Device goes into DFU after adding FOTA over Bluetooth
I added FOTA over Bluetooth to my NRF52840 application. Everything works, I can update the application over bluetooth and it runs properly, but after updating if I unplug the dongle and plug it back in the device starts up in DFU mode instead of just starting up my application normally. Any idea why this would occur? Thanks
  • The only explanation I can think of is that the app/MCUBoot image is being altered at runtime and causing the boot validation to fail on subsequent reboots (see Boot validation modes). If the next image in the boot chain cannot be validated, the bootloader will fall back to DFU mode. If you are actively developing any FW, I recommend using a development kit (nRF52840 DK). The dongle is not designed for this.
  • Ok, I just ordered a nRF52840 DK. Could this have anything to do with my static partition? Do I need to make any changes from the one you had given me before? Thanks!
    nrf5_bootloader:
    address: 0xE0000 # Start address in flash
    end_address: 0x100000 # End address in flash (1 MB boundary)
    placement:
    align:
    start: 0x1000 # Alignment requirement (4 KB boundary)
    before:
    - end # Ensure it gets placed before the flash "end"
    region: flash_primary
    size: 0x20000 # 128 KB reserved for bootloader
  • Good. It's much easier to debug when you have the on-board debugger.
    The problem is not with this reserved partition, but there could be problems with the other parititions. Could you please post the partitions.yaml file from your build folder here?
  • EMPTY_0:
    address: 0xdd000
    end_address: 0xde000
    placement:
    after:
    - mcuboot_secondary
    app:
    address: 0xd200
    end_address: 0x75000
    mcuboot:
    address: 0x1000
    end_address: 0xd000
    placement:
    align:
    end: 0x1000
    before:
    - mcuboot_primary
    mcuboot_pad:
    address: 0xd000
    end_address: 0xd200
    placement:
    align:
    start: 0x1000
    before:
    - mcuboot_primary_app
    mcuboot_primary:
    address: 0xd000
    orig_span: &id001
    - app
    - mcuboot_pad
    sharers: 0x1
    span: *id001
    mcuboot_primary_app:
    address: 0xd200
    orig_span: &id002
    - app
    span: *id002
    mcuboot_secondary:
    address: 0x75000
    end_address: 0xdd000
    placement:
    after:
    - mcuboot_primary
    align:
    start: 0x1000
    share_size:
    - mcuboot_primary
    nrf5_bootloader:
    address: 0xe0000
    placement:
    align:
    start: 0x1000
    before:
    - end
    nrf5_mbr:
    address: 0x0
    end_address: 0x1000
    placement:
    after:
    - start
    settings_storage:
    address: 0xde000
    end_address: 0xe0000
    placement:
    align:
    start: 0x1000
    before:
    - end
    sram_primary:
    address: 0x20000000
    end_address: 0x20040000
    region: sram_primary
  • Thanks for providing the memory layout. Unfortunately, I don't see anything wrong with it, so still not sure what is causing the nRF5 bootloader to fall back into DFU mode. If you have received the nRF52840 DK you can try to reproduce the same using the Open Bootloader with DFU example (pre-programmed bootloader on dongle is based on the same project)
