Error when adding mcuboot for a custom nrf5340 board in the get_flash_area_from_id and dynamic partitioning
I am using a custom board with a nrf5340 and vs code with sdk/toolchain version 3.0.2 and trying to get mcuboot working for FOTA. I have been stepping through mcuboot with my segger and have breakpoints in mcuboot/main.c
I am using dynamic partitioning as recommended.
The error is happening on the second pass through this code within context_boot_go in loader.c:
        for (slot = 0; slot < BOOT_NUM_SLOTS; slot++) {
            fa_id = flash_area_id_from_multi_image_slot(image_index, slot);
            rc = flash_area_open(fa_id, &BOOT_IMG_AREA(state, slot));
            assert(rc == 0);
            if (rc != 0) {
                BOOT_LOG_ERR("Failed to open flash area ID %d (image %d slot %d): %d, "
                             "cannot continue", fa_id, image_index, (int8_t)slot, rc);
                FIH_PANIC;
  • slot = 1
  • flash_map_entries = 5
  • fa_id = 6
which calls:
int flash_area_open(uint8_t id, const struct flash_area **fap)
	const struct flash_area *area;
	if (flash_map == NULL) {
		return -EACCES;
	area = get_flash_area_from_id(id);
	if (area == NULL) {
		return -ENOENT;
	if (!device_is_ready(area->fa_dev)) {
		return -ENODEV;
	*fap = area;
	return 0;
  • id = 6
which calls flash_map_priv.h:
static inline struct flash_area const *get_flash_area_from_id(int idx)
	for (int i = 0; i < flash_map_entries; i++) {
		if (flash_map[i].fa_id == idx) {
			return &flash_map[i];
	return NULL;
  • i=4
  • flash_map[i].fa_id = 5
This call returns a -2:
  • slot = 1
and finally dies on this call in nrf53_cpunet_mgmt.c
static void onoff_stop(struct onoff_manager *mgr, onoff_notify_fn notify)
	nrf_reset_network_force_off(NRF_RESET, true);
	notify(mgr, 0);
Here is the flash:
When I have SB_CONFIG_BOOTLOADER_MCUBOOT=n it runs
I have read Simultaneous updates for both cores of the nRF5340, but get errors when I get to:
 # STEP 7.2 - Add b0n image
SB_CONFIG_SECURE_BOOT_NETCORE=y
the error is:
In file included from /opt/nordic/ncs/v3.0.2/nrf/include/dfu/pcd.h:28,
                 from /opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/zephyr/main.c:96:
/opt/nordic/ncs/v3.0.2/nrf/include/dfu/pcd_common.h: In function 'pcd_write_cmd_lock_debug':
/opt/nordic/ncs/v3.0.2/nrf/include/dfu/pcd_common.h:39:25: error: 'PM__PCD_SRAM_ADDRESS' undeclared (first use in this function); did you mean 'PM_SRAM_ADDRESS'?
I have also looked at Exercise 5 – FOTA over Bluetooth Low Energy and loosly followed it, but there are a lot of differences with my using a custom board and spi external flash.
My regions.yml looks like this when I build successfully:
external_flash:
  base_address: 0x0
  default_driver_kconfig: CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK
  device: DT_CHOSEN(nordic_pm_ext_flash)
  dynamic_partition: null
  placement_strategy: start_to_end
flash_primary:
  base_address: 0x0
  default_driver_kconfig: CONFIG_SOC_FLASH_NRF
  device: flash_controller
  placement_strategy: complex
otp:
  base_address: 0xff8100
  default_driver_kconfig: ''
  device: ''
sram_primary:
  base_address: 0x20000000
  device: ''
  dynamic_partition: sram_primary
and my partitions.yml look like this:
app:
  address: 0xc200
  end_address: 0x100000
  region: flash_primary
external_flash:
  address: 0xcf4000
  end_address: 0x1000000
  region: external_flash
littlefs_storage:
  address: 0x0
  end_address: 0xc00000
  placement:
    before:
    - tfm_storage
    - end
mcuboot:
  address: 0x0
  end_address: 0xc000
  placement:
    align:
      end: 0x1000
    before:
    - mcuboot_primary
mcuboot_pad:
  address: 0xc000
  end_address: 0xc200
  placement:
    before:
    - mcuboot_primary_app
mcuboot_primary:
  address: 0xc000
  orig_span: &id001
  - mcuboot_pad
  - app
  span: *id001
mcuboot_primary_app:
  address: 0xc200
  orig_span: &id002
  - app
  span: *id002
mcuboot_secondary:
  address: 0xc00000
  end_address: 0xcf4000
  placement:
    align:
      start: 0x4
  share_size:
  - mcuboot_primary
otp:
  address: 0xff8100
  end_address: 0xff83fc
  region: otp
rpmsg_nrf53_sram:
  address: 0x20070000
  end_address: 0x20080000
  placement:
    before:
    - end
  region: sram_primary
sram_primary:
  address: 0x20000000
  end_address: 0x20070000
