Enabling uarte0 causes i2c0 ssd1306 driver initialization failure
I'm using zephyr with a custom board (nrf52840) which has a ssd1306 OLED. I have it configured to use i2c0 and is working fine with lvgl.
When I try to enable uart0 (using the async API), the ssd1306 device initialization fails. I can confirm that both display and uart work as expected individually. When enabled together is when this issue occurs. I have triple checked that they don't have any overlapping pin configurations.
Is there anything else I should be checking?
  • Like I said, I'm defining my own board, so there isn't anything to inherit from.
    Here is my pinctrl definitions:
    	pinctrl: pin-controller {
    		uart0_default: uart0_default {
    			phandle = < 0x2 >;
    			group1 {
    				psels = < 0x2b >;
    			group2 {
    				psels = < 0x100002c >;
    				bias-pull-up;
    		uart0_sleep: uart0_sleep {
    			phandle = < 0x3 >;
    			group1 {
    				psels = < 0x2b >,
    				        < 0x100002c >;
    				low-power-enable;
    		i2c0_default: i2c0_default {
    			phandle = < 0x4 >;
    			group1 {
    				psels = < 0xc000004 >,
    				        < 0xb000005 >;
    		i2c0_sleep: i2c0_sleep {
    			group1 {
    				        < 0xb000005 >;
    				low-power-enable;
    Your custom board has external pull resistors on SDA/SCL? What is the speed? If using 400 kHz mode, you will need strong pulls, in the order of < 5kOhm. I suggest that you scope your pins on both scenarios, share run time logs of both working and non-working scenarios.
    Håkon
  • I have 4.7K external pull-ups on SCL and SDA lines. The clock speed was unset till now, but setting it to 100 kHZ (with `clock-frequency = <I2C_BITRATE_STANDARD>;` in the i2c0 node) has no effect.
    I can post scope screenshots and logs tomorrow when I get back to my desk.
    But I'm curious to understand your reasoning... Since i2c0 works if I disable uart0, I'd expect the issue to have something to the way they interact with each other. If it were a physical issue, that would still be the case with i2c0 alone no?
    On the nRF52-series devices, the UART is not a shared resource, which it is on the nRF53-series and on-ward.
    This means that TWIM0 and UARTE0 can be used simultaneously without any issues, provided that they do not create a pin conflict for each other. Ie. there is no reason why these two peripherals cannot coexist on the nRF52840.
    perfect, this would be great.
    Håkon
  • Thanks for the response. I'm aware that those peripherals are non-shared. I was wondering if anything else was shared, such as IRQs, DMAs etc.,
    Here is a scope capture of the failure:
    I found Zephyr tries to send a single 0 byte to the OLED at address 0x3c. This can be seen in the capture as well.
