proper usage of peer manager + advertising and what to do after disconnect
I am using NRF SDK 17.1.0
I inherited some legacy code that was a mess, and rewrote it.
Part 1 -
First I skipped the peer manager thinking it was not necessary.
Then I re-added the peer manager to a peripheral to allow faster reconnects in the event we lose connection.
It happens frequently. The device is frequently submerged in water. Without peer manager, reconnection was slow.
I first was using a manual deactivation of advertising on connect, and activation of advertising on disconnect, and if multiple centrals are nearby, I noticed some cross pairing issues.
Later, I noticed 3 things
  • The legacy code I inherited never turned off advertising, tho I don't see it advertise in nrf connect while connected
  • The legacy code I inherited was skipping
    pm_handler_disconnect_on_sec_failure in the pm_evt_handler(), I re-enabled it
  • I set config.ble_adv_on_disconnect_disabled to false
Between these 2 actions, it seems like the cross pairing issue is gone.
Question 1&2 - is this the correct way to handle advertise on disconnect? Should I never be turning off advertising after a connection is established?
Part 2 -
If a central is scanning and see's my peripheral, it tries to connect.
The central hammers the peripheral and I get an endless loop of
<warning> app: BLE_GAP_EVT_CONNECTED
<info> peer_manager_handler: Connection security failed: role: Peripheral, conn_handle: 0x0, procedure: Encryption, error: 4102
<warning> peer_manager_handler: Disconnecting conn_handle 0.
<warning> app: BLE_GAP_EVT_DISCONNECTED
I expect the security failure given that it isn't paired/bonded.
Question 3 - If I delete the bonds on the peripheral, start advertising (undirected) and want this new central to connect, It seems like it stops scanning and fails to connect.
I am trying to determine if this is a bug in my central or the peripheral. Still gathering data. Open to suggestions.
Thanks!
  • The central device is another nrf52840.
    It does not see the error 4102 warning, it only see's the disconnect reason 0x13.
    The peripheral show's the error 4102 warning.
    It would be better if the central could detect this issue and delete the bonds.
  • If you want the central to delete the bond, then you could implement a simple logic where if the connection failed repeatedly within a small time frame (like more than 3 times within 10-15 seconds), it could delete the bond.
    Deleting bond on the central could be done similar to how it is done in the peripheral.
  • So I did try this, and it did fix the central reconnecting problem.
    However it broke the tolerance to being submerged.
    We frequently submerge the device, which is why I used peer manager in the first place, for quick reconnection, and it worked great.
    The second I implemented the workaround (3x within 10-15 seconds), after submerging, I have to re-pair, which is not good at all.
    Since the central doesn't see the 4102, maybe I need to update peripheral advertisement data to indicate to the central to clear the bonding info, when it see's a 4102. Can you think of anything simpler?
  • I added this exact feature, and now the central can filter scanned devices for the "peripheral with 4102" indicator and delete bonds.
  • I tested a little bit with the ble_app_hrs and ble_app_hrs_c examples and have a few findings.
    First, I found that the disconnection in those examples is due to a pm_handler_disconnect_on_sec_failure() call in the peer manager event handler. A failure in the security procedure doesn't immediately lead to a disconnection.
    Thus, I comment out pm_handler_disconnect_on_sec_failure(), and retry the case where only the peripheral forgets the bond.
    I see that both the central and the peripheral receive error 4102 with different source.
    On the central, Peer Manager report error 4102 with source BLE_GAP_SEC_STATUS_SOURCE_REMOTE.
    On the peripheral, Peer Manager reports error 4102 with source BLE_GAP_SEC_STATUS_SOURCE_LOCAL.
    If your application is also using pm_handler_disconnect_on_sec_failure(), you can try delaying that call until after error checking, detect the error, and raise some flags before disconnecting, for example.
    On a relevant note, if I also remove the auto disconnect, and try the case where only the central forgets the bond, both devices then see Peer Manager reporting error 133, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP. That sounds arguably wrong, but it is what the current behavior is like. If you wish, you can add similar handling on the peripheral side to forget bonds.
    While working on that, I realize something strange. How come the submerged peripheral device forgets the bonds? Does it get bonded with a lot of centrals?
