VS Code+nrf-connect & west flash mostly rebuilds, and “Erase & Flash” rebuilds again – wasting a ton of time on unchanged builds
Environment
  • Board: Thingy91x / nrf9151/ns
  • nRF Connect SDK: v3.1.0
  • Zephyr SDK/Toolchain: 0.17.0
  • west: 1.4.0
  • Host: Windows 11
  • VS Code nRF Connect Extension: 2025.9.732 (win32-x64)
Problem
When I select an application config that was successfully built yesterday (no changes), and then click Action/Flash in VS Code, the extension runs a full rebuild (west flash: rebuilding) before even attempting to flash.
If the flash fails (e.g. because a full erase is required – perfectly understandable), and I immediately retry with Action/Erase & Flash, the toolchain performs yet another full rebuild from scratch — just two minutes after the last one finished, without any source/config change.
That means two complete sysbuilds (MCUboot, b0, TFM, app, signing, merging) back-to-back for exactly the same artifacts. This feels like a massive waste of time, happens a dozen times each day and slows down development cycles dramatically.
Time wasted
Measured via the elapsed: logs:
  • First attempt (Flash): 01:21
  • Second attempt (Erase & Flash, right after): 01:48
Total wasted: 03:09 for something that should need no build at all and only take 10 seconds. Only in rare cases cmake/ninja show "nothing to do" lines instead of full rebuilds.
What can be done to prevent all this from happening?
Log:
* Executing task: nRF Connect: Flash: lwm2m-client/51X-DL-RTT-310 (active)
Flashing 51X-DL-RTT-310 to nRF9151-DK
west flash -d c:\DL\lwm2m-client\bld\51X-DL-RTT-310 --dev-id 1051211295
[10.09.2025 09:08:33.77] START CWD="c:\DL\lwm2m-client" CMD="west flash -d c:\DL\lwm2m-client\bld\51X-DL-RTT-310 --dev-id 1051211295"
-- west flash: rebuilding
[0/31] Performing build step for 'mcuboot'
ninja: no work to do.
[1/31] Performing build step for 'lwm2m-client'
[0/1] Re-running CMake...
Loading Zephyr default modules (Zephyr base (cached)).
-- Application: C:/DL/lwm2m-client
-- CMake version: 3.21.0
-- Cache files will be written to: C:/ncs/v3.1.0/zephyr/.cache
-- Zephyr version: 4.1.99 (C:/ncs/v3.1.0/zephyr)
-- Found west (found suitable version "1.4.0", minimum required is "0.14.0")
-- Board: thingy91x, qualifiers: nrf9151/ns
-- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/b8b84efebd/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/b8b84efebd/opt/zephyr-sdk)
-- Found BOARD.dts: C:/ncs/v3.1.0/nrf/boards/nordic/thingy91x/thingy91x_nrf9151_ns.dts
-- Found devicetree overlay: C:/DL/lwm2m-client/boards/thingy91x_nrf9151_ns.overlay
-- Generated zephyr.dts: C:/DL/lwm2m-client/bld/51X-DL-RTT-310/lwm2m-client/zephyr/zephyr.dts
-- Generated pickled edt: C:/DL/lwm2m-client/bld/51X-DL-RTT-310/lwm2m-client/zephyr/edt.pickle
-- Generated devicetree_generated.h: C:/DL/lwm2m-client/bld/51X-DL-RTT-310/lwm2m-client/zephyr/include/generated/zephyr/devicetree_generated.h
warning: Deprecated symbol MBEDTLS_LEGACY_CRYPTO_C is enabled.
warning: Experimental symbol GNSS is enabled.
Parsing C:/DL/lwm2m-client/Kconfig
Loaded configuration 'C:/DL/lwm2m-client/bld/51X-DL-RTT-310/lwm2m-client/zephyr/.config'
Merged configuration 'C:/DL/lwm2m-client/bld/51X-DL-RTT-310/lwm2m-client/zephyr/.config.sysbuild'
No change to configuration in 'C:/DL/lwm2m-client/bld/51X-DL-RTT-310/lwm2m-client/zephyr/.config'
No change to Kconfig header in 'C:/DL/lwm2m-client/bld/51X-DL-RTT-310/lwm2m-client/zephyr/include/generated/zephyr/autoconf.h'
=========== Generating psa_crypto_config ===============
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
Backup: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
Backup: CONFIG_MBEDTLS_THREADING_C: True
Backup: CONFIG_MBEDTLS_THREADING_ALT: False
=========== Checkpoint: backup ===============
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
Restore: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
Restore: CONFIG_MBEDTLS_THREADING_C: True
Restore: CONFIG_MBEDTLS_THREADING_ALT: False
=========== End psa_crypto_config ===============
=========== Generating psa_crypto_library_config ===============
Backup: CONFIG_MBEDTLS_USE_PSA_CRYPTO: False
Backup: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
Restore: CONFIG_MBEDTLS_USE_PSA_CRYPTO: False
Restore: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
=========== End psa_crypto_library_config ===============
-- Found gen_kobject_list: C:/ncs/v3.1.0/zephyr/scripts/build/gen_kobject_list.py
-- Including signing script: C:/ncs/v3.1.0/nrf/cmake/sysbuild/image_signing.cmake
CMake Warning at C:/ncs/v3.1.0/zephyr/CMakeLists.txt:2232 (message):
-- Configuring done
-- Generating done
-- Build files have been written to: C:/DL/lwm2m-client/bld/51X-DL-RTT-310/lwm2m-client
[0/544] Performing build step for 'tfm'
[51/55] Linking C executable bin\tfm_s.axf
Memory region Used Size Region Size %age Used
FLASH: 31580 B 32256 B 97.90%
RAM: 11108 B 40 KB 27.12%
[55/55] Generating ../bin/tfm_s.hex
[538/538] Linking C executable zephyr\zephyr.elf
FLASH: 386004 B 800 KB 47.12%
RAM: 202656 B 203416 B 99.63%
IDT_LIST: 0 GB 32 KB 0.00%
Generating files from C:/DL/lwm2m-client/bld/51X-DL-RTT-310/lwm2m-client/zephyr/zephyr.elf for board: thingy91x
image.py: sign the payload
[5/25] Performing build step for 'b0'
[9/25] Performing build step for 's1_image'
[18/18] Generating ../merged.hex
-- west flash: using runner nrfutil
-- runners.nrfutil: reset after flashing requested
-- runners.nrfutil: Flashing file: C:\DL\lwm2m-client\bld\51X-DL-RTT-310\merged.hex
-- runners.nrfutil: Erasing address ranges touched by firmware
Error: One or more batch tasks failed:
* 1051211295: The firmware to program contains UICR data, but your device already has data there. These memory regions are not erasable with the erase option you selected. You need to run an ERASE_AL
L to erase the UICR (Generic)
FATAL ERROR: command exited with status 1: nrfutil --json device x-execute-batch --batch-path 'C:\DL\lwm2m-client\bld\51X-DL-RTT-310\generated_nrfutil_batch.json' --serial-number 1051211295
[10.09.2025 09:09:54.08] elapsed: 01:21
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
west flash -d c:\DL\lwm2m-client\bld\51X-DL-RTT-310 --dev-id 1051211295 --erase
[10.09.2025 09:10:02.86] START CWD="c:\DL\lwm2m-client" CMD="west flash -d c:\DL\lwm2m-client\bld\51X-DL-RTT-310 --dev-id 1051211295 --erase"
Loading Zephyr module(s) (Zephyr base (cached)): sysbuild_default
Parsing C:/ncs/v3.1.0/zephyr/share/sysbuild/Kconfig
Loaded configuration 'C:/DL/lwm2m-client/bld/51X-DL-RTT-310/zephyr/.config'
No change to configuration in 'C:/DL/lwm2m-client/bld/51X-DL-RTT-310/zephyr/.config'
No change to Kconfig header in 'C:/DL/lwm2m-client/bld/51X-DL-RTT-310/_sysbuild/autoconf.h'
* Running CMake for mcuboot *
-- Application: C:/ncs/v3.1.0/bootloader/mcuboot/boot/zephyr
-- Found BOARD.dts: C:/ncs/v3.1.0/nrf/boards/nordic/thingy91x/thingy91x_nrf9151.dts
-- Found devicetree overlay: C:/ncs/v3.1.0/bootloader/mcuboot/boot/zephyr/boards/thingy91x_nrf9151.overlay
-- Generated zephyr.dts: C:/DL/lwm2m-client/bld/51X-DL-RTT-310/mcuboot/zephyr/zephyr.dts
-- Generated pickled edt: C:/DL/lwm2m-client/bld/51X-DL-RTT-310/mcuboot/zephyr/edt.pickle
-- Generated devicetree_generated.h: C:/DL/lwm2m-client/bld/51X-DL-RTT-310/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
C:/DL/lwm2m-client/bld/51X-DL-RTT-310/mcuboot/zephyr/.config.sysbuild:11: warning: BOOT_SWAP_USING_MOVE (defined at C:/ncs/v3.1.0/bootloader/mcuboot/boot/zephyr/Kconfig:575) set more than once. Old va
lue "y", new value "n".
C:/DL/lwm2m-client/bld/51X-DL-RTT-310/mcuboot/zephyr/.config.sysbuild:35: warning: BOOT_SWAP_USING_MOVE (defined at C:/ncs/v3.1.0/bootloader/mcuboot/boot/zephyr/Kconfig:575) set more than once. Old va
lue "n", new value "y".
Parsing C:/ncs/v3.1.0/bootloader/mcuboot/boot/zephyr/Kconfig
Loaded configuration 'C:/DL/lwm2m-client/bld/51X-DL-RTT-310/mcuboot/zephyr/.config'
Merged configuration 'C:/DL/lwm2m-client/bld/51X-DL-RTT-310/mcuboot/zephyr/.config.sysbuild'
No change to configuration in 'C:/DL/lwm2m-client/bld/51X-DL-RTT-310/mcuboot/zephyr/.config'
No change to Kconfig header in 'C:/DL/lwm2m-client/bld/51X-DL-RTT-310/mcuboot/zephyr/include/generated/zephyr/autoconf.h'
MCUBoot bootloader key file: C:/ncs/v3.1.0/bootloader/mcuboot/root-ec-p256.pem
CMake Warning at CMakeLists.txt:412 (message):
WARNING: Using default MCUboot signing key file, this file is for debug use
only and is not secure!
-- Configuring done
-- Generating done
-- Build files have been written to: C:/DL/lwm2m-client/bld/51X-DL-RTT-310/mcuboot
* Running CMake for b0 *
-- Application: C:/ncs/v3.1.0/nrf/samples/bootloader
-- Generated zephyr.dts: C:/DL/lwm2m-client/bld/51X-DL-RTT-310/b0/zephyr/zephyr.dts
-- Generated pickled edt: C:/DL/lwm2m-client/bld/51X-DL-RTT-310/b0/zephyr/edt.pickle
-- Generated devicetree_generated.h: C:/DL/lwm2m-client/bld/51X-DL-RTT-310/b0/zephyr/include/generated/zephyr/devicetree_generated.h
Parsing C:/ncs/v3.1.0/zephyr/Kconfig
Loaded configuration 'C:/DL/lwm2m-client/bld/51X-DL-RTT-310/b0/zephyr/.config'
Merged configuration 'C:/DL/lwm2m-client/bld/51X-DL-RTT-310/b0/zephyr/.config.sysbuild'
No change to configuration in 'C:/DL/lwm2m-client/bld/51X-DL-RTT-310/b0/zephyr/.config'
No change to Kconfig header in 'C:/DL/lwm2m-client/bld/51X-DL-RTT-310/b0/zephyr/include/generated/zephyr/autoconf.h'
-- Configuring done
-- Generating done
-- Build files have been written to: C:/DL/lwm2m-client/bld/51X-DL-RTT-310/b0
* Running CMake for lwm2m-client *
-- Configuring done
-- Generating done
* Running CMake for s1_image *
-- Generated zephyr.dts: C:/DL/lwm2m-client/bld/51X-DL-RTT-310/s1_image/zephyr/zephyr.dts
-- Generated pickled edt: C:/DL/lwm2m-client/bld/51X-DL-RTT-310/s1_image/zephyr/edt.pickle
-- Generated devicetree_generated.h: C:/DL/lwm2m-client/bld/51X-DL-RTT-310/s1_image/zephyr/include/generated/zephyr/devicetree_generated.h
-- Configuring done
-- Generating done
-- Build files have been written to: C:/DL/lwm2m-client/bld/51X-DL-RTT-310/s1_image
-- Found partition manager static configuration : C:/ncs/v3.1.0/nrf/boards/nordic/thingy91x/thingy91x_nrf9151_pm_static.yml
Partition 'b0' is not included in the dynamic resolving since it is statically defined.
Partition 'b0_container' is not included in the dynamic resolving since it is statically defined.
Partition 's0' is not included in the dynamic resolving since it is statically defined.
Partition 's0_pad' is not included in the dynamic resolving since it is statically defined.
Partition 's0_image' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot' is not included in the dynamic resolving since it is statically defined.
Partition 's1' is not included in the dynamic resolving since it is statically defined.
Partition 's1_pad' is not included in the dynamic resolving since it is statically defined.
Partition 's1_image' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_primary' is not included in the dynamic resolving since it is statically defined.
Partition 'tfm_secure' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_pad' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_primary_app' is not included in the dynamic resolving since it is statically defined.
Partition 'app_image' is not included in the dynamic resolving since it is statically defined.
Partition 'tfm' is not included in the dynamic resolving since it is statically defined.
Partition 'tfm_nonsecure' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_secondary' is not included in the dynamic resolving since it is statically defined.
Partition 'fmfu_storage' is not included in the dynamic resolving since it is statically defined.
Partition 'settings_storage' is not included in the dynamic resolving since it is statically defined.
Dropping partition 'nrf_modem_lib_trace' since its size is 0.
Dropping partition 'nonsecure_storage' since it is empty.
-- Configuring done
-- Generating done
[34/34] Linking C executable zephyr\zephyr.elf
FLASH: 42596 B 81408 B 52.32%
RAM: 34808 B 40 KB 84.98%
Generating files from C:/DL/lwm2m-client/bld/51X-DL-RTT-310/mcuboot/zephyr/zephyr.elf for board: thingy91x
[0/458] Performing build step for 'tfm'
[74/78] Linking C executable bin\tfm_s.axf
[78/78] Linking C static library secure_fw\libtfm_s_veneers.a
[47/47] Linking C executable zephyr\zephyr.elf
[5/31] Creating signature of application
[9/31] Performing build step for 's1_image'
[201/201] Linking C executable zephyr\zephyr.elf
RAM: 34808 B 203416 B 17.11%
Generating files from C:/DL/lwm2m-client/bld/51X-DL-RTT-310/s1_image/zephyr/zephyr.elf for board: thingy91x
[11/31] Creating validation for zephyr.hex, storing to signed_by_b0_mcuboot.hex
[15/31] Creating signature of application
[16/31] Generating ../signed_by_mcuboot_and_b0_mcuboot.bin
[17/31] Performing build step for 'b0'
[26/26] Linking C executable zephyr\zephyr.elf
FLASH: 27448 B 32 KB 83.76%
RAM: 37288 B 203416 B 18.33%
Generating files from C:/DL/lwm2m-client/bld/51X-DL-RTT-310/b0/zephyr/zephyr.elf for board: thingy91x
[18/31] Generating ../signed_by_mcuboot_and_b0_mcuboot.hex
[21/31] Creating validation for zephyr.hex, storing to signed_by_b0_s1_image.hex
[27/31] Generating ../signed_by_mcuboot_and_b0_s1_image.bin
[28/31] Generating ../signed_by_mcuboot_and_b0_s1_image.hex
[31/31] Generating ../merged.hex
-- runners.nrfutil: mass erase requested
-- runners.nrfutil: Erasing non-volatile memory (ERASEALL)
-- runners.nrfutil: Programming image
-- runners.nrfutil: Verifying image
-- runners.nrfutil: Reset
-- runners.nrfutil: Board(s) with serial number(s) 1051211295 flashed successfully.
[10.09.2025 09:11:50.83] elapsed: 01:48
  • Hi, I’m running into a very similar issue — with a medium-large NCS project on Windows, my incremental build times are already over 2 minutes. It would really help if you could share your dev setup in detail.
  • Thank you for this update. It looks like there is some interest in your solution. Other things that may be worth checking are the antivirus configuration and setting up a dev drive (https://learn.microsoft.com/en-us/windows/dev-drive/ ).
    We also need to investigate on our end why cmake is being re-run in some cases when calling west flash after having just built the project.
  • Thanks for pointing me to Dev Drive — that’s completely new to me! I’ll definitely give it a try.
    That said, WSL2 still seems to be way faster, especially with Unix-like build chains that push lots of small files through tons of forked processes.
    This benchmark even found WSL2 to be about 2× faster than Windows 11 on Dev Drive:
    superuser.com/.../1825686
    My go-to AI says:
    Comparison: File Systems / Build Environments
    Workload / Environment Windows NTFS (Standard) Windows Dev Drive (ReFS + Performance Mode) Linux / WSL2 (ext4)
    git clone large repo (100k+ files) Slow (many small file creates, AV hooking, NTFS overhead) ~20–40% faster due to reduced AV/Indexing + more efficient ReFS Often 2–5× faster than Windows NTFS; cheap I/O and fork
    npm install / pip install (10k+ small files) Notoriously slow on Windows (NTFS fragmentation, AV, expensive process creation) ~30% faster, but still slower than Linux 2–10× faster, ext4 + copy-on-write fork
    CMake/Ninja rebuild (C++ project, 1M LOC) Works, but many process spawns + I/O → often 5–20× slower than Linux 10–30% faster, I/O bottlenecks reduced, but process creation remains expensive Baseline: fast, fork/exec + pipes are cheap
    Large Embedded/SDK project (Zephyr, Yocto, west) Very slow: tens of thousands of shell tools, process creation extremely costly Slightly better (faster I/O, less AV overhead), but process creation still the bottleneck 2–20× faster (matches observed real-world results)
    Antivirus/Indexing impact Often massive, every file access scanned Dev Drive can run AV in “Performance Mode” → minimal overhead None (unless you explicitly install AV)
    Stability / Tool support NTFS = universally supported ReFS: newer, some older tools/backups may not support it ext4 = standard, rock-solid
    TL;DR
    • Dev Drive is a real improvement on Windows: typically 10–40% faster for I/O-heavy developer workloads.
    • But it does not solve the architectural issue (expensive process creation, no cheap fork).
    • For POSIX-heavy builds (Zephyr, Yocto, SDKs), Linux/WSL2 remains unbeatable, often 2–20× faster.
  • Apologies for the slow reply —
    After working for a few months with my command-line orchestrator, I renamed it from build_and_flash to west-wind — because it feels like a strong headwind for west: it adds intelligence, guardrails, and a lot of comfort to my daily nRF Connect SDK work on a Windows / WSL2 hybrid setup.
    Then west-wind was my daily tool, but I was still running into some strange nRF Connect VS Code extension issues: hot CPU, (re)builds using the wrong configs, flaky debugging — the whole “why is my machine suddenly suffering?” experience. At some point I asked myself: could I build an almost full replacement for the nRF Connect extension for most of my daily work, so I can keep the official one disabled most of the time? Mainly to prevent it from turning my poor CPU fan into a glowing-red 200,000 RPM Dyson.
    After a bit of prototyping, it looked very promising — and that’s how nRF Connect Lite was born. Then, after a few days of using this setup exclusively, I had a small “aha” moment: my day-to-day work more and more felt zen-like compared to the months of friction before. The machine just did what I wanted and I enjoyed the silence. A bit of back-and-forth later, the wordplay zenRF emerged: a tooling for nRF that brings calm, flow-like development back into the loop — and here we are.
    If you’re curious, I can share some details.
  • It is good to hear you have found a way to improve your workflow! I have created a bug report internally that links to this thread about the slow build times and the issue with cmake being re-run even when nothing has changed in the project.
