Try to program a custom board using BL5340PA module to see LOG
I have made a PCB using a BL5340PA module, to start i have tried a simple code to see log from RTT using the SWD SWCLK pin, i am using an NRF5340 DK as debugger/programmer, my pin connection bewteen my board  and nrf5340 dk seem good as i was able to flash the code without error.
But still can't see the log in JLink RTT Viewer.
#include <zephyr/kernel.h>
LOG_MODULE_REGISTER(main, LOG_LEVEL_DBG);
        LOG_INF("Hello from RTT!");
        while (1) {
                LOG_DBG("Toggling");
                 k_msleep(1000);
        return 0;
  • I have create my board's DTS file but i don't know what to put inside.
    /dts-v1/;
    #include <nordic/nrf5340_cpuapp_qkaa.dtsi>
    #include "custom_bl5340pa-pinctrl.dtsi"
    	model = "Custom Board auto generated by nRF Connect for VS Code (CPUAPP)";
    	compatible = "Ezurio,custom-bl5340pa-cpuapp";
    	chosen {
    		zephyr,sram = &sram0_image;
    		zephyr,flash = &flash0;
    		zephyr,code-partition = &slot0_partition;
    		zephyr,sram-secure-partition = &sram0_s;
    		zephyr,sram-non-secure-partition = &sram0_ns;
    #include "custom_bl5340pa-cpuapp_partitioning.dtsi"
    #include "custom_bl5340pa-shared_sram.dtsi"
  • When i try to debug, i still block in line 131 of the cpu_idle.c, what that means ?
     * Copyright (c) 2013-2014 Wind River Systems, Inc.
     * Copyright (c) 2023 Arm Limited
     * @file
     * @brief ARM Cortex-M power management
    #include <cmsis_core.h>
    #if defined(CONFIG_ARM_ON_EXIT_CPU_IDLE)
    #include <soc_cpu_idle.h>
     * @brief Initialization of CPU idle
     * Only called by arch_kernel_init(). Sets SEVONPEND bit once for the system's
     * duration.
    void z_arm_cpu_idle_init(void)
    	SCB->SCR = SCB_SCR_SEVONPEND_Msk;
    #define ON_EXIT_IDLE_HOOK SOC_ON_EXIT_CPU_IDLE
    #else
    #define ON_EXIT_IDLE_HOOK do {} while (false)
    #if defined(CONFIG_ARM_ON_ENTER_CPU_IDLE_HOOK)
    #define SLEEP_IF_ALLOWED(wait_instr) do { \
    	/* Skip the wait instr if on_enter_cpu_idle returns false */ \
    	if (z_arm_on_enter_cpu_idle()) { \
    		/* Wait for all memory transaction to complete */ \
    		/* before entering low power state. */ \
    		__DSB(); \
    		wait_instr(); \
    		/* Inline the macro provided by SoC-specific code */ \
    		ON_EXIT_IDLE_HOOK; \
    } while (false)
    #else
    	__DSB(); \
    	wait_instr(); \
    } while (false)
    void arch_cpu_idle(void)
    #if defined(CONFIG_TRACING)
    	sys_trace_idle();
    #if CONFIG_ARM_ON_ENTER_CPU_IDLE_PREPARE_HOOK
    	z_arm_on_enter_cpu_idle_prepare();
    #if defined(CONFIG_ARMV7_M_ARMV8_M_MAINLINE)
    	 * PRIMASK is always cleared on ARMv7-M and ARMv8-M (not used
    	 * for interrupt locking), and configuring BASEPRI to the lowest
    	 * priority to ensure wake-up will cause interrupts to be serviced
    	 * Set PRIMASK before configuring BASEPRI to prevent interruption
    	 * before wake-up.
    	__disable_irq();
    	 * Set wake-up interrupt priority to the lowest and synchronize to
    	 * ensure that this is visible to the WFI instruction.
    	__set_BASEPRI(0);
    	__ISB();
    #else
    	 * For all the other ARM architectures that do not implement BASEPRI,
    	 * PRIMASK is used as the interrupt locking mechanism, and it is not
    	 * necessary to set PRIMASK here, as PRIMASK would have already been
    	 * set by the caller as part of interrupt locking if necessary
    	 * (i.e. if the caller sets _kernel.idle).
    	SLEEP_IF_ALLOWED(__WFI);
    	__enable_irq();
    	__ISB();
    void arch_cpu_atomic_idle(unsigned int key)
    	sys_trace_idle();
    	 * Lock PRIMASK while sleeping: wfe will still get interrupted by
    	 * incoming interrupts but the CPU will not service them right away.
    	__disable_irq();
    	 * No need to set SEVONPEND, it's set once in z_arm_cpu_idle_init()
    	 * and never touched again.
    #if defined(CONFIG_ARMV6_M_ARMV8_M_BASELINE)
    	/* No BASEPRI, call wfe directly. (SEVONPEND is set in z_arm_cpu_idle_init()) */
    #elif defined(CONFIG_ARMV7_M_ARMV8_M_MAINLINE)
    	/* unlock BASEPRI so wfe gets interrupted by incoming interrupts  */
    	__set_BASEPRI(0);
    	__ISB();
    #else
    #error Unsupported architecture
    	SLEEP_IF_ALLOWED(__WFE);
    	arch_irq_unlock(key);
    	__enable_irq();
  • resolve need to add in prj.conf
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM=y
