I'm trying to set up SEGGER SystemView on our custom nRF5340 board for debugging purposes using the SEGGER SystemView application.
Below is the configuration I'm using for SEEGER:
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_TRACING=y
CONFIG_THREAD_NAME=y
CONFIG_SEGGER_SYSTEMVIEW=y
CONFIG_SEGGER_SYSVIEW_POST_MORTEM_MODE=n
CONFIG_LOG_BACKEND_UART=n
CONFIG_MAIN_STACK_SIZE=2048
CONFIG_IDLE_STACK_SIZE=1024
The issue arises when I enable CONFIG_SEGGER_SYSTEMVIEW=y. Once it's enabled, BLE stops working. After some debugging, I found that the firmware hangs during the bt_enable() call.
Could you please help me identify the cause of this issue or suggest how to resolve the conflict between SEGGER SystemView and BLE?
Thank you,
Alireza
