Thingy91X npm1300 fuel gauge sample configuration/build problem
The Nordic Thingy:91X board has a Nordic nmp1300 pmic device, but the samples do not support the board (a lot of time would be saved it they did);
https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/samples/pmic/native/npm13xx_fuel_gauge/README.html
Attempting to modify sample npm1300_fuel_gauge to work with the Thingy-91X
Added boards/thingy91x_nrf5340_cpuapp.overlay with;
&npm1300_charger {
		compatible = "nordic,npm1300-charger";
        status = "okay";
&pmic_main {
    	compatible = "nordic,npm1300";
        status = "okay";
Side question - is the 'compatible' statement needed?  - appears to be redundant but was a suggestion in one of the many searches.
And build with;
npm1300_fuel_gauge$ west build --build-dir build_thingy91x_nrf5340_cpuapp --board thingy91x/nrf5340/cpuapp
The overlay is picked up for this build target and enables these two drivers defined in ncs/v3.0.2/nrf/boards/nordic/thingy91x/thingy91x_common.dtsi which are disabled by default.
BTW, seems you cant rely on prj.conf:CONFIG_NRF_FUEL_GAUGE=y to enable the dependent I2C & npm1300 & pmic drivers like it seems to do for the supported boards.
That is confirmed in the generated files;
npm1300_fuel_gauge/build_thingy91x_nrf5340_cpuapp/npm1300_fuel_gauge/zephyr/include/generated/zephyr/devicetree_generated.h
and
npm1300_fuel_gauge/build_nrf5340dk_nrf5340_cpuapp/npm1300_fuel_gauge/zephyr/zephyr.dts
However, the build still fails with the following errors which I'm having difficultly troubleshooting after much research on this site and generally;
It's probably something simple, just like the overlay file is simple when you've figured out which SOC on the board to use, the correct filename, location in the tree and the correct contents.
<snip>
[0/78] Creating public key from private key used for signing
[31/78] Performing build step for 'npm1300_fuel_gauge'
[0/1] Re-running CMake...
Loading Zephyr default modules (Zephyr base (cached)).
-- Application: /home/rgjones/nordic/npm1300_fuel_gauge
-- CMake version: 3.21.0
-- Cache files will be written to: /home/rgjones/.cache/zephyr
-- Zephyr version: 4.0.99 (/home/rgjones/ncs/v3.0.2/zephyr)
-- Board: thingy91x, qualifiers: nrf5340/cpuapp
-- Found host-tools: zephyr 0.17.0 (/home/rgjones/ncs/toolchains/7cbc0036f4/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.17.0 (/home/rgjones/ncs/toolchains/7cbc0036f4/opt/zephyr-sdk)
-- Found BOARD.dts: /home/rgjones/ncs/v3.0.2/nrf/boards/nordic/thingy91x/thingy91x_nrf5340_cpuapp.dts
-- Found devicetree overlay: /home/rgjones/nordic/npm1300_fuel_gauge/boards/thingy91x_nrf5340_cpuapp.overlay
-- Generated zephyr.dts: /home/rgjones/nordic/npm1300_fuel_gauge/build_thingy91x_nrf5340_cpuapp/npm1300_fuel_gauge/zephyr/zephyr.dts
-- Generated pickled edt: /home/rgjones/nordic/npm1300_fuel_gauge/build_thingy91x_nrf5340_cpuapp/npm1300_fuel_gauge/zephyr/edt.pickle
-- Generated devicetree_generated.h: /home/rgjones/nordic/npm1300_fuel_gauge/build_thingy91x_nrf5340_cpuapp/npm1300_fuel_gauge/zephyr/include/generated/zephyr/devicetree_generated.h
-- Including generated dts.cmake file: /home/rgjones/nordic/npm1300_fuel_gauge/build_thingy91x_nrf5340_cpuapp/npm1300_fuel_gauge/zephyr/dts.cmake
warning: Deprecated symbol SOC_DCDC_NRF53X_APP is enabled.
warning: Deprecated symbol SOC_DCDC_NRF53X_NET is enabled.
warning: Deprecated symbol NFCT_PINS_AS_GPIOS is enabled.
warning: Deprecated symbol DEPRECATED_UART_NRFX_UARTE_LEGACY_SHIM is enabled.
Parsing /home/rgjones/ncs/v3.0.2/zephyr/Kconfig
Loaded configuration '/home/rgjones/nordic/npm1300_fuel_gauge/build_thingy91x_nrf5340_cpuapp/npm1300_fuel_gauge/zephyr/.config'
Merged configuration '/home/rgjones/nordic/npm1300_fuel_gauge/build_thingy91x_nrf5340_cpuapp/npm1300_fuel_gauge/zephyr/.config.sysbuild'
No change to configuration in '/home/rgjones/nordic/npm1300_fuel_gauge/build_thingy91x_nrf5340_cpuapp/npm1300_fuel_gauge/zephyr/.config'
No change to Kconfig header in '/home/rgjones/nordic/npm1300_fuel_gauge/build_thingy91x_nrf5340_cpuapp/npm1300_fuel_gauge/zephyr/include/generated/zephyr/autoconf.h'
-- Using ccache: /home/rgjones/ncs/toolchains/7cbc0036f4/usr/bin/ccache
-- Including signing script: /home/rgjones/ncs/v3.0.2/nrf/cmake/sysbuild/image_signing.cmake
-- Configuring done
-- Generating done
-- Build files have been written to: /home/rgjones/nordic/npm1300_fuel_gauge/build_thingy91x_nrf5340_cpuapp/npm1300_fuel_gauge
[1/223] Preparing syscall dependency handling
[5/223] Generating include/generated/zephyr/version.h
-- Zephyr version: 4.0.99 (/home/rgjones/ncs/v3.0.2/zephyr), build: v4.0.99-ncs1-2
[216/223] Building C object zephyr/drivers/mfd/CMakeFiles/drivers__mfd.dir/mfd_npm1300.c.obj
FAILED: zephyr/drivers/mfd/CMakeFiles/drivers__mfd.dir/mfd_npm1300.c.obj
ccache /home/rgjones/ncs/toolchains/7cbc0036f4/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13570 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13570 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DPICOLIBC_DOUBLE_PRINTF_SCANF -DUSE_PARTITION_MANAGER=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR_SUPERVISOR__ -D__ZEPHYR__=1 -I/home/rgjones/nordic/npm1300_fuel_gauge/build_thingy91x_nrf5340_cpuapp/npm1300_fuel_gauge/zephyr/include/generated/zephyr -I/home/rgjones/ncs/v3.0.2/zephyr/include -I/home/rgjones/nordic/npm1300_fuel_gauge/build_thingy91x_nrf5340_cpuapp/npm1300_fuel_gauge/zephyr/include/generated -I/home/rgjones/ncs/v3.0.2/zephyr/soc/nordic -I/home/rgjones/ncs/v3.0.2/zephyr/lib/posix/options/getopt -I/home/rgjones/ncs/v3.0.2/zephyr/soc/nordic/nrf53/. -I/home/rgjones/ncs/v3.0.2/zephyr/soc/nordic/common/. -I/home/rgjones/ncs/v3.0.2/zephyr/subsys/shell/modules/kernel_service/thread/.. -I/home/rgjones/ncs/v3.0.2/nrf/include -I/home/rgjones/ncs/v3.0.2/nrf/tests/include -I/home/rgjones/ncs/v3.0.2/modules/hal/cmsis/CMSIS/Core/Include -I/home/rgjones/ncs/v3.0.2/zephyr/modules/cmsis/. -I/home/rgjones/ncs/v3.0.2/nrf/modules/hal_nordic/. -I/home/rgjones/ncs/v3.0.2/modules/hal/nordic/nrfx -I/home/rgjones/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/include -I/home/rgjones/ncs/v3.0.2/modules/hal/nordic/nrfx/mdk -I/home/rgjones/ncs/v3.0.2/zephyr/modules/hal_nordic/nrfx/. -I/home/rgjones/ncs/v3.0.2/modules/debug/segger/SEGGER -I/home/rgjones/ncs/v3.0.2/modules/debug/segger/Config -I/home/rgjones/ncs/v3.0.2/nrfxlib/nrf_fuel_gauge/include -isystem /home/rgjones/ncs/v3.0.2/zephyr/lib/libc/common/include -isystem /home/rgjones/ncs/v3.0.2/nrfxlib/crypto/nrf_cc312_platform/include -Wshadow -fno-strict-aliasing -Os -imacros /home/rgjones/nordic/npm1300_fuel_gauge/build_thingy91x_nrf5340_cpuapp/npm1300_fuel_gauge/zephyr/include/generated/zephyr/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee -mtp=soft --sysroot=/home/rgjones/ncs/toolchains/7cbc0036f4/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros /home/rgjones/ncs/v3.0.2/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/home/rgjones/nordic/npm1300_fuel_gauge=CMAKE_SOURCE_DIR -fmacro-prefix-map=/home/rgjones/ncs/v3.0.2/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/home/rgjones/ncs/v3.0.2=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=picolibc.specs -D_POSIX_THREADS -std=c99 -MD -MT zephyr/drivers/mfd/CMakeFiles/drivers__mfd.dir/mfd_npm1300.c.obj -MF zephyr/drivers/mfd/CMakeFiles/drivers__mfd.dir/mfd_npm1300.c.obj.d -o zephyr/drivers/mfd/CMakeFiles/drivers__mfd.dir/mfd_npm1300.c.obj -c /home/rgjones/ncs/v3.0.2/zephyr/drivers/mfd/mfd_npm1300.c
In file included from /home/rgjones/ncs/v3.0.2/zephyr/include/zephyr/sys/util_macro.h:34,
from /home/rgjones/ncs/v3.0.2/zephyr/include/zephyr/irq_multilevel.h:16,
from /home/rgjones/ncs/v3.0.2/zephyr/include/zephyr/devicetree.h:20,
from /home/rgjones/ncs/v3.0.2/zephyr/include/zephyr/device.h:12,
from /home/rgjones/ncs/v3.0.2/zephyr/include/zephyr/drivers/i2c.h:27,
from /home/rgjones/ncs/v3.0.2/zephyr/drivers/mfd/mfd_npm1300.c:10:
/home/rgjones/ncs/v3.0.2/zephyr/include/zephyr/device.h:96:41: error: '__device_dts_ord_122' undeclared here (not in a function); did you mean '__device_dts_ord_22'?
96 | #define DEVICE_NAME_GET(dev_id) _CONCAT(__device_, dev_id)
/home/rgjones/ncs/v3.0.2/zephyr/include/zephyr/sys/util_internal.h:72:26: note: in definition of macro '__DEBRACKET'
72 | #define __DEBRACKET(...) __VA_ARGS__
/home/rgjones/ncs/v3.0.2/zephyr/include/zephyr/sys/util_internal.h:64:9: note: in expansion of macro '__GET_ARG2_DEBRACKET'
64 | __GET_ARG2_DEBRACKET(one_or_two_args _if_code, _else_code)
/home/rgjones/ncs/v3.0.2/zephyr/include/zephyr/sys/util_internal.h:59:9: note: in expansion of macro '__COND_CODE'
59 | __COND_CODE(_XXXX##_flag, _if_1_code, _else_code)
/home/rgjones/ncs/v3.0.2/zephyr/include/zephyr/sys/util_macro.h:196:9: note: in expansion of macro 'Z_COND_CODE_1'
196 | Z_COND_CODE_1(_flag, _if_1_code, _else_code)
/home/rgjones/ncs/v3.0.2/zephyr/include/zephyr/devicetree.h:4946:9: note: in expansion of macro 'COND_CODE_1'
4946 | COND_CODE_1(DT_HAS_COMPAT_STATUS_OKAY(DT_DRV_COMPAT), \
/home/rgjones/ncs/v3.0.2/zephyr/include/zephyr/sys/util_internal.h:69:53: note: in expansion of macro '__DEBRACKET'
69 | #define __GET_ARG2_DEBRACKET(ignore_this, val, ...) __DEBRACKET val
/home/rgjones/ncs/v3.0.2/zephyr/include/zephyr/drivers/i2c.h:122:17: note: in expansion of macro 'COND_CODE_1'
122 | COND_CODE_1(DT_ON_BUS(node_id, i3c), \
/home/rgjones/ncs/v3.0.2/zephyr/include/zephyr/toolchain/common.h:138:23: note: in expansion of macro '_DO_CONCAT'
138 | #define _CONCAT(x, y) _DO_CONCAT(x, y)
/home/rgjones/ncs/v3.0.2/zephyr/include/zephyr/device.h:96:33: note: in expansion of macro '_CONCAT'
/home/rgjones/ncs/v3.0.2/zephyr/include/zephyr/device.h:237:37: note: in expansion of macro 'DEVICE_NAME_GET'
237 | #define DEVICE_DT_NAME_GET(node_id) DEVICE_NAME_GET(Z_DEVICE_DT_DEV_ID(node_id))
/home/rgjones/ncs/v3.0.2/zephyr/include/zephyr/device.h:254:34: note: in expansion of macro 'DEVICE_DT_NAME_GET'
254 | #define DEVICE_DT_GET(node_id) (&DEVICE_DT_NAME_GET(node_id))
/home/rgjones/ncs/v3.0.2/zephyr/include/zephyr/drivers/i2c.h:107:16: note: in expansion of macro 'DEVICE_DT_GET'
107 | .bus = DEVICE_DT_GET(DT_BUS(node_id)), \
/home/rgjones/ncs/v3.0.2/zephyr/include/zephyr/drivers/i2c.h:124:30: note: in expansion of macro 'I2C_DT_SPEC_GET_ON_I2C'
124 | (I2C_DT_SPEC_GET_ON_I2C(node_id))) \
/home/rgjones/ncs/v3.0.2/zephyr/include/zephyr/drivers/i2c.h:136:9: note: in expansion of macro 'I2C_DT_SPEC_GET'
136 | I2C_DT_SPEC_GET(DT_DRV_INST(inst))
/home/rgjones/ncs/v3.0.2/zephyr/drivers/mfd/mfd_npm1300.c:315:24: note: in expansion of macro 'I2C_DT_SPEC_INST_GET'
315 | .i2c = I2C_DT_SPEC_INST_GET(inst), \
/home/rgjones/nordic/npm1300_fuel_gauge/build_thingy91x_nrf5340_cpuapp/npm1300_fuel_gauge/zephyr/include/generated/zephyr/devicetree_generated.h:19822:49: note: in expansion of macro 'MFD_NPM1300_DEFINE'
19822 | #define DT_FOREACH_OKAY_INST_nordic_npm1300(fn) fn(0)
/home/rgjones/ncs/v3.0.2/zephyr/include/zephyr/sys/util_internal.h:105:36: note: in expansion of macro 'DT_FOREACH_OKAY_INST_nordic_npm1300'
105 | #define UTIL_PRIMITIVE_CAT(a, ...) a##__VA_ARGS__
/home/rgjones/ncs/v3.0.2/zephyr/drivers/mfd/mfd_npm1300.c:325:1: note: in expansion of macro 'DT_INST_FOREACH_STATUS_OKAY'
325 | DT_INST_FOREACH_STATUS_OKAY(MFD_NPM1300_DEFINE)
FAILED: _sysbuild/sysbuild/images/npm1300_fuel_gauge-prefix/src/npm1300_fuel_gauge-stamp/npm1300_fuel_gauge-build /home/rgjones/nordic/npm1300_fuel_gauge/build_thingy91x_nrf5340_cpuapp/_sysbuild/sysbuild/images/npm1300_fuel_gauge-prefix/src/npm1300_fuel_gauge-stamp/npm1300_fuel_gauge-build
cd /home/rgjones/nordic/npm1300_fuel_gauge/build_thingy91x_nrf5340_cpuapp/npm1300_fuel_gauge && /home/rgjones/ncs/toolchains/7cbc0036f4/usr/local/bin/cmake --build .
FATAL ERROR: command exited with status 1: /home/rgjones/ncs/toolchains/7cbc0036f4/usr/local/bin/cmake --build /home/rgjones/nordic/npm1300_fuel_gauge/build_thingy91x_nrf5340_cpuapp
  • I've received some feedback now, Richard.
    Supposedly, it is difficult to do what you want, as we on the Thingy:91 X don't show how to use the nRF53 as anything else than a connectivity bridge (other than a proof-of-concept config of wifi shell).
    I've been told that there should be two ways to go at this.
    • Either use the nRF53 as a BLE controller, with the host running on the nRF91.
    • Or do the reconfiguration procedure that gives the nRF53 control of the I2C and SPI buses. There are device tree overlays in the board files for this. Also, additional partition tables, since external flash belongs to the chip who owns the SPI.
    All of this is highly experimental and not documented, I'm afraid.
  • Update.  I was able to get battery SOC data using the asset tracker example which does support the Thingy-91X;
    https://docs.nordicsemi.com/bundle/asset-tracker-template-latest/page/index.html
    This code builds for thingy91x/nrf9151/ns and ideally we'd like to run on the nrf53 since that's supporting BLE and the battery service.
    The SOC values seem OK in limited testing but I take Achim's point that a battery model 91X would be needed.
    Regarding Mathiaso "reconfiguration procedure that gives the nRF53 control of the I2C" - any more info on this?  Perhaps that is why the build above fails? - lack of reconfiguration of the i2c bus from '91 to '53?
    BTW I had already made the DEVICE_DT* changes to the fuel gauge sample to use the 91x names;
    npm1300_fuel_gauge/src/main.c;
    #ifdef TEST_ON_91X_NRF53 // build fails
    static const struct device *pmic = DEVICE_DT_GET(DT_NODELABEL(pmic_main));
    static const struct device *charger = DEVICE_DT_GET(DT_NODELABEL(npm1300_charger));
    #else // works for nrf5340dk_nrf5340_cpuapp
    static const struct device *pmic = DEVICE_DT_GET(DT_NODELABEL(npm1300_ek_pmic));
    static const struct device *charger = DEVICE_DT_GET(DT_NODELABEL(npm1300_ek_charger));
    and above you see if created thingy91x_nrf5340_cpuapp.overlay
  • Thanks for the link to the asset-tracker-template, seems that contains the battery model.
    Asset-Tracker-Template lp803448_model.h
    To be frank, I don't think, that using the nRF53 for the fuel guage is easy, if possible at all.
    The Thingy:91X uses i2c a lot from the nRF91 and I'm not aware, that i2c supports a "multi-master-mode".
    My plan was to use it for a better battery level value, but I send that over cellular to my server. As I wrote above, I don't think it makes sense to change the app in a way, to make the nRF53 the i2c master instead of the nRF91. What I would try (but I don't need that on the BLE) is to enable the i2c device mode on the nRF53 and then transfer the battery level to that nRF53.
