Max TX power for channel sounding
In the example ras_initiator for channel sounding, there is a macro set for maximum TxPower:
const struct bt_le_cs_set_default_settings_param default_settings = {
		.enable_initiator_role = true,
		.enable_reflector_role = false,
		.cs_sync_antenna_selection = BT_LE_CS_ANTENNA_SELECTION_OPT_REPETITIVE,
		.max_tx_power = BT_HCI_OP_LE_CS_MAX_MAX_TX_POWER,
where
#define BT_HCI_OP_LE_CS_MAX_MAX_TX_POWER 20
In the datasheet for nRF54L15, I see that the maximum possible TX power is +8 dBm.
But when I run the example, the log shows TX power: 0 dBm
[00:00:02.301,953] <inf> app_main: CS config creation complete. ID: 0
[00:00:02.501,909] <inf> app_main: CS security enabled.
[00:00:02.752,027] <inf> app_main: CS procedures enabled:
 - config ID: 0
 - antenna configuration index: 0
 - TX power: 0 dbm
 - subevent length: 28198 us
 - subevents per event: 1
 - subevent interval: 0
 - event interval: 2
 - procedure interval: 10
 - procedure count: 0
 - maximum procedure length: 1000
So what is really valid?
What TX power is really used for CS procedures?
How can I set the highest possible TX power for channel sounding on nRF54L15?
Thank you.
