quantifying PMIC overhead
actually a general question, though i'm working with the nPM2100 EK....
assume my target MCU operates "most efficiently" when supplied 1V8 -- expressing overall energy consumption in Joules....
but i'm using a 3V battery as my power source, hence i'll need to buck my voltage down to 1V8....
assuming i'm using a PMIC (like the nPM2100), how should i best capture the "real energy" consumed by this configuration....
using (say) a PPK, do i measure current "upstream" near my 3V source??? (or maybe i use the PPK to source 3V ???)
said another way, should i really be multiplying the Coulombs reported by the PPK by 3V to get my true energy consumption in Joules???
i have similar boards to the nPM2100 EK from other vendors and want to ensure i'm truly making an "apples-to-apples" comparison....
  • my goal is to quantify overall energy efficiency in my target system doing "something" typical -- for instance, BLE advertising at a 1s interval....
    i want to do A-B comparisons -- with vs without the PMIC, Nordic's PMIC versus someone else's, etc....
    given that the nRF54 has an onboard DCDC, will i do better sending 3V directly to the MCU or should i send it to a PMIC which will output 1V8 directly into the MCU???
    The nRF54L15 will always use the internal DCDC as some internal voltages are lower. Also, note that using an external regulator or not is not just a matter of efficienty, as the GPIO voltage will be the same as the VDD voltage, and this along with other factors such as potentially a rechargable battery, need for fule gauging etc, determine what type of PMIC you should use or if you do not need any at all.
