having issues with saving coredump to flash or at all
Hi Nordic
I am working with nrf52840 and nrf52832 using ncs v2.8.0
I am trying to save coredump to flash according to instructions on this link - https://docs.nordicsemi.com/bundle/ncs-2.8.0/page/zephyr/services/debugging/coredump.html
I added this to my pm_static_my_board.yml
coredump_partition:
  address: 0xCF000
  region: flash_primary
And this to my_board.overlay
&flash0 {
     * For more information, see:
     * http: //docs.zephyrproject.org/latest/guides/dts/index.html#flash-partitions
    partitions {
        #address-cells = <1>;
        #size-cells = <1>;
        coredump_partition: partition@000080000 { //THIS IS NOT LEGIT ADDRESS(END OF FLASH) BUT IT IS NOT TAKEN TO ACOUNT BECAUS PM_STATIC IS
            label = "coredump-partition";
            reg = <0x000080000 DT_SIZE_K(4)>;
A side note is that this is strange that I need to set it in the overlay which is basically ignored because pm_static partitions is the one that actually matters (unless i got something wrong ? )
And this configs to my prj.conf
# Coredump
CONFIG_DEBUG_COREDUMP=y
CONFIG_DEBUG_COREDUMP_BACKEND_FLASH_PARTITION=y
CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_THREADS=y
In my my_board/my_app/zephyr/.config i see this coredump related configs
CONFIG_ARCH_SUPPORTS_COREDUMP=y
CONFIG_ARCH_SUPPORTS_COREDUMP_THREADS=y
# CONFIG_COREDUMP_DEVICE is not set
CONFIG_DEBUG_THREAD_INFO=y
# CONFIG_DEBUG_COREDUMP_BACKEND_LOGGING is not set
# CONFIG_DEBUG_COREDUMP_BACKEND_OTHER is not set
# CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_MIN is not set
# CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_LINKER_RAM is not set
CONFIG_DEBUG_COREDUMP_FLASH_CHUNK_SIZE=64
CONFIG_DEBUG_COREDUMP_THREADS_METADATA=y
I am generating a coredump using this implementation
void trigger_coredump(void)
    __ASSERT(0, "Forcing coredump");
When i try to read the flash area after generating the coredump with nrfjprog --memrd 0xCF000 --w 32 --n 0x8000
i get all 0xFF
what i am missing ?
I also tried to check myself by replacing CONFIG_DEBUG_COREDUMP_BACKEND_FLASH_PARTITION=y
With CONFIG_DEBUG_COREDUMP_BACKEND_LOGGING=y
Hopping to see the coredump on my open rtt but nothing .. when coredump is triggered prints just stop
  1. What am I missing? Why can't I find a coredump on the flash partition or in the rtt log ?
  2. Can it be that the device does not have the time to write the coredump before the actual crash ? If so, how can I manage that ?
  3. Is there some auto deletion of the flash partition with the coredump so new coredumps can be saved or is it something i have to manage myself after i read the coredump from flash ?
Hope to read you soon
Best regards
Ziv
  • Well, what Vidar suggests is NOT using Coredump with RAM, but rather using some variables declared in the no_init area to save the crash log data in them and then to check them when you start up again.
    thanks, but our application is already using most of available RAM so giving some of it up just for saving crashes is not a valid option
    I get it. We're also REALLY tight on RAM. We didn't hit the limit yet, but I expect we will in the next few months/ soon. But that's also the point! Enabling and using the Coredump feature costs you WAAAAY more ROM and RAM than simply doing his suggestion, which takes up ~70-80 bytes. Sunglasses
    Note: this whole "RAM implementation" is based on the two variables that he mentioned in that 2 year old ticket:
    __noinit static z_arch_esf_t esf;
    __noinit static uint32_t esf_crc;
    I tried checking out "z_arch_esf_t" to see its size so I can get a rough estimate of the amount of RAM used. This led me down a small rabbit hole, which took me to: https://docs.zephyrproject.org/latest/releases/migration-guide-3.7.html
    Where we find this phrase:
    Migration guide to Zephyr v3.7.0
    This document describes the changes required when migrating your application from Zephyr v3.6.0 to Zephyr v3.7.0.
    Kernel
    All architectures are now required to define the new struct arch_esf, which describes the members of a stack frame. This new struct replaces the named struct z_arch_esf_t. (GitHub #73593)
    The named struct z_arch_esf_t is now deprecated. Use struct arch_esf instead. (GitHub #73593)
    The header file include/zephyr/arch/arch_interface.h has been moved from include/zephyr/sys/ into include/zephyr/arch/. Out-of-tree source files will need to update the include path. (GitHub #64987)
    So those previous two lines turn into:
    __noinit static arch_esf esf;
    Keep in mind that we have NCS version 3.0.0, in which Zephyr has version v4.0.99-a0e545cb437a. You mentioned you're using v2.8.0 and I'm not sure which Zephyr version comes with that version of the NCS. So you gotta check if your Zephyr is >= v3.7.0 for the above to apply.
    I doubt Coredump beats this given that the serial CLI logs it generates fill up a file with ~35kb of text.
  • Hey Vidar.
    I finished implementing your proposal and in the end it worked like a charm! The implementation:
    #include <zephyr/arch/cpu.h>
    #include <zephyr/sys/reboot.h>
    #include <zephyr/fatal.h>
    #define LOG_LEVEL CONFIG_LOG_DEFAULT_LEVEL
    #include <zephyr/logging/log_ctrl.h>
    LOG_MODULE_REGISTER(aaa);
    __noinit static struct arch_esf esf_keep;
    __noinit static uint32_t esf_crc = 0;
    extern void sys_arch_reboot(int type);
    void k_sys_fatal_error_handler(unsigned int reason, const struct arch_esf *esf)
        (void)irq_lock();
        // From Nordic DevZone example
    	/* Store stack frame along with a checksum value to the __noinit section in RAM  */
        memcpy(&esf_keep, esf, sizeof(*esf));
        LOG_ERR("AAA! Faulting instruction address (r15/pc): 0x%08x", esf_keep.basic.pc);
        esf_crc = crc32_ieee((uint8_t *)&esf_keep, sizeof(esf_keep));
        // From fatal_error.c
    	LOG_ERR("Resetting system");
    	LOG_PANIC();
    	sys_arch_reboot(0);
    	CODE_UNREACHABLE;
    // generate fault
    static mp_obj_t mp_do_fault(void)
    	*(uint32_t *) 0xFFFFFFFF = 1;
    static MP_DEFINE_CONST_FUN_OBJ_0(mp_do_fault_obj, mp_do_fault);
    // check fault and print stored stack frame
    static mp_obj_t mp_check_val(void)
        // esf_crc =0;
    	printk("Stored CRC val is: ~%ld~ \r\n", esf_crc);
        uint32_t computed_crc = crc32_ieee((uint8_t *)&esf_keep, sizeof(esf_keep));
        printk("Computed CRC val is: ~%ld~ \r\n", computed_crc);
        if (computed_crc == esf_crc) {
            printk("Exception stack frame:\n\r");
            printk("r0/a1:  0x%08x  r1/a2:  0x%08x  r2/a3:  0x%08x\n\r", esf_keep.basic.a1,
                esf_keep.basic.a2, esf_keep.basic.a3);
            printk("r3/a4:  0x%08x r12/ip:  0x%08x r14/lr:  0x%08x\n\r", esf_keep.basic.a4,
                esf_keep.basic.ip, esf_keep.basic.lr);
            printk("xpsr:  0x%08x  pc: 0x%08x\n\r", esf_keep.basic.xpsr, esf_keep.basic.pc);
            esf_crc = 0; // Invalidate CRC
        } else {
            printk("CRC mismatch\n\r");
        return mp_const_none;
    static MP_DEFINE_CONST_FUN_OBJ_0(mp_check_val_obj, mp_check_val);
    And actually running it:
    *** Booting nRF Connect SDK v3.0.0-3bfc46578e42 ***
    *** Using Zephyr OS v4.0.99-a0e545cb437a ***
    MicroPython v1.24.0-preview.485.ge5af5faf8.dirty on 2025-09-28; zephyr-nrf5340dk with nrf5340
    Type "help()" for more information.
    >>> import aaa as a
    >>> a.dofault()
    [00:00:08.744,354] <err> os: ***** USAGE FAULT *****
    [00:00:08.750,000] <err> os:   Unaligned memory access
    [00:00:08.760,162] <err> os: r0/a1:  0x00000000  r1/a2:  0x00000000  r2/a3:  0x00000001
    [00:00:08.768,890] <err> os: r3/a4:  0xfffff000 r12/ip:  0x00041e43 r14/lr:  0x0002452d
    [00:00:08.777,648] <err> os:  xpsr:  0x29100000
    [00:00:08.782,928] <err> os: s[ 0]:  0x20004a28  s[ 1]:  0x00042e3b  s[ 2]:  0x00042e1f  s[ 3]:  0x20022088
    [00:00:08.793,426] <err> os: s[ 4]:  0x0004f580  s[ 5]:  0x00000157  s[ 6]:  0x0004f4f8  s[ 7]:  0x00021477
    [00:00:08.803,924] <err> os: s[ 8]:  0x0004f4f8  s[ 9]:  0x00000157  s[10]:  0x20022088  s[11]:  0x20006987
    [00:00:08.814,422] <err> os: s[12]:  0x20022088  s[13]:  0x2000698b  s[14]:  0x0004e038  s[15]:  0x00041e51
    [00:00:08.824,890] <err> os: fpscr:  0x20022088
    [00:00:08.830,139] <err> os: Faulting instruction address (r15/pc): 0x0002a0d8
    [00:00:08.838,104] <err> os: >>> ZEPHYR FATAL ERROR 31: Unknown error on CPU 0
    [00:00:08.846,069] <err> os: Current thread: 0x20001c10 (mp_main)
    [00:00:08.852,905] <err> aaa: AAA! Faulting instruction address (r15/pc): 0x0002a0d8
    >>> import aaa as a
    >>> a.checkval()
    Stored CRC val is: ~396985589~
    Computed CRC val is: ~396985589~
    xpsr:  0x29100000  pc: 0x0002a0d8
    Note that we're using MicroPython in our project. But the relevant C code excerpts can be easily extracted.
  • Hi Vidar
    I took the approach of the merged solution you found, for using nrf apis to collect the CD instead of zephyr's, - https://github.com/nrfconnect/sdk-nrf/pull/21418/files#diff-fcf14c4b7b34fe7a11916195871ae66a59be87a395f28db73e345ebdc828085b and integrated it in my ncs ..
    it seems to be working fine with assertion and i get the crash log as expected
    but .. when i read the flash area where the CD was saved i do not see what i expect - the initials 0x5a,0x45 are missing and the whole thing looks like it is missing some data .. in every 4 bytes it seems to be writing only one with a value and the rest are zeros (the core dump i see when using memfault does not look like this)
    any idea what is the reason for that ?
    plus, i would really appreciate if you can give some clarity on what i asked in prev message regarding the weak api that is not overwritten and about the order in which things are happening at crash and what about all the asserts in zephyr code if assert is disabled Pray
     i you were successful, i think if you have farther questions on the solution you adopt it might be better to open a new thread since we took different approaches for CD collection  Pray
    hope to read you soon
    best regards
    Ziv
  • Thanks for the update  . I’m glad to see you got it working. Just want to add that the noinit section may become overwritten on startup if you include a bootloader. A solution is to place the data at the end of RAM and reduce the RAM size in the sram0 devicetree node to ensure the area remains unallocated.
    &sram0 {
       reg = <0x20000000 DT_SIZE_K(<total ram size in kB) - <size of area you want to set aside for crash data>>;
    Hard to say what's causing this. I suggest you try this in a minimal sample in the latest SDK to see if you are able to reproduce the same.
    You need to use LOG_PANIC() to be able to flush the log buffer from the fault handler.
  • Sorry Ziv, it seems Vidar brought up a valid point.
    Going with your example Vidar, I would foresee something like:
    &sram0 {
       reg = <0x20000000 DT_SIZE_K(458752) - 150;
    This brings an interesting question: why don't I have the full 512Kb RAM?
    I set the RAM config with 448Kb total since whatever configs I use, I get:
    [650/650] Linking C executable zephyr/zephyr.elf
               FLASH:      402024 B         3 MB     12.78%
                 RAM:      190868 B       448 KB     41.61%
            IDT_LIST:          0 GB        32 KB      0.00%
    I don't have TFM or MCUBoot enabled. Since currently we're using nrf5340dk and nrf7002dk Where are 64Kb disappearing to?
  • Related
