nRF52833 + external 32 kHz TCXO: soft reset hangs
I’m working with a custom board based on the nRF52833. It uses an external 32 kHz TCXO (SiT1552) as the LFCLK source.
  • In my main Zephyr app I set: CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_FULL_SWING=y  and in mcuboot i set CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=y. This boots fine if I power cycle the board, but then when the app does a software reboot (sys_reboot(...) or NVIC_SystemReset()), the system hangs indefinitely. Power-cycling causes it to again boot into the primary image normally.
  • If I switch mcuboot to also use EXT_FULL_SWING, then after reset I see the UART log:
    mcuboot: Jumping to the first image slot
    but then nothing. I investigated with a debugger and it the app never seems to reach main() or even any SYS_INIT routines. Whenever I break, it's just in the zephyr kernel's idle thread.
So, to summarize:
  • App works with TCXO only if mcuboot uses RC, but any software reboots causes hang.
  • If both use TCXO, app never boots.
  • If both use RC, then every thing works normally (but i of course want to use the external tcxo).
Versions:
zephyr: nrfconnect sdk-zephyr v3.5.99
nrf: nrfconnect sdk-nrf v2.6.1
Any help on this is greatly appreciated.
Thanks
EDIT: I forgot to mention that I have indeed verified that the program is getting past the `lfclk_spinwait` function, so it does seem to be detecting that the clock has started. I placed a breakpoint at `clock_control_nrf.c:540` after the `!nrf_clock_is_running` loop, and it does indeed reach that point.
  • Never mind.. it actually appears like it wasn't using the TCXO at all when it was booting successfully. It must have fallen back to the internal RC since the drift I measured was way way too high to be the TCXO, even though it was configured with EXT_FULL_SWING.
    EDIT: confirmed, i printed the LFCLKSRC register. if mcuboot is configured with CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_FULL_SWING=y, this register is 0, meaning it's using the internal RC.
    If mcuboot is using the internal RC, then this register is 0x00030001 meaning it's using external TCXO.
  • So i managed to make some progress.
    From what I can tell the LFCLK is not turned off when it resets or when mcuboot passes execution off to the primary image (can you confirm?), and if it's already running from an external source, it does not get configured correctly. So it's able to go from RC->TCXO, but not TCXO->RC or TCXO->TCXO. This would explain the behaviour in the OP.
    When it's in this state where it's not configured correctly, i can attach with a debugger and read out the LFCLKSTAT and LFCLKSRC registers:
    (gdb) x/wx 0x40000518
    0x40000518:     0x00000000
    (gdb) x/wx 0x4000041c
    0x4000041c:     0x00000000
    (gdb) x/wx 0x40000418
    0x40000418:     0x00010001
    so LFCLKSRC and LFCLKSRCCOPY is configured to use the internal RC while LFCLKSTAT is configured to use the xtal.
    I can set LFCLKSRC manually, but this then switches LFCLKSTAT to use the RC oscillator:
    (gdb) set {int}0x40000518 = 0x00030001
    0x40000518:     0x00030001
    0x40000518:     0x00010000
    BUT now if I let execution continue, my app boots normally,  but with the RC clock.
    Please advise on what I should do. Is this a bug in clock_control_nrf.c?
    I can likely stop the LFCLK in my application and configure it from scratch but this doesn't solve the case where it reboots and enters MCUBOOT while running off the TCXO.
  • I have asked around internally but I haven’t found anyone who has used a TCXO and experienced this problem. Could you please try enabling  CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY in both bootloader and app to see if that might help? From the clock_control_nrf.c implementation it seems like this should ensure that the LF clock start task is triggered. I will continue checking internally in the meantime.
  • I have tried enabling that config and it had no effect unfortunately.
    The only way I have gotten it to work reliably is by adding this:
    int start_lfclk() {
    	nrfx_clock_lfclk_stop();
    	NRF_CLOCK->LFCLKSRC = (CLOCK_LFCLKSRC_SRC_Xtal << CLOCK_LFCLKSRC_SRC_Pos) | (CLOCK_LFCLKSRC_BYPASS_Enabled << CLOCK_LFCLKSRC_BYPASS_Pos) | (CLOCK_LFCLKSRC_EXTERNAL_Enabled << CLOCK_LFCLKSRC_EXTERNAL_Pos);
    	nrfx_clock_lfclk_start();
    	return 0;
    SYS_INIT(start_lfclk, POST_KERNEL, 0);
    to one of our custom drivers that is included in both the main image and mcuboot. This is good enough to allow us to continue development but it would be good to find a better solution.
  • Thank you for the update. I’m happy to hear that you’ve found a temporary workaround. I think this issue should be investigated further on our end, so I’ll report it as a bug internally. I’ll update the thread as soon as I know more.
