Environment
NCS: v3.0.2 (Zephyr 4.0.99)
Toolchain: Zephyr SDK 0.17.0 (arm-zephyr-eabi gcc 12.2)
West: 1.2.0
Building via nRF Connect / sysbuild
Board: custom nRF52840 (project also builds fine on NCS 2.4.2)
Issue Summary:
I’m facing an issue with mcuboot in NCS 3.0.2. Initially, I started getting undefined reference to rsa_pub_key and rsa_pub_key_len during the build. To resolve this, I checked mcuboot_config.h and saw that only 2048 and 3072 bit RSA keys are supported. I then tried adding CONFIG_BOOT_SIGNATURE_TYPE_RSA_LEN=2048 in sysbuild.conf, but got this warning instead:
warning: attempt to assign the value '2048' to the undefined symbol BOOT_SIGNATURE_TYPE_RSA_LEN
sysbuild.conf:
SB_CONFIG_BOOTLOADER_MCUBOOT=y SB_CONFIG_PARTITION_MANAGER=y # SB_CONFIG_BOOT_SIGNATURE_TYPE_ED25519=y # SB_CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=y SB_CONFIG_BOOT_SIGNATURE_TYPE_RSA=y # SB_CONFIG_BOOT_SIGNATURE_TYPE_RSA_LEN=2048 SB_CONFIG_BOOT_SIGNATURE_KEY_FILE="D://Development//Repo//BLE_firmware_nRF//signature//infinity.pem"
prj.conf:
# Incresed stack due to settings API usage # CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=8192 CONFIG_BT=y # CONFIG_BT_LL_SOFTDEVICE=n # Enable Bluetooth Controller CONFIG_BT_CTLR=y CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL=y CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=y CONFIG_BT_CTLR_TX_PWR_PLUS_8=y # Enable SMP Server CONFIG_MCUMGR=y CONFIG_MCUMGR_GRP_IMG=y # CONFIG_MCUMGR_GRP_IMG dependencies CONFIG_IMG_MANAGER=y # CONFIG_IMG_MANAGER dependencies CONFIG_STREAM_FLASH=y # CONFIG_MCUMGR dependencies CONFIG_NET_BUF=y CONFIG_ZCBOR=y # Ensure an MCUboot-compatible binary is generated. CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_BT_PERIPHERAL=y CONFIG_BT_CENTRAL=y CONFIG_BT_SCAN=y CONFIG_BT_SCAN_FILTER_ENABLE=y CONFIG_BT_SCAN_UUID_CNT=1 CONFIG_BT_GATT_DM=y CONFIG_BT_GATT_CLIENT=y CONFIG_BT_GATT_DYNAMIC_DB=y CONFIG_BT_DEVICE_NAME="SB PINPAD" CONFIG_BT_DEVICE_APPEARANCE=833 CONFIG_BT_DEVICE_NAME_DYNAMIC=n # check if we need this CONFIG_BT_SETTINGS=y CONFIG_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_FLASH_MAP=y # for LittleFS CONFIG_FILE_SYSTEM=y CONFIG_FILE_SYSTEM_LITTLEFS=y # Enable loging # IMPORTANT -> THIS MUST BE COMMENTED OUT DURING PRODUCTION # CONFIG_LOG=y CONFIG_SERIAL=y CONFIG_CONSOLE=y CONFIG_UART_CONSOLE=y # CONFIG_LOG_DEFAULT_LEVEL=3 # CONFIG_LOG_MODE_IMMEDIATE=y CONFIG_BT_CREATE_CONN_TIMEOUT=10 CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=10000 CONFIG_BT_CONN_PARAM_RETRY_COUNT=6 CONFIG_BT_CONN_PARAM_RETRY_TIMEOUT=10000 CONFIG_BASE64=y CONFIG_BT_L2CAP_TX_MTU=251 CONFIG_BT_BUF_ACL_RX_SIZE=256 CONFIG_BT_BUF_ACL_TX_SIZE=256 CONFIG_BT_PHY_UPDATE=n CONFIG_BT_BUF_ACL_RX_COUNT=4 CONFIG_BT_BUF_ACL_TX_COUNT=4 CONFIG_BT_MAX_CONN=4 # Enable ADC for temp & Battery status CONFIG_ADC=y # Power Management CONFIG_PM=y CONFIG_PM_DEVICE=y CONFIG_REBOOT=y CONFIG_BT_DIS=y # CONFIG_BT_DIS_MANUF="SwipBox International A/S" # CONFIG_BT_DIS_MODEL="Infinity PINpad" CONFIG_BT_DIS_PNP=n CONFIG_BT_DIS_FW_REV=y CONFIG_BT_DIS_FW_REV_STR="1.0.3" CONFIG_BT_DIS_HW_REV=y CONFIG_BT_DIS_HW_REV_STR="1" CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=n CONFIG_MBEDTLS_PSA_CRYPTO_C=y CONFIG_CRYPTO=y CONFIG_MBEDTLS=y # Enable nordic security backend and PSA APIs CONFIG_NRF_SECURITY=y CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_GENERATE=y CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_DERIVE=y CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_IMPORT=y CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_EXPORT=y CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY=y CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN=y CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT=y CONFIG_PSA_CRYPTO_DRIVER_CC3XX=y # Algorithms CONFIG_PSA_WANT_ALG_SHA_256=y # Define key size CONFIG_PSA_WANT_RSA_KEY_SIZE_1024=y # Mbedtls configuration CONFIG_MBEDTLS_ENABLE_HEAP=y CONFIG_MCUMGR_TRANSPORT_BT=y CONFIG_MCUMGR_TRANSPORT_BT_PERM_RW=n CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL=y # CONFIG_MCUMGR_TRANSPORT_UART=y CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y # Enable the mcumgr Packet Reassembly feature over Bluetooth and its configuration dependencies. # MCUmgr buffer size is optimized to fit one SMP packet divided into five Bluetooth Write Commands, # transmitted with the maximum possible MTU value: 498 bytes. CONFIG_MCUMGR_TRANSPORT_BT_REASSEMBLY=y CONFIG_MCUMGR_GRP_OS_MCUMGR_PARAMS=y CONFIG_THREAD_NAME=y #32KB CONFIG_MAIN_STACK_SIZE=27648 #18KB CONFIG_HEAP_MEM_POOL_SIZE=18432 #8KB CONFIG_MBEDTLS_HEAP_SIZE=7168 #5KB CONFIG_FS_LITTLEFS_FC_HEAP_SIZE=5120 #8KB CONFIG_BT_RX_STACK_SIZE=9216 #4KB CONFIG_BT_HCI_TX_STACK_SIZE=5120 CONFIG_DISABLE_FLASH_PATCH=y # CONFIG_MCUMGR_SMP_BT=y # CONFIG_BT_DFU_SMP=y # SMP GATT service registration CONFIG_MCUMGR_TRANSPORT_BT_DYNAMIC_SVC_REGISTRATION=y
For context, I was using this same RSA signature setup in NCS 2.4.2 without any issue. Can someone clarify what’s changed in NCS 3.0.2, and also confirm if it’s possible to still use a 1024-bit RSA key with mcuboot in this version?
Thanks.
