nRF7002-DK TCP: Data buffer allocation failed
I am solving a problem with nRF7002-DK, I am using TCP sockets for communication. MTU can have up to 6800 bytes, unfortunately, both in STA and AP mode, the connection is interrupted and the following message is displayed in the terminal:
[00:25:28.479,705] <err> net_pkt: Data buffer (1133) allocation failed.
[00:25:28.486,968] <err> net_tcp: conn: 0x200624d8 packet allocation failed, len=1085
[00:25:28.495,452] <err> net_tcp: TCP failed to allocate buffer in retransmission
[00:25:28.604,309] <err> net_pkt: Data buffer (1413) allocation failed.
[00:25:28.611,572] <err> net_tcp: conn: 0x20062738 packet allocation failed, len=1365
[00:25:28.620,056] <err> net_tcp: TCP failed to allocate buffer in retransmission
[00:25:28.934,387] <err> net_pkt: Data buffer (1413) allocation failed.
[00:25:28.941,650] <err> net_tcp: conn: 0x20062738 packet allocation failed, len=1365
[00:25:28.950,134] <err> net_tcp: TCP failed to allocate buffer in retransmission
[00:25:29.072,448] <err> net_pkt: Data buffer (1260) allocation failed.
[00:25:29.079,742] <err> net_tcp: conn: 0x200624d8 packet allocation failed, len=1212
[00:25:29.088,226] <err> net_tcp: TCP failed to allocate buffer in retransmission
Sometimes the connection is restored, sometimes it drops completely. Please advise what to do about this. I am attaching prj.conf.
Thank you.
# Copyright (c) 2022 Nordic Semiconductor ASA
# General
CONFIG_LOG=y
CONFIG_ASSERT=y
CONFIG_MAIN_STACK_SIZE=2048
CONFIG_TEST_RANDOM_GENERATOR=y
CONFIG_RESET_ON_FATAL_ERROR=n
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_SERIAL=y
CONFIG_UART_ASYNC_API=y
CONFIG_UART_1_ASYNC=y
CONFIG_UART_1_INTERRUPT_DRIVEN=n
CONFIG_UART_1_NRF_HW_ASYNC=y
CONFIG_UART_1_NRF_HW_ASYNC_TIMER=2
CONFIG_UART_1_NRF_ASYNC_LOW_POWER=y
CONFIG_NRFX_TIMER2=y
# Logging configuration
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_LOG_MODE_IMMEDIATE=y
CONFIG_LOG_BUFFER_SIZE=2048
CONFIG_ZVFS_OPEN_MAX=32
# WiFi Configuration - STA MODE
CONFIG_WIFI=y
CONFIG_WIFI_NRF70=y
# WPA supplicant pro STA mode
CONFIG_WIFI_NM_WPA_SUPPLICANT=y
CONFIG_WIFI_READY_LIB=y
# Logging pro WiFi
CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_INF=y
# Networking
CONFIG_NETWORKING=y
CONFIG_NET_CONNECTION_MANAGER=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_LOG=y
CONFIG_NET_IPV4=y
CONFIG_NET_UDP=y
CONFIG_NET_TCP=y
CONFIG_POSIX_API=y
# Network buffer sizes
CONFIG_NET_PKT_RX_COUNT=98
CONFIG_NET_PKT_TX_COUNT=74
CONFIG_NET_BUF_RX_COUNT=130
CONFIG_NET_BUF_TX_COUNT=100
# Below section is the primary contributor to SRAM and is currently
# tuned for performance, but this will be revisited in the future.
CONFIG_NRF70_RX_NUM_BUFS=20
CONFIG_NRF_WIFI_CTRL_HEAP_SIZE=30000
CONFIG_NRF_WIFI_DATA_HEAP_SIZE=50000
CONFIG_NET_TC_TX_COUNT=1
CONFIG_NET_IF_UNICAST_IPV4_ADDR_COUNT=1
CONFIG_NET_MAX_CONN=10
CONFIG_NET_MAX_CONTEXTS=64
CONFIG_NET_CONTEXT_SYNC_RECV=y
CONFIG_INIT_STACKS=y
CONFIG_NET_L2_ETHERNET=y
# Network configuration pro STA (DHCP klient místo statické IP)
CONFIG_NET_CONFIG_SETTINGS=y
CONFIG_NET_CONFIG_INIT_TIMEOUT=0
CONFIG_NET_DHCPV4=y
CONFIG_NET_SOCKETS_POLL_MAX=10
# Memories
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_NET_TX_STACK_SIZE=8192
CONFIG_NET_RX_STACK_SIZE=8192
CONFIG_MBEDTLS_HEAP_SIZE=512
# Debugging
CONFIG_STACK_SENTINEL=y
CONFIG_DEBUG_COREDUMP=y
CONFIG_DEBUG_COREDUMP_BACKEND_LOGGING=y
CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_MIN=y
CONFIG_SHELL_CMDS_RESIZE=n
# Kernel options
CONFIG_ENTROPY_GENERATOR=y
# Logging
CONFIG_LOG=y
CONFIG_POSIX_CLOCK=y
# printing of scan results puts pressure on queues in new locking
# design in net_mgmt. So, use a higher timeout for a crowded
# environment.
CONFIG_NET_MGMT_EVENT_QUEUE_TIMEOUT=5000
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=8192
CONFIG_NET_TCP_WORKQ_STACK_SIZE=8192
  • Hello, yes, I have also tried increasing CONFIG_HEAP_MEM_POOL_SIZE.
    I am sending the complete prj. conf here, but I am mainly dealing with a lack of RAM—if I increase some parameters, I can no longer compile the program; as it is, it is at the compilation limit (99.5% RAM used).
    # General
    CONFIG_LOG=y
    CONFIG_ASSERT=y
    # UART Console
    CONFIG_CONSOLE=y
    CONFIG_SERIAL=y
    # UART1 async
    CONFIG_WIFI=y
    CONFIG_WIFI_NRF70=y
    # Logging pro WiFi
    # Networking
    CONFIG_NETWORKING=y
    CONFIG_NET_LOG=y
    CONFIG_NET_IPV4=y
    CONFIG_NET_UDP=y
    CONFIG_NET_TCP=y
    CONFIG_POSIX_API=y
    CONFIG_NET_PKT_RX_COUNT=72
    CONFIG_NET_PKT_TX_COUNT=78
    CONFIG_NET_BUF_RX_COUNT=48
    CONFIG_NET_BUF_TX_COUNT=38
    CONFIG_NET_BUF_FIXED_DATA_SIZE=y
    CONFIG_NET_BUF_DATA_SIZE=256
    CONFIG_NRF70_RX_NUM_BUFS=30
    CONFIG_HEAP_MEM_POOL_SIZE=34000
    CONFIG_HEAP_MEM_POOL_IGNORE_MIN=y
    CONFIG_NRF_WIFI_CTRL_HEAP_SIZE=38000
    CONFIG_NRF_WIFI_DATA_HEAP_SIZE=85000
    CONFIG_NET_DHCPV4=y
    # Memories
    CONFIG_NET_TX_STACK_SIZE=4096
    CONFIG_NET_RX_STACK_SIZE=4096
    # Debugging
    # Kernel options
    # Logging
    CONFIG_LOG=y
    # environment.
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=6144
    CONFIG_NET_TCP_WORKQ_STACK_SIZE=6144
    #Memory stats
    CONFIG_SYS_MEM_BLOCKS=y
    CONFIG_THREAD_STACK_INFO=y
    CONFIG_THREAD_RUNTIME_STATS=y
    CONFIG_SYS_HEAP_RUNTIME_STATS=y
    CONFIG_NET_BUF_POOL_USAGE=y
    CONFIG_NET_DEBUG_NET_PKT_ALLOC=y
    CONFIG_NET_STATISTICS=y
    CONFIG_NET_SHELL=y
    CONFIG_NET_STATISTICS_IPV4=y
    CONFIG_NET_STATISTICS_TCP=y
    CONFIG_NET_STATISTICS_WIFI=y
    Thank you
    34000 can be too low for CONFIG_HEAP_MEM_POOL_SIZE. I recommend trying to increase this and see if that helps.
    If you have problems with RAM usage, I recommend looking at Memory footprint optimization and Wi-Fi stack configuration and performance to see how you can reduce your application's memory usage.
    Marte
