having issues with saving coredump to flash or at all
Hi Nordic
I am working with nrf52840 and nrf52832 using ncs v2.8.0
I am trying to save coredump to flash according to instructions on this link - https://docs.nordicsemi.com/bundle/ncs-2.8.0/page/zephyr/services/debugging/coredump.html
I added this to my pm_static_my_board.yml
coredump_partition:
  address: 0xCF000
  region: flash_primary
And this to my_board.overlay
&flash0 {
     * For more information, see:
     * http: //docs.zephyrproject.org/latest/guides/dts/index.html#flash-partitions
    partitions {
        #address-cells = <1>;
        #size-cells = <1>;
        coredump_partition: partition@000080000 { //THIS IS NOT LEGIT ADDRESS(END OF FLASH) BUT IT IS NOT TAKEN TO ACOUNT BECAUS PM_STATIC IS
            label = "coredump-partition";
            reg = <0x000080000 DT_SIZE_K(4)>;
A side note is that this is strange that I need to set it in the overlay which is basically ignored because pm_static partitions is the one that actually matters (unless i got something wrong ? )
And this configs to my prj.conf
# Coredump
CONFIG_DEBUG_COREDUMP=y
CONFIG_DEBUG_COREDUMP_BACKEND_FLASH_PARTITION=y
CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_THREADS=y
In my my_board/my_app/zephyr/.config i see this coredump related configs
CONFIG_ARCH_SUPPORTS_COREDUMP=y
CONFIG_ARCH_SUPPORTS_COREDUMP_THREADS=y
# CONFIG_COREDUMP_DEVICE is not set
CONFIG_DEBUG_THREAD_INFO=y
# CONFIG_DEBUG_COREDUMP_BACKEND_LOGGING is not set
# CONFIG_DEBUG_COREDUMP_BACKEND_OTHER is not set
# CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_MIN is not set
# CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_LINKER_RAM is not set
CONFIG_DEBUG_COREDUMP_FLASH_CHUNK_SIZE=64
CONFIG_DEBUG_COREDUMP_THREADS_METADATA=y
I am generating a coredump using this implementation
void trigger_coredump(void)
    __ASSERT(0, "Forcing coredump");
When i try to read the flash area after generating the coredump with nrfjprog --memrd 0xCF000 --w 32 --n 0x8000
i get all 0xFF
what i am missing ?
I also tried to check myself by replacing CONFIG_DEBUG_COREDUMP_BACKEND_FLASH_PARTITION=y
With CONFIG_DEBUG_COREDUMP_BACKEND_LOGGING=y
Hopping to see the coredump on my open rtt but nothing .. when coredump is triggered prints just stop
  1. What am I missing? Why can't I find a coredump on the flash partition or in the rtt log ?
  2. Can it be that the device does not have the time to write the coredump before the actual crash ? If so, how can I manage that ?
  3. Is there some auto deletion of the flash partition with the coredump so new coredumps can be saved or is it something i have to manage myself after i read the coredump from flash ?
Hope to read you soon
Best regards
Ziv
  • The r14/lr register will tell you were the call was made from. But yes, there might of be cases were even a minimal CD will provide relevant debug information that's not shown in the crash log.
  • Thank you for the hasty reply Vidar.
    Well, given your answer, could you provide us a minimal sample project with the necessary changes to be able to save the CD to the internal/ external flash? For me, external is preferred since we'll also want to save the reset reason and have it all in one place. and I saw that the logging CD generates ~34kb of data. Dunno what Zhiv prefers.
  • As mentioned earlier, writing to external flash requires a custom bare metal SPI flash driver that does not rely on any Zephyr primitives and can operate from the hardfault interrupt context. For internal flash, we already have a driver, see the PR linked earlier.
    I'm not sure what you have in mind here. How would you include the reset reason in the CD.
  • i suggested this for you, before .. we use it in main when app re starts
    uint32_t reset_reason = nrf_power_resetreas_get(NRF_POWER);
  • hi Vidar
    What is relevant here is whether you have CONFIG_ASSERT enabled in your build not
    we use assert a lot in our code and also zephyr uses it internally so this is why it is wird for me and also why i try to avoid it plus i don't seem to be getting to the writing of CD to flash at the moment .. anyway i'll try to run with it disabled and see
    i can not use RAM for saving logs or CD since the devices in the field are configured with logs disabled and i need to know what happens there in a retrospective, after they reset and reconnected with a node
    i don't mind using the internal flash or the external (external will be more comfortable obviously but internal will work for now as well)
    You can simply redefine the weakly defined k_sys_fatal_error_handler() function in your application
    the api seems to have fatal error reason and exception context .. are those filled automatically ?
    just to be sure if i overwrite this api then i do not have to CONFIG_ASSERT=n ?
    p.s. this api seems to be called from inside z_fatal_error which i don't thing i am getting into since i both don't see its prints and putting a breakpoint at the beginning of it when debugging did not stop there
