nRF54L15 spi slave
Hi :
 Here is the initialization in C:
#define SPIS_INST_IDX       22
static nrfx_spis_t spis_inst = NRFX_SPIS_INSTANCE(SPIS_INST_IDX);
void device_spis_init(void)
    nrfx_err_t status;
    (void)status;
#if defined(__ZEPHYR__)
    IRQ_CONNECT(NRFX_IRQ_NUMBER_GET(NRF_SPIS_INST_GET(SPIS_INST_IDX)), IRQ_PRIO_LOWEST, \
                NRFX_SPIS_INST_HANDLER_GET(SPIS_INST_IDX), 0, 0);
    nrfx_spis_config_t spis_config = NRFX_SPIS_DEFAULT_CONFIG(6,
                                                              9,
                                                              8,
                                                              10);
    spis_config.mode = NRF_SPIS_MODE_3;
    spis_config.def = 0xFF;
    memset(m_tx_buffer_slave, 0x55, sizeof(m_tx_buffer_slave));
    memset(m_rx_buffer_slave, 0xaa, sizeof(m_rx_buffer_slave));
    status = nrfx_spis_init(&spis_inst, &spis_config, spis_handler, NULL);
    NRFX_ASSERT(status == NRFX_SUCCESS);
    status = nrfx_spis_buffers_set(&spis_inst,
                                   m_tx_buffer_slave, 36,
                                   m_rx_buffer_slave, 36);
    printk("%s %d\n", __func__, status);
    printk("%s success\n", __func__);
&spi22 {
    status = "okay";
    easydma-maxcnt-bits = <8>;
    compatible = "nordic,nrf-spis";
    max-frequency = <DT_FREQ_M(32)>;
    def-char = <0x00>;
    /delete-property/ rx-delay-supported;
    /delete-property/ rx-delay;
    cs-gpios = <&gpio2 10 0>;
    pinctrl-0 = <&spi22_default>;
    pinctrl-names = "default";
    zephyr,deferred-init;
here is the prj file:
CONFIG_SPI_SLAVE=y
CONFIG_NRFX_SPIS22=y
I completed the above initialization, but I couldn't receive any data from the slave device. The callback function didn't execute. I can confirm that the wiring of the SPI master end and the I/O is correct.  Could you please tell me if there are any abnormalities with this initialization?
  • yes, uart can output log. This is main func.
    here is spis callback func:
    static void spis_handler(nrfx_spis_evt_t const * p_event, void * p_context)
        if (p_event->evt_type == NRFX_SPIS_XFER_DONE)
            nrfx_err_t status;
            (void)status;
            nrfx_spis_t * p_spis_inst = p_context;
            printk("SPIS finished.");
            if (p_event->tx_amount > 0)
                printk("SPIS: Message transmitted: %d", p_event->tx_amount);
            if (p_event->rx_amount > 0)
                printk("SPIS: Message received: %d", p_event->rx_amount);
            status = nrfx_spis_buffers_set(p_spis_inst, m_tx_buffer_slave, PACKET_MAX_SIZE, m_rx_buffer_slave, PACKET_MAX_SIZE);
