nPM1300 does not exit ship hold mode when SHPHLD button pressed or VBUS connected
I have custom hardware using an nPM1300 and nRF52840, and I am having trouble getting the nPM1300 to work as described in its documentation. I have a button connected between the SHPHLD pin and ground, and I can tell it is working because I get GPIO events, and a long press does reset the nPM1300. However, if I enable ship hold mode, then it does not exit ship hold mode with either a short press of the button or plugging in USB. I can only get it to exit with a long press.
You can see my hardware at kicanvas.org/?github=https%3A%2F%2Fgithub.com%2Fjoelspadin%2Fmarten_numpad%2Fblob%2Fmain%2Fpcb%2Fnumpad.kicad_pro. The relevant schematics are in usb.kicad_sch and numpad.kicad_sch.
I am using Zephyr 4.1. My devicetree setup for the nPM1300 looks like this:
&i2c0 {
    compatible = "nordic,nrf-twi";
    status = "okay";
    pinctrl-0 = <&i2c0_default>;
    pinctrl-1 = <&i2c0_sleep>;
    npm1300_pmic: pmic@6b {
        compatible = "nordic,npm1300";
        status = "okay";
        reg = <0x6b>;
        host-int-gpios = <&gpio0 30 0>;
        pmic-int-pin = <1>;
        long-press-reset = "one-button";
        npm1300_regulators: regulators {
            compatible = "nordic,npm1300-regulator";
            main_regulator: BUCK2 {
                regulator-min-microvolt = <3300000>;
                regulator-max-microvolt = <3300000>;
                regulator-always-on;
        npm1300_charger: charger {
            compatible = "nordic,npm1300-charger";
            charging-enable;
            term-microvolt = <4150000>;
            term-warm-microvolt = <4000000>;
            current-microamp = <250000>;
            dischg-limit-microamp = <1000000>;
            vbus-limit-microamp = <500000>;
            // No thermistor
            thermistor-ohms = <0>;
            thermistor-beta = <3380>;
        npm1300_leds: leds {
            compatible = "nordic,npm1300-led";
            nordic,led0-mode = "charging";
            nordic,led1-mode = "host";
            nordic,led2-mode = "host";
Using
    static struct gpio_callback event_cb;
    gpio_init_callback(&event_cb, power_button_callback, BIT(NPM1300_EVENT_SHIPHOLD_PRESS));
    mfd_npm1300_add_callback(pmic, &event_cb);
I have set up a callback which checks if USB is powered. If not, it blinks an LED a few times, then calls regulator_parent_ship_mode(). With the board powered only from a battery, when I press the button, the LED blinks, then it shuts off and the voltage to the SoC drops to 0 as expected. When I press the button again, nothing happens. (I can tell it is not waking, immediately triggering the GPIO event, and then going back into ship mode, because the LED does not blink.) Similarly, reconnecting USB power does not wake it either.
Is there something else I'm missing that needs to be configured?
  • I found the issue. Setting a "regulator-always-on" property on BUCK2 seems to force that regulator to remain on, even when the PMIC itself is in ship mode, which then seems to break waking from ship mode. After removing that property, everything works as expected.
    I had set this because I wanted the regulator to always be on provided the PMIC was on, and I had assumed that the PMIC being off would override that. I'm not sure why this affects ship mode but not hibernate mode.
    I discovered this after testing on an npm1300 EK with an nrf5340 DK, using Zephyr's npm1300_ek sample application which I had modified to function similarly to my application. Everything worked as expected there, so I compared my setup to npm1300_ek.overlay and started removing differences between them until it worked on my hardware.
    Thanks for all the help!
    Edit: not actually the solution. See below.
  • I spoke too soon. I had accidentally left in code to test hibernate mode, so it was triggering hibernate instead of ship mode. Ship mode still does not work.
    I did notice a new, interesting behavior which seems to have started after removing "regulator-always-on". If I remove USB power, enter ship mode, and then plug USB back in, it wakes up. However, now if I unplug USB again, it seems to immediately return to ship mode, with the BUCK2 output disabled, VSYS at 4 V again, and average current draw of ~0.4 uA. Holding the button for 10 seconds gets it back out of this state until the next time I enter ship mode.
  • I think I have actually figured it out this time.
    regulator_parent_ship_mode() does not take a regulator device, look up its parent, and call ship mode on the parent. regulator_parent_ship_mode() wants a regulator's parent device to be passed to it.
    I expect that calling regulator_parent_ship_mode() on the BUCK2 device did something that actually sent a command to the PMIC, but which it disliked enough to disable BUCK2 and get stuck in a bad state which looked a lot like ship mode, and where only a hard reset could recover it.
    Calling regulator_parent_ship_mode() on the nordic,npm1300-regulator device works as expected. Hibernate mode was working before because that uses mfd_npm1300_hibernate(), which is called on the nordic,npm1300 device.
