Combining GNSS and CoAP client in nRF Connect SDK — GNSS fix not read, CoAP request not sent
Hi Nordic team,
I’m working on an nRF9151 DK with nRF Connect SDK v3.0.0.
My goal is to send GNSS latitude/longitude data to a CoAP server.
  • The GNSS sample works fine → I get correct coordinates.
  • The CoAP client sample works fine → I can send POST requests and get responses from my server.
  • But when I combine both in one project, I get no GNSS fix and no CoAP messages are sent.
I only see:
<inf> coap_client_sample: Starting GNSS + CoAP client
<inf> coap_client_sample: Bringing network interface up
<inf> coap_client_sample: Waiting for network connectivity
  • Is there a specific order required for modem/LTE/GNSS init when used with CoAP?
  • Any debugging tips to see why GNSS events never trigger and CoAP never sends?
Additional info
  • Board: nRF9151 DK
  • SDK: nRF Connect SDK v3.0.0
  • Both examples work independently
  • Using IPv6 CoAP server
Any guidance or example on how to properly combine GNSS fix + CoAP POST would be greatly appreciated.
Regards
Arun
  • Hi Dejan,
    Yes, I have reset the DK board and waited, but the behavior is the same. I can get a fix reliably only when the device is stationary outdoors.
    For outdoor testing, I was in an open area with minimal obstructions (no tall buildings or dense trees). When moving, I carried the board in my hand while walking at normal pace. I have tested only while walking so far.
    It seems that GNSS fix is lost or not acquired reliably when the device is in motion. Could this be due to the GNSS configuration? Is there a recommended mode or setting for continuous tracking while moving?
    Arun
  • Hi Arun,
    Operation modes for GNSS sample mention this
    "By default, the sample runs in continuous tracking mode. In continuous mode, GNSS tries to acquire a fix once a second."
    Have you considered using A-GNSS / P-GPS? You can find configuration for A-GNSS and P-GPS in the documentation.
    Are you not getting fix at all or sometimes? Can you elaborate?
    Dejan
  • Hi Dejan,
    Thank you for the clarification.
    I have not yet enabled A-GNSS or P-GPS. I am currently testing with standard GNSS mode. I will try enabling A-GNSS and P-GPS as you suggested.
    Regarding the fix issue — when the device is stationary outdoors, I get a fix successfully and it updates continuously.
    However, when I start walking or moving, the fix is sometimes lost, and occasionally it does not recover until the device stops moving again.
    It looks like GNSS is struggling to maintain continuous tracking while the board is in motion.
    Also, if you have any example code or reference project for A-GNSS or P-GPS integration, it would be very helpful.
    Arun
  • Hi Arun,
    With regard to use of A-GNSS or P-GPS you can look at the following samples:
    nRF Cloud Multi Service
    Modem Shell
    Location
    GNSS
    Dejan
  • Hi Dejan,
    I have already tested the standard GNSS example, but I’m unable to get a valid fix while walking. The fix works reliably only when the device is stationary outdoors. It seems that the GNSS is struggling to maintain continuous tracking while in motion.
    Could you please clarify if the nRF91 GNSS is expected to work reliably while walking or during motion? If so, is there a recommended configuration or mode to enable continuous tracking while moving?
    Arun
