Bootloader does not start application
I am trying to get my device (nrf52832) to do DFU OTA, and to do so I am programming the bootloader before programming the s132 softdevice and the application. However, the device seems to stay stuck in bootloader mode without ever starting the application. I am able to perform a DFU using a test application, so the bootloader is indeed functionnal. I have tried merging the bootloader settings file at this location : here. If I only program the softdevice and the application, everything works well (except dfu).
This does not fix my problem. Do my settings have to be different than the ones found in this file? I have already looked through a dozen posts on this site and have yet to find a solution that works. I am using SDK 9.2 and Eclipse gcc. Any help would be greatly appreciated!
Thanks!
  • If you are uploading an application via dfu service and through the bootloader, then you are most certainly not flashing the application + softdevice + bootlaoder via the Jlink programmer. The memory region 0x7f000 will be written to by the bootloader, to indicate that the application is valid or not after the CRC, which explains why it is not erased. The above command is only for the first time you flash the chip via Jlink programmer, not for after a dfu via bootloader.
