Unable to install SDK via VS Code
I have installed nRF connect 2025.9.732 on my VS code Version: 1.103.2 on Ubuntu 22.04.
I am able to install the toolchains successful but I am getting this weird error message
[14:05:44] nrfutil-sdk-manager install,v3.1.0,--sdk-path,/home/akshay/ncs/v3.1.0,--type,nrf: Install toolchain v3.1.0
[14:05:44] nrfutil-sdk-manager install,v3.1.0,--sdk-path,/home/akshay/ncs/v3.1.0,--type,nrf: Toolchain with version v3.1.0 already installed: success
[14:05:44] nrfutil-sdk-manager install,v3.1.0,--sdk-path,/home/akshay/ncs/v3.1.0,--type,nrf: Calculating SDK checksum
[14:05:53] nrfutil-sdk-manager install,v3.1.0,--sdk-path,/home/akshay/ncs/v3.1.0,--type,nrf: Verified previously download file: success
[14:05:53] nrfutil-sdk-manager install,v3.1.0,--sdk-path,/home/akshay/ncs/v3.1.0,--type,nrf: Unpack SDK v3.1.0
[14:06:06] nrfutil-sdk-manager install,v3.1.0,--sdk-path,/home/akshay/ncs/v3.1.0,--type,nrf: Unpacked SDK tarball: success
[west]: usage: west [-h] [-z ZEPHYR_BASE] [-v] [-q] [-V] <command> ...
[west]: west: unknown command "zephyr-export"; workspace /home/akshay/ncs/v3.1.0 does not define this extension command -- try "west help" and "west -vv status"
[west]: exited with code 1.
[west]: FATAL ERROR: failed manifest import in zephyr (zephyr):
[west]:   Failed importing "west.yml" from revision "ncs-v3.1.0"
[west]:   Hint: zephyr must be cloned, owned by the user and its manifest-rev ref must point to a commit with the import data
[west]:   To fix, run "west update. If it still fails, try "west -vv ..."
I have west installed globally via pip, but I do NOT have ZEPHYR os installed in ~/zephyrproject.
I am not sure what that error is, do I have to go to /home/akshay/ncs/v3.1.0 and type west update?
  • Okay, that downloaded the repos without any error. But it doesn't work in nrfutil sdk-manager toolchain launch --ncs-version v3.1.0 --shell.
    And in VS Code console I get this error
    I got that error by going to - nRF Connect | Manage SDKs | Install SDK | nRF Connect SDK - now check your nRF Connect console under Output. And if I click on Manage toolchains from the side menu, I get the same error in the console.
    And when trying to create a new sample application, I get the same error (screenshot below)
  • Hi Akshay,
    Could you attach your Support Information?
    -Priyanka
  • Here you go
    // IMPORTANT: The following data can contain sensitive or confidential information about your environment.
    // If you do not want others to see this information, make sure to remove it before sharing the data.
    // For help and support, visit Nordic Semiconductor's DevZone at https://devzone.nordicsemi.com/.
      "platform": {
        "os": "linux",
        "osVersion": "#79~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Fri Aug 15 16:54:53 UTC 2",
        "osKernel": "6.8.0-79-generic",
        "vscode": "1.103.2",
        "electron": "37.2.3",
        "node": "v22.17.0",
        "name": "Ubuntu",
        "id": "ubuntu",
        "version": "22.04.5 LTS (Jammy Jellyfish)",
        "versionId": "22.04",
        "appName": "Visual Studio Code",
        "appHost": "desktop"
      "system": {
        "date": "2025-09-04T09:34:29.529Z",
        "vscodeRoot": "/usr/share/code/resources/app",
        "nrfConnectForDesktopInstalled": "unknown",
        "vscodeUptime": "00:00:58",
        "osUptime": "36:15:41",
        "cpu": "11th Gen Intel(R) Core(TM) i7-11850H @ 2.50GHz"
      "workspace": {
        "name": null,
        "workspaceFile": null,
        "folders": []
      "sdks": [
          "version": "v3.1.0",
          "path": "/home/akshay/ncs/v3.1.0"
      "apps": [],
      "toolchains": [
          "version": "3.1.0",
          "path": "/home/akshay/ncs/toolchains/c5be9c56c7",
          "displayName": "nRF Connect SDK Toolchain v3.1.0",
          "compilerTools": [
            "Zephyr SDK (arm) 0.17.0",
            "Zephyr SDK (riscv) 0.17.0"
          "version": "3.0.2",
          "path": "/home/akshay/ncs/toolchains/7cbc0036f4",
          "displayName": "nRF Connect SDK Toolchain v3.0.2",
          "compilerTools": [
      "connectedDevices": [],
      "tools": {
        "/home/akshay/ncs/toolchains/c5be9c56c7/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc": "0.17.0",
        "/opt/SEGGER/JLink/JLinkExe": "8.18",
        "/home/akshay/ncs/toolchains/c5be9c56c7/nrfutil/bin/nrfutil": "8.1.0",
        "/home/akshay/ncs/toolchains/c5be9c56c7/usr/local/bin/cmake": "3.21.0",
        "/home/akshay/ncs/toolchains/c5be9c56c7/usr/local/bin/west": "1.4.0",
        "/home/akshay/ncs/toolchains/c5be9c56c7/usr/local/bin/python3": "3.12.4",
        "/home/akshay/ncs/toolchains/c5be9c56c7/usr/local/bin/ninja": "1.10.2",
        "/home/akshay/ncs/toolchains/c5be9c56c7/usr/bin/gperf": "3.1",
        "/home/akshay/ncs/toolchains/c5be9c56c7/usr/bin/dtc": "1.5.0",
        "/home/akshay/ncs/toolchains/c5be9c56c7/opt/bin/gn": "2132",
        "/home/akshay/ncs/toolchains/c5be9c56c7/usr/local/bin/git": "git version 2.37.3",
        "debugger (arm)": "/home/akshay/ncs/toolchains/c5be9c56c7/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gdb",
        "debugger (riscv)": "/home/akshay/ncs/toolchains/c5be9c56c7/opt/zephyr-sdk/riscv64-zephyr-elf/bin/riscv64-zephyr-elf-gdb"
      "nrfutil": {
        "nrfutil-device": {
          "version": "2.12.7",
          "binPath": "/home/akshay/.vscode/extensions/nordic-semiconductor.nrf-connect-2025.9.732-linux-x64/platform/nrfutil/bin/nrfutil-device",
          "jlinkInfo": {
            "description": "This version of SEGGER J-Link is different from the J-Link version that was used to test nrfutil device commands",
            "expectedVersion": {
              "version": "JLink_V8.42",
              "versionFormat": "string"
            "name": "JlinkARM",
            "version": "JLink_V8.18",
        "nrfutil-sdk-manager": {
          "version": "1.6.0",
          "binPath": "/home/akshay/.vscode/extensions/nordic-semiconductor.nrf-connect-2025.9.732-linux-x64/platform/nrfutil/bin/nrfutil-sdk-manager"
      "environment": {
        "westEnv": {
          "GIT_EXEC_PATH": "/home/akshay/ncs/toolchains/c5be9c56c7/usr/local/libexec/git-core",
          "HOME": "/home/akshay",
          "PATH": "/home/akshay/ncs/toolchains/c5be9c56c7/usr/bin:/home/akshay/ncs/toolchains/c5be9c56c7/usr/bin:/home/akshay/ncs/toolchains/c5be9c56c7/usr/local/bin:/home/akshay/ncs/toolchains/c5be9c56c7/opt/bin:/home/akshay/ncs/toolchains/c5be9c56c7/opt/nanopb/generator-bin:/home/akshay/ncs/toolchains/c5be9c56c7/nrfutil/bin:/home/akshay/ncs/toolchains/c5be9c56c7/opt/zephyr-sdk/arm-zephyr-eabi/bin:/home/akshay/ncs/toolchains/c5be9c56c7/opt/zephyr-sdk/riscv64-zephyr-elf/bin:/home/akshay/.vscode/extensions/stmicroelectronics.stm32cube-ide-core-0.17.1/resources/binaries/linux/x86_64:/home/akshay/miniconda3/bin:/home/akshay/miniconda3/condabin:/home/linuxbrew/.linuxbrew/bin:/home/linuxbrew/.linuxbrew/sbin:/home/akshay/flutter/bin:/home/akshay/bin:/home/akshay/.nvm/versions/node/v22.17.1/bin:/home/akshay/.bun/bin:/home/akshay/.cargo/bin:/home/akshay/st/stm32cubeclt_1.19.0:/home/akshay/st/stm32cubeclt_1.19.0/STM32CubeProgrammer/bin:/home/akshay/st/stm32cubeclt_1.19.0/STLink-gdb-server/bin:/home/akshay/st/stm32cubeclt_1.19.0/CMake/bin:/home/akshay/st/stm32cubeclt_1.19.0/Ninja/bin:/home/akshay/st/stm32cubeclt_1.19.0/st-arm-clang/bin:/home/akshay/st/stm32cubeclt_1.19.0/GNU-tools-for-STM32/bin:/home/akshay/st/stm32cubeclt_1.19.0:/home/akshay/st/stm32cubeclt_1.19.0/STM32CubeProgrammer/bin:/home/akshay/st/stm32cubeclt_1.19.0/STLink-gdb-server/bin:/home/akshay/st/stm32cubeclt_1.19.0/CMake/bin:/home/akshay/st/stm32cubeclt_1.19.0/Ninja/bin:/home/akshay/st/stm32cubeclt_1.19.0/st-arm-clang/bin:/home/akshay/st/stm32cubeclt_1.19.0/GNU-tools-for-STM32/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/snap/bin:/home/akshay/.dotnet/tools:/home/akshay/golang/bin:/home/akshay/Android/Sdk/platform-tools:/home/akshay/Android/Sdk/cmdline-tools/latest/bin:/home/akshay/bin:/home/akshay/.local/bin:/home/akshay/Qt/6.2.12/gcc_64/bin:/home/akshay/cmake/bin:/home/akshay/.dotnet:/home/akshay/zig:/home/akshay/.dotnet/tools:/home/akshay/.pub-cache/bin:/home/akshay/.dotnet/tools:/home/akshay/.vscode/extensions/stmicroelectronics.stm32cube-ide-core-0.17.1/resources/binaries/linux/x86_64:/home/akshay/miniconda3/bin:/home/akshay/miniconda3/condabin:/home/linuxbrew/.linuxbrew/bin:/home/linuxbrew/.linuxbrew/sbin:/home/akshay/flutter/bin:/home/akshay/bin:/home/akshay/.nvm/versions/node/v22.17.1/bin:/home/akshay/.bun/bin:/home/akshay/.cargo/bin:/home/akshay/st/stm32cubeclt_1.19.0:/home/akshay/st/stm32cubeclt_1.19.0/STM32CubeProgrammer/bin:/home/akshay/st/stm32cubeclt_1.19.0/STLink-gdb-server/bin:/home/akshay/st/stm32cubeclt_1.19.0/CMake/bin:/home/akshay/st/stm32cubeclt_1.19.0/Ninja/bin:/home/akshay/st/stm32cubeclt_1.19.0/st-arm-clang/bin:/home/akshay/st/stm32cubeclt_1.19.0/GNU-tools-for-STM32/bin:/home/akshay/st/stm32cubeclt_1.19.0:/home/akshay/st/stm32cubeclt_1.19.0/STM32CubeProgrammer/bin:/home/akshay/st/stm32cubeclt_1.19.0/STLink-gdb-server/bin:/home/akshay/st/stm32cubeclt_1.19.0/CMake/bin:/home/akshay/st/stm32cubeclt_1.19.0/Ninja/bin:/home/akshay/st/stm32cubeclt_1.19.0/st-arm-clang/bin:/home/akshay/st/stm32cubeclt_1.19.0/GNU-tools-for-STM32/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/snap/bin:/home/akshay/.dotnet/tools:/home/akshay/golang/bin:/home/akshay/Android/Sdk/platform-tools:/home/akshay/Android/Sdk/cmdline-tools/latest/bin:/home/akshay/bin:/home/akshay/.local/bin:/home/akshay/Qt/6.2.12/gcc_64/bin:/home/akshay/cmake/bin:/home/akshay/.dotnet:/home/akshay/zig:/home/akshay/.dotnet/tools:/home/akshay/.pub-cache/bin:/home/akshay/.dotnet/tools",
          "ZEPHYR_SDK_INSTALL_DIR": "/home/akshay/ncs/toolchains/c5be9c56c7/opt/zephyr-sdk",
          "PYTHONPATH": "/home/akshay/ncs/toolchains/c5be9c56c7/usr/local/lib/python3.12:/home/akshay/ncs/toolchains/c5be9c56c7/usr/local/lib/python3.12/site-packages",
          "USER": "akshay"
        "inherited": {
          "ELECTRON_RUN_AS_NODE": "1",
          "PATH": "/home/akshay/.vscode/extensions/stmicroelectronics.stm32cube-ide-build-cmake-1.40.1/resources/cube-cmake/linux:/home/akshay/.vscode/extensions/stmicroelectronics.stm32cube-ide-core-0.17.1/resources/binaries/linux/x86_64:/home/akshay/miniconda3/bin:/home/akshay/miniconda3/condabin:/home/linuxbrew/.linuxbrew/bin:/home/linuxbrew/.linuxbrew/sbin:/home/akshay/flutter/bin:/home/akshay/bin:/home/akshay/.nvm/versions/node/v22.17.1/bin:/home/akshay/.bun/bin:/home/akshay/.cargo/bin:/home/akshay/st/stm32cubeclt_1.19.0:/home/akshay/st/stm32cubeclt_1.19.0/STM32CubeProgrammer/bin:/home/akshay/st/stm32cubeclt_1.19.0/STLink-gdb-server/bin:/home/akshay/st/stm32cubeclt_1.19.0/CMake/bin:/home/akshay/st/stm32cubeclt_1.19.0/Ninja/bin:/home/akshay/st/stm32cubeclt_1.19.0/st-arm-clang/bin:/home/akshay/st/stm32cubeclt_1.19.0/GNU-tools-for-STM32/bin:/home/akshay/st/stm32cubeclt_1.19.0:/home/akshay/st/stm32cubeclt_1.19.0/STM32CubeProgrammer/bin:/home/akshay/st/stm32cubeclt_1.19.0/STLink-gdb-server/bin:/home/akshay/st/stm32cubeclt_1.19.0/CMake/bin:/home/akshay/st/stm32cubeclt_1.19.0/Ninja/bin:/home/akshay/st/stm32cubeclt_1.19.0/st-arm-clang/bin:/home/akshay/st/stm32cubeclt_1.19.0/GNU-tools-for-STM32/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/snap/bin:/home/akshay/.dotnet/tools:/home/akshay/golang/bin:/home/akshay/Android/Sdk/platform-tools:/home/akshay/Android/Sdk/cmdline-tools/latest/bin:/home/akshay/bin:/home/akshay/.local/bin:/home/akshay/Qt/6.2.12/gcc_64/bin:/home/akshay/cmake/bin:/home/akshay/.dotnet:/home/akshay/zig:/home/akshay/.dotnet/tools:/home/akshay/.pub-cache/bin:/home/akshay/.dotnet/tools",
          "USER": "akshay"
      "terminal": {
        "defaultProfile": null
      "config": {
          "ozonePath": "",
          "applications": [],
          "applicationOptions": {},
          "kconfig": {
            "interface": "kconfig"
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [],
          "taskBindings": {},
          "debugging": {
            "flash": true,
            "bindings": {},
            "justMyCode": false
          "flash": {
            "softreset": false,
            "erase": false,
            "recover": false
          "enableTelemetry": false,
          "thirdpartyIntegration": {},
          "toolchainManager": {
            "indexURL": null,
            "installDirectory": null
          "nrfutil": {
            "home": null
          "defaultOpenAction": "ask",
          "terminalProfile": {
            "shell": null
          "terminalMode": "character",
          "localEcho": false
        "marus25.cortex-debug": {
          "variableUseNaturalFormat": true,
          "liveWatchRefreshRate": "300",
          "armToolchainPath": null,
          "armToolchainPrefix": "arm-none-eabi",
          "gdbPath": null,
          "objdumpPath": null,
          "JLinkGDBServerPath": null,
          "openocdPath": null,
          "pyocdPath": null,
          "PEGDBServerPath": null,
          "stutilPath": null,
          "stlinkPath": null,
          "stm32cubeprogrammer": null,
          "enableTelemetry": true,
          "dbgServerLogfile": null
      "extensions": {
        "internal": {
            "version": "2025.9.732",
            "path": "/home/akshay/.vscode/extensions/nordic-semiconductor.nrf-connect-2025.9.732-linux-x64",
            "isActive": true
            "version": "2025.8.103",
            "path": "/home/akshay/.vscode/extensions/nordic-semiconductor.nrf-terminal-2025.8.103",
            "isActive": true
            "version": "2025.8.140",
            "path": "/home/akshay/.vscode/extensions/nordic-semiconductor.nrf-devicetree-2025.8.140",
            "isActive": true
            "version": "2025.9.123",
            "path": "/home/akshay/.vscode/extensions/nordic-semiconductor.nrf-kconfig-2025.9.123",
            "isActive": true
        "external": {
          "marus25.cortex-debug": "1.12.1",
          "ms-vscode.cpptools": "1.26.3",
          "ms-vscode.js-debug": "1.102.0",
          "alefragnani.pascal": "9.9.0",
          "AykutSarac.jsoncrack-vscode": "3.0.0",
          "bierner.markdown-mermaid": "1.28.0",
          "bradlc.vscode-tailwindcss": "0.14.26",
          "charliermarsh.ruff": "2025.24.0",
          "dan-c-underwood.arm": "1.7.4",
          "Dart-Code.dart-code": "3.118.1",
          "Dart-Code.flutter": "3.118.0",
          "denoland.vscode-deno": "3.45.2",
          "docker.docker": "0.16.0",
          "eamodio.gitlens": "17.4.1",
          "esbenp.prettier-vscode": "11.0.0",
          "GitHub.copilot": "1.364.0",
          "GitHub.copilot-chat": "0.30.3",
          "GitHub.github-vscode-theme": "6.3.5",
          "github.vscode-github-actions": "0.27.2",
          "golang.go": "0.48.0",
          "Gruntfuggly.todo-tree": "0.0.226",
          "hbenl.vscode-test-explorer": "2.22.1",
          "idleberg.emoji-code": "0.15.2",
          "James-Yu.latex-workshop": "10.10.2",
          "llvm-vs-code-extensions.lldb-dap": "0.2.16",
          "mcu-debug.debug-tracker-vscode": "0.0.15",
          "mcu-debug.memory-view": "0.0.26",
          "mcu-debug.peripheral-viewer": "1.6.0",
          "mcu-debug.rtos-views": "0.0.10",
          "mechatroner.rainbow-csv": "3.21.0",
          "mjmlio.vscode-mjml": "2.1.0",
          "ms-azuretools.vscode-containers": "2.1.0",
          "ms-azuretools.vscode-docker": "2.0.0",
          "ms-python.debugpy": "2025.10.0",
          "ms-python.python": "2025.12.0",
          "ms-python.vscode-pylance": "2025.7.1",
          "ms-python.vscode-python-envs": "1.2.0",
          "ms-toolsai.jupyter": "2025.7.0",
          "ms-toolsai.jupyter-keymap": "1.1.2",
          "ms-toolsai.jupyter-renderers": "1.3.0",
          "ms-toolsai.vscode-jupyter-cell-tags": "0.1.9",
          "ms-toolsai.vscode-jupyter-slideshow": "0.1.6",
          "ms-vscode-remote.remote-containers": "0.422.1",
          "ms-vscode-remote.remote-ssh": "0.120.0",
          "ms-vscode-remote.remote-ssh-edit": "0.87.0",
          "ms-vscode-remote.remote-wsl": "0.99.0",
          "ms-vscode.cmake-tools": "1.21.36",
          "ms-vscode.cpptools-extension-pack": "1.3.1",
          "ms-vscode.hexeditor": "1.11.1",
          "ms-vscode.powershell": "2025.2.0",
          "ms-vscode.remote-explorer": "0.5.0",
          "ms-vscode.remote-repositories": "0.42.0",
          "ms-vscode.test-adapter-converter": "0.2.1",
          "ms-vscode.vscode-embedded-tools": "0.8.0",
          "myriad-dreamin.tinymist": "0.13.24",
          "nefrob.vscode-just-syntax": "0.8.0",
          "redhat.vscode-xml": "0.29.0",
          "redhat.vscode-yaml": "1.18.0",
          "ritwickdey.LiveServer": "5.7.9",
          "rust-lang.rust-analyzer": "0.3.2593",
          "saoudrizwan.claude-dev": "3.27.0",
          "STMicroelectronics.stm32-vscode-extension": "2.1.1",
          "STMicroelectronics.stm32cube-ide-build-cmake": "1.40.1",
          "STMicroelectronics.stm32cube-ide-core": "0.17.1",
          "STMicroelectronics.stm32cube-ide-debug-core": "0.19.0",
          "STMicroelectronics.stm32cube-ide-debug-stlink-gdbserver": "0.10.1",
          "streetsidesoftware.code-spell-checker": "4.2.6",
          "tamasfe.even-better-toml": "0.21.2",
          "tauri-apps.tauri-vscode": "0.2.9",
          "theqtcompany.qt": "1.2.0",
          "theqtcompany.qt-core": "1.6.0",
          "theqtcompany.qt-cpp": "1.6.0",
          "theqtcompany.qt-cpp-pack": "1.0.1",
          "theqtcompany.qt-qml": "1.6.0",
          "theqtcompany.qt-ui": "1.6.0",
          "twxs.cmake": "0.0.17",
          "vscode-icons-team.vscode-icons": "12.14.0",
          "Vue.volar": "3.0.6",
          "yzhang.markdown-all-in-one": "3.6.3",
          "ziglang.vscode-zig": "0.6.13",
          "ZixuanWang.linkerscript": "1.0.4"
  • Hi Akshay,
    I am checking this internally with experts and will get back to you as soon as I get a solution.
    -Priyanka
