On-demand start of uart shell and dynamic pin control.
Hi!
We have three different uart applications (two for production use, and the uart shell backend) and three different hardware output paths, but nRF52840 features just two uart controllers. So we would like to be able to pick any two out of the three applications, and run them on the two controllers using dynamic pin control. We would like to be able to do so dynamically during boot.
So far I can re-route our uarts using the pinctrl_update_states and pinctrl_apply_states.
A problem comes with the uart shell, as we need to dynamically either start it or not, where by not starting I mean to not make it even claim the uart controller.
The minimum config that allows me to compile seems to be:
CONFIG_SHELL=y
CONFIG_SHELL_AUTOSTART=n
CONFIG_SHELL_BACKEND_SERIAL=y
CONFIG_UART_CONSOLE=n
Now when I set `CONFIG_SHELL_BACKEND_SERIAL=y` and reassign the pins using the pinctrl_* functions then:
-  I can start the shell on demand with `shell_start(shell_backend_uart_get_ptr());`
-  but when I hook a logic analyzer, I don't see any traffic on the line where I had redirected the production app traffic to. This line and controller is also specified as the dts "chosen" zephyr,shell-uart.
When I set `CONFIG_SHELL_BACKEND_SERIAL=n` and remove all code that relies on it:
-  then redirecting the traffic to the other set of lines works fine - I see there the traffic using a logic analyzer
-  but I loose the ability to start the shell on uart, since `shell_backend_uart_get_ptr()` is not compiled in without CONFIG_SHELL_BACKEND_SERIAL
I assume that it is because while the shell didn't autostart, the shell backend was automatically initialized at startup and claimed the pins.
How do we compile zephyr in such way that uart shell support is compiled in, but doesn't claim any controller unless told to?
Thanks!
Karel
  • After reading your problem description again and reviewing the implementation a bit more, I understand the problem better, but I'm not sure I see a clean solution to this. As you pointed out, the shell uart backend is initilized on startup regardless of the CONFIG_SHELL_AUTOSTART setting. This means the UART receiver will already be enabled when you reach main(). You could try to re-initialize he shell backend as done in this sample: https://github.com/nrfconnect/sdk-zephyr/blob/29feb191e381db3f73eb2443f0bec047837d5086/samples/subsys/shell/shell_module/src/uart_reinit.c#L11 to see if this enables you to properly re-enable the receiver.
  • Thanks for pointers Vidar!
    I am afraid I am still missing something.
    I have reduced the code to a one function that just tries to uninitialize the shell, stop and resume the device, and reinitialize it again:
    void PinWiring_Test() {
        // ### Uninitialize the shell
            // uninitialize the shell
            int err;
            const struct shell *sh = NULL;
            LogS("Uninitializing shell...\n");
            sh = shell_backend_uart_get_ptr();
            shell_uninit(sh, shell_uninit_cb);
            k_sleep(K_MSEC(500));
            //disable uart rx
            err = uart_rx_disable(uart0.device);
            if (err != 0) {
                LogS("Failed to disable UART RX: %d\n", err);
        // ### Suspend uart0
            int ret = pm_device_action_run(uart0.device, PM_DEVICE_ACTION_SUSPEND);
            if (ret != 0) {
                LogS("Failed to suspend device: %d\n", ret);
            LogS("Suspended device %s\n", uart0.name);
        // ### Resume uart0
            int ret = pm_device_action_run(uart0.device, PM_DEVICE_ACTION_RESUME);
            if (ret != 0) {
                LogS("Failed to resume device: %d\n", ret);
            LogS("Resumed device %s\n", uart0.name);
        // ### (Re)start the shell
            int ret;
            if (!sh) {
                LogS("Shell backend not found\n");
                return -ENODEV;
            LogS("A\n");
            // (Re)initialize the shell
            bool log_backend = CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL > 0;
            uint32_t level = (CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL > LOG_LEVEL_DBG) ? CONFIG_LOG_MAX_LEVEL : CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL;
            // ### I am getting the error inside this call:
            ret = shell_init(sh, uart0.device, sh->ctx->cfg.flags, log_backend, level);
            if (ret < 0) {
                LogS("Shell init failed: %d\n", ret);
                return ret;
            LogS("A1\n");
            // Start the shell
            ret = shell_start(sh);
            if (ret < 0) {
                LogS("Shell start failed: %d\n", ret);
                return ret;
            LogS("A2\n");
            // init our custom commands
            InitShell();
    But this fails with Busy when the shell tries to uart_rx_enable again.
    fatal_error: Resetting system
    async RX enable: 0
    Shell uninitialized with result: 0
    Suspended device uart0
    Resumed device uart0
    A
    async RX enable: -16
    ASSERTION FAIL @ WEST_TOPDIR/zephyr/subsys/shell/backends/shell_uart.c:261
    os: r0/a1:  0x00000004  r1/a2:  0x00000105  r2/a3:  0x20012048
    os: r3/a4:  0x00000004 r12/ip:  0x2000f580 r14/lr:  0x0004d929
    os:  xpsr:  0x01000000
    os: r4/v1:  0xfffffff0  r5/v2:  0x00082468  r6/v3:  0x20014745
    os: r7/v4:  0x00000001  r8/v5:  0x00082468  r9/v6:  0x0000030c
    os: r10/v7: 0x00000000  r11/v8: 0x00000000    psp:  0x200376e8
    os: EXC_RETURN: 0x0
    os: Faulting instruction address (r15/pc): 0x00078290
    os: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0
    os: Current thread: 0x20012048 (main)
    ===== PANIC ==
    I.e., calling shell_init goes into shell_uart.c, function async_init. There it calls uart_rx_enable which returns -16 (busy) then (inside the async_init) assert (err == 0) is encountered.
    When trying to trace uart_rx_enable, I got thoroughly lost.
  • Please try to comment this return at this line https://github.com/nrfconnect/sdk-zephyr/blob/37b9a01aa8037dc373465760ee3c64cba2179318/drivers/serial/uart_nrfx_uarte.c#L1956 and see if it works then. This isn't a solution or workaround, but it would help us understand whether the only remaining problem is that the shell backend fails to re-enable reception.
  • Yes, it works after commenting out that line. (I.e., no crash happens when running the PinWiring_Test() and I can interact with the uart shell afterwards.)
    I guess I should clarify that we are on zephyr 3.7.99.0, namely 0bc3393fb11 .
  • Thanks for confirming. So I think the problem is that uart0 is suspended immediately after the uart_rx_disable() call before the RXTO event (mentioned here: https://github.com/nrfconnect/sdk-zephyr/blob/d141a610109b40133b0d0c549a67273e866c8f7f/drivers/serial/uart_nrfx_uarte.c#L1034) is triggered. As a result, the  async_rx->discard_fifo flag remains 'true' .
    Please add a delay (k_msleep() or k_busy_wait() after the disable call to see if that helps.
    Thanks.
