Undefined reference to mbedtls_sha256
Hello, we are currently migrating from nRF Connect v2.9.1 to v3.0.2. When doing so, we found that the tinycrypt API was deprecated and decided to move things to mbedtls. We got things to build when we have Bluetooth Security Manager Protocol (SMP) disabled, however, once we enable the security manager protocol, we run into a build error where the mbedtls functions are not defined (due to NRF_SECURITY being enabled).
Is there a configuration that will allow us to use the mbedtls functions without disabling SMP? If not, is there a way to compute the hash through Zephyr?
  • Hi Dejan,
    all of the configs above are shown (They were combined). I went ahead and attached the files here.
    4572.prj.conf
    shell.conf
    5153.common.conf
    -- west build: making build dir /home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/build pristine
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: /home/tschmitz/ncs/toolchains/7cbc0036f4/usr/local/bin/python3.12 (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Cache files will be written to: /home/tschmitz/.cache/zephyr
    CMake Warning at /home/tschmitz/ncs/v3.0.2/zephyr/cmake/modules/boards.cmake:136 (message):
      BOARD_ROOT element without a 'boards' subdirectory:
      /home/tschmitz/advanced-optronic/pcap04-zephyr
      Hints:
        - if your board directory is '/foo/bar/boards/my_board' then add '/foo/bar' to BOARD_ROOT, not the entire board directory
        - if in doubt, use absolute paths
      cmake/modules/sysbuild_default.cmake:15 (include)
      /home/tschmitz/ncs/v3.0.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
      /home/tschmitz/ncs/v3.0.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      /home/tschmitz/ncs/v3.0.2/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
      template/CMakeLists.txt:10 (find_package)
    -- Board: nrf52840dk, qualifiers: nrf52840
    Parsing /home/tschmitz/ncs/v3.0.2/zephyr/share/sysbuild/Kconfig
    Loaded configuration '/home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/build/_sysbuild/empty.conf'
    Merged configuration '/home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/build/_sysbuild/empty.conf'
    Configuration saved to '/home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/build/zephyr/.config'
    Kconfig header saved to '/home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/build/_sysbuild/autoconf.h'
       * Running CMake for firmware *
    -- Application: /home/tschmitz/advanced-optronics/pcap04-zephyr/firmware
    -- CMake version: 3.21.0
    -- Found Python3: /home/tschmitz/ncs/toolchains/7cbc0036f4/usr/local/bin/python (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Zephyr version: 4.0.99 (/home/tschmitz/ncs/v3.0.2/zephyr)
      Hints:
      /home/tschmitz/ncs/v3.0.2/zephyr/cmake/modules/zephyr_default.cmake:133 (include)
      /home/tschmitz/ncs/v3.0.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
      CMakeLists.txt:2 (find_package)
    -- Found host-tools: zephyr 0.17.0 (/home/tschmitz/ncs/toolchains/7cbc0036f4/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (/home/tschmitz/ncs/toolchains/7cbc0036f4/opt/zephyr-sdk)
    -- Found Dtc: /home/tschmitz/ncs/toolchains/7cbc0036f4/usr/bin/dtc (found suitable version "1.5.0", minimum required is "1.4.6")
    -- Found BOARD.dts: /home/tschmitz/ncs/v3.0.2/zephyr/boards/nordic/nrf52840dk/nrf52840dk_nrf52840.dts
    -- Found devicetree overlay: overlay/nrf52840dk.overlay
    node '/settings' compatible 'advanced-optronics,static-settings' has unknown vendor prefix 'advanced-optronics'
    -- Generated zephyr.dts: /home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/build/firmware/zephyr/zephyr.dts
    -- Generated pickled edt: /home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/build/firmware/zephyr/edt.pickle
    -- Generated devicetree_generated.h: /home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/build/firmware/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: /home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/build/firmware/zephyr/dts.cmake
    warning: LOG_PRINTK (defined at subsys/logging/Kconfig.processing:8) was assigned the value 'y' but
    got the value 'n'. Check these unsatisfied dependencies: LOG (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_LOG_PRINTK and/or look up LOG_PRINTK in the
    menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values,
    and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
    warning: LOG_BACKEND_UART (defined at subsys/logging/backends/Kconfig.uart:4) was assigned the value
    'y' but got the value 'n'. Check these unsatisfied dependencies: LOG (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_LOG_BACKEND_UART and/or look up
    LOG_BACKEND_UART in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
    too.
    warning: SHELL_LOG_BACKEND (defined at subsys/shell/Kconfig:272) was assigned the value 'y' but got
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_SHELL_LOG_BACKEND and/or look up
    SHELL_LOG_BACKEND in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    too.
    warning: The choice symbol MBEDTLS_BUILTIN (defined at modules/mbedtls/Kconfig:30,
    modules/mbedtls/Kconfig:30) was selected (set =y), but MBEDTLS_LIBRARY_NRF_SECURITY (defined at
    /home/tschmitz/ncs/v3.0.2/nrf/subsys/nrf_security/Kconfig:250) ended up as the choice selection. See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_BUILTIN and/or look up
    MBEDTLS_BUILTIN in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    too.
    Parsing /home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/Kconfig
    Loaded configuration '/home/tschmitz/ncs/v3.0.2/zephyr/boards/nordic/nrf52840dk/nrf52840dk_nrf52840_defconfig'
    Merged configuration '/home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/prj.conf'
    Merged configuration '/home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/config/shell.conf'
    Merged configuration '/home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/ao-common/common.conf'
    Merged configuration '/home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/build/firmware/zephyr/.config.sysbuild'
    Configuration saved to '/home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/build/firmware/zephyr/.config'
    Kconfig header saved to '/home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/build/firmware/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: /home/tschmitz/ncs/toolchains/7cbc0036f4/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
    -- Found assembler: /home/tschmitz/ncs/toolchains/7cbc0036f4/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    =========== Generating psa_crypto_config ===============
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: True
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Backup: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Backup: CONFIG_MBEDTLS_THREADING: False
    Backup: CONFIG_MBEDTLS_THREADING_ALT: True
    =========== Checkpoint: backup ===============
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_C: True
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Restore: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Restore: CONFIG_MBEDTLS_THREADING: False
    Restore: CONFIG_MBEDTLS_THREADING_ALT: True
    =========== End psa_crypto_config ===============
    =========== Generating psa_crypto_library_config ===============
    Backup: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
    Backup: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    Restore: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
    Restore: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    =========== End psa_crypto_library_config ===============
    -- Using ccache: /home/tschmitz/ncs/toolchains/7cbc0036f4/usr/bin/ccache
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/build/firmware
    -- Configuring done
    -- Generating done
    [1/10] Creating directories for 'firmware'
    [2/10] No download step for 'firmware'
    [3/10] No update step for 'firmware'
    [4/10] No patch step for 'firmware'
    [5/10] No configure step for 'firmware'
    [5/10] Performing build step for 'firmware'
    [1/348] Preparing syscall dependency handling
    [2/348] Generating ../../zephyr/include/generated/zephyr_commit.h
    [3/348] Generating ../../zephyr/include/generated/ncs_commit.h
    [4/348] Generating ../../zephyr/include/generated/ncs_version.h
    [5/348] Generating include/generated/zephyr/app_version.h
    [6/348] Generating include/generated/zephyr/version.h
    -- Zephyr version: 4.0.99 (/home/tschmitz/ncs/v3.0.2/zephyr), build: v4.0.99-ncs1-2
    [7/348] Generating misc/generated/syscalls_subdirs.trigger
    [8/348] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [9/348] Generating include/generated/device-api-sections.ld, include/generated/device-api-sections.cmake
    [10/348] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscall_exports_llext.c, syscall_weakdefs_llext.c, include/generated/zephyr/syscall_list.h
    [11/348] Generating include/generated/zephyr/driver-validation.h
    [12/348] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, include/generated/zephyr/otype-to-size.h
    [13/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/mbedtls/library/pem.c.obj
    [14/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/mbedtls/library/memory_buffer_alloc.c.obj
    [15/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/mbedtls/library/dhm.c.obj
    [16/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/mbedtls/library/pkcs12.c.obj
    [17/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/mbedtls/library/pkcs5.c.obj
    [18/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/mbedtls/library/pkparse.c.obj
    [19/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/mbedtls/library/md.c.obj
    [20/348] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [21/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/mbedtls/library/pkwrite.c.obj
    [22/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/mbedtls/library/cipher.c.obj
    [23/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/mbedtls/library/cipher_wrap.c.obj
    [24/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/oberon-psa-crypto/programs/ssl/library/pk.c.obj
    [25/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/mbedtls/library/pk_ecc.c.obj
    [26/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/mbedtls/library/pk_wrap.c.obj
    [27/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/mbedtls/library/psa_util.c.obj
    [28/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_mutexes.c.obj
    [29/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_events.c.obj
    [30/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/mbedtls/library/oid.c.obj
    [31/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/mbedtls/library/asn1parse.c.obj
    [32/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/mbedtls/library/asn1write.c.obj
    [33/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/mbedtls/library/base64.c.obj
    [34/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/mbedtls/library/bignum.c.obj
    [35/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/mbedtls/library/bignum_core.c.obj
    [36/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/mbedtls/library/block_cipher.c.obj
    [37/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/mbedtls/library/nist_kw.c.obj
    [38/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/mbedtls/library/padlock.c.obj
    [39/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/mbedtls/library/version.c.obj
    [40/348] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/mbedtls/library/constant_time.c.obj
    [41/348] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/oberon-psa-crypto/library/platform_util.c.obj
    [42/348] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/oberon-psa-crypto/library/platform.c.obj
    [43/348] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/oberon-psa-crypto/library/psa_crypto_client.c.obj
    [44/348] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/oberon-psa-crypto/library/psa_crypto.c.obj
    [45/348] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/oberon-psa-crypto/library/psa_crypto_slot_management.c.obj
    [46/348] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/oberon-psa-crypto/library/psa_crypto_storage.c.obj
    [47/348] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tschmitz/ncs/v3.0.2/nrf/subsys/nrf_security/src/psa_crypto_driver_wrappers.c.obj
    [48/348] Building C object modules/nrf/subsys/nrf_security/src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_helpers.c.obj
    [49/348] Building C object modules/nrf/subsys/nrf_security/src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_ecdh.c.obj
    [50/348] Building C object modules/nrf/subsys/nrf_security/src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_ecdsa.c.obj
    [51/348] Building C object modules/nrf/subsys/nrf_security/src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_ec_keys.c.obj
    [52/348] Building C object modules/nrf/subsys/nrf_security/src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_jpake.c.obj
    [53/348] Building C object modules/nrf/subsys/nrf_security/src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_spake2p.c.obj
    [54/348] Building C object modules/nrf/subsys/nrf_security/src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_srp.c.obj
    [55/348] Building C object modules/nrf/subsys/nrf_security/src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_rsa.c.obj
    [56/348] Building C object modules/nrf/subsys/nrf_security/src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_wpa3_sae.c.obj
    [57/348] Building C object modules/nrf/subsys/nrf_security/src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_key_management.c.obj
    [58/348] Building C object modules/nrf/subsys/nrf_security/src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_cipher.c.obj
    [59/348] Building C object modules/nrf/subsys/nrf_security/src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_hash.c.obj
    [60/348] Linking C static library modules/nrf/subsys/nrf_security/src/libnrf_security_utils.a
    [61/348] Building C object modules/nrf/subsys/nrf_security/src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_mac.c.obj
    [62/348] Building C object modules/nrf/subsys/nrf_security/src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/home/tschmitz/ncs/v3.0.2/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_key_agreement.c.obj
    [63/348] Linking C static library modules/nrf/subsys/nrf_security/src/libmbedcrypto_base.a
    [64/348] Linking C static library modules/nrf/subsys/nrf_security/src/drivers/nrf_oberon/liboberon_psa_driver.a
    [65/348] Linking C static library modules/nrf/subsys/nrf_security/src/core/nrf_oberon/liboberon_psa_core.a
    [66/348] Linking C static library modules/nrf/subsys/nrf_security/src/libmbedcrypto.a
    [67/348] Generating include/generated/zephyr/offsets.h
    [68/348] Building C object CMakeFiles/app.dir/src/ble/ble_app_peripheral.c.obj
    [69/348] Building C object CMakeFiles/app.dir/src/ao_version.c.obj
    [70/348] Building C object CMakeFiles/app.dir/src/button.c.obj
    [71/348] Building C object CMakeFiles/app.dir/src/commands.c.obj
    [72/348] Building C object CMakeFiles/app.dir/src/datetime.c.obj
    [73/348] Building C object CMakeFiles/app.dir/src/main.c.obj
    [74/348] Building C object CMakeFiles/app.dir/src/op_modes.c.obj
    [75/348] Building C object CMakeFiles/app.dir/src/led.c.obj
    [76/348] Building C object CMakeFiles/app.dir/src/sensor_stream.c.obj
    [77/348] Building C object CMakeFiles/app.dir/src/pcap.c.obj
    /home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/src/pcap.c: In function 'get_single_result':
    /home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/src/pcap.c:810:9: warning: unused variable 'err' [-Wunused-variable]
      810 |     int err;
    [78/348] Building C object CMakeFiles/app.dir/src/settings.c.obj
    [79/348] Building C object CMakeFiles/app.dir/src/spi.c.obj
    [80/348] Building C object CMakeFiles/app.dir/src/ble/services/aos.c.obj
    [81/348] Building C object CMakeFiles/app.dir/src/shell/shell.c.obj
    [82/348] Building C object CMakeFiles/app.dir/src/shell/login.c.obj
    [83/348] Building C object zephyr/CMakeFiles/zephyr.dir/home/tschmitz/ncs/v3.0.2/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
    [84/348] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc32_sw.c.obj
    [85/348] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc24_sw.c.obj
    [86/348] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc16_sw.c.obj
    [87/348] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc8_sw.c.obj
    [88/348] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc32c_sw.c.obj
    [89/348] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc7_sw.c.obj
    [90/348] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc4_sw.c.obj
    [91/348] Building C object zephyr/CMakeFiles/zephyr.dir/lib/heap/heap.c.obj
    [92/348] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [93/348] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [94/348] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [95/348] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [96/348] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [97/348] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [98/348] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/poweroff.c.obj
    [99/348] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/dec.c.obj
    [100/348] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/hex.c.obj
    [101/348] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/rb.c.obj
    [102/348] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/timeutil.c.obj
    [103/348] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/bitarray.c.obj
    [104/348] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/onoff.c.obj
    [105/348] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/notify.c.obj
    [106/348] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/ring_buffer.c.obj
    [107/348] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/last_section_id.c.obj
    [108/348] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [109/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/nvs/nvs.c.obj
    [110/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/mem_mgmt/mem_attr.c.obj
    [111/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [112/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
    [113/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
    [114/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings.c.obj
    [115/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_store.c.obj
    [116/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/modules/kernel_service/kernel_shell.c.obj
    [117/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_init.c.obj
    [118/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_line.c.obj
    [119/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_nvs.c.obj
    [120/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/modules/kernel_service/thread/thread.c.obj
    [121/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/modules/kernel_service/cycles.c.obj
    [122/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/modules/kernel_service/sleep.c.obj
    [123/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/modules/kernel_service/uptime.c.obj
    [124/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/modules/kernel_service/version.c.obj
    [125/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/modules/kernel_service/thread/list.c.obj
    [126/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/modules/kernel_service/thread/stacks.c.obj
    [127/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_fprintf.c.obj
    [128/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell.c.obj
    [129/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/modules/device_service.c.obj
    [130/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/modules/devmem_service.c.obj
    [131/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/backends/shell_uart.c.obj
    [132/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_utils.c.obj
    [133/348] Linking C static library app/libapp.a
    [134/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_ops.c.obj
    [135/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_help.c.obj
    [136/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_cmds.c.obj
    [137/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_history.c.obj
    [138/348] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_wildcard.c.obj
    [139/348] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/flash/flash_util.c.obj
    [140/348] Building C object zephyr/CMakeFiles/zephyr.dir/home/tschmitz/ncs/v3.0.2/nrf/lib/boot_banner/banner.c.obj
    [141/348] Building C object zephyr/CMakeFiles/zephyr.dir/home/tschmitz/ncs/v3.0.2/nrf/subsys/bluetooth/hci_vs_sdc.c.obj
    [142/348] Building C object zephyr/CMakeFiles/zephyr.dir/home/tschmitz/ncs/v3.0.2/nrf/subsys/bluetooth/host_extensions/host_extensions.c.obj
    [143/348] Building C object zephyr/CMakeFiles/zephyr.dir/home/tschmitz/ncs/v3.0.2/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
    [144/348] Building C object zephyr/CMakeFiles/zephyr.dir/home/tschmitz/ncs/v3.0.2/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [145/348] Building C object zephyr/CMakeFiles/zephyr.dir/home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/ao-common/src/ao_error.c.obj
    [146/348] Building C object zephyr/CMakeFiles/zephyr.dir/home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/ao-common/src/ao_frame.c.obj
    [147/348] Building C object zephyr/CMakeFiles/zephyr.dir/home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/ao-common/pcap04-driver/src/core/pcap04_default_config.c.obj
    [148/348] Building C object zephyr/CMakeFiles/zephyr.dir/home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/ao-common/pcap04-driver/src/core/pcap04_firmware.c.obj
    [149/348] Building C object modules/nrf/lib/dk_buttons_and_leds/CMakeFiles/..__nrf__lib__dk_buttons_and_leds.dir/dk_buttons_and_leds.c.obj
    [150/348] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [151/348] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [152/348] Building C object zephyr/CMakeFiles/zephyr.dir/home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/ao-common/pcap04-driver/src/pcap04_api.c.obj
    /home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/ao-common/pcap04-driver/src/pcap04_api.c:226:12: warning: 's_lock_memory' defined but not used [-Wunused-function]
      226 | static int s_lock_memory(struct pcap04_device *device) {
    /home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/ao-common/pcap04-driver/src/pcap04_api.c:136:12: warning: 's_read_config_reg' defined but not used [-Wunused-function]
      136 | static int s_read_config_reg(struct pcap04_device *device, uint8_t address,
    [153/348] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/fatal.c.obj
    [154/348] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi.c.obj
    [155/348] Building ASM object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi_on_reset.S.obj
    [156/348] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/tls.c.obj
    [157/348] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault.c.obj
    [158/348] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/exc_exit.c.obj
    [159/348] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault_s.S.obj
    [160/348] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/reset.S.obj
    [161/348] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fpu.c.obj
    [162/348] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/scb.c.obj
    [163/348] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread_abort.c.obj
    [164/348] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/vector_table.S.obj
    [165/348] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/swap_helper.S.obj
    [166/348] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_manage.c.obj
    [167/348] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/prep_c.c.obj
    [168/348] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread.c.obj
    [169/348] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/cpu_idle.c.obj
    [170/348] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_init.c.obj
    [171/348] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/isr_wrapper.c.obj
    [172/348] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/__aeabi_read_tp.S.obj
    [173/348] Linking C static library zephyr/arch/common/libisr_tables.a
    [174/348] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_core_mpu.c.obj
    [175/348] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu.c.obj
    [176/348] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu_regions.c.obj
    [177/348] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/assert.c.obj
    [178/348] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/cbprintf.c.obj
    [179/348] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/chk_fail.c.obj
    [180/348] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/errno_wrap.c.obj
    [181/348] Linking C static library zephyr/arch/arch/arm/core/libarch__arm__core.a
    [182/348] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/exit.c.obj
    [183/348] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/locks.c.obj
    [184/348] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/stdio.c.obj
    [185/348] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/abort.c.obj
    [186/348] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/malloc.c.obj
    [187/348] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/getopt/getopt_common.c.obj
    [188/348] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/fnmatch.c.obj
    [189/348] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/getentropy.c.obj
    [190/348] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/getopt/getopt.c.obj
    [191/348] Building C object zephyr/soc/soc/nrf52840/CMakeFiles/soc__nordic.dir/validate_binding_headers.c.obj
    [192/348] Linking C static library zephyr/arch/common/libarch__common.a
    [193/348] Building C object zephyr/lib/net_buf/CMakeFiles/lib__net_buf.dir/buf.c.obj
    [194/348] Building C object zephyr/lib/net_buf/CMakeFiles/lib__net_buf.dir/buf_simple.c.obj
    [195/348] Building C object zephyr/soc/soc/nrf52840/CMakeFiles/soc__nordic.dir/validate_base_addresses.c.obj
    [196/348] Building C object zephyr/soc/soc/nrf52840/CMakeFiles/soc__nordic.dir/validate_enabled_instances.c.obj
    [197/348] Building C object zephyr/soc/soc/nrf52840/CMakeFiles/soc__nordic.dir/nrf52/soc.c.obj
    [198/348] Building C object zephyr/soc/soc/nrf52840/CMakeFiles/soc__nordic.dir/common/reboot.c.obj
    [199/348] Linking C static library zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a
    [200/348] Linking C static library zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a
    [201/348] Building C object zephyr/soc/soc/nrf52840/CMakeFiles/soc__nordic.dir/common/poweroff.c.obj
    [202/348] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/random_xoshiro128.c.obj
    [203/348] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/random_entropy_device.c.obj
    [204/348] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/addr.c.obj
    [205/348] Linking C static library zephyr/lib/libc/picolibc/liblib__libc__picolibc.a
    [206/348] Linking C static library zephyr/lib/libc/common/liblib__libc__common.a
    [207/348] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/rpa.c.obj
    [208/348] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/dummy.c.obj
    [209/348] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/bt_str.c.obj
    [210/348] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/settings.c.obj
    [211/348] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/long_wq.c.obj
    [212/348] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/uuid.c.obj
    [213/348] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/addr.c.obj
    [214/348] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/buf.c.obj
    [215/348] Linking C static library zephyr/lib/posix/options/liblib__posix__options.a
    [216/348] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/data.c.obj
    [217/348] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_core.c.obj
    [218/348] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/id.c.obj
    [219/348] Linking C static library zephyr/lib/net_buf/liblib__net_buf.a
    [220/348] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_common.c.obj
    [221/348] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/adv.c.obj
    [222/348] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/ecc.c.obj
    [223/348] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/conn.c.obj
    [224/348] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/l2cap.c.obj
    [225/348] Linking C static library zephyr/subsys/random/libsubsys__random.a
    [226/348] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/att.c.obj
    [227/348] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/gatt.c.obj
    [228/348] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/smp.c.obj
    [229/348] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/keys.c.obj
    [230/348] Building C object zephyr/subsys/bluetooth/crypto/CMakeFiles/subsys__bluetooth__crypto.dir/bt_crypto.c.obj
    [231/348] Building C object zephyr/subsys/bluetooth/crypto/CMakeFiles/subsys__bluetooth__crypto.dir/bt_crypto_psa.c.obj
    [232/348] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
    [233/348] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/entropy_nrf5.c.obj
    [234/348] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/home/tschmitz/ncs/v3.0.2/nrf/drivers/entropy/entropy_cc3xx.c.obj
    [235/348] Linking C static library zephyr/libzephyr.a
    [236/348] Linking C static library zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a
    [237/348] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [238/348] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/entropy_bt_hci.c.obj
    [239/348] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/nrf_qspi_nor.c.obj
    [240/348] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/jesd216.c.obj
    [241/348] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
    [242/348] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [243/348] Generating linker_zephyr_pre0.cmd
    [244/348] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
    [245/348] Building C object zephyr/drivers/hwinfo/CMakeFiles/drivers__hwinfo.dir/hwinfo_nrf.c.obj
    [246/348] Building C object zephyr/drivers/hwinfo/CMakeFiles/drivers__hwinfo.dir/hwinfo_weak_impl.c.obj
    [247/348] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [248/348] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [249/348] Building C object zephyr/drivers/pwm/CMakeFiles/drivers__pwm.dir/pwm_nrfx.c.obj
    [250/348] Linking C static library zephyr/soc/soc/nrf52840/libsoc__nordic.a
    [251/348] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [252/348] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spi.c.obj
    [253/348] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_common.c.obj
    [254/348] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spim.c.obj
    [255/348] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [256/348] Linking C static library zephyr/subsys/bluetooth/crypto/libsubsys__bluetooth__crypto.a
    [257/348] Linking C static library zephyr/drivers/console/libdrivers__console.a
    [258/348] Linking C static library zephyr/drivers/entropy/libdrivers__entropy.a
    [259/348] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [260/348] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [261/348] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [262/348] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a
    [263/348] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a
    [264/348] Linking C static library zephyr/drivers/pwm/libdrivers__pwm.a
    [265/348] Building C object modules/nrf/lib/multithreading_lock/CMakeFiles/..__nrf__lib__multithreading_lock.dir/multithreading_lock.c.obj
    [266/348] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_internal_wrappers.c.obj
    [267/348] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_driver.c.obj
    [268/348] Linking C static library zephyr/drivers/hwinfo/libdrivers__hwinfo.a
    [269/348] Linking C static library modules/nrf/lib/dk_buttons_and_leds/lib..__nrf__lib__dk_buttons_and_leds.a
    [270/348] Linking C static library zephyr/drivers/serial/libdrivers__serial.a
    [271/348] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_internal.c.obj
    [272/348] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/crypto.c.obj
    [273/348] Building C object modules/nrf/subsys/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/mbedtls_heap.c.obj
    [274/348] Building C object modules/nrf/subsys/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/psa_crypto_init.c.obj
    [275/348] Linking C static library zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a
    [276/348] Linking C static library zephyr/drivers/flash/libdrivers__flash.a
    [277/348] Building C object modules/nrf/subsys/mpsl/init/CMakeFiles/..__nrf__subsys__mpsl__init.dir/mpsl_init.c.obj
    [278/348] Building C object modules/nrf/subsys/mpsl/fem/CMakeFiles/..__nrf__subsys__mpsl__fem.dir/api_init/mpsl_fem_api_init.c.obj
    [279/348] Building C object modules/nrf/drivers/hw_cc3xx/CMakeFiles/..__nrf__drivers__hw_cc3xx.dir/hw_cc3xx.c.obj
    [280/348] Building C object modules/nrf/drivers/mpsl/clock_control/CMakeFiles/..__nrf__drivers__mpsl__clock_control.dir/nrfx_clock_mpsl.c.obj
    [281/348] Linking C static library zephyr/drivers/spi/libdrivers__spi.a
    [282/348] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [283/348] Building C object modules/nrf/drivers/mpsl/flash_sync/CMakeFiles/..__nrf__drivers__mpsl__flash_sync.dir/flash_sync_mpsl.c.obj
    [284/348] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tschmitz/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [285/348] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tschmitz/ncs/v3.0.2/modules/hal/nordic/nrfx/mdk/system_nrf52840.c.obj
    [286/348] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [287/348] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tschmitz/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_ram_ctrl.c.obj
    [288/348] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tschmitz/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_gppi_dppi.c.obj
    [289/348] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tschmitz/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_gppi_ppi.c.obj
    [290/348] Linking C static library modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a
    [291/348] Linking C static library modules/nrf/subsys/nrf_security/src/zephyr/libmbedtls_zephyr.a
    [292/348] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tschmitz/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [293/348] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tschmitz/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [294/348] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tschmitz/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_ppi.c.obj
    [295/348] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tschmitz/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_pwm.c.obj
    [296/348] Linking C static library modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a
    [297/348] Linking C static library modules/nrf/subsys/mpsl/init/lib..__nrf__subsys__mpsl__init.a
    [298/348] Linking C static library modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a
    [299/348] Linking C static library modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a
    [300/348] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tschmitz/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_qspi.c.obj
    [301/348] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tschmitz/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_spi.c.obj
    [302/348] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tschmitz/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_spim.c.obj
    [303/348] Building C object modules/segger/CMakeFiles/modules__segger.dir/home/tschmitz/ncs/v3.0.2/modules/debug/segger/SEGGER/SEGGER_RTT.c.obj
    [304/348] Linking C static library modules/nrf/drivers/hw_cc3xx/lib..__nrf__drivers__hw_cc3xx.a
    [305/348] Linking C static library modules/nrf/drivers/mpsl/flash_sync/lib..__nrf__drivers__mpsl__flash_sync.a
    [306/348] Building C object modules/segger/CMakeFiles/modules__segger.dir/SEGGER_RTT_zephyr.c.obj
    [307/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [308/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [309/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/busy_wait.c.obj
    [310/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [311/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [312/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [313/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init_static.c.obj
    [314/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [315/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [316/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [317/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/float.c.obj
    [318/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [319/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [320/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [321/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [322/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [323/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [324/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [325/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [326/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [327/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [328/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [329/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/priority_queues.c.obj
    [330/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [331/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [332/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeslicing.c.obj
    [333/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread_monitor.c.obj
    [334/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [335/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [336/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [337/348] Linking C static library modules/segger/libmodules__segger.a
    [338/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/poll.c.obj
    [339/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/dynamic_disabled.c.obj
    [340/348] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [341/348] Linking C static library modules/hal_nordic/modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [342/348] Linking C static library zephyr/kernel/libkernel.a
    [343/348] Linking C executable zephyr/zephyr_pre0.elf
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/build/firmware/zephyr/zephyr_pre0.map
    : && ccache /home/tschmitz/ncs/toolchains/7cbc0036f4/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc  -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/build/firmware/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/libarch__arm__core.a  zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a  zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a  zephyr/lib/libc/picolibc/liblib__libc__picolibc.a  zephyr/lib/libc/common/liblib__libc__common.a  zephyr/lib/posix/options/liblib__posix__options.a  zephyr/lib/net_buf/liblib__net_buf.a  zephyr/soc/soc/nrf52840/libsoc__nordic.a  zephyr/subsys/random/libsubsys__random.a  zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a  zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a  zephyr/subsys/bluetooth/crypto/libsubsys__bluetooth__crypto.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/entropy/libdrivers__entropy.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/hwinfo/libdrivers__hwinfo.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  zephyr/drivers/pwm/libdrivers__pwm.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/spi/libdrivers__spi.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/lib/dk_buttons_and_leds/lib..__nrf__lib__dk_buttons_and_leds.a  modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a  modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a  modules/nrf/subsys/nrf_security/src/zephyr/libmbedtls_zephyr.a  modules/nrf/subsys/mpsl/init/lib..__nrf__subsys__mpsl__init.a  modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a  modules/nrf/drivers/hw_cc3xx/lib..__nrf__drivers__hw_cc3xx.a  modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a  modules/nrf/drivers/mpsl/flash_sync/lib..__nrf__drivers__mpsl__flash_sync.a  modules/hal_nordic/modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  modules/segger/libmodules__segger.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L/home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/build/firmware/zephyr  zephyr/arch/common/libisr_tables.a  -mcpu=cortex-m4  -mthumb  -mabi=aapcs  -mfp16-format=ieee  -mtp=soft  -fuse-ld=bfd  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -Wl,-no-pie  -specs=picolibc.specs  -DPICOLIBC_LONG_LONG_PRINTF_SCANF  modules/nrf/subsys/nrf_security/src/libmbedcrypto.a  modules/nrf/subsys/nrf_security/src/core/nrf_oberon/liboberon_psa_core.a  modules/nrf/subsys/nrf_security/src/drivers/nrf_oberon/liboberon_psa_driver.a  /home/tschmitz/ncs/v3.0.2/nrfxlib/crypto/nrf_oberon/lib/cortex-m4/soft-float/liboberon_mbedtls_3.0.16.a  modules/nrf/subsys/nrf_security/src/libmbedcrypto.a  modules/nrf/subsys/nrf_security/src/core/nrf_oberon/liboberon_psa_core.a  modules/nrf/subsys/nrf_security/src/drivers/nrf_oberon/liboberon_psa_driver.a  /home/tschmitz/ncs/v3.0.2/nrfxlib/crypto/nrf_oberon/lib/cortex-m4/soft-float/liboberon_mbedtls_3.0.16.a  /home/tschmitz/ncs/v3.0.2/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m4/soft-float/no-interrupts/libnrf_cc310_platform_0.9.19.a  modules/nrf/subsys/nrf_security/src/libmbedcrypto_base.a  modules/nrf/subsys/nrf_security/src/libnrf_security_utils.a  zephyr/kernel/libkernel.a  /home/tschmitz/ncs/v3.0.2/nrfxlib/crypto/nrf_oberon/lib/cortex-m4/soft-float/liboberon_3.0.16.a  /home/tschmitz/ncs/v3.0.2/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_peripheral.a  /home/tschmitz/ncs/v3.0.2/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a  /home/tschmitz/ncs/v3.0.2/nrfxlib/mpsl/fem/nrf21540_gpio/lib/nrf52/soft-float/libmpsl_fem_nrf21540_gpio.a  /home/tschmitz/ncs/v3.0.2/nrfxlib/mpsl/fem/nrf21540_gpio_spi/lib/nrf52/soft-float/libmpsl_fem_nrf21540_gpio_spi.a  /home/tschmitz/ncs/v3.0.2/nrfxlib/mpsl/fem/nrf2220/lib/nrf52/soft-float/libmpsl_fem_nrf2220.a  /home/tschmitz/ncs/v3.0.2/nrfxlib/mpsl/fem/nrf2240/lib/nrf52/soft-float/libmpsl_fem_nrf2240.a  /home/tschmitz/ncs/v3.0.2/nrfxlib/mpsl/fem/nrf22xx/lib/nrf52/soft-float/libmpsl_fem_nrf22xx.a  /home/tschmitz/ncs/v3.0.2/nrfxlib/mpsl/fem/simple_gpio/lib/nrf52/soft-float/libmpsl_fem_simple_gpio.a  /home/tschmitz/ncs/v3.0.2/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a -L"/home/tschmitz/ncs/toolchains/7cbc0036f4/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v7e-m/nofp" -lc -lgcc && cd /home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/build/firmware/zephyr && /home/tschmitz/ncs/toolchains/7cbc0036f4/usr/local/bin/cmake -E true
    /home/tschmitz/ncs/toolchains/7cbc0036f4/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(login.c.obj): in function `compute_hash':
    /home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/src/shell/login.c:112: undefined reference to `mbedtls_sha256'
    collect2: error: ld returned 1 exit status
    FAILED: _sysbuild/sysbuild/images/firmware-prefix/src/firmware-stamp/firmware-build /home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/build/_sysbuild/sysbuild/images/firmware-prefix/src/firmware-stamp/firmware-build
    cd /home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/build/firmware && /home/tschmitz/ncs/toolchains/7cbc0036f4/usr/local/bin/cmake --build .
    FATAL ERROR: command exited with status 1: /home/tschmitz/ncs/toolchains/7cbc0036f4/usr/local/bin/cmake --build /home/tschmitz/advanced-optronics/pcap04-zephyr/firmware/build
    choice AOS_SECURITY_LEVEL_CHOICE
        prompt "Security level required for AOS"
        default AOS_SECURITY_ENCRYPT
        depends on AOS
        config AOS_SECURITY_NONE
            bool "None"
        config AOS_SECURITY_ENCRYPT
            bool "Encryption without authentication"
            select BT_SMP
        config AOS_SECURITY_AUTHEN
            bool "Encryption with authentication"
            select BT_SMP
            select SETTINGS
            select BT_SETTINGS
            select FLASH
            select FLASH_PAGE_LAYOUT
            select FLASH_MAP
            select NVS
            select BT_FILTER_ACCEPT_LIST
            select BT_PRIVACY
    endchoice
    Best Regards,
    Tom
  • Hi Tom,
    You are using legacy API for SHA which is in the process of being removed. MBEDTLS_BUILTIN is not supported either. Instead, it is recommended that you use PSA APIs. You can find more information about PSA Certified Security Framework and PSA Certified APIs in the documentation.
    Dejan
  • Hi Dejan,
    moving things over to the PSA APIs worked!
    For those looking for a quick answer to the question above, here are the new configs you need:
    CONFIG_MBEDTLS=y
    CONFIG_MBEDTLS_PSA_CRYPTO_C=y
    And you want to use the hash functions from psa/crypto.h
    Thank you,
    Tom
