 *
    -- Application: /opt/nordic/ncs/v3.0.2/nrf/samples/bootloader
    -- Generated zephyr.dts: /Users/anders/Sources/thingy91x/at_client/build/b0/zephyr/zephyr.dts
    -- Generated pickled edt: /Users/anders/Sources/thingy91x/at_client/build/b0/zephyr/edt.pickle
    -- Generated devicetree_generated.h: /Users/anders/Sources/thingy91x/at_client/build/b0/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: /Users/anders/Sources/thingy91x/at_client/build/b0/zephyr/dts.cmake
    Parsing /opt/nordic/ncs/v3.0.2/zephyr/Kconfig
    Merged configuration '/opt/nordic/ncs/v3.0.2/nrf/samples/bootloader/prj.conf'
    Merged configuration '/Users/anders/Sources/thingy91x/at_client/build/b0/zephyr/.config.sysbuild'
    Configuration saved to '/Users/anders/Sources/thingy91x/at_client/build/b0/zephyr/.config'
    Kconfig header saved to '/Users/anders/Sources/thingy91x/at_client/build/b0/zephyr/include/generated/zephyr/autoconf.h'
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /Users/anders/Sources/thingy91x/at_client/build/b0
    * Running CMake for at_client *
    -- Application: /Users/anders/Sources/thingy91x/at_client
    -- Found BOARD.dts: /opt/nordic/ncs/v3.0.2/nrf/boards/nordic/thingy91x/thingy91x_nrf9151_ns.dts
    -- Generated zephyr.dts: /Users/anders/Sources/thingy91x/at_client/build/at_client/zephyr/zephyr.dts
    -- Generated pickled edt: /Users/anders/Sources/thingy91x/at_client/build/at_client/zephyr/edt.pickle
    -- Generated devicetree_generated.h: /Users/anders/Sources/thingy91x/at_client/build/at_client/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: /Users/anders/Sources/thingy91x/at_client/build/at_client/zephyr/dts.cmake
    warning: UPDATEABLE_IMAGE_NUMBER (defined at
    /opt/nordic/ncs/v3.0.2/nrf/boards/nordic/thingy91x/Kconfig.defconfig.nrf5340:92,
    /opt/nordic/ncs/v3.0.2/nrf/samples/common/mcumgr_bt_ota_dfu/Kconfig:99, subsys/dfu/Kconfig:96) was
    assigned the value '1' but got the value ''. See
    docs.zephyrproject.org/.../kconfig.html and/or look up
    UPDATEABLE_IMAGE_NUMBER in the menuconfig/guiconfig interface. The Application Development Primer,
    Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
    helpful too.
    warning: PM_DEVICE_RUNTIME (defined at soc/nordic/nrf54h/Kconfig.defconfig:45, subsys/pm/Kconfig:96)
    was assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies:
    ((SOC_SERIES_NRF54HX && SOC_FAMILY_NORDIC_NRF) || PM_DEVICE) (=n). See
    PM_DEVICE_RUNTIME in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
    too.
    warning: MCUBOOT_UPDATE_FOOTER_SIZE (defined at subsys/dfu/Kconfig:55) was assigned the value
    '0x3000' but got the value ''. Check these unsatisfied dependencies: MCUBOOT_IMG_MANAGER (=n),
    IMG_MANAGER (=n). See
    MCUBOOT_UPDATE_FOOTER_SIZE in the menuconfig/guiconfig interface. The Application Development
    Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
    might be helpful too.
    /Users/anders/Sources/thingy91x/at_client/prj.conf:14: warning: attempt to assign the value 'y' to the undefined symbol NET_SOCKETS_POSIX_NAMES
    error: Aborting due to Kconfig warnings
    Loaded configuration '/opt/nordic/ncs/v3.0.2/nrf/boards/nordic/thingy91x/thingy91x_nrf9151_ns_defconfig'
    Merged configuration '/Users/anders/Sources/thingy91x/at_client/prj.conf'
    Merged configuration '/Users/anders/Sources/thingy91x/at_client/build/at_client/zephyr/.config.sysbuild'
    CMake Error at /opt/nordic/ncs/v3.0.2/zephyr/cmake/modules/kconfig.cmake:396 (message):
    command failed with return code: 1
    /opt/nordic/ncs/v3.0.2/nrf/cmake/modules/kconfig.cmake:36 (include)
    /opt/nordic/ncs/v3.0.2/zephyr/cmake/modules/zephyr_default.cmake:133 (include)
    /opt/nordic/ncs/v3.0.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
    /opt/nordic/ncs/v3.0.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
    CMakeLists.txt:9 (find_package)
    CMake Error at cmake/modules/sysbuild_extensions.cmake:514 (message):
    CMake configure failed for Zephyr project: at_client
    cmake/modules/sysbuild_images.cmake:43 (ExternalZephyrProject_Cmake)
    cmake/modules/sysbuild_default.cmake:21 (include)
    /opt/nordic/ncs/v3.0.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
    /opt/nordic/ncs/v3.0.2/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
    template/CMakeLists.txt:10 (find_package)
    See also "/Users/anders/Sources/thingy91x/at_client/build/CMakeFiles/CMakeOutput.log".
    FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/cmake -DWEST_PYTHON=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/[email protected]/bin/python3.12 -B/Users/anders/Sources/thingy91x/at_client/build -GNinja -DBOARD=thingy91x/nrf9151/ns -S/opt/nordic/ncs/v3.0.2/zephyr/share/sysbuild -DAPP_DIR:PATH=/Users/anders/Sources/thingy91x/at_client
    * The terminal process terminated with exit code: 1.
    * Terminal will be reused by tasks, press any key to close it.
  • Deleted old at_client and started with at_client from nRF Connect SDK v3.0.2. Built successfully. Loaded on target successfully.
    Deleted build directory. Added mrf91-modem-uart-trace snippet to build configuration
    Got following build error (re-build here to shorten output):
    * Executing task: nRF Connect: Build: at_client/build (active)
    Building at_client
    [0/31] Performing build step for 'mcuboot'
    ninja: no work to do.
    [0/14] Performing build step for 'tfm'
    [5/25] Performing build step for 's1_image'
    [1/6] Linking C executable zephyr/zephyr_pre0.elf
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /Users/anders/Sources/thingy91x/at_client/build/b0/zephyr/zephyr_pre0.map
    : && ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -T zephyr/linker_zephyr_pre0.cmd -Wl,-Map=/Users/anders/Sources/thingy91x/at_client/build/b0/zephyr/zephyr_pre0.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/libarch__arm__core.a zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a zephyr/lib/libc/picolibc/liblib__libc__picolibc.a zephyr/lib/libc/common/liblib__libc__common.a zephyr/soc/soc/nrf9151/libsoc__nordic.a zephyr/drivers/clock_control/libdrivers__clock_control.a zephyr/drivers/console/libdrivers__console.a zephyr/drivers/pinctrl/libdrivers__pinctrl.a zephyr/drivers/serial/libdrivers__serial.a zephyr/drivers/timer/libdrivers__timer.a modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a modules/nrf/subsys/bootloader/bl_boot/lib..__nrf__subsys__bootloader__bl_boot.a modules/nrf/subsys/bootloader/bl_crypto/lib..__nrf__subsys__bootloader__bl_crypto.a modules/nrf/subsys/bootloader/bl_validation/lib..__nrf__subsys__bootloader__bl_validation.a modules/nrf/subsys/bootloader/bl_storage/lib..__nrf__subsys__bootloader__bl_storage.a modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a modules/nrf/drivers/hw_cc3xx/lib..__nrf__drivers__hw_cc3xx.a modules/hal_nordic/modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a -L/Users/anders/Sources/thingy91x/at_client/build/b0/zephyr zephyr/arch/common/libisr_tables.a /opt/nordic/ncs/v3.0.2/nrfxlib/crypto/nrf_oberon/lib/cortex-m33/hard-float/liboberon_3.0.16.a /opt/nordic/ncs/v3.0.2/nrfxlib/crypto/nrf_cc310_bl/lib/cortex-m33/hard-float/no-interrupts/libnrf_cc310_bl_0.9.12.a -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mfp16-format=ieee -mtp=soft -fuse-ld=bfd -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -Wl,-X -Wl,-N -Wl,--orphan-handling=warn -Wl,-no-pie -specs=picolibc.specs -DPICOLIBC_DOUBLE_PRINTF_SCANF /opt/nordic/ncs/v3.0.2/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m33/hard-float/no-interrupts/libnrf_cc310_platform_0.9.19.a -L"/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v8-m.main+fp/hard" -lc -lgcc && cd /Users/anders/Sources/thingy91x/at_client/build/b0/zephyr && /opt/nordic/ncs/toolchains/ef4fc6722e/Cellar/cmake/3.21.0/bin/cmake -E true
    /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/kernel/libkernel.a(timeout.c.obj): in function `elapsed':
    /opt/nordic/ncs/v3.0.2/zephyr/kernel/timeout.c:80: undefined reference to `sys_clock_elapsed'
    collect2: error: ld returned 1 exit status
    [12/24] cd /Users/anders/Sources/thingy91x/at_client/build/_sysbuild && /opt/nordic/ncs/toolchains/ef4fc6722e/Cellar/cmake/3.21.0/bin/cmake -E true
    FAILED: modules/nrf/b0-prefix/src/b0-stamp/b0-build /Users/anders/Sources/thingy91x/at_client/build/modules/nrf/b0-prefix/src/b0-stamp/b0-build
    cd /Users/anders/Sources/thingy91x/at_client/build/b0 && /opt/nordic/ncs/toolchains/ef4fc6722e/Cellar/cmake/3.21.0/bin/cmake --build .
    FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/cmake --build /Users/anders/Sources/thingy91x/at_client/build
    You can try to shorten the path to the sample project. Do you get different result?
    Dejan
  • Pulled new sample project to /opt/tst/at/
    This gives exact same error.
