USB Serial Device port not found
Before i inserted in my code to use ppi + gpiote + spim usb serial device port worked properly, it connected normally, but now it doesn't connect the port at all, did i create blocking functions even though they should work without CPU. Also my timer interrupt seems not to be happening, in interrupt i set a flag processing_ready = true; but it seems that in main()
if (processing_ready){
            processing_ready = false;
            nrf_gpio_pin_set(CS_PIN);
            k_msleep(3);
        }  never happens.
 * Copyright (c) 2016 Intel Corporation
#include <stdio.h>
#include "radc.h"
#include "communication.h"
#include "init.h"
#include "spi_mcp3562.h"
#include <zephyr/kernel.h>
#include <nrfx_spim.h>
#include <nrfx_gpiote.h>
#include <hal/nrf_ppi.h>
#include <nrfx_timer.h>
#include <nrfx_ppi.h>
LOG_MODULE_REGISTER(main, LOG_LEVEL_DBG);
#define SPI_INSTANCE 1
#define DRDY_PIN     NRF_GPIO_PIN_MAP(1, 3)   // P1.03
#define CS_PIN       NRF_GPIO_PIN_MAP(1, 12)  // P1.12
#define LED0_NODE DT_ALIAS(led0)
#define BYTES_PER_SAMPLE  3
#define SAMPLE_COUNT 2000
static volatile bool use_ping = true;
static int sample_count = 0;
static const struct gpio_dt_spec led = GPIO_DT_SPEC_GET(LED0_NODE, gpios);
uint32_t flags = NRFX_SPIM_FLAG_HOLD_XFER
            	| NRFX_SPIM_FLAG_REPEATED_XFER
               | NRFX_SPIM_FLAG_RX_POSTINC
			   | NRFX_SPIM_FLAG_NO_XFER_EVT_HANDLER;
volatile bool ping_ready = false;
volatile bool pong_ready = false;
//static bool using_ping = true;
//volatile bool config = false;
//volatile bool read = false;
volatile bool using_buf_a = true;
volatile bool processing_ready = false;
#define MAX_SAMPLES SAMPLE_COUNT
static const nrfx_timer_t counter_timer = NRFX_TIMER_INSTANCE(2);
static const nrfx_spim_t spi = NRFX_SPIM_INSTANCE(SPI_INSTANCE);
const nrfx_gpiote_t gpiote = NRFX_GPIOTE_INSTANCE(0);
#define PPI_CHANNEL   NRF_PPI_CHANNEL0
#define PPI_CH_T 	NRF_PPI_CHANNEL1
#define ADC_QUE_SIZE    2000
typedef struct ArrayList
    uint8_t rx_buffer[3];
}ArrayList_type;
static ArrayList_type p_rx_buffer_a[ADC_QUE_SIZE],p_rx_buffer_b[ADC_QUE_SIZE] ;
void spi_init(uint8_t *rx_ptr)
	//NRF_SPIM1->RXD.MAXCNT = 3;
	//NRF_SPIM1->RXD.PTR = (int32_t)rx_ptr;
    //NRF_SPIM1->RXD.LIST = SPIM_RXD_LIST_LIST_ArrayList;
    nrfx_spim_config_t config = {
		.sck_pin           = NRF_GPIO_PIN_MAP(1, 11), //43
		.mosi_pin          = NRF_GPIO_PIN_MAP(1, 2), // 34
		.miso_pin          = NRF_GPIO_PIN_MAP(1, 10), //42
		.ss_pin            = NRF_SPIM_PIN_NOT_CONNECTED,  //44
		.frequency         = NRFX_MHZ_TO_HZ(4), //SPIM_FREQUENCY_FREQUENCY_M4,
		.mode              = NRF_SPIM_MODE_0,
		.bit_order         = NRF_SPIM_BIT_ORDER_MSB_FIRST,
		//.dcx_pin = NRF_SPIM_PIN_NOT_CONNECTED,
		//.orc               = 0xFF,
		//.irq_priority      = 6,
		//.use_hw_ss         = false,
		.ss_active_high    = false
	nrfx_err_t err = (nrfx_spim_init(&spi, &config, NULL, NULL));
	if (err != NRFX_SUCCESS) {
		printk("nrfx_spim_init() failed! Error code: %08X\n", err);
		return;  // ili k_panic(); ili __ASSERT_NO_MSG(false);
	else{
		LOG_INF("prosao spim");
void gpiote_init(void)
    nrf_gpio_cfg_input(DRDY_PIN, NRF_GPIO_PIN_NOPULL);
    NRF_GPIOTE->CONFIG[0] =
        (GPIOTE_CONFIG_MODE_Event << GPIOTE_CONFIG_MODE_Pos) |
        (DRDY_PIN << GPIOTE_CONFIG_PSEL_Pos) |
        (GPIOTE_CONFIG_POLARITY_HiToLo << GPIOTE_CONFIG_POLARITY_Pos);
    NRF_GPIOTE->EVENTS_IN[0] = 0;
	LOG_INF("prosao gpiote");
void ppi_init(void)
	NRF_PPI->CHENCLR = (1U << PPI_CHANNEL);
    uint32_t event_addr = (uint32_t)&NRF_GPIOTE->EVENTS_IN[0];
    uint32_t task_addr  = (uint32_t)&spi.p_reg->TASKS_START;
    NRF_PPI->CH[PPI_CHANNEL].EEP = event_addr;
    NRF_PPI->CH[PPI_CHANNEL].TEP = task_addr;
    NRF_PPI->CHENSET = (1 << PPI_CHANNEL);
	LOG_INF("prosao ppi");
void mcp3562_conf(void)
	LOG_INF("→ enter mcp3562_conf");
	uint8_t data_to_send[9];
	data_to_send[0] = CLOCK_EXTERNAL | CURNT_SRC_DIS | MODE_CONVERTION;
	data_to_send[1] = PRESCALER_NO_MCLK | OSR_64;
	data_to_send[2] = ADC_CURRENT_X1 | GAIN_X1 | MUX_DIS_AUTO_ZEROING;
	data_to_send[3] = CONV_MODE_CONTINUOUS | FORMAT_24_BIT | CRC_DISABLED | OFFCAL_DISABLED | GAINCAL_DISABLED;
	data_to_send[4] = DATA_NOT_UPDATED | CRC_ERROR_NOT_OCURRED | POR_NOT_OCURRED | IRQ_MODE_IRQ_SELECTED | IRQ_MODE_NO_EXT_PULL_UP | FAST_COMMANDS_ENABLE | STP_DISABLE;
	data_to_send[5] = 0B00001000;
	data_to_send[6] = SCAN_DLY_0_DMCLK;
    data_to_send[7] = 0B00000000 ;
    data_to_send[8] = 0;
	uint8_t tx_buf[] = {(DEVICE_ADDRESS | CONFIG0 | FLAG_INCREMENTAL_WRITE), data_to_send[0], data_to_send[1], data_to_send[2], data_to_send[3], data_to_send[4], data_to_send[5], data_to_send[6], data_to_send[7], data_to_send[8]};
	//NRF_SPIM1->TXD.PTR    = (uint32_t)&tx_buf;
	//NRF_SPIM1->TXD.MAXCNT = 10;
	nrfx_spim_xfer_desc_t xfer_desc;
    xfer_desc.p_tx_buffer = tx_buf;
    xfer_desc.tx_length   = 10;
    xfer_desc.rx_length   = 0;
    xfer_desc.p_rx_buffer = NULL;
    nrfx_err_t err = (nrfx_spim_xfer(&spi, &xfer_desc, NRFX_SPIM_FLAG_NO_XFER_EVT_HANDLER));  // startuje se odmah!
		printk("SPIM transfer error: %d\n", err);
	else {
		LOG_INF("adc konfigurisan!\n");
	spi.p_reg->EVENTS_END = 0;
void spi_ping_pong_transfer_rx(uint8_t *rx_ptr)
	//spi.p_reg->EVENTS_END = 0;
	//uint8_t tx_buffer[CPU_BUF_SIZE];
	uint8_t tx_buffer[3] = {0};
	/*NRF_SPIM1->RXD.MAXCNT = 3;
    NRF_SPIM1->RXD.LIST = SPIM_RXD_LIST_LIST_ArrayList;*/
    xfer_desc.p_tx_buffer = NULL;
    xfer_desc.tx_length   = 0;
    xfer_desc.rx_length   = BYTES_PER_SAMPLE;
    xfer_desc.p_rx_buffer = rx_ptr;
	//nrfx_spim_xfer_desc_t xfer = NRFX_SPIM_XFER_TRX(tx_buffer,3,rx_ptr, 3);
	nrfx_err_t err = (nrfx_spim_xfer(&spi, &xfer_desc, flags));
    //nrfx_err_t err = (nrfx_spim_xfer(&spi, &xfer, flags));  // ne startuje se odmah!
	else {
		LOG_INF("zapoceo citanje!\n");
	/*while (spi.p_reg->EVENTS_END == 0) {
        // optional: dodaj timeout da ne zapne zauvek
void reg_citanje_conf(void)
	uint8_t tx_buff = DEVICE_ADDRESS | ADCDATA | FLAG_STATIC_READ;
    xfer_desc.p_tx_buffer = &tx_buff;
    xfer_desc.tx_length   = 1;
    nrfx_err_t err = (nrfx_spim_xfer(&spi, &xfer_desc, NRFX_SPIM_FLAG_NO_XFER_EVT_HANDLER));  // ne startuje se odmah!
	else{
		LOG_INF("reg konfigurisan!\n");
void counter_handler(nrf_timer_event_t event_type, void *p_context)
	//processing_ready = true;
    if (event_type == NRF_TIMER_EVENT_COMPARE0)
        // Ovde CPU preuzima prethodni bafer
		gpio_pin_toggle_dt(&led);
        // Prebaci DMA na drugi bafer
        using_buf_a = !using_buf_a;
        uint8_t *next_buffer = using_buf_a ? (uint8_t *)p_rx_buffer_a : (uint8_t *)p_rx_buffer_b;
        // Samo zameni RX buffer
        //NRF_SPIM1->EVENTS_END = 0;
        //NRF_SPIM1->RXD.PTR = (uint32_t)next_buffer;
        //NRF_SPIM1->RXD.MAXCNT = BYTES_PER_SAMPLE;
		spi_ping_pong_transfer_rx(next_buffer);
        nrfx_timer_clear(&counter_timer);
        nrfx_timer_enable(&counter_timer);
		//nrfx_spim_abort(&spi);
void timer_counter_init(void)
	nrfx_timer_config_t cfg = NRFX_TIMER_DEFAULT_CONFIG(NRFX_MHZ_TO_HZ(16));
    cfg.mode = NRF_TIMER_MODE_COUNTER;
	cfg.bit_width = NRF_TIMER_BIT_WIDTH_32;
	nrfx_err_t err = nrfx_timer_init(&counter_timer, &cfg, counter_handler);
		printk("Timer error: %d\n", err);
	else {
		LOG_INF("spreman timer!\n");
	nrfx_timer_extended_compare(
        &counter_timer,
        NRF_TIMER_CC_CHANNEL0,
        MAX_SAMPLES,
        NRF_TIMER_SHORT_COMPARE0_STOP_MASK,
        true
	NRF_PPI->CHENCLR = (1U << PPI_CH_T);
    uint32_t evt_end = (uint32_t)&NRF_GPIOTE->EVENTS_IN[0];
    uint32_t task_count = nrfx_timer_task_address_get(&counter_timer, NRF_TIMER_TASK_COUNT);
	NRF_PPI->CH[PPI_CH_T].EEP = evt_end;
    NRF_PPI->CH[PPI_CH_T].TEP = task_count;
	NRF_PPI->CHENSET = (1U << PPI_CH_T);
	NVIC_ClearPendingIRQ(TIMER2_IRQn); //ovo je radilo reset (ponovo pozivajuci main)
    NVIC_EnableIRQ(TIMER2_IRQn);
void TIMER2_IRQHandler(void)
    nrfx_timer_irq_handler(&counter_timer);
	uint8_t timer_count_value;
	pin_initialization();
	gpio_pin_configure_dt(&led, GPIO_OUTPUT_INACTIVE);
	spi_init((uint8_t *)p_rx_buffer_a);
	mcp3562_conf();
	nrf_gpio_pin_clear(CS_PIN);
	reg_citanje_conf();
	spi_ping_pong_transfer_rx((uint8_t *)p_rx_buffer_a);
	gpiote_init();
	timer_counter_init();
	ppi_init();
	communication_init();
	while(1){
			k_msleep(3);
		NRF_TIMER2->TASKS_CAPTURE[0] = 1;
        timer_count_value = NRF_TIMER2->CC[0];
        NRF_TIMER2->TASKS_CAPTURE[0] = 0;
        printf("count = %d\n", timer_count_value);
        k_msleep(5000);
		//__WFI();
