Wi-Fi STA sample not connecting in NCS v3.1.0 (works in v2.9.2)
I am trying to run the Wi-Fi STA sample on nRF7002DK.
  • With nRF Connect SDK v2.9.2, the STA sample connects successfully to my Wi-Fi AP (router).
  • With NCS v3.1.0, the exact same STA sample does not connect.
Logs in v2.9.2 show that the STA attempts to connect, connection success.
Logs in v3.1.0 show that the STA attempts to connect with same nrf7002dk, but fails
Questions:
  1. Is there any restriction, change, or configuration update required for Wi-Fi STA in v3.1.0 compared to v2.9.2?
  2. Has anything changed in the Wi-Fi driver, supplicant, or configuration (Kconfig/prj.conf) that would prevent connection in v3.1.0?
  3. Could you please guide me on how to fix this issue and get STA working in v3.1.0?
Setup:
  • Board: nRF7002DK
  • SDK versions tested:
    • v2.9.2 → STA connects fine
    •  v3.1.0 → STA fails to connect
  • Both setups use the same configuration and the same Wi-Fi router (I only have one router). The difference is only in the SDK version: the wifi/sta sample from SDK v2.9.2 connects successfully, but the wifi/sta sample from SDK v3.1.0 does not connect. The only difference is the SDK sample, not the Wi-Fi router. I have downloaded the sdk form vs code and the dk also same nrf7002dk.
    1. Has anything changed in the Wi-Fi driver or configuration between SDK v2.9.2 and v3.1.0 that could cause this issue?
    2. Are there additional settings or configurations required in v3.1.0 for the wifi/sta sample to connect?
    3. Could this be a known issue in SDK v3.1.0?
    1. There is always a possibility for that but I do not have a yes/no answer for that.
    2. No.
    3. There is no other reports of this problem.
    Do you experience the problem when building with and without TF-M (/ns)?
    Do you spot any differences in the build logs in the two NCS versions? Please share if possible.
    Do you experience the issue on NCS version between? Again, doing a git bisect would be helpful.
    • If I build with NS, QSPI encryption is not used. Without NS, encryption is enabled.
    • I also tried changing from NCS v3.1.0 to v3.1.1, but the problem remains. Anyway, I’ve shared the logs for both NCS versions.
     *  Executing task: nRF Connect: Build [pristine]: sta/build (active)
    Building sta
    west build --build-dir c:/Nrf_ws_sdk_v2.9.2/sta/build c:/Nrf_ws_sdk_v2.9.2/sta --pristine --board nrf7002dk/nrf5340/cpuapp/ns --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION="NONE"
    -- Application: C:/Nrf_ws_sdk_v2.9.2/sta
    -- CMake version: 3.21.0
    -- Found Python3: C:/ncs/toolchains/b620d30767/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter
    -- Cache files will be written to: C:/ncs/v2.9.2/zephyr/.cache
    -- Zephyr version: 3.7.99 (C:/ncs/v2.9.2/zephyr)
    -- Board: nrf7002dk, qualifiers: nrf5340/cpuapp/ns
    -- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/b620d30767/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/b620d30767/opt/zephyr-sdk)
    -- Found Dtc: C:/ncs/toolchains/b620d30767/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/ncs/v2.9.2/zephyr/boards/nordic/nrf7002dk/nrf7002dk_nrf5340_cpuapp_ns.dts
    -- Generated zephyr.dts: C:/Nrf_ws_sdk_v2.9.2/sta/build/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/Nrf_ws_sdk_v2.9.2/sta/build/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/Nrf_ws_sdk_v2.9.2/sta/build/zephyr/dts.cmake
    warning: Deprecated symbol MBEDTLS_LEGACY_CRYPTO_C is enabled.
    warning: Deprecated symbol POSIX_CLOCK is enabled.
    warning: Experimental symbol WIFI_CREDENTIALS is enabled.
    warning: Experimental symbol WIFI_READY_LIB is enabled.
    warning: Experimental symbol WIFI_NM_WPA_SUPPLICANT is enabled.
    warning: Experimental symbol NRF_WIFI_RPU_RECOVERY is enabled.
    warning: Experimental symbol POSIX_ASYNCHRONOUS_IO is enabled.
    warning: Experimental symbol POSIX_DEVICE_IO is enabled.
    warning: Experimental symbol POSIX_FD_MGMT is enabled.
    warning: Experimental symbol POSIX_MULTI_PROCESS is enabled.
    warning: Experimental symbol POSIX_REALTIME_SIGNALS is enabled.
    warning: Experimental symbol POSIX_SIGNALS is enabled.
    warning: Experimental symbol NET_BUF_VARIABLE_DATA_SIZE is enabled.
    Parsing C:/Nrf_ws_sdk_v2.9.2/sta/Kconfig
    Loaded configuration 'C:/ncs/v2.9.2/zephyr/boards/nordic/nrf7002dk/nrf7002dk_nrf5340_cpuapp_ns_defconfig'
    Merged configuration 'C:/Nrf_ws_sdk_v2.9.2/sta/prj.conf'
    Configuration saved to 'C:/Nrf_ws_sdk_v2.9.2/sta/build/zephyr/.config'
    Kconfig header saved to 'C:/Nrf_ws_sdk_v2.9.2/sta/build/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
    -- Found assembler: C:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    =========== Generating psa_crypto_config ===============
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Backup: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Backup: CONFIG_MBEDTLS_THREADING: False
    Backup: CONFIG_MBEDTLS_THREADING_ALT: False
    =========== Checkpoint: backup ===============
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Restore: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Restore: CONFIG_MBEDTLS_THREADING: False
    Restore: CONFIG_MBEDTLS_THREADING_ALT: False
    =========== End psa_crypto_config ===============
    =========== Generating psa_crypto_library_config ===============
    Backup: CONFIG_MBEDTLS_USE_PSA_CRYPTO: False
    Backup: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    Restore: CONFIG_MBEDTLS_USE_PSA_CRYPTO: False
    Restore: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    =========== End psa_crypto_library_config ===============
    -- Setting build type to 'MinSizeRel' as none was specified.
    CMake Deprecation Warning at C:/ncs/v2.9.2/nrf/cmake/partition_manager.cmake:32 (message):
                --- WARNING: Child and parent image functionality is deprecated   ---
                --- and should be replaced with sysbuild. Child and parent image  ---
                --- support remains only to allow existing customer applications  ---
                --- to build and allow porting to sysbuild, it is no longer       ---
                --- receiving updates or new features and it will not be possible ---
                --- to build using child/parent image at all in nRF Connect SDK   ---
                --- version 2.9 onwards.                                          ---
      C:/ncs/v2.9.2/zephyr/cmake/modules/kernel.cmake:255 (include)
      C:/ncs/v2.9.2/zephyr/cmake/modules/zephyr_default.cmake:142 (include)
      C:/ncs/v2.9.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
      C:/ncs/v2.9.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      CMakeLists.txt:9 (find_package)
    Dropping partition 'nonsecure_storage' since it is empty.
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Nrf_ws_sdk_v2.9.2/sta/build
    ←[92m-- west build: building application
    [5/464] Generating include/generated/zephyr/version.h
    -- Zephyr version: 3.7.99 (C:/ncs/v2.9.2/zephyr), build: v3.7.99-ncs2-2
    [6/464] Generating ../../tfm/CMakeCache.txt
    -- Found Git: C:/ncs/toolchains/b620d30767/mingw64/bin/git.exe (found version "2.37.3.windows.1")
    -- Found Python3: C:/ncs/toolchains/b620d30767/opt/bin/python.exe (found version "3.12.4") found components: Interpreter
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm
    [11/464] Performing build step for 'tfm'
    [1/146] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/platform/auto_[3/146] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/crypto/auto_ge[5/146] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/tf[6/146] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/tf[8/146] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/fa[9/146] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/ta[10/146] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/__/platform/ext/commo[15/146] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/__/interface/src/tfm_[17/146] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/spm/core/psa_interfac[19/146] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/__/interface/src/tfm_[20/146] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/C_/ncs/v2.9.2/nrf/modules/trus[21/146] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/__/interface/src/tfm_[22/146] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sp_log.dir/__/__/__/__/platform/ext/com[23/146] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sp_log.dir/__/__/__/__/platform/ext/com[24/146] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_library.[26/146] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/genera[30/146] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_asymmetr[34/146] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key_deri[35/146] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key_mana[37/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/[38/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/[39/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/[40/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/[41/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedc[42/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/[43/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/[44/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/[45/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/[46/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/[47/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/[48/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/[49/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/nrf_security_utils.d[50/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/nrf_security_utils.d[54/146] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/target/nordic_nrf/common/core/startup_nr[56/146] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/crypto/auto_generated/[58/146] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/platform/auto_generate[78/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon...n_psa_core.di[79/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon...n_psa_core.di[79/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/ober[80/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/ober[81/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/ober[82/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/ober[82/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon...les/oberon_ps[83/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/ober[84/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon...es/oberon_psa[85/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...eron_psa_driv[86/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe.../oberon_psa_d[87/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...oberon_psa_dr[88/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...oberon_psa_dr[89/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...eron_psa_driv[90/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...eron_psa_driv[91/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...s/oberon_psa_[92/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe.../oberon_psa_d[93/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...a_driver.dir/[94/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...a_driver.dir/[95/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...a_driver.dir/[95/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...s/oberon_psa_[96/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe.../oberon_psa_d[97/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...s/oberon_psa_[98/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...sa_driver.dir[99/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...er.dir/C_/ncs[100/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_ob...er.dir/C_/ncs[100/146] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_ob...beron_psa_dri[101/146] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/platform_s[102/146] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/g[103/146] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/p[104/146] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/sp[105/146] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.9.2/modules/hal/nordic/nrfx/drivers/src/n[107/146] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/mp[108/146] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/nrf_exception_inf[109/146] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/services/src/tfm_[110/146] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/services/src/tfm_[111/146] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/cmsis_drivers/Dri[112/146] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/cmsis_drivers/Dri[112/146] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.9.2/modules/hal/nordic/nrfx/drivers/src/n[113/146] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.9.2/nrf/modules/trusted-firmware-m/tfm_bo[114/146] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.9.2/modules/hal/nordic/nrfx/mdk/system_nr[115/146] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.9.2/nrf/modules/trusted-firmware-m/tfm_bo[116/146] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.9.2/nrf/modules/trusted-firmware-m/tfm_bo[117/146] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.9.2/nrf/modules/trusted-firmware-m/tfm_bo[118/146] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.9.2/nrf/modules/trusted-firmware-m/tfm_bo[119/146] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.9.2/nrf/modules/trusted-firmware-m/tfm_bo[121/146] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.9.2/nrf/modules/trusted-firmware-m/tfm_bo[122/146] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.9.2/nrf/modules/trusted-firmware-m/tfm_bo[131/146] Linking C static library secure_fw\partitions\crypto\mbedcrypto\nrf_security_src\drivers\nrf_oberon\libo[132/146] Linking C static library secure_fw\partitions\crypto\mbedcrypto\nrf_security_src\core\nrf_oberon\libober[133/146] Linking C static library secure_fw\partitions\crypto\mbedcrypto\nrf_security_src\core\nrf_oberon\libober[135/146] Linking C static library secure_fw\partitions\crypto\mbedcrypto\nrf_security_src\libcrypto_service_mbedc[136/146] Linking C static library secure_fw\partitions\crypto\mbedcrypto\nrf_security_src\libcrypto_service_mbedc[140/146] Building C object platform/target/nrf5340/nrf_common/CMakeFiles/tfm_s_scatter.dir/__/__/__/__/common/gcc[142/146] Linking C executable bin\tfm_s.axf
               FLASH:       32100 B        32 KB     97.96%
                 RAM:       11972 B        32 KB     36.54%
    [146/146] Generating ../bin/tfm_s.bin
    [18/464] Performing install step for 'tfm'
    -- Install configuration: "MinSizeRel"
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/tfm_ioctl_core_api.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/src/tfm_ioctl_core_ns_api.c
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/config_nordic_nrf_spe.cmake
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/driver/Driver_Common.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/driver/Driver_Flash.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/driver/Driver_USART.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/startup.c
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/startup_nrf5340.c
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/nrfx_glue.c
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/pal_plat_test.c
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/pal_plat_test.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/startup.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/target_cfg.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/nrfx_config.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/CMakeLists.txt
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/config.cmake
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/native_drivers
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/native_drivers/mpu_armv8m_drv.c
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/native_drivers/mpu_armv8m_drv.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/native_drivers/spu.c
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/native_drivers/spu.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/cmsis_drivers
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/cmsis_drivers/Driver_Flash.c
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/cmsis_drivers/Driver_USART.c
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/common
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/common/cmsis.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/common/nrf-pinctrl.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/common/nrfx_glue.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/common/nrfx_log.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/common/tfm_hal_platform_common.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/nrfx/nrfx.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/services
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/services/include
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/services/include/tfm_ioctl_core_api.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/services/include/tfm_platform_hal_ioctl.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/services/src
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/services/src/tfm_ioctl_core_ns_api.c
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/services/src/tfm_ioctl_core_s_api.c
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/services/src/tfm_platform_hal_ioctl.c
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/tests
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/core/tests/tfm_tests_config.cmake
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/linker_scripts/tfm_common_ns.ld
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/nrf5340/nrfx_config_nrf5340_application.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/nrf5340/CMakeLists.txt
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/nrf5340/config.cmake
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/nrf5340/cpuarch.cmake
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/nrf5340/tests
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/nrf5340/tests/psa_arch_tests_config.cmake
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/nrf5340/partition
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/nrf5340/partition/flash_layout.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/common/nrf5340/partition/region_defs.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/CMakeLists.txt
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/cpuarch.cmake
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/config.cmake
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/../common/config.cmake
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/tests
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/tests/psa_arch_tests_config.cmake
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/tests/tfm_tests_config.cmake
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/bin
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/bin/tfm_s.axf
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/bin/tfm_s.bin
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/bin/tfm_s.elf
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/bin/tfm_s.hex
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/bin/tfm_s.map
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/lib/s_veneers.o
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/psa/client.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/psa/error.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/psa_manifest/sid.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/config_impl.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/tfm_veneers.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/tfm_ns_interface.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/tfm_ns_client_ext.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/config_tfm.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/config_base.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/tfm_psa_call_pack.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/psa/framework_feature.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/psa/build_info.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/psa/crypto_adjust_auto_enabled.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/psa/crypto_adjust_config_key_pair_types.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/psa/crypto_adjust_config_synonyms.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/psa/crypto_compat.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/psa/crypto_driver_common.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/psa/crypto_driver_contexts_composites.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/psa/crypto_driver_contexts_key_derivation.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/psa/crypto_driver_contexts_primitives.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/psa/crypto_extra.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/psa/crypto_legacy.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/psa/crypto_platform.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/psa/crypto_se_driver.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/psa/crypto_sizes.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/psa/crypto_struct.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/psa/crypto_types.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/psa/crypto_values.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/psa/crypto.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/mbedtls/build_info.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/mbedtls/config_psa.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/nrf-config.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/nrf-psa-crypto-config.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/tfm_platform_api.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/src/tfm_tz_psa_ns_api.c
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/os_wrapper
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/os_wrapper/common.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/include/os_wrapper/mutex.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/src/os_wrapper
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/src/os_wrapper/tfm_ns_interface_bare_metal.c
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/src/os_wrapper/tfm_ns_interface_rtos.c
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/src/tfm_crypto_api.c
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/interface/src/tfm_platform_api.c
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/config/cp_check.cmake
    ----- Installing platform NS -----
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/a-profile
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/a-profile/cmsis_armclang_a.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/a-profile/cmsis_clang_a.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/a-profile/cmsis_cp15.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/a-profile/cmsis_gcc_a.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/a-profile/cmsis_iccarm_a.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/a-profile/irq_ctrl.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/cmsis_compiler.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/cmsis_version.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/core_ca.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/core_cm0.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/core_cm0plus.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/core_cm1.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/core_cm23.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/core_cm3.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/core_cm33.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/core_cm35p.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/core_cm4.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/core_cm52.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/core_cm55.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/core_cm7.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/core_cm85.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/core_sc000.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/core_sc300.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/core_starmc1.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/m-profile
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/m-profile/armv7m_cachel1.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/m-profile/armv7m_mpu.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/m-profile/armv81m_pac.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/m-profile/armv8m_mpu.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/m-profile/armv8m_pmu.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/m-profile/cmsis_armclang_m.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/m-profile/cmsis_clang_m.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/m-profile/cmsis_gcc_m.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/m-profile/cmsis_iccarm_m.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/m-profile/cmsis_tiarmclang_m.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/cmsis/Include/tz_context.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/common/uart_stdout.c
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/ext/common/uart_stdout.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/boot_hal.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/cmsis_override.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/exception_info.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/fatal_error.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/mbedtls_entropy_nv_seed_config.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/region.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/tfm_attest_hal.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/tfm_hal_defs.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/tfm_hal_device_header.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/tfm_hal_interrupt.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/tfm_hal_isolation.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/tfm_hal_its.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/tfm_hal_its_encryption.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/tfm_hal_mailbox.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/tfm_hal_multi_core.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/tfm_hal_platform.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/tfm_hal_ps.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/tfm_platform_system.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/tfm_plat_boot_seed.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/tfm_plat_config.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/tfm_plat_crypto_keys.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/tfm_plat_crypto_nv_seed.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/tfm_plat_defs.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/tfm_plat_device_id.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/tfm_plat_ns.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/tfm_plat_nv_counters.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/tfm_plat_otp.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/tfm_plat_provisioning.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/tfm_plat_rotpk.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/tfm_plat_test.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/CMakeLists.txt
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/cmake/toolchain_ns_GNUARM.cmake
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/cmake/toolchain_ns_ARMCLANG.cmake
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/cmake/toolchain_ns_IARARM.cmake
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/platform/include/fih.h
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/cmake/spe_export.cmake
    -- Installing: C:/Nrf_ws_sdk_v2.9.2/sta/build/tfm/api_ns/cmake/set_extensions.cmake
    [19/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.9.2/module[19/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.9.2/module[20/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.9.2/module[21/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.9.2/module[22/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.9.2/module[24/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.9.2/module[26/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.9.2/module[28/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.9.2/module[30/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.9.2/modules/cry[31/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.9.2/modules/cry[33/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.9.2/modules/cry[36/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.9.2/modules/cry[37/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.9.2/modules/cry[39/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.9.2/modules/cry[42/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.9.2/modules/cry[45/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.9.2/modules/cry[46/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.9.2/modules/cry[48/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.9.2/modules/cry[50/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.9.2/modules/cry[51/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.9.2/modules/cry[54/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.9.2/modules/cry[56/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.9.2/modules/cry[58/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.9.2/modules/cry[60/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.9.2/modules/cry[61/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.9.2/modules/cry[62/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.9.2/modules/cry[64/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.9.2/modules/cry[65/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.9.2/modules/cry[69/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/C_/ncs/v2.9.2/modules/crypt[70/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.9.2/modules/cry[73/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/C_/ncs/v2.9.2/modules/crypt[75/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/C_/ncs/v2.9.2/modules/crypt[78/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/C_/ncs/v2.9.2/modules/crypt[82/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/C_/ncs/v2.9.2/modules/crypto[83/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/C_/ncs/v2.9.2/modules/crypto[86/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/C_/ncs/v2.9.2/modules/crypto[88/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/C_/ncs/v2.9.2/modules/crypto[89/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/C_/ncs/v2.9.2/modules/crypto[92/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/C_/ncs/v2.9.2/modules/crypto[95/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/C_/ncs/v2.9.2/modules/crypto[96/464] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/C_/ncs/v2.9.2/modules/crypto[121/464] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.2/modules/lib/hostap/src/crypto/aes-internal.[122/464] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.2/modules/lib/hostap/src/crypto/aes-unwrap.c.[125/464] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.2/modules/lib/hostap/src/crypto/aes-wrap.c.ob[128/464] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.2/modules/lib/hostap/src/crypto/sha256-prf.c.[129/464] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.2/modules/lib/hostap/src/crypto/sha1-internal[134/464] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.2/modules/lib/hostap/src/crypto/sha512-prf.c.[137/464] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.2/modules/lib/hostap/src/crypto/tls_none.c.ob[139/464] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.2/nrf/subsys/partition_manager/flash_map_part[141/464] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.2/modules/lib/hostap/src/common/hw_features_c[144/464] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.2/modules/lib/hostap/src/drivers/driver_commo[145/464] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.2/modules/lib/hostap/src/drivers/drivers.c.ob[146/464] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.2/modules/lib/hostap/src/common/wpa_ctrl.c.ob[152/464] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.2/modules/lib/hostap/src/utils/wpa_debug_zeph[154/464] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.2/modules/lib/hostap/src/drivers/driver_zephy[156/464] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.2/modules/lib/hostap/wpa_supplicant/eap_regis[157/464] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.2/modules/lib/hostap/src/l2_packet/l2_packet_[159/464] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.2/modules/lib/hostap/wpa_supplicant/config_no[161/464] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.2/modules/lib/hostap/wpa_supplicant/bssid_ign[162/464] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.2/modules/lib/hostap/wpa_supplicant/events.c.[165/464] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.2/modules/lib/hostap/wpa_supplicant/wpa_suppl[170/464] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.2/modules/lib/hostap/wpa_supplicant/wpa_cli_c[174/464] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.2/modules/lib/hostap/wpa_supplicant/op_classe[175/464] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault_s.[176/464] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.2/modules/lib/hostap/wpa_supplicant/wnm_sta.c[180/464] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.2/modules/lib/hostap/src/rsn_supp/wpa_ie.c.ob[185/464] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.2/modules/lib/hostap/src/crypto/dh_groups.c.o[190/464] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/reset.S.[191/464] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread_abo[194/464] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/prep_c.c.o[197/464] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/cpu_idle.c[199/464] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/swap_hel[200/464] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_init.c[202/464] Building C object zephyr/arch/arch/arm/core/cortex_m/cmse/CMakeFiles/arch__arm__core__cortex_m__cmse.dir[273/464] Building C object zephyr/subsys/debug/coredump/CMakeFiles/subsys__debug__coredump.dir/coredump_memory_re[274/464] Building C object zephyr/subsys/debug/coredump/CMakeFiles/subsys__debug__coredump.dir/coredump_core.c.ob[275/464] Building C object zephyr/subsys/debug/coredump/CMakeFiles/subsys__debug__coredump.dir/coredump_backend_l[297/464] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/exc_exit.c[335/464] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c[353/464] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/api_ns/interface/src/tfm_i[354/464] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/api_ns/interface/src/tfm_c[356/464] Building C object modules/nrf/subsys/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/C_/ncs/v2.9.2[359/464] Building C object modules/nrf/subsys/net/lib/wifi_credentials/CMakeFiles/wifi_credentials.dir/wifi_crede[362/464] Building C object modules/nrf/subsys/net/lib/wifi_mgmt_ext/CMakeFiles/..__nrf__subsys__net__lib__wifi_mg[363/464] Building C object modules/nrf/modules/trusted-firmware-m/CMakeFiles/..__nrf__modules__trusted-firmware-m[367/464] Linking C static library modules\nrf\subsys\net\lib\wifi_mgmt_ext\lib..__nrf__subsys__net__lib__wifi_mgm[372/464] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/api_ns/interface/src/tfm_p[373/464] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.9.2/modules[376/464] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.9.2/modules[379/464] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.9.2/modules[382/464] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.9.2/modules[384/464] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.9.2/modules[385/464] Building C object modules/nrf_wifi/os/CMakeFiles/modules__nrf_wifi__os.dir/C_/ncs/v2.9.2/modules/lib/nrf[388/464] Building C object modules/nrf_wifi/os/CMakeFiles/modules__nrf_wifi__os.dir/C_/ncs/v2.9.2/modules/lib/nrf[389/464] Building C object modules/nrf_wifi/os/CMakeFiles/modules__nrf_wifi__os.dir/C_/ncs/v2.9.2/modules/lib/nrf[392/464] Building C object modules/nrf_wifi/os/CMakeFiles/modules__nrf_wifi__os.dir/C_/ncs/v2.9.2/modules/lib/nrf[395/464] Building C object modules/nrf_wifi/os/CMakeFiles/modules__nrf_wifi__os.dir/C_/ncs/v2.9.2/modules/lib/nrf[398/464] Building C object modules/nrf_wifi/os/CMakeFiles/modules__nrf_wifi__os.dir/C_/ncs/v2.9.2/modules/lib/nrf[400/464] Building C object modules/nrf_wifi/os/CMakeFiles/modules__nrf_wifi__os.dir/C_/ncs/v2.9.2/modules/lib/nrf[404/464] Building C object modules/nrf_wifi/os/CMakeFiles/modules__nrf_wifi__os.dir/C_/ncs/v2.9.2/modules/lib/nrf[462/464] Linking C executable zephyr\zephyr.elf
               FLASH:      506740 B       992 KB     49.89%
                 RAM:      198648 B       416 KB     46.63%
            IDT_LIST:          0 GB        32 KB      0.00%
    Generating files from C:/Nrf_ws_sdk_v2.9.2/sta/build/zephyr/zephyr.elf for board: nrf7002dk
    [464/464] Generating zephyr/merged.hex
    Building sta
    west build --build-dir c:/Nrf_ws_sdk_v3_1_1/sta/build c:/Nrf_ws_sdk_v3_1_1/sta --pristine --board nrf7002dk/nrf5340/cpuapp/ns --sysbuild -- -DCONF_FILE="prj.conf"
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: C:/ncs/toolchains/c1a76fddb2/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Cache files will be written to: C:/ncs/v3.1.1/zephyr/.cache
    -- Found west (found suitable version "1.4.0", minimum required is "0.14.0")
    Parsing C:/ncs/v3.1.1/zephyr/share/sysbuild/Kconfig
    Loaded configuration 'C:/Nrf_ws_sdk_v3_1_1/sta/build/_sysbuild/empty.conf'
    Merged configuration 'c:/Nrf_ws_sdk_v3_1_1/sta/sysbuild.conf'
    Configuration saved to 'C:/Nrf_ws_sdk_v3_1_1/sta/build/zephyr/.config'
    Kconfig header saved to 'C:/Nrf_ws_sdk_v3_1_1/sta/build/_sysbuild/autoconf.h'
       * Running CMake for sta *
    -- Application: C:/Nrf_ws_sdk_v3_1_1/sta
    -- Zephyr version: 4.1.99 (C:/ncs/v3.1.1/zephyr)
    -- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/c1a76fddb2/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/c1a76fddb2/opt/zephyr-sdk)
    -- Found Dtc: C:/ncs/toolchains/c1a76fddb2/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/ncs/v3.1.1/zephyr/boards/nordic/nrf7002dk/nrf7002dk_nrf5340_cpuapp_ns.dts
    -- Generated zephyr.dts: C:/Nrf_ws_sdk_v3_1_1/sta/build/sta/zephyr/zephyr.dts
    -- Generated pickled edt: C:/Nrf_ws_sdk_v3_1_1/sta/build/sta/zephyr/edt.pickle
    -- Generated devicetree_generated.h: C:/Nrf_ws_sdk_v3_1_1/sta/build/sta/zephyr/include/generated/zephyr/devicetree_generated.h
    Parsing C:/Nrf_ws_sdk_v3_1_1/sta/Kconfig
    Loaded configuration 'C:/ncs/v3.1.1/zephyr/boards/nordic/nrf7002dk/nrf7002dk_nrf5340_cpuapp_ns_defconfig'
    Merged configuration 'C:/Nrf_ws_sdk_v3_1_1/sta/prj.conf'
    Merged configuration 'C:/Nrf_ws_sdk_v3_1_1/sta/build/sta/zephyr/.config.sysbuild'
    Configuration saved to 'C:/Nrf_ws_sdk_v3_1_1/sta/build/sta/zephyr/.config'
    Kconfig header saved to 'C:/Nrf_ws_sdk_v3_1_1/sta/build/sta/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: c:/ncs/toolchains/c1a76fddb2/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
    -- Found assembler: C:/ncs/toolchains/c1a76fddb2/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    Backup: CONFIG_MBEDTLS_THREADING_C: True
    Restore: CONFIG_MBEDTLS_THREADING_C: True
    -- Found gen_kobject_list: C:/ncs/v3.1.1/zephyr/scripts/build/gen_kobject_list.py
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Nrf_ws_sdk_v3_1_1/sta/build/sta
    -- Configuring done
    -- Generating done
    [5/10] Performing build step for 'sta'
    [6/444] Generating include/generated/zephyr/version.h
    -- Zephyr version: 4.1.99 (C:/ncs/v3.1.1/zephyr), build: ncs-v3.1.1
    [8/444] Building C object modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/hw_if/hal/src/common/hal_[11/444] Building C object modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/fw_if/umac_if/src/common[12/444] Building C object modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/fw_if/umac_if/src/common[14/444] Building C object modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/fw_if/umac_if/src/common[15/444] Building C object modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/hw_if/hal/src/common/hal[17/444] Building C object modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/hw_if/hal/src/common/hal[20/444] Building C object modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/fw_if/umac_if/src/system[21/444] Building C object modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/fw_if/umac_if/src/system[23/444] Building C object modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/fw_if/umac_if/src/system[25/444] Building C object modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/fw_if/umac_if/src/system[25/444] Building C object modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/fw_if/umac_if/src/system[27/444] Building C object modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/fw_if/umac_if/src/system[31/444] Generating ../../tfm/CMakeCache.txt
    -- Found Git: C:/ncs/toolchains/c1a76fddb2/mingw64/bin/git.exe (found version "2.37.3.windows.1")
    -- Found Python3: C:/ncs/toolchains/c1a76fddb2/opt/bin/python.exe (found version "3.12.4") found components: Interpreter
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Nrf_ws_sdk_v3_1_1/sta/build/sta/tfm
    [36/444] Performing build step for 'tfm'
    [0/147] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/se[1/147] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/crypto/auto_ge[3/147] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/platform/auto_[5/147] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/tf[7/147] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/tf[8/147] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/fa[9/147] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/ta[10/147] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/t[11/147] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/__/platform/ext/commo[14/147] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/__/interface/src/tfm_[15/147] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/__/interface/src/tfm_[16/147] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/C_/ncs/v3.1.1/nrf/modules/trus[19/147] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/spm/core/psa_interfac[22/147] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/__/interface/src/tfm_[24/147] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sp_log.dir/__/__/__/__/platform/ext/com[31/147] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key_deri[32/147] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_library.[34/147] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_asymmetr[35/147] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key_mana[37/147] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/genera[38/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/[39/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/[40/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/[41/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/[42/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/[43/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedc[44/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/[45/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/[46/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/[47/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/[48/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/[49/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/psa_[50/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon...s/psa_core.di[51/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/psa_[52/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/psa_[53/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/psa_[54/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/psa_[55/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/nrf_security_utils.d[56/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/nrf_security_utils.d[57/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/psa_[61/147] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/platform/auto_generate[63/147] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/crypto/auto_generated/[64/147] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/target/nordic_nrf/common/core/startup_nr[86/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...eron_psa_driv[87/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe.../oberon_psa_d[88/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...eron_psa_driv[89/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...oberon_psa_dr[90/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...oberon_psa_dr[91/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...s/oberon_psa_[92/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...eron_psa_driv[93/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...s/oberon_psa_[94/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...a_driver.dir/[95/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...ron_psa_drive[96/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...a_driver.dir/[97/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe.../oberon_psa_d[98/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...s/oberon_psa_[99/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...sa_driver.dir[100/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_ob...beron_psa_dri[101/147] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_ob...er.dir/C_/ncs[102/147] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/platform_s[103/147] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/p[104/147] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/g[106/147] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/mp[107/147] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v3.1.1/modules/hal/nordic/nrfx/drivers/src/n[108/147] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/sp[109/147] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v3.1.1/modules/hal/nordic/nrfx/drivers/src/n[110/147] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/services/src/tfm_[111/147] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/nrf_exception_inf[112/147] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/cmsis_drivers/Dri[113/147] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/services/src/tfm_[114/147] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_bo[115/147] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_bo[116/147] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_bo[117/147] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_bo[118/147] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v3.1.1/modules/hal/nordic/nrfx/mdk/system_nr[119/147] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_bo[120/147] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_bo[121/147] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_bo[122/147] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_bo[132/147] Linking C static library secure_fw\partitions\crypto\mbedcrypto\nrf_security_src\drivers\nrf_oberon\libo[133/147] Linking C static library secure_fw\partitions\crypto\mbedcrypto\nrf_security_src\core\nrf_oberon\libpsa_[136/147] Linking C static library secure_fw\partitions\crypto\mbedcrypto\nrf_security_src\libcrypto_service_mbedc[141/147] Building C object platform/target/nrf5340/nrf_common/CMakeFiles/tfm_s_scatter.dir/__/__/__/__/common/gcc[143/147] Linking C executable bin\tfm_s.axf
                 RAM:       11524 B        32 KB     35.17%
    [147/147] Generating ../bin/tfm_s.bin
    [38/444] Performing install step for 'tfm'
    [40/444] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, include/g[42/444] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscall_exports_llext.c,[44/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.1/modules/cry[44/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.1/modules/cry[46/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v3.1.1/module[48/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v3.1.1/module[50/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v3.1.1/module[53/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v3.1.1/module[56/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v3.1.1/module[59/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v3.1.1/module[69/444] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v3.1.1/modules/lib/hostap/src/crypto/crypto_mbedtls[71/444] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v3.1.1/modules/lib/hostap/src/crypto/aes-unwrap.c.o[84/444] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v3.1.1/modules/lib/hostap/src/crypto/aes-internal.c[87/444] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v3.1.1/modules/lib/hostap/src/common/ieee802_11_com[88/444] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v3.1.1/modules/lib/hostap/src/common/hw_features_co[90/444] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v3.1.1/modules/lib/hostap/src/common/wpa_common.c.o[91/444] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v3.1.1/modules/lib/hostap/src/drivers/driver_common[99/444] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v3.1.1/modules/lib/hostap/src/l2_packet/l2_packet_z[100/444] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v3.1.1/modules/lib/hostap/src/utils/os_zephyr.c.ob[101/444] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v3.1.1/modules/lib/hostap/src/drivers/drivers.c.ob[107/444] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v3.1.1/modules/lib/hostap/wpa_supplicant/notify.c.[109/444] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v3.1.1/modules/lib/hostap/src/drivers/driver_zephy[111/444] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v3.1.1/modules/lib/hostap/wpa_supplicant/config.c.[112/444] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v3.1.1/modules/lib/hostap/wpa_supplicant/bssid_ign[113/444] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault_s.[114/444] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/reset.S.[117/444] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/exc_exit.c[118/444] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/vector_t[120/444] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/swap_hel[122/444] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/cpu_idle.c[123/444] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_init.c[126/444] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread.c.o[128/444] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/coredump.c[129/444] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/isr_wrappe[131/444] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/prep_c.c.o[133/444] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu_regions.c.ob[234/444] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v3.1.1/modules/lib/hostap/wpa_supplicant/wpa_cli_c[236/444] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v3.1.1/modules/lib/hostap/wpa_supplicant/events.c.[240/444] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v3.1.1/modules/lib/hostap/src/rsn_supp/pmksa_cache[246/444] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v3.1.1/modules/lib/hostap/src/common/dragonfly.c.o[294/444] Building C object zephyr/subsys/net/lib/wifi_credentials/CMakeFiles/wifi_credentials.dir/wifi_credential[297/444] Building C object zephyr/subsys/net/lib/wifi_credentials/CMakeFiles/wifi_credentials.dir/wifi_credential[298/444] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c[321/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v3.1.1/modul[326/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.1/modules/cr[327/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.1/modules/cr[330/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.1/modules/cr[332/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.1/modules/cr[334/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.1/modules/cr[336/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.1/modules/cr[338/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.1/modules/cr[339/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.1/modules/cr[342/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.1/modules/cr[343/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.1/modules/cr[345/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.1/modules/cr[346/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.1/modules/cr[349/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.1/modules/cr[351/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.1/modules/cr[352/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.1/modules/cr[354/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.1/modules/cr[356/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.1/modules/cr[358/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.1/modules/cr[361/444] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/ecjpake_oberon.c.[363/444] Building C object modules/nrf/subsys/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/psa_crypto_in[373/444] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/api_ns/interface/src/tfm_p[374/444] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/api_ns/interface/src/tfm_i[378/444] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_[379/444] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_[382/444] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_[384/444] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_[386/444] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_[387/444] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_[389/444] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_[444/444] Linking C executable zephyr\zephyr.elf
               FLASH:      536040 B       992 KB     52.77%
                 RAM:      181736 B       416 KB     42.66%
    Generating files from C:/Nrf_ws_sdk_v3_1_1/sta/build/sta/zephyr/zephyr.elf for board: nrf7002dk
    [8/10] cmd.exe /C "cd /D C:\Nrf_ws_sdk_v3_1_1\sta\build\_sysbuild && C:\ncs\toolchains\c1a76fddb2\opt\bin\cmake.ex[10/10] Generating ../merged.hex
  • Just another question, have you successfully connected to another AP using NCS 3.1.0? If yes, what are the differences between you working and non working AP? If no, could you test and report back?
  • Yes, I am able to connect using another access point, such as a mobile hotspot, which has the same configuration as I shared in the initial screenshot. I even changed that Mobile AP’s settings from Wi-Fi 4 to Wi-Fi 6 and updated the security from WPA2 to WPA3, and it still connects using NCS v3.1.0. However, my concern is that my Wi-Fi router does not connect with v3.1.0 but connecting in v2.9.2, even though it has the same configuration as the connecting AP.
