AWS IOT example - utilizing ~92.5% flash without configuration changes on 7002DK
Hi Nordic Support Team,I'm experiencing severe memory constraints with the AWS IoT Core example on the nRF7002DK (nRF5340) that make it impractical for real-world applications requiring WiFi provisioning and custom functionality.
Current Memory Usage:
Memory region         Used Size  Region Size  %age Used
           FLASH:      742308 B       784 KB     92.46%
             RAM:      327392 B       400 KB     79.93%
        IDT_LIST:          0 GB        32 KB      0.00%
I appreciate that the example includes comprehensive crypto and certificate handling, but the current memory footprint makes it challenging to build practical applications on top of it.
The AWS IoT Core example leaves only ~40KB of flash memory available, which is insufficient for adding WiFi provisioning logic and custom application code that would be required in a production scenario
Build Configuration:
  • SDK: nRF Connect SDK v3.1.1
  • Toolchain: nRF Connect SDK Toolchain v3.1.1
  • Board target: nrf7002dk/nrf5340/cpuapp/ns
  • Extra Kconfig fragments: boards/nrf7002dk_nrf5340_cpuapp_ns.conf
  • Optimization level: Use project default
  • Build directory: build
  • System build (sysbuild):
  • Build system default
  • Use sysbuild: Yes
  • No sysbuild: No
Key Configuration Details:
  • Using external flash (mx25r64) for partition manager
  • FOTA enabled (required for our use case)
  • TF-m optimizations are applied.
Attempts Made:
  1. Tried building without /ns suffix: Build failed
  1. WiFi Firmware Patches: I understand these could potentially be moved to save space, but I've seen Nordic support advise against relocating them - seems complicated with FOTA, but does give 83KB. I was not able to get this to apply to the project successfuly.
Requirements:
  • FOTA capability (non-negotiable)
  • WiFi provisioning functionality
  • IOT Core shadow states and telemetry.
  • Production-ready security (not necessarily using TF-M). but SSL/https required.
Questions:
  1. What would be the easiest Flash saving for a project based on this example, given that FOTA is needed.
  1. What is the official guidance on building without TF-M (/ns) for production applications? What security implications should we consider?
  1. Is there a way to optimize the TF-M memory allocation to reclaim some of the apparent 16KB waste in trustzone storage? Or shrink the 128KB it is taking?
    If its not possible to make quite big savings, I'll consider not using IOT core, but it requires doing all the telemetry and much more work on the FOTA manually.
Any guidance on the largest bang for buck memory optimization strategies or alternative starting point would be greatly appreciated.
Kind Regards
Dan
  • I have successfully configured WiFi firmware patches to be stored in external flash (MX25R64) and managed by MCUboot as a multi-image setup. The device boots and runs correctly with the patches in external flash. I can perform FOTA updates of the application, but am unsure of the best approach for updating the FW patches.
    CONFIG_NRF_WIFI_FW_PATCH_DFU remains disabled despite all documented dependencies being met.
    I have tried CONFIG_NRF_WIFI_FW_PATCH_DFU=y in both:
    - prj.conf
    - boards/nrf7002dk_nrf5340_cpuapp_ns.conf
    ✓ CONFIG_NRF_WIFI_PATCHES_EXT_FLASH_STORE=y
    ✓ CONFIG_PARTITION_MANAGER_ENABLED=y
    ✓ CONFIG_BOOTLOADER_MCUBOOT=y
    ✗ CONFIG_NRF_WIFI_FW_PATCH_DFU=y (set in prj.conf but shows as "not set" in build/.config)
    After building, the generated .config shows:
    # CONFIG_NRF_WIFI_FW_PATCH_DFU is not set
    Partition Layout (pm_static.yml):
    - mcuboot_secondary (0x0, 0xe4000) - App secondary
    - nrf70_wifi_fw_mcuboot_pad (0xe4000, 0x200)
    - nrf70_wifi_fw (0xe4200, 0x20000)
    - mcuboot_primary_1 (0xe4000, 0x21000)
    - mcuboot_secondary_1 (0x105000, 0x21000)
    Questions:
    1. Why is CONFIG_NRF_WIFI_FW_PATCH_DFU not being enabled? Are there hidden dependencies?
    2. How should I configure FOTA updates for WiFi firmware patches when using AWS IoT FOTA library? Currently, AWS FOTA treats all updates as application updates (image 0), causing WiFi patch binaries to be written to the wrong slot.
    3. Should I be trying to get MCUboot to handle it, or do I need to intercept download and overwrite it in the application? Is there documentation I'm missing?
    4. Is there example code or documentation for performing OTA updates of WiFi patches stored in external flash with MCUboot multi-image support?
    Files available upon request:
    - Complete prj.conf and board configs
    - pm_static.yml
    - sysbuild.conf
    - Build logs showing config resolution
    Thank you for your assistance.
  • Thanks for the patience
    Could be some missing dependency. Does the build log mention it? It typically says something along the line of "trying to set the config to this, but it got that value instead".
    This, and the rest regarding OTA for patches I am not sure about, I've forwarded this to the relevant R&D team to see if they have an idea. I'll let you know once I hear from them.
    Elfving
    The wifi fw patch FOTA process is same as app and net images. The device can use nrf FOTA library to finish firmware download and MCUBoot to do swap afterwards. Looks some customer has made this work with their http server: https://devzone.nordicsemi.com/f/nordic-q-a/122242/nrf5340-nrf7002-multi-image-https-fota. AWS should be able to handle this as http sever.
    Have a look here.
    You do for instance have this matter sample.
    Elfving
  • Hi, thanks the CONFIG_DFU_MULTI_IMAGE=y dependency was missing. There are still 2 issues I have though:
    1. Multi-Image Package Build Error
    When we enable:
        SB_CONFIG_DFU_MULTI_IMAGE_PACKAGE_BUILD=y
        SB_CONFIG_DFU_MULTI_IMAGE_PACKAGE_WIFI_FW_PATCH=y
    The build fails with:
        FileNotFoundError: build/nrf70.signed.bin
    I think sysbuild system tries to create dfu_multi_image.bin before nrf70.signed.bin is generated (build ordering issue).
    2. The Matter bridge example demonstrates WiFi patch FOTA, which indicates MCUBoot can handle it, however the in the library used by the IOT core example, the fota_download library hardcodes img_num=0 when calling dfu_target_init() at line 183 of fota_download.c:
        err = dfu_target_init(img_type, 0, file_size, dfu_target_callback_handler);
    This means WiFi firmware patches (nrf70.signed.bin) are always written to mcuboot_secondary (image 0) instead of mcuboot_secondary_1 (image 1), causing MCUboot to reject and revert the update.
    MCUboot is correctly managing both images (we see "Image index: 0" and "Image index: 1" in boot logs), and application FOTA works fine. The issue is specifically that the FOTA library can't target image 1.
    Note: We observed that Matter OTA handles WiFi patch updates using the dfu_multi_image API with combined packages, whereas AWS FOTA uses the fota_download API which hardcodes img_num=0 - is there a recommended way to integrate dfu_multi_image support into AWS FOTA?
  • Hi again,
    Considering this:
    Could you check if either of these are set?
    Elfving
